作品名:[AD 16][4层]视觉分析基于 OMAPL-138 的硬件软件参考平台参考设计(压缩文件内包含原理图和PCB), D. a0 _! k6 U) u' H7 Q8 @8 r
* q8 ^1 f9 A) A% Z) N
文件描述
) m: @; X! q1 e( y& {1. 作品用途:视觉分析基于 OMAPL-138 的硬件; c/ a O: |+ j
2. 软件版本:AD 16
; K8 z/ ]' _$ k! N3. 层数:4层板5 q) Z' Z! {! Y" L( N3 i
4. 用到的主要芯片:TLV803SDBZR! j# Y' R) u, C9 ~. A
5. PCB尺寸:114mm*95mm2 C" i+ b" R& s5 M* w
) j7 w, y8 i; w4 x: E4 ]
作品截图如下:+ _! u& S1 G0 l& \0 ~
顶层截图:3 S% P& c; A- r `" c
( B0 L; \3 i- I6 `0 @0 l% t) X/ f/ \8 y" l/ }8 J6 p1 n N
底层截图:8 E8 A" K. J# Q( Q8 C
, _% f& ]& P" x5 d0 M
" [1 q2 h0 g. p; g4 x8 n' T8 ^: @
全层截图:/ [9 u$ s" B% b! u7 N1 e/ j I
f: i9 U/ N" E: ~! q0 k9 C [7 f% k) _
叠层信息截图如下:( D) h6 I& t `4 L" d% T9 Q( }- c$ W
: L" s) g: Q; z: Y9 V% n5 _6 ?1 ~$ Z# E n6 ?( n% k- |& C
BOM:! h5 p# p0 o3 w: F; i5 G1 _8 W
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | BR1225-1VC | B100 | BR1225-1VC | 1 | 0.1uF | C100, C103, C104, C105, C106, C107, C108, C109, C110, C113, C117, C119, C120, C200, C203, C204, C205, C206, C207, C208, C209, C210, C211, C212, C213, C214, C215, C216, C217, C301, C304, C305, C306, C504, C900 | C0402L | 35 | 0.1uF | C101, C102, C303, C310, C401, C404, C406, C407, C408, C409, C410, C411, C502, C503, C608 | C0603N | 15 | 100uF | C111, C112 | CAPC3216X18N | 2 | 33pF | C201, C202 | C0402L | 2 | 15uF | C300, C400, C403 | SMD_TAN_B | 3 | 1.0uF | C302, C402, C405, C505, C506, C507, C508, C614, C901 | C0603N | 9 | 1.0uF | C307 | CAPCP2012X12N | 1 | 560pF | C308, C311, C312, C314 | C0402L | 4 | 1800pF | C309, C313 | C0402N | 2 | 0.01uF | C600, C604, C609 | C0603N | 3 | 4.7uF | C601, C602, C605, C606, C800, C801, C805, C807 | CAPC3216X18N | 8 | 100uF | C603, C607 | SMD_TAN_D | 2 | 1.0uF | C610 | CAPC2012X14N | 1 | 22uF | C611, C612, C615 | CAPC3225X27N | 3 | 0.22uF | C613 | C0603N | 1 | 12pF | C907, C908 | C0402L | 2 | B340A-13-F | D600, D601, D602 | SMA | 3 | MBRA160T3G | D603 | 403D-02-SMA | 1 | MF-MSMF110/24X-2 | F601, F602, F603, F604 | F1812N | 4 | UX60-MB-5S8 | J100 | UX60-MB-5S8 | 1 | MityOMAP_InteRFace_wpg | J101 | 10033853-152FSLF | 1 | USB-A-S-RA-TSMT | J102 | USB-A-S-RA-TSMT | 1 | 1775059-1 | J103 | 67913-0002 | 1 | 87832-2420 | J104 | 87832-2420 | 1 | JX0011D21BNL | J200 | JX0011 | 1 | SJ-3523-SMT | J300 | SJ-3523-SMT | 1 | 74320-4004 | J400 | 74320-4004 | 1 | IDC_DB9 | J501, J502, J504 | 5103308-1 | 3 | 67491-1032 | J503 | 67491-1032 | 1 | 1711026 | J600 | 1711026 | 1 | 79109-1224 | J700, J701, J702 | 79109-1224 | 3 | JUMPER | JP504 | JUMPER | 1 | | L300, L400, L401 | L0603 | 3 | IHLP2525CZER220M11 | L600, L601, L602 | IHLP2525X30 | 3 | 2N7002ET1G | Q100 | SOT-23-3 | 1 | MMBT2222A | Q500, Q501, Q502, Q503 | SOT-23-3 | 4 | FDS6681Z | Q600 | SO-8 | 1 | 1.00K | R100, R101, R102, R103, R104, R105, R106, R107, R109, R110, R501, R503, R504, R505, R506, R507, R508, R509 | R0402L | 18 | 33.0 | R108, R215, R216, R217, R218, R219, R220, R226, R227, R228, R229, R700, R701, R702, R703, R704, R705 | R0402L | 17 | 2.20k | R200, R201, R203, R204, R205, R206, R213, R221, R223, R224 | R0402L | 10 | 1.00M | R207 | R0402L | 1 | 0.0 | R208, R908, R909 | R0402L | 3 | 49.9 | R209, R210, R211, R212 | R0603L | 4 | 4.99K | R214 | R0402L | 1 | 130 | R222, R225 | R0402L | 2 | 1.80k | R300, R302, R305, R309, R312 | R0402L | 5 | 3.30k | R301, R307, R308, R314 | R0402L | 4 | 680 | R303, R306, R310, R313 | R0402L | 4 | 100 | R304, R311 | R0402L | 2 | 510 | R400, R401, R402, R403 | R0603N | 4 | 10.0k | R408, R500 | R0603N | 2 | 1.00k | R409 | R0402N | 1 | 120 | R502 | R1206N | 1 | 10.0k | R600, R602 | R0402L | 2 | 3.24k | R601 | R0402L | 1 | 5.90K | R603 | R0402L | 1 | 348K | R604 | R0402L | 1 | 20.0K | R605 | R0402L | 1 | 15.8K | R606 | R0402L | 1 | 140k | R607 | R0402L | 1 | 270 | R804, R810 | R1206N | 2 | VC15MA0160KBA | RV600 | 2220 | 1 | KMR221GLFS | S100, S101 | KMR221GLFS | 2 | 5001 | TP1 | TP | 1 | TLV803SDBZR | U12 | SOT-23-3 | 1 | TPS2041BDBVR | U100, U101 | SOT-23-5 | 2 | USBLC6-2P6 | U102, U103 | SOT-666 | 2 | TLK100PHP | U200 | PHP48_N | 1 | DSD1791DB | U300 | DB28 | 1 | OPA2134UA | U301 | SO-8 | 1 | TFP410PAP | U400 | PAP64_N | 1 | ISO1050DUBR | U501 | DUB08 | 1 | TRS232ECPWR | U502 | TSSOP16 | 1 | SM712.TCT | U505 | SOT-23-3 | 1 | TPS5430 | U600, U601, U602 | SO8(PWP) | 3 | VIBLSD1-S12-S5-SIP | U800, U801 | VIBLSD1 | 2 | MCP2515-I/ST | U900 | TSSOP20 | 1 | CB3LV-3I-24M5760 | X100 | CB3LV | 1 | 25.000 MHZ | Y200 | CSM-7 | 1 | 20.000MHz | Y900 | CSM-7 | 1 | + Y$ f0 W) p# l) w- \7 P
附件:
- r3 Z2 V) i6 {; G, D3 ]6 {9 w原理图和PCB源文件如下:- \/ @# \% T# Y/ N! Z+ r- Z
4 t5 l. p) J3 ?( @. y( L% u/ _
9 h2 e. |4 D3 u1 K7 |5 N |
