# P8 r5 U+ p/ p7 _8 l1 T/ a( ?
& I% b- g! g8 \4 P# C8 ?作品名:[AD 16][4层] LPC1114点阵显示(LPC1114+CAT6219-330TD-GT3+74HC244)PCB源文件% L; F% x& x! K$ @) I
7 k% {4 U y1 f8 z
( _. L" z3 z; s l$ Y
文件描述9 E3 V$ ?% Y. `' A, ?
1. 作品用途:LPC1114点阵显示" z; J+ s o7 S Q7 I, q3 j& S! t4 M
2. 软件版本:AD 16
2 x# E1 Q: x; V% A3 M3. 层数:4层板7 X5 ^# q8 f, B; K( T8 s! i" |# l1 j
4. 用到的主要芯片: LPC1114+CAT6219-330TD-GT3+74HC244
4 L3 q' s, x* o: ?8 f, d/ M7 R# ]5. PCB尺寸:157mm*72mm- O \1 B/ w0 R5 T5 G8 q# f& s
0 S3 m6 [- `- M8 e
; \1 r9 m! \1 U( k' W2 }' t: l
作品截图如下:
3 C2 \: J- `$ x顶层截图:
1 \3 ~4 \9 ~! o3 L7 [
0 ]3 M+ B# m% t4 S( _底层截图:9 T( K) q7 n; T5 N! r
$ @. g5 l! F/ p5 u
全层截图:
8 a3 R) V$ h! a' ~9 x5 H. W* Z
5 {4 ^" l+ j" T" x$ v4 K0 t叠层信息截图如下:
% T/ K. e# f+ Y( M" O5 O5 n2 v8 m
% e p' |% ^& m0 U- H5 m3 yBOM:
9 ?0 D- ~* Y. Z- ~( L& p2 z/ l/ LComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | Comment | | LOGO-EP | 1 | Comment | | LOGO-ESD | 1 | 0.1uF/50V | C1, C2, C6, C10, C12, C14, C16, C17, C20, C21, C22, C23, C24, C25, C26, C27, C28, C29, C30, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C44, C45, C46, C47, C48, C49, C50, C51, C52, C53, C54, C55, C56, C57, C58, C59, C60, C61, C62, C63, C64, C65, C66, C67, C68, C69, C70, C71, C72, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C83, C84, C85, C86, C87, C88, C89, C90, C91, C92, C93, C94, C95, C96, C97, C98, C99, C100, C101, C102, C103, C104, C105, C106, C107, C108, C109, C110, C111, C112, C113, C114, C115, C116, C117, C118, C119, C120, C121, C122, C123, C124, C125, C126, C127, C128, C129, C130, C131, C132, C133, C134, C135, C136, C137, C138, C139, C140, C141, C142, C143, C144 | SMDCC-0603 | 133 | 100uF/10V | C3, C9, C145 | tc-d-h2.8 | 3 | 4.7uF/50V | C4 | SMDCC-0805 | 1 | 10uF/50V | C5, C7, C146, C147 | SMDCC-1210 | 4 | 4.7uF/50V | C8 | SMDCC-1206 | 1 | 10nF/100V | C11 | SMDCC-0603 | 1 | 10nF/3KV | C13 | SMDCC-2220 | 1 | 47UF/50V(Φ6.3*11) | C15 | EC(5.2*12-2W) | 1 | 18pF/50V | C18, C19 | SMDCC-0603 | 2 | 1N4007 | D1 | SMDD-4007 | 1 | 1N5822JF | D2 | SMDD-CCE | 1 | SMCJ-33CA | D3 | SMDD-CCE | 1 | LL-S150VC(1206) | D4 | SMDLED-1206 | 1 | LL4148 | D5, D6 | SMD4148 | 2 | BAV99 | D7, D8, D9, D10, D11, D12, D13, D14, D17, D18, D19, D20, D21, D22, D23, D24, D25 | SOT-23 | 17 | S1ML | D15, D16 | SMDLED-1206 | 2 | CA-7188BXX | DOT1, DOT2, DOT3, DOT4, DOT5, DOT6, DOT7, DOT8, DOT9, DOT10, DOT11, DOT12 | CA-788 | 12 | 0.5A | F1 | SMDL-1812 | 1 | SW-SPDT | Fun_SW, ICS_Sw | MSS3-V-SL-7/R | 2 | Header 5 | J1 | SIP-5 | 1 | B6B -PH-SM3 | J3 | B6B-PH-SM3 | 1 | S4B-PH-K-S | JP1 | PH-4AW | 1 | 10PIN | JP2 | B10B-PH-SM3 | 1 | 10R-1812 | L1 | SMDL-1812 | 1 | 22uH/2.5A | L2 | SMDL-220(CDRH104R) | 1 | 100R-0.3A | L3 | SMDR-0603 | 1 | Header 8 | P1 | B8B-PH-SM3 | 1 | Header 4 | P2, P3 | 1.25T-4-4A | 2 | TP | P&Mode1, P&Mode2, TP1, TP2, TP3, TP4, TP5, TP6, TP7, TP8, TP9, TP10, TP11, TP12, TP13, TP14, TP15, TP16, TP17, TP18, TP19, TP21, TP22, TP23, TP24, TP25, TP26, TP27, TP28, TP29, TP30, TP31, TP32, TP33, TP34, TP35, TP36, TP37, TP38, TP39, TP40, TP41, TP42, TP43, TP44, TP45, TP46, TP47, TP48, TP49, TP50, TP51, TP52, TP53, TP54, TP55, TP56, TP57, TP58, TP59, TP60, TP61, TP62, TP63, TP64, TP65, TP66, TP67, TP68, TP69, TP70 | TEST-1 | 71 | BC807 | Q1 | SOT-23 | 1 | 9013 | Q2 | SOT-23 | 1 | DTC114YU-10K/47K | Q3, Q4, Q5, Q6, Q7, Q8, Q9, Q10, Q11, Q12, Q13, Q14, Q15, Q16, Q17, Q18, Q19, Q20, Q21, Q22, Q23, Q24, Q25, Q26, Q27, Q28, Q29, Q30, Q31, Q32, Q33, Q34, Q35, Q36, Q37, Q38, Q39, Q40, Q41, Q42, Q43, Q44, Q45, Q46, Q47, Q48, Q49, Q50, Q51, Q52, Q53, Q54, Q55, Q56, Q57, Q58, Q59, Q60, Q61, Q62, Q63, Q64, Q65, Q66, Q67, Q68, Q69, Q70, Q71, Q72, Q73, Q74, Q75, Q76, Q77, Q78, Q79, Q80, Q81, Q82, Q83, Q84, Q85, Q86, Q87, Q88, Q89, Q90, Q91, Q92, Q93, Q94, Q95, Q96, Q97, Q98 | SOT-323 | 96 | 4.7R | R1 | SMDR-2512 | 1 | 4.7K | R2 | SMDR-0805 | 1 | SMV1812H380NXB | R3 | SMDR-1812 | 1 | 10K | R4, R9, R10, R11, R13, R22, R23, R24, R25, R50, R51, R52, R53, R54, R55, R56, R57, R62, R63, R76, R77, R78, R79, R80, R81, R82, R83, R182, R184 | SMDR-0603 | 29 | 1.6K | R5 | SMDR-0805 | 1 | 1M | R6 | SMDR-1206 | 1 | 15k | R7 | SMDR-0603 | 1 | 100k | R8 | SMDR-0603 | 1 | 4.7K | R12, R14, R15, R17, R18 | SMDR-0603 | 5 | 680R | R16 | SMDR-0603 | 1 | 1K | R19, R20, R21 | SMDR-0805 | 3 | 100R | R26, R27, R28, R29, R30, R31, R32, R33 | SMDR-0603 | 8 | 20K | R34, R35, R36, R37, R38, R39, R40, R41, R58, R59, R64, R65, R66, R67, R68, R69, R180 | SMDR-0805 | 17 | 10K | R42, R43, R44, R45, R46, R47, R48, R49, R60, R61, R70, R71, R72, R73, R74, R75, R181 | smdr-1206 | 17 | 200R | R84, R85, R86, R87, R88, R89, R90, R91, R92, R93, R94, R95, R96, R97, R98, R99, R100, R101, R102, R103, R104, R105, R106, R107, R108, R109, R110, R111, R112, R113, R114, R115, R116, R117, R118, R119, R120, R121, R122, R123, R124, R125, R126, R127, R128, R129, R130, R131, R132, R133, R134, R135, R136, R137, R138, R139, R140, R141, R142, R143, R144, R145, R146, R147, R148, R149, R150, R151, R152, R153, R154, R155, R156, R157, R158, R159, R160, R161, R162, R163, R164, R165, R166, R167, R168, R169, R170, R171, R172, R173, R174, R175, R176, R177, R178, R179 | smdr-0603 | 96 | 1K | R183 | SMDR-0603 | 1 | 8P4R-1K | RP25, RP26, RP27, RP28 | RN(0603) | 4 | SW-DIP4 | S1 | SW | 1 | ? | T1, T7, T10, T15, T17, T19, T20, T21, T22, T25, T26, T28, T29, T30, T31, T32, T33, T34, T35, T36, T37, T38, T39, T40, T74, T76, T77, T78, T79, T80, T81, T82, T83, T84, T85, T86, T87, T153, T154, T155, T156, T158, T159, T160, T161, T162, T163, T164, T166, T167, T168, T169, T170, T171, T172, T174, T175, T176, T177, T178, T179, T180, T181, T182, T183, T184, T185, T186, T187, T188, T189, T190, T191, T192, T193, T194, T195, T196, T197, T198, T199, T200, T201, T202, T203, T204, T205, T206, T207, T208, T209, T210, T211, T212, T213, T214, T215, T216, T217, T218, T219, T220, T221, T222, T223, T224, T226, T227, T228, T229, T230, T231, T232, T233, T234, T235, T236, T237, T238, T239, T240, T241, T242, T243, T244, T245, T246, T247, T248, T250, T251, T252, T253, T254, T255, T256, T257, T258, T259, T260, T261, T262, T263, T264, T265, T266, T267, T268, T269, T270, T271, T272, T273, T274, T275, T276, T277, T278, T279, T280, T281, T282, T283, T284, T285, T286, T287, T288, T289, T290, T291, T292, T293, T294, T295, T296, T297, T298, T299, T300, T301, T302, T303, T304, T305, T306, T307, T308, T309, T310, T311, T312, T313, T314, T315, T316, T317, T318, T319, T320, T321, T322, T324, T325, T326, T327, T328, T329, T330, T331, T332, T333, T334, T335, T336, T337, T338, T339, T340, T341, T342, T343, T344, T345, T346, T347, T348, T349, T350, T351, T352, T353, T354, T355, T356, T357, T358, T359, T360, T361, T362, T363, T364, T365, T366, T367, T368, T369, T370, T371 | TEST-1 | 250 | TESTPOINT | T2, T3, T4, T5, T8, T9, T11, T14, T16, T18, T23, T24, T41, T42, T43, T44, T45, T46, T47, T48, T49, T50, T51, T52, T53, T54, T55, T56, T57, T58, T59, T60, T61, T62, T63, T64, T65, T66, T67, T68, T69, T70, T71, T72, T88, T89, T90, T91, T92, T93, T94, T95, T96, T97, T98, T99, T100, T101, T102, T103, T104, T105, T106, T107, T108, T109, T110, T111, T112, T113, T114, T115, T116, T117, T118, T119, T120, T121, T122, T123, T124, T125, T126, T127, T128, T129, T130, T131, T132, T133, T134, T135, T136, T137, T138, T139, T140, T141, T142, T143, T144, T145, T146, T147, T148, T149, T150, T151 | TEST-1 | 108 | CAT6219-330TD-GT3 | U1 | SOT-23-5 | 1 | LM22676-ADJ | U2 | PSOP-8 | 1 | LPC1114FBD48 | U3 | LQFP48 | 1 | 74HC595-B | U4, U5, U6, U7, U12, U13, U14, U15, U16, U17, U18, U19 | tSSOP-16(6.5MM) | 12 | Si 9945BDY | U8, U9, U10, U11 | SO-8 | 4 | 74VHC14 | U20, U21, U22 | TSSOP-14(6.5mm) | 3 | 74HC244 | U23 | SOP-20(300MIL) | 1 | SP809NEK-L-2-9 | U24 | SOT-23 | 1 | 12.000MHz | XT1 | HCX-5SB | 1 | 附件:/ E. T+ k( C8 O3 o! X0 g( n" L& n
PCB源文件如下:
# n0 G/ ~2 W, x% G( m/ G" v
% S6 r1 w" ?! y/ l: X" `1 P, l& k/ f* G S5 X# `, N/ s
