作品名:[AD 10][4层] ZYNQ-MZ7035FB 开发板底板(PCA9548APW+CR1220+USB2514)原理图、PCB源文件- K& w9 s Y4 j" v% v* Z
" K3 O V$ Z; y# V, w2 a* J& m
文件描述
& J& T; O3 R D) l# m9 @4 d1. 作品用途:开发板7 g. Z% y6 i+ v i- r1 y9 r
2. 软件版本:AD 108 Q) n2 E1 ?1 I% J) o4 Y( h8 B
3. 层数:4层板+ r/ X1 s+ {& ~8 \
4. 用到的主要芯片:PCA9548APW+CR1220+USB2514
. r8 R9 @; }, c1 H/ l5. PCB尺寸:200mm*100mm
# n6 m# T3 _: D5 W
; q7 j- |* g& l. W9 @作品截图如下:
( x8 z- G3 l% K顶层截图:
5 S1 M+ w4 u, x, o+ S" r
* @0 K4 ~$ U1 B
底层截图:
( B8 x" Q O- ^+ X
5 `3 x! P8 ~0 S' K" h0 p
全层截图:
E: B( S y" D D8 O
7 f3 P; d+ o; R) Q; X2 M7 u叠层信息截图如下:) e6 f! o0 b- w/ j
* v3 T' \" U' B- T9 i* m) d/ [5 t
BOM:
% F; |2 {2 F+ M0 Q: DComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 10uf | AC1, AC3, AC5, AC7, BC1, BC3, BC5, BC7, C11, C12, C13, C128, C131, C132, CC1, CC3, CC5, CC7, DC1, DC3, DC5, DC7 | CAP0603 | 22 | 0.1uf | AC2, AC4, AC6, AC8, BC2, BC4, BC6, BC8, C1, C2, C3, C5, C43, C44, C48, C49, C50, C51, C52, C53, C54, C55, C56, C57, C58, C59, C61, C118, C119, C120, C121, C122, C123, C125, C126, CC2, CC4, CC6, CC8, DC2, DC4, DC6, DC8, EC2, EC3, EC5, FC2, FC3, FC5 | CAP0402 | 49 | 22uf/16V | AC9, AC10, AC11 | CAP1206 | 3 | 100uf/6V3 | AC12, AC13 | CAP1206 | 2 | 4.7K | AR1, AR2, AR3, AR4, AR5, AR6, AR7, AR8, BR1, BR2, BR3, BR4, BR5, BR6, BR7, BR8, CR1, CR2, CR3, CR4, CR5, CR6, CR7, CR8, DR1, DR2, DR3, DR4, DR5, DR6, DR7, DR8, R1, R2, R3, R4, R5, R6, R7, R8 | RES0402 | 40 | 2.2uf | C4, C6 | CAP0402 | 2 | 10uf/6V3 | C30 | CAP0603 | 1 | 1uf | C124, C127 | CAP0402 | 2 | 12pf | C129, C130 | CAP0402 | 2 | 1N5822 | D1, D3, D8 | SMA_DO_214AC | 3 | TVS_SMAJ5.0CA_12V | D2 | SMA_DO_214AC | 1 | BAS16XV2T1-D | D4 | SOD-523 | 1 | 22uf/16V | EC1, FC1 | CAP0603 | 2 | 3.3nf | EC4, FC4 | CAP0402 | 2 | 20pf | EC6, FC6 | CAP0402 | 2 | 47uf | EC7, EC8, FC7, FC8 | CAP0603 | 4 | 100nf | EC9, FC9 | CAP0402 | 2 | 2.2uh | EL1, FL1 | L4X4X2 | 2 | 22.1K1% | ER2, FR2 | CAP0603 | 2 | 124K1% | ER3 | CAP0603 | 1 | TPS54627 | EU1, EU2 | SOP8_EP_127P4X5X1_5 | 2 | FUSE | F1, F2 | 1206 | 2 | FB_100R | FBA1, FBA2, FBA3, FBB1, FBB2, FBC1, FBC2, FBD1 | CAP0603 | 8 | FEP | FEP1 | FEPX4M | 1 | 73.2K1% | FR3 | CAP0603 | 1 | Header 3 | H2 | HDR1X3 | 1 | FX8-120S-SV92 | HT1, HT2 | FX8-120S-SV92 | 2 | FX8-100S-SV92 | HT3 | FX8-100S-SV92 | 1 | 1981584-1 | J1 | MicroUsb | 1 | Dual USB A | J3, J5 | USBAX2 | 2 | SDK | J4 | TF_K | 1 | HDMI_A | JH2 | HDMI_1903015 | 1 | HY911130A | JPS | HY911130A | 1 | JTAG | JT1 | HEADER5X2X2.0T | 1 | FB | L1 | CAP0603 | 1 | LED | LD1, LD2, LD3, LD4, LD5 | 0603D | 5 | LED | LD6 | D0603 | 1 | RED | LED1, LED2, LED3, LED4 | 0603D | 4 | DC | P3 | DC5.0 | 1 | 100R | R9, R54, R57 | RES0402 | 3 | 0R | R15, R70 | RES0402 | 2 | 22R | R17, R18 | RES0402 | 2 | 2K2 | R25, R26, R55, R56, R58, R75, R76 | RES0402 | 7 | 49.9R1% | R27, R28, R29, R30, R35, R38, R39, R40 | RES0402 | 8 | 10K | R36, R37, R53, R71, R72, R73, R74 | RES0402 | 7 | 27K | R60 | RES0402 | 1 | 2.2k | R62, R65, R67 | RES0402 | 3 | 470R | R63, R64, R66, R68, R69 | RES0402 | 5 | 1M | R77 | RES0402 | 1 | 12K1% | R78 | RES0402 | 1 | 100K | R80 | RES0402 | 1 | 80.6 | R83, R84 | RES0402 | 2 | SPF_Caqesx4 | SFP1 | SPF_Caqesx4 | 1 | SW-1 | SW1, SW2, SW3, SW4 | SW-3X9 | 4 | SW123 | SW5 | SW1-2-3 -B | 1 | PCA9548APW | U1 | TSSOP24 | 1 | CR1220 | U2 | R190 | 1 | SP2526A-1EN-L | U3, U8 | SOP8 | 2 | DS1337 | U4 | SOP8 | 1 | TXS0108EPWR | U5, U14, U15, U16 | TSSOP20_6.5_4.4 | 4 | RCLAMP0524P | U6, U11, U12 | SLP2510P8_10 | 3 | USB2514 | U7 | QFN36 | 1 | 24LC02B-I/SN | U10 | SOP8 | 1 | SI570 | U18 | DFN8_8.2_7.3 | 1 | 24MHZ | Y2 | CRY5032_2 | 1 | 附件:- I- k9 w: W- ^: P7 `' G6 g
原理图和PCB源文件如下:
6 D& _' d; r7 f3 N4 B+ u
! y! c+ X/ P1 N2 P% [* ]: h' G0 l2 E' K+ |8 \
