E" S, w( O. } g4 E. g3 e* G& U$ m. @# f7 |! m2 d% d
作品名:[AD 16][2层] LPC1124FBD48点阵显示(LPC1124FBD48+MAX485ESA+MP2451)PCB源文件4 S+ q4 D( b6 L- r( e: [$ `
6 F7 p3 c0 W8 J% ~, P% ~
; u) [0 J& g9 a E% o3 j文件描述
% b P& Z3 m( `6 I: g+ h! y" C n1. 作品用途:LPC1124FBD48点阵显示
4 c& I* V. B6 s( Y& H3 a$ ?: d2. 软件版本:AD 16$ M0 f% ]" _# h' U7 x8 U: C
3. 层数:2层板
7 `5 {4 }9 ^& t# P2 E4. 用到的主要芯片:LPC1124FBD48+MAX485ESA+MP24517 H# g/ ]6 \+ D1 `- V! c
5. PCB尺寸:88mm*73mm
/ `$ F, n$ m( U; w; i% F1 S* |7 I- _
- b% R' b) C: J0 T; B作品截图如下:0 s N3 e1 T/ z* g3 v4 [/ |3 y
顶层截图:' C! U1 S ` o
+ w9 ?3 d: B. Z+ l( V; U
底层截图:4 ]/ G! H7 j% i1 e) d3 m
* ^- g8 b+ R6 E# M全层截图:" }! G0 {; U( H0 |
3 A7 G3 t# U( L- ~5 P1 F, w, @1 ?叠层信息截图如下:5 ^9 P8 _1 B2 O$ c; c- x5 `- f
5 B' @% m8 T4 s" K% A8 ^$ SBOM:4 z) V5 z1 Q- A, Y- I& j
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1uF | C1, C3, C7, C8, C9, C13, C15, C17, C18, C19, C20 | SMDCC-0603 | 11 | 10nF/2KV | C4 | SMDCC-1812 | 1 | 100uF/16V | C5 | SMDEC-6MM(220MIL) | 1 | 22uF/10V | C6 | SMDCC-1206 | 1 | 47uF/50V | C10, C11 | SMDEC-8MM(6.3MM)) | 2 | 10uF/50V | C12 | SMDCC-1206 | 1 | 2.2uF | C14 | SMDCC-0603 | 1 | 10nF | C16 | SMDCC-0603 | 1 | 18pF | C21, C22 | SMDCC-0603 | 2 | SPE06SB | D1, D2, D3, D4 | SMB | 4 | S1ML | D5, D8 | SOD-123 | 2 | SMCJ-33CA | D6 | SMC | 1 | SS14 | D7 | SMA | 1 | Comment | Designator107 | LOGO-ESD | 1 | Comment | Designator108 | logo-pb | 1 | Comment | Designator109 | LOGO-SN | 1 | 0.1A | F1, F2, F3, F4 | SMDR-0805 | 4 | SM030 | F5, F7 | SM030 | 2 | EMI FILTER | F6 | WE-SL2 | 1 | 100R | FB1, FB2, FB3, FB4, FB5 | SMDR-0603 | 5 | Header 5 | J1 | SIP-5 | 1 | 3PIN | JP1 | tj-5.08-3p | 1 | 2PIN | JP2 | tj-5.08-2p | 1 | 5PIN | JP3 | tj-5.08-5p | 1 | 22uH/1A | L1 | SWPA4030 | 1 | LED | LED1 | SMDLED-0603 | 1 | KRC105S | Q1 | SOT-23 | 1 | 10K | R1, R2, R3, R4, R5, R6, R13, R19, R20, R21, R22, R23, R24, R25, R26, R27, R36, R37, R38, R39, R40, R41, R42, R43, R44, R45, R46, R48, R50, R51, R52, R53, R54 | SMDR-0603 | 33 | 100 | R9, R10 | SMDR-1210 | 2 | 1K | R11, R49 | SMDR-0603 | 2 | 4.7R | R12 | SMDR-2512 | 1 | 124K | R14 | SMDR-0805 | 1 | 100K | R15, R47 | SMDR-0603 | 2 | 1M | R16 | SMDR-1206 | 1 | 15K | R17 | SMDR-0603 | 1 | 23.7K | R18 | SMDR-0805 | 1 | 0 | R28, R29, R30, R31, R32, R33, R34, R35 | smdr-0603 | 8 | 8P4R-1K | RP1, RP2 | RN(0603) | 2 | SW-SPDT | SW1, SW2 | MSS3-V-SL-7/R | 2 | 16bit拨码 | SW3, SW4, SW6 | SW(DIP6 SWITCH) | 3 | KSD-02H | SW5 | SW(SMD-4) | 1 | ? | T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T11, T12, T13, T14, T15, T16, T17, T19, T20, T21, T22, T23, T24, T25, T26, T27, T28, T29, T30, T31, T33, T34, T35, T36, T37, T38, T39, T40, T41, T42, T43, T44, T45, T46, T50, T51, T52, T53, T54, T55, T56, T57, T58, T59, T60, T61, T62, T63, T64, T65, T66, T67, T68, T69, T70, T71, T72, T73, T74, T75, T76, T77, T79, T80 | TEST | 74 | MAX485ESA | U1 | SO-8 | 1 | RSM485PHT | U2 | RSM485PHT | 1 | MP2451 | U3 | SOT23-6P | 1 | CAT6219-330TD-GT3 | U4 | SOT-23-5 | 1 | LPC1124FBD48 | U5 | LQFP48 | 1 | CAT706SVI | U6 | SO-8 | 1 | 12MHz | XT1 | HCX-5SB | 1 | 附件:
7 k+ g1 G5 Y" D, N* ^ PCB源文件如下:
0 M% c, F/ Q2 E0 c& y0 y
$ ]0 `4 P5 m0 o5 i, X2 Q) b3 [7 G/ \
+ b8 z: D2 r4 O' w& t# B |
