6 l4 L0 U8 k4 n' _+ W6 P[AD 10][2层]I.MX6网络摄像机底板(SP7656EN2-L/TR+ISL1208+SP3232EEY)原理图和PCB文件
# _" }$ J c6 {1 t/ h; A/ t7 N4 f+ ~- P$ v: c8 L
文件描述
2 R2 @+ x) O8 R7 [, r8 B+ K1. 作品用途:I.MX6网络摄像机底板
' {; c5 b1 o' f& U! q* l2. 软件版本:AD 10
( R) u" [2 w4 w3. 层数:2层板
7 b$ X4 R- [0 C. {" D0 w; j7 \4. 用到的主要芯片:SP7656EN2-L/TR+ISL1208+SP3232EEY
& M8 z) Q) k2 {$ Y/ E5. PCB尺寸:134*71 mm
* r% Y: A$ `) p3 m% Z
3 M' ]6 p& x! \作品截图如下:, K- Y+ I: P9 w" G
顶层截图:
% w% t5 `( H% S! O4 c$ ~
4 W! ^3 M5 @( s
4 T/ E/ K# s& x
底层截图:4 d* w5 V0 Q! `; i
) m6 Q( c/ U* {2 }
) A+ N4 i8 E! s; F9 @6 H全层截图:) E- k- e6 Q# T9 o1 O' J
, j& M4 j( \4 M
叠层信息截图如下:
$ ^# Y! m* ?; U7 w0 o" M4 D0 j
& U) @2 o& m8 Y% @BOM:7 j& M, _, M8 D" [$ _- Y
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | Battery | BT1 | BATTERY2 | 1 | 16V | C5, C10, C58, C155, C156, C157 | C0805 | 6 | Cap2 | C13 | C1206 | 1 | Cap | C15, C21, C22, C24, C28, C30, C31, C32, C33, C34, C36, C37, C65, C67, C68, C70, C77, C83, C97 | C0805 | 19 | C17 | C17 | C0805 | 1 | Cap2 | C20, C25 | C0805 | 2 | Cap Pol3 | C26, C27, C29, C35, C66, C122, C123, C124 | C0805 | 8 | 10V | C60 | C0805 | 1 | 0.1uF | C114 | C0805 | 1 | 10uF | C115 | C0805 | 1 | 1pF | C125 | C0805 | 1 | 1.2pF | C126 | C0805 | 1 | LED_GREEN | D1 | R0603_LED | 1 | LED_RED | D2 | R0603_LED | 1 | SMF5.0A | D3 | SOD123FL_5A_2R7X1R65 | 1 | MMSZ5231BT1G | D4 | SOD_123_MMSZ52 | 1 | SS32 | D5 | DO-214AB | 1 | MBR0520 | D12 | SOD123 | 1 | Antenna cdma_t | E5 | CDMA_T | 1 | F1206FA | F1 | F_1206 | 1 | POWER_DC9V | J3 | POWER | 1 | CON2 | J5 | SW | 1 | 10X2P_254 | J9, J14 | DIP_2X10P_254 | 2 | CONN PLUC 100*2 | J10 | DIMM200_SOCK_IMX6_1V8 | 1 | CON40 | J22 | OMRON_XF2M-4015-1A | 1 | SDCard | J25 | SDCARD_PROCONN | 1 | Inductor | L1 | SLF7032 | 1 | MCZ1210AH900T | L7 | MCZ1210AH900T | 1 | 120 OHM@100MHz | L8 | L_0603 | 1 | Inductor | L10, L11 | L_0603 | 2 | L_0603 | L19 | L_0603 | 1 | miniUSB | miniUSB | MINI_USB | 1 | DB9_FEMALE | P2 | CONNECTORDB9 | 1 | HR911105A | P4 | HR911105A | 1 | SI7129DN-TI-GE3 | Q1 | QFN_8_3R3X3R3 | 1 | MMBT3906TT1 | Q2 | SOT_23_MMBT3906 | 1 | 2N7002 | Q3 | SOT23_3 | 1 | Res1 | R2, R3, R12, R13, R14, R15, R16, R17, R18, R19, R20, R21, R22, R24, R26, R27, R28, R29, R33, R38, R39, R51, R52, R53, R54, R60, R61, R69, R70, R71, R79, R89, R90, R91, R92, R93, R112, R113, R114, R115, R116, R117, R118 | R0805 | 43 | DNP | R25 | R0805 | 1 | SW PUSHBUTTON-SPST-2 | SW1, SW2 | SW4_PB_ESW_SM_P177 | 2 | BR3 BGX50A | U001 | SOT143 | 1 | SP7656EN2-L/TR | U3 | HSOICN8 | 1 | FDC642P | U4 | SOT23_6 | 1 | SP3232EEY | U5 | TSSOP16 | 1 | LAN8720 | U10 | QFN24_4X4MM_SLUG | 1 | RL-UM12BS-8188EUS-V1.2 | U16 | UM12BS-8188EUS | 1 | ISL1208 | U19 | SOIC8 | 1 | XTAL_32768 | Y2 | Y_D1P5MM | 1 | 附件:
- X% u+ K! o# F4 N原理图和PCB文件如下:
% u2 l, _6 ?8 c% Z/ S4 t' M2 ]* F6 W9 A E$ |
% a9 M5 V+ Z" V |
