- h" a' `6 w. E$ e6 |8 d4 n
" M" \% K7 P4 b) O/ P8 X[AD 10][4层]耳机短路版( EXC24CE900U+SSAJ120100+SKSVCAE010)PCB文件2 ]& `5 N4 @4 Z; o1 O
4 t$ D+ j7 W+ B文件描述0 E( p) l7 c1 e+ H- m3 J
1. 作品用途:耳机短路版( `; |% z+ V9 ]$ ~ T0 @& @) e4 q
2. 软件版本:AD 100 f* G# U3 O- E8 |3 |# E
3. 层数:4层板# J: f! y7 k: j/ T
4. 用到的主要芯片:EXC24CE900U+SSAJ120100+SKSVCAE010
. ?. _+ y8 ~+ `2 b5. PCB尺寸:1473*333 mil
+ V" X+ P2 b& e* O$ O+ V" a d6 j
' `( ]" Y% b \作品截图如下:
3 s5 u! W. [1 {9 v, X/ `# W顶层截图:2 g- m3 l* w! Q
% i) D/ l. Y( Z
9 d9 Z- f2 A8 d0 E; g2 F v- R底层截图:2 S& J& Z4 B' B; B
- S s, I2 |- {4 J
+ m) b( B; \3 A8 {4 B2 `; {
全层截图:
& I: [+ u; l p' r m& f7 F1 ~$ j
0 l# w$ K; y3 o A, x: O8 n
叠层信息截图如下:: R8 @7 H! p% s X
6 ~8 L0 n2 I2 x
BOM:# d y' r( Z1 f1 J c: O5 L
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | WAN3216F245C0X | ANT1 | WAN3216F245C0X | 1 | 10uF | C1, C5, C18, C24, C26, C32, C33, C34, C35, C37 | C0402 | 10 | 1uF | C2, C4, C6, C10, C12, C13, C14, C15, C16, C17, C23, C25, C28, C31 | C0201 | 14 | 0R | C3, C38 | C0201 | 2 | NC | C7, C8 | C0201 | 2 | 4.7uF | C9, C27, C29 | C0402 | 3 | 33PF | C19, C20, C21, C22, C36 | C0201 | 5 | 10pf | C39, C40 | C0201 | 2 | 0.1uF | C41 | C0201 | 1 | NC | D1, D2, D6, D7, D8 | D0402 | 5 | SE10F15B5.0A | D3 | D0402 | 1 | SE9D15B3.3A | D4, D5 | D0402 | 2 | DIODE | D9, D10 | SOD523 | 2 | PAD | FFL+, FFL-, FFR+, FFR-, GND, L+, L-, R+, R-, VBAT, VL, VR | pad 1.2*0.8mm | 12 | 4.7uH | L1, L2 | L0805 | 2 | RG-LED | LED1 | LED-RG双色 | 1 | PAD | ON, RX, TX, VBUS, vio | PAD 1.2MM | 5 | 510Ω | R1, R7, R13 | R0201 | 3 | 2.2PF | R2 | R0201 | 1 | 22KΩ | R4 | R0201 | 1 | 10KΩ | R5, R6, R8, R9, R16, R17 | R0201 | 6 | 1KΩ | R10, R11, R12, R18 | R0201 | 4 | 4.7KΩ | R15 | R0201 | 1 | SKSVCAE010 | S1, S2, S3 | SKSVCAE010 | 3 | SSAJ120100 | S4 | SSAJ120100 | 1 | EXC24CE900U | TX1, TX2 | EXC24CE900U | 2 | 26M | TX3 | CRY26_2016 | 1 | BES2000IS | U1 | BES2000IS | 1 | ETA4056 | U2 | ETA4056 | 1 | SMA-3722F422 | U3 | MIC-38*23*1.2 | 1 | Micro USB | USB1 | USB-MICRO1 | 1 | 附件:
! T0 J" h) g) [4 X$ J2 s- Y/ Q# dPCB文件如下:, ^- w7 F# {5 W* s" R
/ n. x, D: |- X7 W
( ^ p) ~( f M0 ~' e, b: C
