查看: 164|回复: 0
[allegro16.3][4层]TWR-S08MM128 MC9S08MM医疗开发塔式系统模块(MIC2526+MMA7360L...
发表于 2020-2-17 12:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][4层]TWR-S08MM128 MC9S08MM医疗开发塔式系统模块(MIC2526+MMA7360L+MC9S08MM128)原理图和pcb文件
3 v5 r% T8 a1 M2 b) Y% _+ h
$ x8 l0 O! k0 w( k# g# a文件描述:* p' m5 U' G8 w3 M5 R
* ]. r6 M3 S# M( D1. 作品用途:TWR-S08MM128 MC9S08MM医疗开发塔式系统模块$ s1 N% p' x  M  L' q+ c" \
2. 软件版本:allegro16.3
" F4 ]; ?' F! k% Z8 z! \4 {3. 层数:4层
( ]; o. i& D1 f" Q4. 用到的主要芯片:MIC2526+MMA7360L+MC9S08MM128+ ?, I( ]) [5 K
5. pcb尺寸: 3543* 3175 MIL
  f. R# D: \( m* p$ [6 f/ y9 U; G7 Y3 P
作品截图如下:
6 _! \" v. B( b% R; T: ?" B. W; m1 _4 C
顶层截图:
0 B" Q5 p8 z3 B% ?
4 Z' q0 H' J+ b1 G$ F底层截图:5 N0 E- l9 ^9 s* Z& T0 C9 e
' s( l# O. U2 Q( _6 V" F8 e. }+ D1 D, D2 K8 }+ w4 V
全层截图:
# v4 i7 }5 R$ M/ R0 Q8 S6 Z3 G : l& U8 u- ]; g, D
6 T2 t$ p/ N1 u+ d叠层阻抗信息如下:% N) @$ y! J1 m$ O9 J: E
  N5 T8 Z' v/ P, p
BOM:
% s3 d6 d7 a3 u$ P5 l
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BPW34SBPW_34_S_BPW34S_IC_4MM_480-7797Q65110A1209IC1D1
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.95M0.1UFDISCRETE26C4; C5; C6; C10; C13; C14; C15; C16; C19; C21; C25; C26; C27; C29; C32; C34; C36; C39; C41; C45; C46; C47; C48; C49; C50; C51
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE4C7; C8; C30; C31
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9 M12.0PFDISCRETE2C9; C11
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.01UFDISCRETE1C17
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_10.47UFDISCRETE1C18
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.871000PFDISCRETE2C28; C40
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM3300PFDISCRETE3C42; C43; C44
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.73M1pFDISCRETE1C1
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.88M8200PFDISCRETE1C2
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_110UFDISCRETE6C3; C12; C22; C23; C24; C33
CC3528-21CAP_POL_CC3528-21_DISCRETE_2.1M47UFDISCRETE2C37; C38
CCE40X54CAP_POL_CCE40X54_DISCRETE_5.5MM4.7UFDISCRETE1C20
CCE63X55CAP_POL_CCE63X55_DISCRETE_5.7MM100UFDISCRETE1C35
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS X 16IO1J28
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5IO1J17
CON_HDR_20F_100_TH_RACONN_HDR_10X2_CON_HDR_20F_100_TPPPC102LJBN-RCIO1J27
DIODE_3P2X2P2_SMDLED_1A2C_DIODE_3P2X2P2_SMD_IC_1IR12-21C/TR8IC1D2
HC49SDLFCRYSTAL_HC49SDLF_IC_4.3MM_230-716MHzIC1Y2
HC49SDLFXTAL_HC49SDLF_IC_4.2MM_230-77704MHzIC1Y3
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO9J1; J2; J4; J6; J9; J11; J12; J20; J24
HDR103CONN_HDR_3X1_HDR103_IO_8.38 MM_HDR_1X3IO8J3; J5; J7; J8; J10; J15; J16; J26
HDR203_M20CONN_HDR_3X2_HDR203_M20_IO_8.64HDR 2X3IO4J13; J14; J19; J25
HDR205CONN_HDR_5X2_HDR205_IO_8.6MM_21HDR 2X5IO1J21
IND_0603IND_IND_0603_DISCRETE_0.8MM_180100MHZDISCRETE3L1; L2; L3
IND_1206ABEAD_IND_1206A_DISCRETE_1.3MM_126OHMDISCRETE2L4; L5
JUMP2X7-6040HDR-2X7_JUMP2X7-6040_IO_8.6MM_2HDR_2X7IO1J18
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-_1OR/REDIC2D3; D11
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-_3YEL/GRNIC2D6; D9
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-_2YELIC2D7; D12
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-76AMBIC2D8; D10
LGA14_0P80_3X5_SHMMA7360L_LGA14_0P80_3X5_SH_1.05MMA7361LIC1U6
PHTRANS_2P2X3P2PT12_PHTRANS_2P_PHTRANS_2P2X3P2PT12-21C/TR8IC1Q1
POT3_3352WPOT_POT3_3352W_DISCRETE_470-79910KDISCRETE1R35
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE5R1; R3; R7; R10; R36
RC0603_OVRES_RC0603_OV_DISCRETE_470-75841.0MDISCRETE6R2; R5; R6; R11; R14; R43
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_1.0KDISCRETE2R4; R13
RC0603_OVRES_RC0603_OV_DISCRETE_470-800516KDISCRETE2R8; R9
RC0603_OVRES_RC0603_OV_DISCRETE_470-78661.5KDISCRETE1R12
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_133DISCRETE1R15
RC0603_OVRES_RC0603_OV_DISCRETE_470-7545330DISCRETE6R16; R34; R37; R38; R39; R40
RC0603_OVRES_RC0603_OV_DISCRETE_470-75414.7KDISCRETE4R17; R27; R41; R42
RC0603_OVRES_RC0603_OV_DISCRETE_470-75392.2KDISCRETE1R18
RC0603_OVRES_RC0603_OV_DISCRETE_470-799947DISCRETE2R19; R24
RC0603_OVRES_RC0603_OV_DISCRETE__470-7541KDISCRETE2R20; R28
RC0603_OVRES_RC0603_OV_DISCRETE_470-75_110KDISCRETE5R21; R23; R25; R26; R44
RC0603_OVRES_RC0603_OV_DISCRETE_470-75_21KDISCRETE1R22
RC0603_OVRES_RC0603_OV_DISCRETE_470-79_11.8KDISCRETE1R29
RC0603_OVRES_RC0603_OV_DISCRETE_470-755510MDISCRETE1R31
RC0603_OVRES_RC0603_OV_DISCRETE_470-3029220DISCRETE1R45
RC0805_OVRES_RC0805_OV_DISCRETE_470-754933DISCRETE4R32; R33; R46; R47
RNET_4_8RES_ISO4_SINGLE_RNET_4_8_DISCRE10kDISCRETE3RN1; RN2; RN3
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P2LIC1D4
SO6_A1T45_SO6_A_1.1MM_312-75172_SN74SN74LVC1T45IC2U3; U8
SO8MIC2526_8P_SO8_1.73MM_312-75936MIC2026-1YMIC1U2
SOT23PNP_SOT23_IC_1.3MM_480-75192_MMMMBT3906LIC1Q2
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC2Q4; Q5
SOT23-40X40MOSFET_P_SOT23-40X40_IC_1.1MM_4ZXM61P02FIC1Q6
SOT223LM1117_SOT223_1.9 MM_315-78813_LD1117-3.3IC1U5
SOT-23BAT721B_SOT-23_DISCRETE_1.3MM_4BAT54CDISCRETE1D5
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115TIC1Q3
SW4_6P5X7MMSW_DIP-2_SW4_6P5X7MM_IC_4.2MM_5SW_DIP-2/SMIC1SW3
SW_SPST_THSW_PSHBT_SPST_2_SW_SPST_TH_IC_7LIGHT TOUCH PUSH BUTTONIC3SW1; SW2; SW4
TP_TH_040TESTLOOP_TP_TH_040_IO_5.1MM_210GROUND PIN/LOOPIO9TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9
TQFP44MC9S08JM60CFGE_TQFP44_1.60 MM_3MC9S08JM60CLDIC1U4
TQFP80_5MMMC9S08MM128-LQFP80_TQFP80_5MM_1MC9S08MM128VLKIC1U1
TSSOP16ICL3232_TSSOP16_1.1 MM_312-7954ICL3232IC1U7
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.0MM_230-732.768kHzIC1Y1
附件:
2 ]3 U! o9 Q8 `) E3 _" z4 p原理图和pcb文件如下:
) E- T) w9 s2 o3 d2 l3 P
游客,如果您要查看本帖隐藏内容请回复
# p% O; c7 |- t  b  G
GMT+8, 2025-7-25 10:47 , Processed in 0.140625 second(s), 28 queries , Gzip On.
