Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0402_MLP | DIODE_TVS_BIDIR_0402_MLP_IC_0.4 | 0402ESDA-MLP | IC | 6 | TVS1; TVS2; TVS3; TVS4; TVS504; TVS505 |
0603LED | LED_0603LED_IC_0.65MM_370-75905 | RED LED | IC | 1 | D4 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 0.1UF | DISCRETE | 41 | C1; C4; C5; C6; C7; C12; C13; C14; C15; C503; C507; C508; C510; C511; C512; C513; C514; C515; C517; C518; C521; C524; C526; C527; C528; C529; C530; C532; C536; C537; C538; C539; C540; C541; C542; C543; C544; C549; C550; C551; C553 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 33PF | DISCRETE | 2 | C545; C546 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | DISCRETE | 2 | C548; C552 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | DISCRETE | 1 | C11 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 47PF | DISCRETE | 2 | C500; C502 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 0.47UF | DISCRETE | 1 | C509 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4MM | 4.7UF | DISCRETE | 1 | C10 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 10UF | DISCRETE | 3 | C506; C519; C522 |
CC3528-21 | CAP_POL_CC3528-21_DISCRETE_2.1M | 10UF | DISCRETE | 5 | C2; C8; C17; C516; C534 |
CC3528-21 | CAP_POL_CC3528-21_DISCRETE_2.1 | 4.7UF | DISCRETE | 4 | C3; C16; C520; C547 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS X 16 | IO | 1 | J15 |
CON4_USB_A_RA_SMT | USB_A_CON4_USB_A_RA_SMT_IO_7.2M | USAF-4S-SR0BTA | IO | 1 | J6 |
CON5_MUSB_AB_0P8_RA_SMT | USB_MINI_B_SKT_CON5_MUSB_AB_0P8 | USB_MINI_B 5 | IO | 1 | J5 |
CON5_MUSB_AB_0P8_RA_SMT | USB_MINI_AB_RECEPTACLE_CON5_MUS | USB_MINI_AB_RECEPTACLE | IO | 1 | J18 |
CON8_RJ45_TH1_METAL | J1011F01PNL_CON8_RJ45_TH1_METAL | RJ45-8 | IO | 2 | J12; J17 |
CON_DB9S_RA_318 | CONN_DB9F_MTGTABS_CON_DB9S_RA_3 | DB9 | IO | 1 | J14 |
HC49SDLF | XTAL_HC49SDLF_IC_4.2MM_230-7779 | 24MHZ | IC | 1 | Y1 |
HDR102_STAG_SM | CONN_HDR_2X1_HDR102_STAG_SM_IO_ | HDR_1X2 | IO | 5 | J8; J9; J16; J21; J24 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_IO_ | HDR 1X3 | IO | 3 | J1; J2; J13 |
HDR202_TSM_SM | CONN_HDR_2X2_HDR202_TSM_SM_IO_9 | HDR_2X2 | IO | 1 | J7 |
HDR203_M20 | CONN_HDR_3X2_HDR203_M20_IO_8.64 | HDR 2X3 | IO | 1 | J10 |
HDR203_TSM_SM | CONN_HDR_3X2_HDR203_TSM_SM_IO_9 | HDR_2X3 | IO | 2 | J3; J4 |
HDR204_TSM_SM | CONN_HDR_4X2_HDR204_TSM_SM_IO_9 | HDR_2X4 | IO | 2 | J22; J23 |
HDR205 | CONN_HDR_5X2_HDR205_IO_8.6MM_21 | HDR 2X5 | IO | 3 | J11; J19; J20 |
IND_0603 | IND_IND_0603_DISCRETE_0.8MM_180 | 100MHZ | DISCRETE | 7 | L1; L503; L506; L507; L509; L510; L511 |
IND_0603 | INDUCTOR_IND_0603_DISCRETE_0.95 | 470OHM | DISCRETE | 1 | L504 |
IND_1206A | BEAD_IND_1206A_DISCRETE_1.3MM_1 | 26OHM | DISCRETE | 3 | L2; L502; L508 |
LED_0603_C1 | LED_LED_0603_C1_IC_0.9MM_370-76 | YELLOW | IC | 1 | D5 |
MSOP10_60X12 | ISL3176EIUZ_MSOP10_60X12_IC_1.1 | ISL3176E | IC | 1 | U502 |
OSC4_7P5X5MM | FXO-HC735_OSC4_7P5X5MM_IC_1.55M | 25MHZ | IC | 1 | U506 |
QFN24_0P65_5X5 | MC9S08JS16XXX_QFN24_0P65_5X5_IC | MC9S08JS16C | IC | 1 | U500 |
QFN32 | USB3300_QFN32_IC_1.0MM_312-7553 | USB3300 | IC | 1 | U511 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7835 | 2.2K | DISCRETE | 14 | R3; R13; R523; R524; R557; R558; R559; R560; R561; R562; R563; R564; R565; R566 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7563 | 33 | DISCRETE | 24 | R500; R501; R508; R516; R525; R527; R530; R531; R533; R535; R536; R540; R545; R546; R547; R549; R550; R551; R552; R553; R554; R575; R578; R582 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | DISCRETE | 8 | R1; R2; R4; R16; R512; R522; R568; R571 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7543 | 49.9 | DISCRETE | 8 | R5; R8; R9; R11; R15; R17; R19; R20 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | DISCRETE | 9 | R6; R7; R12; R18; R528; R567; R572; R573; R579 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7545 | 330 | DISCRETE | 6 | R10; R534; R541; R555; R556; R581 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 100 | DISCRETE | 1 | R14 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3021 | 60.4 | DISCRETE | 2 | R502; R509 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_2 | 4.7K | DISCRETE | 6 | R503; R518; R521; R526; R529; R542 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7866 | 1.5K | DISCRETE | 1 | R504 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7539 | 120 | DISCRETE | 2 | R505; R513 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7591 | 2.7K | DISCRETE | 2 | R506; R510 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7544 | 15K | DISCRETE | 2 | R507; R517 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7624 | 1.0M | DISCRETE | 2 | R511; R570 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7669 | 4.87K | DISCRETE | 1 | R548 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7998 | 820 | DISCRETE | 1 | R574 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7551 | 12.0K | DISCRETE | 1 | R577 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3030 | 560 | DISCRETE | 1 | R580 |
RNET_4_8 | RESISTOR_ARRAY_RNET_4_8_DISCRET | 33 | DISCRETE | 1 | RN500 |
SC-70 | NL17SZ00_SC-70_IC_1.1MM_312-303 | NL17SZ00 | IC | 1 | U503 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7 | MSS1P3L | IC | 1 | D3 |
SO8_1P27_4X5 | TJA1051T_SO_8P_SO8_1P27_4X5_IC_ | TJA1051T/3 | IC | 1 | U501 |
SO8_1P27_4X5 | NB2304AI2DG_SO8_1P27_4X5_IC_1.7 | NB2304AI2DG | IC | 1 | U504 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | IC | 1 | U508 |
SOD323 | DIODE_SCHTKY_SOD323_IC_1.1MM_48 | NSR0320 | IC | 2 | D1; D2 |
SOT223 | LM1117_SOT223_IC_1.9 MM_315-788 | LD1117-3.3 | IC | 1 | U507 |
SSOP20 | ICL3225_SSOP20_IC_1.99MM_312-75 | ICL3225E | IC | 3 | U505; U509; U510 |
SW_DIP16_8POS_SMD | SW_DIP_8_SW_DIP16_8POS_SMD_IC_2 | HRM-08-T-R-H | IC | 2 | SW1; SW2 |
TESTPOINT_35MIL | TEST PAD_TESTPOINT_35MIL_IC_0.1 | 35 MIL | IC | 9 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9 |
TP_075_045MIL | TESTLOOP_TP_075_045MIL_IO_5.0MM | 999-60-110045 | IO | 3 | T1; T2; T3 |
TQFP80_5MM | DP83849IVS_80P_TQFP80_5MM_IC_1. | DP83849I | IC | 1 | U1 |
XTAL3_4P5X2_SM | XTAL_CS_XTAL3_4P5X2_SM_IC_1.2MM | 4MHZ | IC | 1 | X500 |
附件:
