- z: x( _. H l6 Q6 u8 E/ I$ ?4 E! L' o# T- U3 R; P; t4 X
[AD 10][8层]EP2AGX125EF35开发板(EP2AGX125EF35+CY7C68013A-100AXC+ADP2323-LCC32)原理图和PCB文件7 t$ m+ M4 \. m! {% ]! d
9 o# {$ Q+ q6 c! ?/ {5 h% ?" w文件描述
- M. ?4 B; m, t1. 作品用途:EP2AGX125EF35开发板. e. Y7 u" G' K# ?+ l
2. 软件版本:AD 10
* k5 a7 @. F: c/ i3. 层数:8层板
U9 ^: h6 f8 Y0 f6 B9 o4. 用到的主要芯片:EP2AGX125EF35+CY7C68013A-100AXC+ADP2323-LCC32
* A" P3 h1 Q8 \5. PCB尺寸:228*113 mm# F# g% q2 D6 d7 j" }* B
; z5 _. @* X+ b( Q作品截图如下:
( j9 S3 m$ Q1 U. L顶层截图:. |4 H9 {5 E: t, x* {4 a
, V& ?- ^2 R6 g5 z
5 y5 M" V5 a9 P, \- y" M B底层截图:
0 }! u% J6 Q! \
' P, r. P& M4 h, G" l0 [( I9 V
8 u$ I1 k; a& M a# [全层截图:
6 M% \/ G3 [7 @' e1 g+ G7 L$ E- `
6 n& @, _% e; B3 y1 ~: {0 V9 ~
叠层信息截图如下:' S& _$ N: ]$ Q% [5 l9 X1 V
) z- o/ P" A/ N2 g% KBOM:
- B3 n7 [3 e" SComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1uF | C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, C22, C23, C26, C27, C28, C29, C30, C31, C32, C33, C42, C43, C51, C52, C53, C57, C58, C59, C60, C61, C62, C67, C68, C69, C70, C71, C72, C77, C78, C79, Cb1, Cb2, Cd10, Cd11, Cd12, Cd13, Cd14, Cd15, Cd16, Cd17, Cd18, Cd19, Cd20, Cd21, Cd22, Cdb10, Cdb11, Cdb12, Cdb13, Cdb14, Cdb15, Cdb16, Cdb17, Cdb18, Cdb19, Cdb20, Cdb21, Cdb22 | C_0402 | 79 | 0.01uF | C34, C35, C36, C44, C45, C46, C47, C54, C55, C56, C63, C64, C65, C66, C73, C74, C75, C76, C81, C82, C83, C86, C87, C89, C90, C91, C92, C93, C94, C95, C96, C97, C98, C99, C100, C101, C102, C103, C104, C105, C106, C107, C108, C109 | C_0402 | 44 | 1nF | C37, C38, C39 | C_0402 | 3 | 10uF | Ca1, Ca2, Ca6, Ca7, Ca11, Ca12, Ca16, Ca17, Cp22, Cp27, Cp32, Cp37, Ct1, Ct3 | C_1206 | 14 | 0.1uF | Ca3, Ca4, Ca5, Ca8, Ca9, Ca10, Ca13, Ca14, Ca15, Ca18, Ca19, Ca20, Ca21, Ca24, Ca25, Ca26, Ca29, Ca30, Ca31, Ca32, Ca35, Ca36, Ca37, Ca38, Ca41, Ca42, Ca43, Ca44, Cp23, Cp28, Cp33, Cp38, Cp39, Ct2, Ct4, CY4, CY5, CY6, CY7, CY8, CY9, CY10, CY11, CY12, CY13, CY14, CY15 | C_0603 | 47 | 1uF | Ca22, Ca27, Ca33, Ca39, Cp5, Cp6 | C_1206 | 6 | 0.01uF | Ca23, Ca28, Ca34, Ca40, Cf1, Co1, Cp20, Cp25, Cp30, Cp35, CY3, CY16 | C_0603 | 12 | 47uF | Cc1, Cc2 | C_1210 | 2 | 47uF X5R | Cd1, Cdb1 | C_1210 | 2 | 220uF X5R | Cd2, Cdb2 | Cap_D-AL | 2 | 0.01uF X5R | Cd3, Cdb3 | C_0603 | 2 | 0.1uF X5R | Cd4, Cd5, Cdb4, Cdb5 | C_0603 | 4 | 22nF | Cp1, Cp10 | C_0603 | 2 | 1500pF | Cp2, Cp12 | C_0603 | 2 | 10uF/35v-X5R | Cp3, Cp11 | C_1206 | 2 | 0.1uF-X5R、X7R | Cp4, Cp9 | C_0603 | 2 | 100uF/16v | Cp7, Cp8, Cp21, Cp26, Cp31, Cp36, Cp45 | Cap_D-AL | 7 | 33pF | Cp13 | C_0603 | 1 | 0.1uF-X5R | Cp14 | C_0603 | 1 | 4.7uF/16v-X5R | Cp15, Cp16 | C_1206 | 2 | 10uF-X5R | Cp17, Cp18 | C_1206 | 2 | 10uF/35v | Cp19, Cp24, Cp29, Cp34, Cp41 | C_1206 | 5 | 100uF/35v | Cp40 | Cap_D-AL | 1 | 680pF/16v | Cp42 | C_0603 | 1 | 0.47uF/16v | Cp43 | C_0603 | 1 | 47uF/35v | Cp44 | C_1210 | 1 | Cap | Cs1, Cs2, Cs3, Cs4 | C_0603 | 4 | 12pF | CY1, CY2 | C_0603 | 2 | led | Do1, Do2, Do3, Do4, Do5, Do6, Do7, Do8, Do9, Do10, Do11 | LED_0805 | 11 | D Schottky | Dp1, Dp2, Dp3, Dp4, Dp6 | 1N5822 | 5 | | Dp5 | 1N5822 | 1 | 1-353576-1 | JY1 | USB-B | 1 | Ferrite Bead | Ld1, Ldb1, Lf1, Lp9, Lp10 | R_1206 | 5 | 10uH | Lp1 | inductor_4 x 4 mm | 1 | 3.3uH | Lp2 | inductor_4 x 4 mm | 1 | 2.2uH | Lp3, Lp4 | inductor_4 x 4 mm | 2 | 100uH | Lp5, Lp6, Lp7, Lp8 | Inductor_7 X 7 MM | 4 | 8.2uH/2A | Lp11 | inductor_4 x 4 mm | 1 | Ferrite Bead | LY1 | R_0603 | 1 | FDS8880-MOSFET | Mp1, Mp2 | MOS-SOP8 | 2 | Header 5X2 | Pf1 | JTAG_HEADER-5 X 2_2.54mm | 1 | Header 6 | Po1 | 1.25-6 | 1 | Header 5X2H | Po2 | 2X1.25-10 | 1 | Header 10X2A | Po3, Po4 | HDR2X10_CEN | 2 | Header 2 | Pp1 | POWERIN_CH3.96 | 1 | Header 4 | PY1 | 1.25-4 | 1 | Header 2X2 | PY2 | 2_bit_switch | 1 | no pop | R1, R2 | R_0603 | 2 | Res2 | Ra13, Ra14, Ra15, Ra16, Ra17, Ra18, Ra19, Ra20, Ro12, Ro15, Rs1, Rs2, Rs3, Rs4, RY3, RY10, RY11 | R_0603 | 17 | 50 1% | Rb1, Rb2, Rb3, Rb4, Rdb7 | R_0402 | 5 | 22 | Rb5, Rb6, Rb7, Rb8, Rb9, Rb10, Rb11, Rb12, Rb13, Rb14, Rb15, Rb16 | R_0402 | 12 | 10k | Rb17, Rb18, Rb19, Rb20, Rb21, Rb22, Rb23, Rb24, Rb25, Rb26, Rb27, Rb28, RF1, Rf2, Rf3, Rf16 | R_0402 | 16 | 100 1% | Rd9 | R_0402 | 1 | 1k | Rf4, Ro1, Ro2, Ro3, Ro4, Ro5, Ro6, Ro7, Ro8, Ro9, Ro10, Ro11 | R_0603 | 12 | 10k | Rf5, Rf6, Rp14, Rp17, Rp20, Rp22, RY5, RY8, RY9 | R_0603 | 9 | no pop | Rf7, Rf8, Rf9, Rf10, Rf11, Rf12, Rf13, Rf14 | R_0402 | 8 | 22 | Rf15 | R_0603 | 1 | RN-4 | Rn9, Rn10, Rn11, Rn12, Rn13, Rn14, Rnb9, Rnb10, Rnb11, Rnb12, Rnb13, Rnb14 | RN-4 | 12 | 100k | Ro13, Ro14, Rp29 | R_0603 | 3 | 3k-1% | Rp1 | R_0603 | 1 | 22k-1% | Rp2 | R_0603 | 1 | 62k | Rp3, Rp7 | R_0603 | 2 | 200k | Rp4 | R_0603 | 1 | 10k-1% | Rp5, Rp6, Rp8, Rp9, Rp10, Rp11, Rp13 | R_0603 | 7 | 12k-1% | Rp12 | R_0603 | 1 | 4.7k | Rp15, Rp18, Rp23 | R_0603 | 3 | 1.2k | Rp16, Rp24 | R_0603 | 2 | 5.6k | Rp19 | R_0603 | 1 | 22k | Rp21 | R_0603 | 1 | 17.4k 1% | Rp25 | R_0603 | 1 | 63.4k 1% | Rp26 | R_0603 | 1 | 50k 1% | Rp27 | R_0603 | 1 | 715k 1% | Rp28 | R_0603 | 1 | 510 | Rt1, Rt2 | R_0603 | 2 | 2.2k | RY1, RY2 | R_0603 | 2 | 0 | RYu2, RYu3 | R_0603 | 2 | SW-DPST | So1, So2 | RESET_DIP-4 | 2 | EP2AGX125EF35 | U1 | FBGA1152 | 1 | CY7C68013A-100AXC | U24 | CY7C68013A_LQFP-100 | 1 | WM8214 | Ua1, Ua2, Ua3, Ua4 | WM8214 | 4 | DL526-03UHK | Uc1, Uc2 | DL526-03UHK_RFF-22 | 2 | K4T1G164QF-BIE6 | Ud1, Udb1 | FBGA84_DDRII_K4T1G164QF | 2 | LP2997M | Ud2, Udb2 | LP2997_PSOP-8 | 2 | EPCS64SI16N | Uf1 | EPCS16_SOIC-8&16 | 1 | 50MHz_OSCILLATOR | Uf2 | XTAL(5032) | 1 | 24LC64 | Uo2, UY2, UY3 | 24LCXX_SSOP-8 | 3 | ADP2323-LCC32 | Up1 | LCC32 | 1 | ADP5034-LCC24 | Up2 | LCC24 | 1 | TPS5430 | Up3, Up4, Up5, Up6 | TPS5430 | 4 | LT3693 | Up7 | LT3693 | 1 | SRAM_A | Us1 | TSOP44-2 | 1 | SRAM_B | Us2 | TSOP44-2 | 1 | TLC5917 | Ut1, Ut2 | TLC5917 | 2 | BAT54S | UY4, UY5 | BAT54S_SOT-23 | 2 | XTAL_24MHz | YY1 | Crystal_5 X 11 MM | 1 | 附件:1 |& G6 `* q7 X# P9 r7 ? ~
原理图和PCB文件如下:
) e) d& g1 R; N) j4 `5 [# T' ?% }6 g5 p) m9 E% Z4 } C: a
) F0 g: B9 v4 `7 e" n
