作品名:[AD 15][4层] 电源板(GS66502B+AMC1100+SI8610)PCB源文件
( a( O8 w2 {" Q }. R5 G8 w D3 f9 C4 Y9 @& f1 ]
文件描述
5 y+ K. {1 U: T* a% _1. 作品用途:电源板& m9 q$ l' i' ?: W
2. 软件版本:AD 152 x2 i* K* q: ]# m
3. 层数:4层板* @, o; [; z- @, N
4. 用到的主要芯片:GS66502B+AMC1100+SI8610+ P. ^/ b0 q* @# P
5. PCB尺寸: ( T6 y6 o3 t# V0 X+ \1 Z2 w
) c3 W, r9 E: {$ \& }作品截图如下:, k' Y x( E- H' y7 ^
& m7 e$ E, f! q* c全层截图:3 f& u. W4 q2 }. ]
; Y# m6 t, {1 h" C
叠层信息截图如下:! W. I$ H: h2 w; C' O# N* m
, V" F/ m+ k+ k% y' I8 ~1 s/ M5 `
BOM:% M1 a/ e4 o8 A
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1uF | C3, C4, C12, C13 | C0805 | 4 | 4.7uF | C5, C6, C7, C8 | C0805 | 4 | Cap | C16, C17, C18, C19, C21, C22, C23, C24, C25, C29, C30, C31, C32, C33, C34, C35, C38, C39, C40, C41, Cv1, Cv2 | C0805 | 22 | 470uF/50V | C28, Co5, Co6, Co7 | C10x16 | 4 | 1nF | Cin1 | C1206 | 1 | 470uF/50V | Cin2, Cin3 | C8X12 | 2 | 22uF | Co1, Co2, Co3, Co4 | C0805 | 4 | 1nF | Cr1, Cr2, Cr3 | 1206 | 3 | SS26 | D2 | SMA | 1 | Diode | D3 | SMA | 1 | LM5114 | Dri1, Dri2 | LM5114(WSON) | 2 | MBR2060CT | D_Power1 | TO2-DIODE(MBDIODE) | 1 | MBR2060CB | D_power_2 | TO2-DIODE(MBDIODE) | 1 | FS-39-20A | F1 | FUSE | 1 | TP | HG, HS, LG, LS, PWM_PH, PWM_PH_1, PWM_PL, PWM_PL_1, SS1, SS2, VOUT | PIN1 | 11 | Header2 | IN1, OUT1 | conection-135T-10.16mm | 2 | Header 2 | Io_Sense | connection-KF128 | 1 | SI8610 | ISO1, ISO2 | SO-8 | 2 | Inductor Iron | L1 | inductor | 1 | LS05-15B09SS | LDO1, LDO2, LDO3 | SOT23_L | 3 | LP2985 | LDO4, LDO5, LDO7 | DBV5/sot25(LP2985) | 3 | Header 12X2 | PC1 | HDR24 | 1 | Header 7X2A | P_Detect | HDR2X7_CEN | 1 | Header 7 | P_Power | connection-7pin | 1 | Header2 | P_power_15 | connection-KF128 | 1 | GS66502B | Q1, Q2 | IPB65R045C7 | 2 | Res2 | R5, R6, R7, R8, R27, Ri2, Ri3, Ri5, Ri7, Ri8, Ri9, Ri10, Ri11, Ri12 | R0805 | 14 | Res1 | R9, R10, R11, R12, R13, R14, R15, R16, R24, R26, Rv1, Rv2, Rv3, Rv4 | R0805 | 14 | trans | T1 | PQ2625(xin) | 1 | Header2 | TP2 | HDR1X2 | 1 | ACS712 | U1 | ACS712 | 1 | AMC1100 | U2, U3 | AMC1100 | 2 | 附件:8 @, U$ s6 u8 i* W
原理图和PCB源文件如下:
/ B& c, f- X* b
0 ?# f2 |; b* k1 G/ Q0 r
; }$ A; y; x* B8 {" F8 m |
