V$ g8 a) h& S4 `1 h/ n
. l9 b) R: `1 g+ {6 V$ X
[AD 10][4层]ST3241EBPR参考板(MAX9938FEUK+BARRACUDA_256K+ST3241EBPR)原理图和PCB文件
! g2 e i% y- j5 s; ~- V: Q3 R$ c2 y! [' B
文件描述
: Z9 J% |% Z+ S1 l% k1. 作品用途:ST3241EBPR参考板' Y. K8 \0 ~( d6 q7 l- o9 P
2. 软件版本:AD 10- v3 v# i n$ c& ]% F
3. 层数:4层板
' Q0 l3 ?8 h- f4. 用到的主要芯片:MAX9938FEUK+BARRACUDA_256K+ST3241EBPR7 S) q! _* l4 c G7 {
5. PCB尺寸:114*173 mm
0 z* V0 X( ~7 E( \
" d9 A* t7 H) B X9 y5 c作品截图如下:
& D5 ~9 E: Y+ [/ l: k; }顶层截图:( ^9 [/ I5 d2 C
# F$ i! X" w( W, R/ t5 E
7 \9 X' g0 i" }6 @" d底层截图:
, G& W7 I. U. @( r5 A
2 g: n* L8 I$ j% K2 U k
/ a2 T/ v! t9 e" ?全层截图:
0 e2 v3 r9 |& S: {7 A
9 Y) z4 v" y% C叠层信息截图如下:
- N- v% [! j$ Y% I
4 d- _( K) m% z4 ^, w) E, e- e
BOM:7 q9 r# [3 u) C0 x+ V. ~, C1 m
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | RESET | B1 | PB10 | 1 | WKUP | B2 | PB10 | 1 | USER | B3 | PB10 | 1 | Tamper | B4 | PB10 | 1 | CR1220 holder | BT1 | LI1220_1 | 1 | 100nF | C1, C2, C3, C4, C5, C6, C7, C8, C13, C14, C15, C20, C21, C22, C23, C24, C28, C29, C30, C31, C32, C33, C34, C37, C38, C39, C40, C41, C42, C48, C52, C53, C54, C55, C56, C57, C58, C62, C63, C77, C80, C89, C90, C91, C92 | 0603C | 45 | 22pF | C9, C10 | 0603R | 2 | 10uF | C11, C25, C26, C51, C75, C76 | TAN-A | 6 | 4.7uF | C12, C35, C36 | TAN-A | 3 | 10pF | C16, C17 | 0603C | 2 | 20pF | C18, C19 | 0603C | 2 | 470nF | C27 | 0603C | 1 | 0.022uF | C43, C44 | 0603C | 2 | 1uF | C45, C46, C49, C50, C95 | 0603C | 5 | 1uF | C47 | TAN-A | 1 | [N/A] | C59, C64, C65, C66, C67, C68, C69, C70, C71, C72 | 0603C | 10 | 10nF | C60, C73, C81, C82, C83, C84, C85, C86, C87 | 0603C | 9 | 1nF | C61, C88 | 0603C | 2 | 10uF | C74 | C160M | 1 | 0.47uF | C78 | 0603C | 1 | 220uF | C79, C79_1 | C310M | 2 | 150pF(COG) | C93, C94 | 0603C | 2 | J0011D21B | CN1 | J0011D21B | 1 | 475900001 | CN2 | USB-MICRO-AB | 1 | DB9-male CAN connector | CN3, CN4 | DB9/M | 2 | C816 | CN5 | SAM(C816) | 1 | DB9-male UART4 | CN6 | DB9/M | 1 | ST-212-02V | CN7 | ST-212-02V | 1 | Header 25X2 | CN8, CN9 | 2*25P | 2 | VB334 | CN10, CN11 | VB334 | 2 | FTSH-110-01-L-DV | CN12 | FTSH-110-01-L-DV | 1 | JTAG | CN13 | IDC20S | 1 | 3.2" LCD_connector (MB785 with AM-240320D4TOQW-T00H(R)) | CN14 | AM240*320AA | 1 | 2.4" LCD connector (MB542 with AM240320L8TNQW-00H) | CN15 | AM240*320B | 1 | PJS008-2000 | CN16 | MSD(PJS008) | 1 | MC_connector | CN17 | IDC34S | 1 | DC-10B | CN18 | DC10B | 1 | 1N4148 | D1, D2 | 1504D | 2 | | JP1, JP3, JP4, JP7, JP8, JP10, JP11, JP12, JP13, JP14, JP16, JP23, JP24 | SIP3 | 13 | | JP2, JP5, JP6, JP9, JP15, JP17, JP18, JP19, JP20, JP21, JP22, JP26 | SIP2 | 12 | | JP25 | 2*3P | 1 | BEAD | L1 | 0603L | 1 | Green | LD1, LD6 | 0603D | 2 | Orange | LD2 | 0603D | 1 | Red | LD3, LD5, LD7 | 0603D | 3 | Blue | LD4 | 0603D | 1 | 2K2 | R1, R2, R6, R7 | 0603R | 4 | 10K | R3, R32, R37, R40, R46, R47, R56, R60, R61, R64, R65, R66, R67, R74, R89, R90, R91, R92, R93, R106, R107, R121, R122, R123, R124, R125, R126, R127, R128, R152, R160, R164 | 0603R | 32 | 47K | R4, R34, R75 | 0603R | 3 | [N/A] | R5, R54, R55, R62, R118, R119, R120 | 0603R | 7 | 1K5 | R8, R148 | 0603R | 2 | 240 | R13, R14 | 0603R | 2 | 0 | R30, R35, R36, R38, R41, R44, R45, R48, R49, R50, R51, R59, R68, R69, R78, R79, R82, R83, R84, R85, R98, R99, R100, R101, R102, R103, R104, R105, R129, R130, R131, R132, R135, R136, R137, R139, R140, R141, R142, R143, R144, R147, R154, R159, R161, R162, R163, R165, R166, R167, R168, R169 | 0603R | 52 | 4.87K | R31 | 0603R | 1 | 680 | R33, R95, R96, R97 | 0603R | 4 | 330 | R39, R94, R116 | 0603R | 3 | 22[N/A] | R42, R43 | 0603R | 2 | 120 | R52, R53 | 0603R | 2 | 100K | R57, R58, R70, R81, R145 | 0603R | 5 | 390 | R63 | 0603R | 1 | 4K7 | R71, R114, R115, R133, R134, R138, R149 | 0603R | 7 | 51 | R72, R73 | 0603R | 2 | 5 | R76 | 0603R | 1 | 47 | R77, R155 | 0603R | 2 | 100 | R80, R108, R109, R110, R111 | 0603R | 5 | 1K | R86 | 0603R | 1 | 820 | R87, R88 | 0603R | 2 | 50 | R112, R113 | 0603R | 2 | 220K | R117 | 0603R | 1 | 3K3 | R146 | 0603R | 1 | 10K(1%) | R150 | 0603R | 1 | 20K(1%) | R151 | 0603R | 1 | 30K | R153 | 0603R | 1 | 1(1%) | R156 | 0603R | 1 | 1K(1%) | R157 | 0603R | 1 | 15K | R158 | 0603R | 1 | 33 | RS1, RS2, RS3, RS4 | RES-4B | 4 | 50 | RS5 | RES-4B | 1 | 2K2 | RS6 | RES-4B | 1 | 10K | RV1 | ADJRH | 1 | | SB1, SB2, SB3, SB4, SB5 | JP2_SMD | 5 | 09.03290.01 | SW1, SW2 | SIP3 | 2 | STT5PF20V | T1, T2 | SOT-23-6L | 2 | 9013 | T3 | SOT-23 | 1 | 25MHz | TP1 | TP | 1 | AUX2 | TP2 | TP | 1 | AUX1 | TP3 | TP | 1 | PTP_PPS | TP4 | TP | 1 | 2V5 | TP5 | TP | 1 | MCO | TP6 | TP | 1 | AIN- | TP7 | TP | 1 | AIN+ | TP8 | TP | 1 | 3V3 | TP10 | TP | 1 | 5V | TP11 | TP | 1 | Ground | TP12 | TP | 1 | VREF | TP13 | TP | 1 | DP83848CVV | U1 | LQFP48 | 1 | SM7745HEV-50.0M (do not fit) | U2 | XTAL_5X7 | 1 | STMPS2141STR | U3 | SOT-23-5L | 1 | EMIF02-USB03F2 | U4 | FlipChip(11) | 1 | SN65HVD230 | U5, U6 | SO8 | 2 | STMPE811 | U7, U8 | QFN16(3X3) | 2 | BARRACUDA_256K | U9 | TQ100_TOOL | 1 | ST8024CDR | U10 | SO28 | 1 | ST3241EBPR | U11 | SSOP28 | 1 | TFDU4300 | U12 | IR_VISHAY3 | 1 | CS43L22 | U13 | QFN40(6*6) | 1 | MT008-A | U15 | JOY | 1 | LIS302DL | U16 | LGA14(3*5) | 1 | M24C64-WMN6 | U17 | SO8 | 1 | ZEN056V130A24LS | U18 | polyzen | 1 | LD1086D2M33 | U19 | D2PAK/A | 1 | BNX002-01 | U20 | BNX001 | 1 | MAX9938FEUK+ | U21 | SOT-23-5L | 1 | 74H1G66STR | U22 | SOT-23-5L | 1 | 74LX1G04CTR | U23 | SOT323-5L | 1 | M74HC4060TTR | U24 | TSSOP16 | 1 | KSS-1508 or KSSG1708 | U25 | KS1708 | 1 | LD1117S25TR | U27 | SOT-223 | 1 | 25MHz (with socket) | X1 | XTAL1 | 1 | MC306-G-06Q-32.768 (manufacturer JFVNY) | X2 | SM8 | 1 | 25MHz (with socket) | X3 | XTAL_socket | 1 | SMAJ5.0A-TR | Z1 | 1R1C | 1 | 附件:
/ Q" G3 E4 ]" @0 l6 P原理图和PCB文件如下:
/ `" F' e3 n. f4 f+ K1 {, h+ A+ q9 x9 O* L! v2 @
2 I6 V: z, `4 v) g1 h% w3 h
