1 B, J+ W; F: p; |& C& a" i k* ^% D7 u$ Q3 W
作品名:[AD 16][4层] LED信号控制电路(TBD62003AFG+TC7SH08FU+PC844) PCB源文件& x3 d8 C4 c3 B7 x. p, p* r
9 y4 h! O' ]( w3 y, |1 e9 B
* G) } Y" m! o3 |( F# Y8 {
文件描述2 u7 s. l+ M# ~8 M7 B
1. 作品用途:LED信号控制电路4 {6 D! s- x5 z" h; Z
2. 软件版本:AD 16
* Y L# k" ^; p/ ?4 x3. 层数:4层板
) L5 S _- F% ]2 E) X8 w9 ~4. 用到的主要芯片:TBD62003AFG+TC7SH08FU+PC8446 Q9 c) V& o. g9 ~
5. PCB尺寸:227mm*120mm
/ q5 X- x- Z: Q' D' ?
. h5 P$ Y) ^+ U! F. I: l5 e6 _' p9 v5 R% R0 J% r1 b/ J* w: l# }% ~- {6 L
作品截图如下:
9 Q0 p; A' X) _- n. K: Q顶层截图:$ b5 e; F5 S7 C, e
' x; w0 i' D& L9 K
底层截图:
9 @, v' m; U& t8 s) k; D% v
4 v. ~! a: [: B, T3 Y/ G全层截图:. b$ A- C( x; o x, z9 N
6 i1 F9 U" }, A4 F1 i4 O( U( I9 Z5 J叠层信息截图如下:+ r, c/ }1 N, [8 G1 G/ C5 y* h
; G9 X3 M8 A' t, X! p* lBOM:
+ g! r' j, A& L7 E: b1 ?# B; I5 B0 _Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | UPC177G | AR1, AR2 | SOP_14 | 2 | 2200pF | C1, C3 | CAP_RM7.5 | 2 | 0.47uF | C2 | CAP_RM22_安规电容 | 1 | 2200pF | C4, C5, C6, C7, C8, C9 | CAP_1206 | 6 | 0.1uF | C10, C15 | CAP_0805 | 2 | 2.2uF | C11, C16 | CAP_0805 | 2 | 0.1uF | C12, C14, C18, C23 | CAP_0603 | 4 | 1uF | C13, C17 | CAP_0603 | 2 | 0.1uF | C19, C24, C27, C29, C31, C33 | CAP_1812 | 6 | 0.1u | C20 | CAP_0603 | 1 | 0.47uF | C21, C25, C28, C30, C32, C34 | CAP_0805 | 6 | 10uF | C22 | AVX_RM2.54 | 1 | 1uF | C26, C35 | CAP_0805 | 2 | BCR12CS_12AL | CSR1, CSR2, CSR3, CSR4, CSR5, CSR6 | TO_263_2 | 6 | Trans_CT | CT1, CT2 | CT | 2 | LED | D1, D2, D3, D4, D5, D6 | 0805_LED | 6 | UDZV5.6B | DZ1, DZ2, DZ3, DZ4, DZ5, DZ6 | SOD_323 | 6 | FUSE | F1, F2, F3, F4, F5, F6 | FUSE | 6 | JP | J1 | SIP_1X2 | 1 | TLP166J | OS1, OS2, OS3, OS4, OS5, OS6 | SMD_4 | 6 | SIP_3X32 | P1 | SIP_3X32 | 1 | 220k | R1, R8, R69, R82, R93, R104, R115, R126 | RES_1206 | 8 | 47R | R2, R3, R4, R5, R6, R7 | RES_1210 | 6 | 220R | R9, R11, R13, R15, R17, R19 | RES_0603 | 6 | 390R | R10, R12, R14, R16, R18, R20 | RES_0603 | 6 | 1K | R21, R22, R23, R24, R25, R26, R48, R49, R53, R54, R59, R60, R64, R73, R86, R97, R108, R119, R130 | RES_0603 | 19 | 470R | R27, R29, R31, R33, R35, R37 | RES_1210 | 6 | 47R | R28, R30, R32, R34, R36, R38 | RES_2512 | 6 | 10K | R39, R41, R45, R46, R57, R68, R70, R76, R81, R83, R92, R94, R103, R105, R114, R116, R125, R127 | RES_0603 | 18 | 22R | R40, R42 | RES_0603 | 2 | 39K | R43, R55 | RES_0603 | 2 | 33K | R44, R56, R75, R88, R99, R110, R121, R132 | RES_0603 | 8 | 10K | R47, R58 | RES_1210 | 2 | 2.2K | R50, R51, R61, R62, R67, R80, R91, R102, R113, R124 | RES_0603 | 10 | 2K | R52, R63 | RES_1210 | 2 | 15K | R65, R66, R71, R72, R77, R78, R84, R85, R89, R90, R95, R96, R100, R101, R106, R107, R111, R112, R117, R118, R122, R123, R128, R129 | RES_2512 | 24 | 12K | R74, R87, R98, R109, R120, R131 | RES_0603 | 6 | 4.7K | R79 | RES_0603 | 1 | TBD62003AFG | U1, U5 | SOP_16 | 2 | TC7SH08FU | U2, U4 | SOT_353 | 2 | PC844 | U3 | SO-14 | 1 | TLP291 | U6, U7, U8, U9, U10, U11 | SOP_4_P1.27 | 6 | D1UBA80 | VD1, VD2, VD3, VD4, VD5, VD6, VD7, VD8 | MBF | 8 | RES_V | VS1, VS2, VS3, VS4, VS5, VS6, VS7 | RES_V_RM7.5 | 7 | UDZ2.0B | ZD1, ZD3 | SOD_323 | 2 | UDZ4.7B | ZD2, ZD4 | SOD_323 | 2 | 附件:
8 F4 M( @. L/ gPCB源文件如下:: X' H' |& g c; i0 Q
6 Z: O8 d# H0 G$ O# {, ^
' d& }- A6 v+ P$ e& W; V0 j
