& A) n9 A K) p1 h7 T A2 _, \
. D/ I$ C5 P% D H2 z" U% x4 }[AD 10][2层]BOOST主回路1 PCB文件
8 ], r. \$ @5 {4 F7 {* k: A0 ^7 l8 C
文件描述. I5 m2 ~' b5 [" N# ^
1. 作品用途:BOOST主回路1
2 ]9 ]1 Z: G3 }7 L6 u6 R2. 软件版本:AD 105 c) X7 r' P6 n: Y) k$ W' D
3. 层数:2层板
, @/ ^. k: k1 ?) o. v, s6 Z2 i a! Y; Q; `+ x+ g! e6 s9 f* o
# Y+ ?8 Q4 k: y% [+ n1 _6 q
作品截图如下:
3 }1 N1 f* m7 ~. h顶层截图:6 v: g5 E9 l, {5 o& K
! d! Z" C' K1 U7 P7 s: E6 m
全层截图:+ h# h; d* M a ~( } q% n* p
. [5 N- U& R9 P6 F; a& P( ?叠层阻抗信息如下:
9 R$ `; p- }* p
! H. x- k/ h6 x+ E( ]" }+ Y' y
t) |! J6 \# A1 ]5 A: E& eBOM:
3 V& }: |" d/ o# T2 iComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | LM386 | | SOP-8 | 1 | Cap Pol1 | C1 | CAP10mm | 1 | Cap | C1_1, C2_1, C3, C3_1, C4_1, C6, C7, C9, C10, C10_1, C11, C12, C13, C14, C15, C16 | 0805 | 16 | Cap Pol1 | C2 | CAP8.5mm | 1 | Cap Pol1 | C4, C8 | CAP5mm | 2 | Cap Pol1 | C5 | cap5m | 1 | LED2 | D1, D2, D3, D4, D5 | 3.2X1.6X1.1 | 5 | Fuse 2 | F1 | PIN-W2/E2.8 | 1 | CON2 | J1 | CHAZUO2 | 1 | CON2 | J1_1, J2_1, J3, J3_1, J4, J4-1, J6-1, J9, J15-1, J16, J16-1, J17-1, J17.1, J19, J20 | SIP2 | 15 | CON6 | J2 | SIP6 | 1 | CON3 | J3-1, J4_1, J5, J5_1, J6, J7, J10, J10.1 | SIP3 | 8 | Inductor Iron | L1, L2 | AXIAL-0.9 | 2 | DIODE | MBR1545 | TO-220 | 1 | Res Varistor | NTC | YAMIN | 1 | Diode 1N4001 | P6A10 | DO-41 | 1 | IRF540 | Q2 | E3 | 1 | TL431 | Q5 | TL431 | 1 | 20k | R1, R5, R9 | 0805 | 3 | Res3 | R1_1, R10, R11, R12, R13, R14, R15, R21, Rzhishi | 0805 | 9 | 1k | R2, R6 | 0805 | 2 | RES2 | R2_1, R3_1, R4_1, R5_1, R6_1, R7_1, R8_1, R26, R27, R28, R29, R30, R31, Rtest | 0805 | 14 | 10k | R3, R7 | 0805 | 2 | 4.7k | R4, R8 | 0805 | 2 | RPot | R18, R19 | VR5 | 2 | LM358 | U1 | SO-8 | 1 | UC3842 | U2 | SO-8 | 1 | PC817 | U3 | PC817 | 1 | Bridge1 | ZL | zhengliuq | 1 | 附件:
' H% A. X# l/ y$ i0 b% ^pcb文件如下:, ?; V4 J6 s) X
| 1 @6 m$ p! M; H8 ?, D, }9 f
