作品名:[AD 10][4层] TMS320F2812PGFA 做的高压软启(TLP181+6N137 )原理图、PCB源文件
( s2 L* ~& \# S( L& |- r3 g9 b- ~% G+ f& X
/ ]; w( t0 a7 q4 t% X1 K文件描述
/ J6 d4 P: L/ O1. 作品用途:高压软启
" o% m( E0 [0 x& O `5 z1 Y/ c2. 软件版本:AD 10
4 ^3 y' N: W# k s9 ~2 ?3. 层数:4层板' f& z3 _7 U. d' _( e4 V! S
4. 用到的主要芯片:TLP181+6N137
9 b, G: o! N0 c9 ^2 e! |3 g5. PCB尺寸:241mm*106mm
7 d4 j7 M0 `- K) ^- c& y
# l h9 E8 t" c) [1 a2 L# J; J' E+ `8 a
作品截图如下:% [6 h( b4 H6 S8 ~ d* ?9 o
顶层截图:0 Y6 n% ^" X; u0 \0 h3 \: M* r8 R
. G( ^- c$ K+ P- k" X4 J* f
底层截图:% E: Z* r! ?! D0 ^" D4 ^
+ B6 z! ~* r: y7 V. P8 S
全层截图:( ]: o d6 }8 M9 C! |
" }! r8 s3 A3 V# N
叠层信息截图如下:; |3 y3 p5 x6 c) o! }+ F* r& P
6 Y5 Q& J2 X- f( A7 ZBOM:
F; h5 J U* O) CComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 104 | C1, C3 | 1206 | 2 | 104 | C2, C13, C37, C42, C43, C44, C45, C87, C88, C89, C90, C93, C94, C95, C96, C97, C98, C99, C100, C101, C102, C103, C104, C105, C106, C113, C114, C115, C116, C117, C118, C121, C126, C127, C128, C129, C130, C131, C132, C133, C134, C135 | 0805 | 42 | 103 | C4, C5, C8, C9, C10, C11, C12, C14, C15, C16, C17, C18, C19, C20, C21, C22, C24, C25, C26, C27, C28, C31, C32, C34, C91, C92, R5, R6, R11, R12, R13, R14, R15, R16, R17, R18, R23, R24, R25, R26, R40, R41, R42, R43, R44, R45, R46, R47, R48, R49, R50, R51, R52, R53, R54 | 0805 | 55 | 105 | C6, C7, C23, C29, C30, C33, C40, C41, C46, C47, C48, C49, C50, C51, C52, C53, C54, C55, C56, C57, C58, C59, C60, C61, C62, C63, C64, C65, C66, C67, C68, C69, C70, C71, C72, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C85, C86, C107, C108, C110, C111, C112, C119, C120 | 0805 | 54 | 22pF | C35, C36 | 0805 | 2 | 103/2000V | C38, C125 | CAP0.3 | 2 | 105 | C83, C109 | 1206 | 2 | CON40 | CH1, CH2, CH3 | IDC40 | 3 | IDC10 | CH01 | IDC10 | 1 | IDC14 | CH02 | IDC14 | 1 | IDC24 | CH03 | IDC24 | 1 | 470uF/16V | E1, E3, E9 | EC8*10.8 | 3 | 220uF/16V | E2, E10 | EC6.3*5.5 | 2 | 476 | E4, E7, E8 | TCC | 3 | 106/6.3V | E5, E6 | TCA | 2 | TMS320F2812PGFA | IC1 | S-PQFP-G176 | 1 | TPS75733 | IC2 | TO-263KTT | 1 | TPS76801 | IC3 | SO-8 | 1 | TPS3823-33DBVR | IC4, IC15 | SOT23-5 | 2 | X25163-V33 | IC5 | SO-8 | 1 | MAX3232EUE | IC6 | TSSOP-16 | 1 | SN65HVD230 | IC7 | SO-8 | 1 | MAX485CSA | IC8 | SO-8 | 1 | AD7865 | IC9 | QFP44-3 | 1 | EPM1270T144I5N | IC10 | TQFP-144 | 1 | 74LVC4245 | IC11, IC12, IC13, IC14, IC17, IC18, IC19, IC20 | TSSOP-24 | 8 | 74HC14 | IC16 | SO-14 | 1 | SN74CBTD3306 | IC21 | SO-8 | 1 | LED-RED | IN1, IN2, IN3, IN4, IN5 | 1206 | 5 | DB9 | J1 | DB9RA/M | 1 | 6X6 | KK | KK | 1 | 10uH | L1, L2, L3, L4 | 1206 | 4 | LED-GREEN | LED1, UR, US, UT | 1206 | 4 | B0505LS/D-1W | P1 | B0505LS-1W | 1 | 472 | R1 | 1206 | 1 | 2002 | R2 | 0805 | 1 | 3302 | R3 | 0805 | 1 | 472 | R4, R8, R9, R21, R31 | 0805 | 5 | 302 | R7 | 0805 | 1 | 102 | R10, R56, R57, R58, R59, R60, R61, R62, R63 | 1206 | 9 | 24.9k | R19 | 0805 | 1 | 516 | R20A, R20B, R55A, R55B | 2512 | 4 | 162 | R27, R29 | 0805 | 2 | 332 | R28, R30 | 0805 | 2 | 471 | R32, R33, R37 | 1206 | 3 | 103 | R34, R35, R36, R39 | 1206 | 4 | TLP181 | U1, U2, U3, U4, U5 | OPT | 5 | 6N137 | U6, U7, U8 | SO-8 | 3 | SMBJ6.5CA | V1, V2, V3, V4 | DO-214AB | 4 | 16MHz | Y1 | CRYS | 1 | XO75-NAC-10MHz | Y2, Y3 | XO75 | 2 | 附件:
$ D" \! u0 a5 Q4 v# M原理图和PCB源文件如下:
/ k* F& V# A3 h8 @# W* M
8 f* t- A2 a0 y" {0 w$ e
5 `( N/ Z: \. t |
