作品名:[AD 16][4层] DSP四层电路板(TMS2407A+HP200+74LS139)原理图、PCB源文件$ g+ I0 n4 z9 H5 |! W b
4 V1 H( Y' B1 v" ?3 d8 [
( X' r( W* S! Z# m# R( ]* a& j1 L$ |
文件描述
1 C1 r# ^) ]$ @7 Y5 o3 Z1. 作品用途: DSP四层电路板* J3 c4 S3 ^: |3 X2 G% w
2. 软件版本:AD 16
- A, I1 Q0 P3 u$ h( }7 x4 J, \8 B1 N3. 层数:4层板
( {( I3 s/ a! u! D! I( |' u4. 用到的主要芯片:TMS2407A+HP200+74LS139
5 u# _5 L( X; f1 e/ b- \ Z5. PCB尺寸:211mm*122mm
4 _ E0 i" k) o) }# l4 q9 X0 G2 g, V+ Z) y: q
7 i) X8 y5 w' u2 k6 d9 c5 f作品截图如下:
( |) {+ g# S, ?顶层截图:
4 K4 g) a: h+ X8 Y9 Y$ U
, j& ~% p+ K' S) N
底层截图:6 ]" F/ ^( a) Z' K, R0 ~" ~0 o% @" y
* J" Z8 a: z! }+ N: l# z+ Y
全层截图:
) ?0 ~& ]. B: h5 v! ]: x( l
* q! P( ?7 x u. J1 V& \5 s
叠层信息截图如下:
3 t1 K; s% k! n, |5 }/ p5 e: g+ R
6 Y% L0 l5 n1 q- k+ D
BOM:
& w! O8 K# Y0 `Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1u | C1, C3, C5, C6, C7 | 0805 | 5 | 0.0033uf | C2 | 0805 | 1 | 0.15uf | C4 | 0805 | 1 | 0.1u | C8 | RAD0.1 | 1 | 104/35V | C9, C10 | RAD0.1 | 2 | 470uf/35V | C11, C12, C13 | RB.2/.4 | 3 | 0.33uF | C14, C15, C16 | RAD0.1 | 3 | 47uF | C17, C18, C19, C20, C21, C22 | RB.1/.2 | 6 | 104 | C23, C24, C25 | RAD0.1 | 3 | 10000uF | C26, C27 | RB.4/.8 | 2 | 10u | C28 | 1210 | 1 | 103 | C31, C32 | 0805 | 2 | 103 | C33, C34 | RAD0.1 | 2 | 0.1uf | C35, C36, C39, C40, C51, C52 | 0805 | 6 | 6p | C37, C38, C41, C42, C43, C44, C45, C46, C47, C48, C53 | 0805 | 11 | 1N4148 | D3, D4, D5 | DIODE0.4 | 3 | 1N4002 | D6, D34, D35, D36, D37, D38, D39, D40, D41 | DIODE0.4 | 9 | TVS | D7 | DIODE0.4 | 1 | DIODE | D8, D9, D10, D11, D12, D13, D14, D15, D16, D17, D18, D19, D20, D21, D22, D23, D24, D25, D26, D27, D28, D29, D30, D31, D32, D33 | 1206AD | 26 | LM7805CK | DU1 | TO-220H | 1 | LM79L15 | DU2 | TO-220H | 1 | LM7815 | DU3 | TO-220H | 1 | TPS77833 | DU4 | SO-8 | 1 | 10uF | E1, E2, E3, E4, E5, E6, E7, E8, E9, E10, E11, E12, E13, E14, E15, E16, E19, E20, E31, E32, E33, E34, E36, E38, E40, E41, E42, E43, E44, E45, E46, E47, E48, E49, E50 | 1210 | 35 | SLOT96 | J1 | HT96ML | 1 | CON4 | J9, J14 | CON4 | 2 | JTAG_PORT | J10 | IDC14 | 1 | SIP3 | J11 | SIP3 | 1 | IDC10 | J12 | IDC10 | 1 | 3.3uH | L1, L2, L3 | L_RAD0.2 | 3 | POWER | LED1 | LED | 1 | RUN_1 | LED2 | LED | 1 | SCAN_F1 | LED3 | LED | 1 | FAULT1 | LED4 | LED | 1 | NORMAL1 | LED5 | LED | 1 | RUN_2 | LED6 | LED | 1 | SCAN_F2 | LED7 | LED | 1 | FAULT2 | LED8 | LED | 1 | NORMAL2 | LED9 | LED | 1 | COM | LED10 | LED | 1 | LA_28NP | LEM1 | LA28-NP | 1 | 20MHz | OSC1 | OSC1 | 1 | 5.1K | R1, R2, R3, R4, R30, R37, R38, R41, R42 | 0805 | 9 | 2.2K | R5 | 0805 | 1 | 10K | R6, R7, R8, R9, R19, R23, R31, R32, R35, R44, R46, R48, R49, R53, R55, R58, R59, R63, R65, R68, R69, R70, R72, R73, R74, R79, R80, R81, R83, R84, R85, R91, R95, R97, R99, R101, R102, R104, R105, R106, R107, R109, R111, R112, R113, R114, R120, R121, R123, R124, R129, R130, R131, R134, R135, R136, R137, R140, R144, R145, R146, R147, R148, R149, R150, R151, R154 | 0805 | 67 | 1K | R10, R11, R12, R13, R14, R15, R16, R17, R18, R75, R76, R86, R87, R125, R132, R133, R152 | 0805 | 17 | 510 | R20, R22, R39, R40, R51, R61, R139 | 0805 | 7 | 100K | R21, R29, R50, R60, R138 | 0805 | 5 | 24 | R24 | 0805 | 1 | 10 | R25, R26, R67, R78, R143 | 0805 | 5 | 120 | R27 | 0805 | 1 | 100 | R28 | AXIAL0.5 | 1 | 39K | R43, R45, R100, R110 | 0805 | 4 | 20K | R52, R56, R62, R66, R71, R82, R89, R90, R92, R93, R94, R96, R98, R108, R116, R119, R122, R127, R142 | 0805 | 19 | 2.4K | R54, R64, R141 | 0805 | 3 | 150 | R57 | AXIAL0.5 | 1 | 62K | R103, R118 | 0805 | 2 | 75/2W | R115, R126 | AXIAL0.9 | 2 | 300 | R117, R128 | 0805 | 2 | 0 | R160, R170 | 0805 | 2 | SW DIP-4 | SW | SW DIP-4 | 1 | TRANS1 | T1 | TRANS1 | 1 | TMS2407A | U1 | QFP144 | 1 | HP200 | U2, U3 | SO-8 | 2 | 74LS139 | U4 | SO-16 | 1 | SN65HVD251 | U5 | SO-8 | 1 | TCM809 | U6 | SOT-23 | 1 | TL3474 | U7, U11, U12, U13, U14, U18 | SO-14 | 6 | LM239 | U8, U9 | SO-14 | 2 | 74HC245 | U15 | SO20W | 1 | LMV3241 | U16, U17 | SO-14 | 2 | EPM7032AE | U19 | PLCC44 | 1 | 附件:' N# d7 ~7 n6 l2 X0 x& ?
原理图和PCB源文件如下:$ R, H$ ^( J* o3 Y- g8 q
N- N9 v, }% O: \! e; h' V0 N+ e+ C0 Q
