查看: 218|回复: 0
[AD 10][2层]MST6M182VG多媒体方案(FPGA+FK1603A)原理图和PCB文件
发表于 2020-2-19 11:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
/ r) D' K& |0 M8 X" s( Q  S( X% M4 V& K+ p& S' O
[AD 10][2层]MST6M182VG多媒体方案(FPGA+FK1603A)原理图和PCB文件: h& b/ n0 n( M
& @3 R; @) k! H文件描述
* m8 J% v$ J# [, K% r8 W: O  o6 |1. 作品用途:MST6M182VG多媒体方案
% W+ W; ^, V/ P+ ]1 Z2. 软件版本:AD 10
$ D0 g; L  U8 `2 V3. 层数:2层板0 o$ b3 w8 _1 Y( L
4. 用到的主要芯片:FPGA+FK1603A
: ?; M' _2 ]. S( t$ P0 J0 l5. PCB尺寸:175*70 mm
# Z7 X7 y" i: i! E2 s2 \, q$ F
9 c$ G; b: I1 D% C9 G作品截图如下:- u. p& P% ]! [0 `7 @  i& V
顶层截图:
3 n" _% x+ k* z: N0 q  m: L 8 t9 q1 E. w" S: b8 Q* y8 R
, Q/ n2 Y  {, p+ x) J底层截图:
. h' _( H7 z  E7 g) m . T5 y* y, ~! m% ~% w# X9 l( ?
+ N% F3 Y( H6 ]2 L, m全层截图:) S  H. A9 l- U
( o4 t3 A# ~! y% m4 E叠层信息截图如下:
* G2 C5 k& J: n# }% i+ V$ b+ p 1 x! W- m+ L; ^* G5 V
BOM:
" _# C, W& g: Y' O$ C
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
C0402C1, C2, C3, C4, C5, C6, C7, C8, C10, C16, C18, C19, C20, C21, C22, C23, C28, C29, C100, C103, C104, C105, C106, C107, C112, C113, C114, C115, C116, C118, C122, C123, C125, C126, C127, C128, C129, C130, C131, C132, C133, C134, C135, C137, C138, C143, C144, C146, C150, C151, C153, C154, C157, C159, C160, C161, C163, C164, C165, C166, C167, C168, C169, C504, C625, C628, C700, C801, C803, C804, C805, C806, C807, C808, C809, C810, C812, C814, C818, C901, C902, C904, C905, C907, C908, C909, C910, C911, C912, C913, C914, C915, C917C0402
93
C0603C9, C11, C17, C26, C27, C101, C102, C111, C136, C145, C147, C148, C149, C155, C170, C171, C502, C503, C626, C627, C813, C826, C900, C903, C906, C916, C918, C919, C920C0603
29
C0805C30, C124, C158, C162, C500C0805
CE8-3.5CA1, CA901CE8-3.5
CE4-2.0CA2, CA3, CA4, CA5, CA6, CA25, CA802, CA900, CA903CE4-2.0
9
CN12-20ACON1CN12-20A
DC-JACK3PCON2DC-JACK3P
CN6-20ACON3CN6-20A
CN9-20ACON101CN9-20A
RCA3X2CON501RCA3X2
CN4-20ACON503CN4-20A
CKX-3.5-22ACON504CKX-3.5-22A
CON4X2-2.0CON505CON4X2-2.0
VGASCON601VGAS
USB-A-05CON625, CON626USB-A-05
HDMI19PCON700, CON701HDMI19P
CN2-20ACON900, CON901CN2-20A
D0402D1, D101, D102, D501, D502, D503, D504, D505, D506, D600, D601, D602, D603, D604, D625, D626, D627, D628, D700, D701, D702, D703, D704, D705, D706, D707, D708, D709, D710, D711, D712, D713, D714, D715D0402
34
SOT-23D3, D4, D100, D900, Q1, Q2, Q3, Q4, Q5, Q100, Q101, Q500, Q501, Q700, Q701, Q900, Q901, Q902, Q903, Q904SOT-23
20
D4148D801D4148
AXIAL0.4F1AXIAL0.4
PWR_TPH1, H2, H3, H4PWR_TP
HOLE4-7H7, H8, H9, H10HOLE4-7
TPADH11, H12, H13, H14, H15TPAD
JP1X3J1, J2JP1X3
CON20X2-2.0-LVDSJ100CON20X2-2.0-LVDS
L0805L1, L4, L5, L7, L901L0805
L-POWERL2L-POWER
LCS0218L3LCS0218
L0603L100, L101, L102, L103, L801L0603
L1206L625, L626, L900, L902, L903, L904L1206
R7.5MML800R7.5MM
R0402R1, R2, R3, R4, R5, R6, R7, R8, R9, R10, R11, R12, R13, R14, R15, R16, R17, R18, R19, R20, R21, R22, R23, R24, R25, R26, R101, R102, R103, R104, R105, R106, R107, R108, R109, R110, R111, R112, R113, R114, R115, R116, R117, R118, R119, R120, R121, R122, R123, R124, R125, R126, R127, R128, R129, R130, R131, R132, R133, R134, R135, R136, R137, R500, R501, R502, R503, R504, R505, R506, R507, R508, R509, R510, R511, R512, R513, R514, R515, R516, R517, R518, R519, R520, R521, R522, R523, R524, R525, R526, R527, R528, R529, R530, R531, R532, R533, R534, R604, R605, R606, R607, R608, R609, R610, R611, R612, R613, R614, R615, R616, R625, R627, R628, R629, R700, R701, R702, R703, R704, R705, R706, R707, R708, R709, R710, R711, R712, R713, R714, R715, R716, R717, R718, R719, R720, R721, R722, R723, R724, R725, R726, R727, R728, R729, R730, R800, R802, R803, R805, R806, R809, R810, R814, R815, R900, R901, R902, R903, R904, R905, R906, R907, R908, R909, R910, R911, R912, R913, R914, R915, R916, R917, R918, R919, R920, R921, R922, R923, R924, R925R0402
181
TP-1MMTP100, TP101, TP102, TP103, TP104, TP105, TP106, TP109, TP110, TP111, TP112, TP113, TP114, TP115, TP116, TP117, TP118, TP119, TP120, TP121, TP122, TP123, TP124, TP125, TP126, TP127, TP128, TP129, TP130, TP131, TP132, TP133, TP134, TP135, TP136, TP139, TP141, TP142TP-1MM
38
SOP8-225-50U1SOP8-225-50
SOT-23-5U2, U7SOT-23-5
SOT-223U4, U5, U804SOT-223
SOP8-255-50U100SOP8-255-50
IC-200P-LFBGAU101IC-200P-LFBGA
IR-1U102IR-1
TDQ-B8/116HU803TDQ-B8/116H
FK1603AU805FK1603A
IC-24P-TSSOP-6_4MM-GU900IC-24P-TSSOP-6_4MM-G
XTAL\HC49\FY100XTAL\HC49\F
附件:- d1 }; S2 S' m1 T
原理图和PCB文件如下:3 j, X0 I1 u/ b- Z& k) q; E
游客,如果您要查看本帖隐藏内容请回复
8 T& u  p9 [$ P, m# R& o8 a6 O' ?9 ]
GMT+8, 2025-7-26 20:54 , Processed in 0.125000 second(s), 28 queries , Gzip On.
