" h. m) ]3 T3 x% K0 N
: N1 y- H. j' f& W) P[AD 10][2层]HDMI_VGA_CH7101A_V2参考板( LTF5022T+EN25VF010+SY8008B)原理图和PCB文件
, ?, U8 C+ X5 s5 l& N$ ~2 e
9 ~8 j ?4 R: ~" D0 n" j9 K3 t文件描述
4 N* D9 z4 }, M! }3 {1. 作品用途:HDMI_VGA_CH7101A_V2参考板% V" M/ Y6 W; G7 r# `( b" U) j
2. 软件版本:AD 10. v* d$ e0 k+ @6 {- v
3. 层数:2层板
6 ?. S" ^/ I$ o) A6 V% t1 k1 C4. 用到的主要芯片:LTF5022T+EN25VF010+SY8008B
& k( n7 E/ V- L. H0 Y5. PCB尺寸:109.171*61.996 mm7 B h3 U5 i/ X7 [1 G
1 I8 V# \) V4 h& }作品截图如下: p9 K( B3 v, B; [& l7 F
顶层截图:
" G. K# T9 k9 `" B0 |+ ^3 u8 D( i7 ^, Y, {* T& b- C( K
+ |5 G% ]! T* b( J+ @1 R+ _" X底层截图: I0 L9 ]% W" |' g( O% l$ f: L4 {
: C: t* i7 U0 p: O5 J5 P* V1 a0 P/ L% ?: q) e7 u1 f o5 s4 o& o
全层截图:+ O; b4 S) b% }2 i |
; r% X, d" D4 ~% H0 }% s2 {/ T+ r
叠层信息截图如下:1 A. L5 j. o% n, R$ j: w7 R- ?
7 v" K% U+ M' c4 GBOM:
" T( _; E1 ?4 ^. ?Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 104 | C41, C341, C343, C345, C350, C351, C353, C355, C357, C358, C366, C367, C368, C369, C370, C371, C373, C376, C381, C382, C383, C385, CH2, CH4, CH6, CH7, CH8, CH9, CH10, CH34, CH44, CP15 | C0402 | 32 | 106 | C42, C361, CH1, CH5, CH11, CH31, CH33, CH38, CH40, CP7, CP13 | C0805 | 11 | 102 | C325, CH30, CH35 | C0402 | 3 | 47uF16V | C326, CE70, CP18, CP21, CP22 | CAPE-SMD-5 | 5 | 33P | C340, C342, C344, CP11, CP27 | C0402 | 5 | 100P | C354, C386 | C0402 | 2 | 221 | C362, C384 | C0402 | 2 | 105 | C363, C364, CH14, CH16 | C0402 | 4 | 22P | C374 | C0402 | 1 | 104 | C377, CP2, CP5 | C0603 | 3 | 332 | C378 | C0402 | 1 | 47uF25V | CE71, CE72 | CAPE-SMD-6.3 | 2 | 10uF25V | CE73 | CAPE-SMD-5 | 1 | 10uF25V | CE75 | C1210 | 1 | 47P | CH23, CH37, CP3, CP4 | C0402 | 4 | 475 | CH29, CH32 | C0603 | 2 | 22uF6V3 | CH39, CP26 | C0805 | 2 | HDMI_TYPE_A | CHN1 | HDMI-19FS04 | 1 | 2PIN | CN2 | CN2/2.54 | 1 | 15P | CNP1 | CON15_125_SMD | 1 | Header 6 | CN_VGA | con6200 | 1 | 226 | CP12, CP28 | C0805 | 2 | | CP19 | C0805 | 1 | SS16 | D70 | DO-SMA | 1 | ss14 | DH1 | DO-SMA | 1 | 22uH1A | FB70, L71 | VLCF4018-2 | 2 | 120R | FB72, FB73, FH1, FH2, FH3, FH4, FH5, FH9 | L0603 | 8 | 100R | FB80 | L0805 | 1 | 33R | FH6, FH7, FH8 | L0603 | 3 | DC_470 | J1 | DC65CH | 1 | NC | J7 | CN3P2.0 | 1 | 40P0R5 | J8 | FPC_40_0.5 | 1 | PJ370A | J402, JP1 | PJ370-A | 2 | LTF5022T-100M1R4-LC | LP1, LP2 | VLCF4018-2 | 2 | MARK | M1, M2 | MARK | 2 | AP2310 | Q70 | SOT23 | 1 | 75R | R321, R323, R327, R328, R331, R332, R354, R367, R376, RH9, RH10, RH12 | r0402 | 12 | 33R | R322, R329, R333, R368, R371, R372 | r0402 | 6 | 470R | R324 | r0402 | 1 | 0R | R355, R366, R374, R375 | r0402 | 4 | 1M | R361, RH60 | R0402 | 2 | 100K | R362, R377, R378, R379, R380, R381, R382, RP2, RP3, RP4, RP10, RP11, RP14, RP15 | r0402 | 14 | 10R | R364 | r0402 | 1 | 4K7 | R365 | r0402 | 1 | 5K1 | R369, R370 | r0402 | 2 | 1K | RH13 | r0402 | 1 | 47K | RH15, RH47 | r0402 | 2 | 6.8K | RH21, RH22 | R0402 | 2 | 7K5 | RH36, RH38 | r0402 | 2 | 10K | RH48, RH49, RH50, RH51, RH61, RH62, RH63, RP5, RP7, RP8, RP9, RP16, RP17 | r0402 | 13 | 22R*4 | RN20, RN21, RN22, RN23, RN24, RN25, RN26, RN27 | RN0402 | 8 | 22K | RP1 | R0402 | 1 | 120K | RP13 | R0402 | 1 | NC | RS1 | R0603 | 1 | MST703 | U27 | QFp-100 | 1 | EN25VF010 | U29 | SOP8 | 1 | Rclamp0524 | UH2, UH4 | SLP2510P8 | 2 | CH7101 | UH3 | mQFN40_P0M4 | 1 | CS4344 | UH6 | TSSOP10 | 1 | SY8101 | UP1 | SOT23_6 | 1 | PJ3157 | UP2 | SC70_6 | 1 | SY8008B | UP3 | SOT23_6 | 1 | 12MHz | X1 | XTAL/SMT | 1 | 附件:
7 I5 C: O0 |9 {6 \: b! b* @- [. I原理图和PCB文件如下:
9 \0 M& U) j# L( _
: l( L4 |! W7 ?( b) @9 W8 M
* `2 M X6 G. S( c1 @/ J |
