查看: 128|回复: 0
[allegro16.2][4层]TWR-MCF51MM ColdFire MCF51MM 医疗开发塔式系统模块(MMA7360L...
发表于 2020-2-17 11:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.2][4层]TWR-MCF51MM ColdFire MCF51MM 医疗开发塔式系统模块(MMA7360L+MCF51MM256+MIC2526)原理图和pcb文件/ R6 c; x0 ?# M. Y
; i- I( F" t( b( R9 i* k  y
文件描述:
* d0 D3 @4 g! A6 w3 N( m  _  m' S3 @& ^8 @
1. 作品用途:TWR-MCF51MM ColdFire MCF51MM 医疗开发塔式系统模块5 F* n* y$ H# s& E; H% _! W' @% D' y
2. 软件版本:allegro16.2
- n; L) H' p4 ?4 W3. 层数:4层. S* q$ j7 C# r/ Z
4. 用到的主要芯片:MMA7360L+MCF51MM256+MIC2526
3 v7 q  l; w5 X3 ]) {7 N7 `5. pcb尺寸: 3543* 3175 MIL8 @( d* p. N+ t8 r2 ?; o. b8 r9 I: N
5 Z, F, J% n5 r: f. J- V- w7 T
作品截图如下:
" Z' P0 R6 ^; V, O9 X5 x  H$ B  K& N4 v  I
顶层截图:
+ m6 [# `& [, F. T" U" s
! `+ @7 f6 C$ w底层截图:
1 o& P( ]" `% e" Z8 K6 C" v4 h" \( v
& ^4 b4 b, B$ m) F: S
! P9 R; q! u# H0 B全层截图:
' t" V4 P% o# y- F; I3 B: j( \" T) j
# y7 D/ S6 F" e" ^$ p
% k1 r) I7 N/ a/ s叠层阻抗信息如下:' E. O& r: y0 s+ {* ?6 [
! e5 ?. x& E; B  h- Y" c# e& g9 g
BOM:1 G3 g) n+ G; V9 Y" I6 G; W
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BPW34SBPW_34_S_BPW34S_IC_4MM_480-7797Q65110A1209IC1D1
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.95M0.1UFDISCRETE26C4; C5; C6; C10; C13; C14; C15; C16; C19; C21; C25; C26; C27; C29; C32; C34; C36; C39; C41; C45; C46; C47; C48; C49; C50; C51
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE4C7; C8; C30; C31
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9 M12.0PFDISCRETE2C9; C11
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.01UFDISCRETE1C17
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_10.47UFDISCRETE1C18
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.871000PFDISCRETE2C28; C40
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM3300PFDISCRETE3C42; C43; C44
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.73M1pFDISCRETE1C1
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.88M8200PFDISCRETE1C2
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_110UFDISCRETE6C3; C12; C22; C23; C24; C33
CC3528-21CAP_POL_CC3528-21_DISCRETE_2.1M47UFDISCRETE2C37; C38
CCE40X54CAP_POL_CCE40X54_DISCRETE_5.5MM4.7UFDISCRETE1C20
CCE63X55CAP_POL_CCE63X55_DISCRETE_5.7MM100UFDISCRETE1C35
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS X 16IO1J28
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5IO1J17
CON_HDR_20F_100_TH_RACONN_HDR_10X2_CON_HDR_20F_100_TPPPC102LJBN-RCIO1J27
DIODE_3P2X2P2_SMDLED_1A2C_DIODE_3P2X2P2_SMD_IC_1IR12-21C/TR8IC1D2
HC49SDLFCRYSTAL_HC49SDLF_IC_4.3MM_230-716MHzIC1Y2
HC49SDLFXTAL_HC49SDLF_IC_4.2MM_230-77704MHzIC1Y3
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO9J1; J2; J4; J6; J9; J11; J12; J20; J24
HDR103CONN_HDR_3X1_HDR103_IO_8.38 MM_HDR_1X3IO8J3; J5; J7; J8; J10; J15; J16; J26
HDR203_M20CONN_HDR_3X2_HDR203_M20_IO_8.64HDR 2X3IO4J13; J14; J19; J25
HDR205CONN_HDR_5X2_HDR205_IO_8.6MM_21HDR 2X5IO1J21
IND_0603IND_IND_0603_DISCRETE_0.8MM_180100MHZDISCRETE3L1; L2; L3
IND_1206ABEAD_IND_1206A_DISCRETE_1.3MM_126OHMDISCRETE2L4; L5
JUMP2X7-6040HDR-2X7_JUMP2X7-6040_IO_8.6MM_2HDR_2X7IO1J18
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-_1OR/REDIC2D3; D11
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-_3YEL/GRNIC2D6; D9
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-_2YELIC2D7; D12
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-76AMBIC2D8; D10
LGA14_0P80_3X5_SHMMA7360L_LGA14_0P80_3X5_SH_1.05MMA7361LIC1U6
LQFP100_0P5_14X14MCF51MM256_LQFP100_0P5_14X14_1.MCF51MM256IC1U1
PHTRANS_2P2X3P2PT12_PHTRANS_2P_PHTRANS_2P2X3P2PT12-21C/TR8IC1Q1
POT3_3352WPOT_POT3_3352W_DISCRETE_470-79910KDISCRETE1R35
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE5R1; R3; R7; R10; R36
RC0603_OVRES_RC0603_OV_DISCRETE_470-75841.0MDISCRETE6R2; R5; R6; R11; R14; R43
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_1.0KDISCRETE2R4; R13
RC0603_OVRES_RC0603_OV_DISCRETE_470-800516KDISCRETE2R8; R9
RC0603_OVRES_RC0603_OV_DISCRETE_470-78661.5KDISCRETE1R12
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_133DISCRETE1R15
RC0603_OVRES_RC0603_OV_DISCRETE_470-7545330DISCRETE6R16; R34; R37; R38; R39; R40
RC0603_OVRES_RC0603_OV_DISCRETE_470-75414.7KDISCRETE4R17; R27; R41; R42
RC0603_OVRES_RC0603_OV_DISCRETE_470-75392.2KDISCRETE1R18
RC0603_OVRES_RC0603_OV_DISCRETE_470-799947DISCRETE2R19; R24
RC0603_OVRES_RC0603_OV_DISCRETE__470-7541KDISCRETE2R20; R28
RC0603_OVRES_RC0603_OV_DISCRETE_470-75_110KDISCRETE5R21; R23; R25; R26; R44
RC0603_OVRES_RC0603_OV_DISCRETE_470-75_21KDISCRETE1R22
RC0603_OVRES_RC0603_OV_DISCRETE_470-79_11.8KDISCRETE1R29
RC0603_OVRES_RC0603_OV_DISCRETE_470-755510MDISCRETE1R31
RC0603_OVRES_RC0603_OV_DISCRETE_470-3029220DISCRETE1R45
RC0805_OVRES_RC0805_OV_DISCRETE_470-754933DISCRETE4R32; R33; R46; R47
RNET_4_8RES_ISO4_SINGLE_RNET_4_8_DISCRE10kDISCRETE3RN1; RN2; RN3
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P2LIC1D4
SO6_A1T45_SO6_A_1.1MM_312-75172_SN74SN74LVC1T45IC2U3; U8
SO8MIC2526_8P_SO8_1.73MM_312-75936MIC2026-1YMIC1U2
SOT23PNP_SOT23_IC_1.3MM_480-75192_MMMMBT3906LIC1Q2
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC2Q4; Q5
SOT23-40X40MOSFET_P_SOT23-40X40_IC_1.1MM_4ZXM61P02FIC1Q6
SOT223LM1117_SOT223_1.9 MM_315-78813_LD1117-3.3IC1U5
SOT-23BAT721B_SOT-23_DISCRETE_1.3MM_4BAT54CDISCRETE1D5
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115TIC1Q3
SW4_6P5X7MMSW_DIP-2_SW4_6P5X7MM_IC_4.2MM_5SW_DIP-2/SMIC1SW3
SW_SPST_THSW_PSHBT_SPST_2_SW_SPST_TH_IC_7LIGHT TOUCH PUSH BUTTONIC3SW1; SW2; SW4
TP_TH_040TESTLOOP_TP_TH_040_IO_5.1MM_210GROUND PIN/LOOPIO9TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9
TQFP44MC9S08JM60CFGE_TQFP44_1.60 MM_3MC9S08JM60CLDIC1U4
TSSOP16ICL3232_TSSOP16_1.1 MM_312-7954ICL3232IC1U7
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.0MM_230-732.768kHzIC1Y1
附件:
- t3 A6 M; [' t! U1 M. \1 g# N原理图和pcb文件如下:
* _9 e0 C% @, I6 N9 H, ^/ e
游客,如果您要查看本帖隐藏内容请回复
( B8 h) g) _4 H
GMT+8, 2025-7-25 11:28 , Processed in 0.125000 second(s), 28 queries , Gzip On.
