, s8 f# h. U# S. o, f, ]0 y7 o
- t" T: g% {* P1 e7 H
* T4 b0 O0 e3 q
[AD 10][4层]C5000音频电容式触摸增压器组(TMS320C5535+TS3A225E+SST25VF016B)原理图和PCB文件 " p! w' B" x f- w. C9 f
文件描述 1. 作品用途:C5000音频电容式触摸增压器组 2. 软件版本:AD 10 3. 层数:4层板 4. 用到的主要芯片:TMS320C5535+TS3A225E+SST25VF016B 5. PCB尺寸:50*84 mm
4 Z/ Y( w6 q1 ^作品截图如下: 顶层截图:
) Q; s7 f" ^$ Z. }底层截图: - [3 N I6 _0 U4 I H
全层截图: 叠层信息截图如下: BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 10uF | C1, C2, C6, C7, C16, C18, C21, C29, C56, C62, C74, C102, C206 | 0805-c | 13 | NO_POP | C3, C106 | 0402-C | 2 | 0.1uF | C4, C5, C8, C9, C14, C17, C19, C22, C25, C27, C30, C32, C33, C34, C41, C44, C46, C47, C48, C49, C50, C57, C59, C60, C61, C63, C64, C65, C66, C67, C68, C70, C71, C75, C80, C88, C108, C200, C201, C202, C210 | 0402-C | 41 | 0.47uF | C10, C12, C111 | 0402-C | 3 | 22pF | C11, C107 | 0402-C | 2 | 100uF | C13, C15 | SMD-C | 2 | 1000pF | C20, C31, C45, C58 | 0402-C | 4 | 33pF | C23, C24, C79 | 0402-C | 3 | 1uF | C26, C35, C37, C39, C40, C43, C52, C54, C69, C81, C82, C87, C89, C104, C109, C110, C203, C208, C209, C211 | 0603-C | 20 | 0.01uF | C28, C36, C38, C42, C51, C53, C55, C83 | 0402-C | 8 | 2200pF | C72 | 0402-C | 1 | 4.7uF | C73, C76, C77, C78, C85 | 0805-c | 5 | 2.2uF | C100, C101 | 0603-c | 2 | 10pF | C103 | 0402-C | 1 | 10uF/16V | C105 | 0805-c | 1 | 0.022uF | C220 | 0402-C | 1 | MBR0520 | D1, D4, D5 | SOD-123-1 | 3 | 6.2V | D2 | SOD-123-1 | 1 | LED_GREEN | D3 | 0603-1 | 1 | LED8 | D6 | 1206-W | 1 | LED7 | D7 | 1206-W | 1 | LED5 | D8 | 1206-W | 1 | LED6 | D9 | 1206-W | 1 | LED2 | D10 | 1206-W | 1 | LED3 | D11 | 1206-W | 1 | LED1 | D12 | 1206-W | 1 | LED4 | D13 | 1206-W | 1 | LED9 | D14 | 1206-W | 1 | SD CARD | J1 | microsd-TF2 | 1 | OSD9616 | J2 | LCD-UG-9616TLBBG02 | 1 | PAD | J3, J4, J5, J6, J7, J8 | SIP1-TEST | 6 | JUMPER | JP1, JP2, JP3, JP5 | SIP2-2.54 | 4 | NO_POP | JP6 | SIP2-2.54 | 1 | BLM21AG151SN1D | L1, L2 | 0603-L | 2 | BLM18AG601SN1D | L3, L4, L5, L6, L7, L8 | 0603-L | 6 | 2.2uH | L9, L11 | VLF3010A | 2 | NO_POP | P1 | SIP10-2.0 | 1 | Header 10 | P3, P4 | SIP10-2.54MM-SMD | 2 | APM2309A-TRL | Q1 | SOT-23-3P | 1 | NO_POP | R1, R2, R8, R24, R29, R32, R42, R43, R62, R63, R65, R66, R69, R75, R76, R96, R97 | 0402-R | 17 | 0 | R3, R4, R7, R21, R23, R26, R28, R31, R44, R45, R46, R57, R58, R59, R79, R89 | 0402-R | 16 | 10K | R5, R13, R30, R33, R34, R35, R38, R39, R41, R47, R64, R67, R68, R70, R71, R72, R73, R82, R93 | 0402-R | 19 | 4.7K | R6, R16, R22, R56 | 0402-R | 4 | 47K | R9, R10 | 0402-R | 2 | 33 | R11, R48 | 0402-R | 2 | 2.2K | R12 | 0402-R | 1 | 1K | R14 | 0402-R | 1 | 330 | R15, R17, R18, R78, R83, R84, R85, R86, R87 | 0402-R | 9 | 100 | R19 | 0402-R | 1 | 14K 1% | R20 | 0402-R | 1 | 100K | R25, R36, R37, R91 | 0402-R | 4 | 10K 1% | R27 | 0402-R | 1 | 220 | R40 | 0402-R | 1 | 18.2K 1% | R49 | 0402-R | 1 | 3.3K 1% | R50 | 0402-R | 1 | 10.7K 1% | R51 | 0402-R | 1 | 110K 1% | R52 | 0402-R | 1 | 250K | R53 | 0402-R | 1 | 30K 1% | R54 | 0402-R | 1 | NOP_POP_4.7K | R55 | 0402-R | 1 | 392K 1% | R77 | 0402-R | 1 | 1.6M 1% | R80 | 0402-R | 1 | 180K 1% | R81 | 0402-R | 1 | 1 1% | R90 | 0402-R | 1 | 220K | R92 | 0402-R | 1 | 20K | R94 | 0402-R | 1 | 39.2K | R95 | 0402-R | 1 | SIP | SILP | PAD-28MM | 1 | GND | TP1, TP4 | SIP1-TEST | 2 | VBUS | TP2 | SIP1-TEST | 1 | CLKOUT | TP3 | SIP1-TEST | 1 | VCC_3V6_TP | TP5 | SIP1-TEST | 1 | VCC_1V3_TP | TP6 | SIP1-TEST | 1 | TextPoint | TP7, TP10, TP11, TP12 | SIP1-TEST | 4 | VCC_3V3_TP | TP8 | SIP1-TEST | 1 | RTC_CLKOUT | TP9 | SIP1-TEST | 1 | VCC_1V8_TP | TP13 | SIP1-TEST | 1 | TPS77801 | U1 | SOIC-8P | 1 | TLV320AIC3204IRHBT | U2 | QFN-32P-0.5MM | 1 | INA219IDCN | U3 | SOT-23-8P | 1 | DSX321G 12MHZ | U4 | SMD3225-4 | 1 | TMS320C5535 | U5 | BGA-N144-0.8MM | 1 | TPS62260DDCT | U6 | SOT-23-5P | 1 | TS3A225E | U7 | QFN-16P-0.5MM | 1 | TPS79501DCQ | U8 | SOT-223-6 | 1 | TPS79533DCQ | U9 | SOT-223-6 | 1 | SST25VF016B | U10 | son-8p | 1 | SN74AVC4T245 | U11 | TSSOP-16P | 1 | TPS61041DBV | U12 | SOT-23-5P | 1 | Audio Line Input | U13 | KJ-355-X1 | 1 | USB-MINI--F | USB1 | USB-MIN-F | 1 | 32.768KHz | Y1 | SMD4015-2 | 1 |
附件: 原理图和PCB文件如下:
: x7 m* ?& F( B# `1 A" ` |
