作品名:[AD 10][2层]新唐972国网II型集中器(TSOP34838)PCB和元件清单
' h/ C$ z% i* q3 u9 @" H4 t, l8 y6 a. R4 x0 u. N3 w; d
文件描述8 a% w/ Z! Q; C5 t; j z$ F" e
1. 作品用途:新唐972国网II型集中器, Z0 n# q3 ] U& p) F
2. 软件版本:AD 10
# Q$ Y0 z$ C( R/ }% W3. 层数:2层板3 [- L. E4 I6 q( e6 o
4. 用到的主要芯片:TSOP34838
9 y; M5 U9 Z) D9 T, m* U5. PCB尺寸:93.7mm*106.3mm% u5 m9 o3 P0 a& a" h! V4 Y0 u
# u7 R V2 t, p+ I% p/ r
作品截图如下:
7 u+ o4 a) U* J8 i顶层截图:0 U& d: }5 Y: [/ Y" a& ^& V
# h \6 K7 N" [, S) d& m$ s& f5 X
n6 n1 g- X% v) ?底层截图:& J) {4 R; y8 `% d( z* l& r! p
% \! I5 u( N" \; X4 K. P- K7 L9 v6 e5 j
全层截图:/ x9 i4 ?* q$ a" o: C1 _
) ?$ X3 B8 h: Y( C7 L3 I( w2 G; ]
0 m" `+ e( G6 J+ s3 l叠层信息截图如下:# L" T% X; [0 f
" O; u9 q2 O6 M% O3 T
% w7 c$ T) t$ G2 L; f& j+ V" fBOM:
$ x. B& b. Z- E4 C* \% PComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | CON1 | +Y, -Y, A0, A1, A2, B0, B1, B2 | N-2211S-1 | 8 | ER14250 | BAT1 | BAT-TL-5902-1 | 1 | 10uF/16V | C1, C37, C104, C107 | C-1206_1 | 4 | 10uF | C2 | C-0805 | 1 | 100nF | C3, C17, C18, C23, C24, C25, C42, C55, C56, C62, C63, C64, C65, C66, C67, C68, C69, C70, C72, C73, C74, C76, C79, C80, C81, C85, C86, C103 | C-0603_1 | 28 | 10pF/16V | C4 | C-0603 | 1 | 330uF/10V | C5, C7, C8, C10 | C-Φ6.3 | 4 | 10pF | C6, C19, C20, C21, C22, C40, C41, C58, C75, C84, C87 | C-0603_1 | 11 | 10uF/16V | C9 | 1206_C | 1 | 470pF | C11 | C-0603_1 | 1 | 470uF/25V | C12 | C-CA45-C | 1 | 10uF/16V | C13 | C-1206 | 1 | 0.1uF | C14, C202 | C-0603_1 | 2 | 10nF | C15 | C-0603_1 | 1 | 15p | C16, C29, C30, C31 | C-0603_1 | 4 | 22uF/16V | C26, C27, C28, C108 | C-1206_1 | 4 | 1u | C32 | C-0603_1 | 1 | 10u | C33, C46, C49, C77 | C-0805 | 4 | 1n | C34, C54 | C-0603_1 | 2 | 10n | C35, C48, C57, C82 | C-0603_1 | 4 | 0.1u | C36, C38 | C-0603_1 | 2 | GRM31CR71A106K | C39, C45, C59, C71 | C-0805 | 4 | 100n | C43, C44, C47, C50, C51, C52, C53, C60, C61, C78 | C-0603_1 | 10 | 1uF | C83 | C-0603_1 | 1 | | C90, C91 | C-3 | 2 | 4.7uF/10V | C97 | C-0805 | 1 | 30pF | C105, C106 | C-0603_1 | 2 | 1000pF | C114, C115 | C-0603_1 | 2 | 1nF | C203 | C-0603_1 | 1 | GRM31CR71A106K | C204 | C-1206 | 1 | IR333-A | D1 | D-0805 | 1 | 333-2SURD | D2, D3, D4 | D-0805 | 3 | 333-2SYGD | D5, D29 | D-0805 | 2 | 339-1SURSYGW | D6, D13, D25 | D-Φ5LED-HT333-2SRVGW | 3 | SMAJ6.5CA | D7, D8, D9, D12, D14, D16, D18 | D-DO-214AC - 1 | 7 | LL4148 | D10, D24, D26, D31 | SOD80 | 4 | SMBJ6.5CA | D11 | D-DO-214AC | 1 | SMBJ6.5CA | D15, D17, D19 | D-DO-214AC - 1 | 3 | PESD5V0S1BB | D20, D21, D22, D23, D27, D28, D35, D36, D37, D39, D40, D41, D42, D49 | SOD523 | 14 | 17-21SURC | D30 | D-0805 | 1 | LL4148 | D32 | D-SOD80 | 1 | PRTR5V0U2X | D33, D38 | SOT143B | 2 | PESD15VL1BA | D34, D47 | D-SOD323 | 2 | PESD3V3U1UT | D43, D44, D45, D46 | IC-SOT-23-3 | 4 | JP | J1 | JP-2-2 | 1 | CBG2012U751T | L1 | L-0805 | 1 | CBG160808U202 | L2 | 0603 | 1 | CBG2012U102T | L5, L6, L7, L8, L9, L10, L11, L12, L13, L14 | 0805 | 10 | S62 | L15 | s62 | 1 | CON8 | N1 | N-2211S-8 | 1 | Header 18 | N2 | N-2213S-18 | 1 | N-CON2 | N3 | N-CH2.54-2直 | 1 | 5075AS-4 | N4 | N-5075AS-041 | 1 | N-CON8 | N5 | N-CH2.54-8直 | 1 | USB-B | N6 | N-CH2.54-6直 | 1 | 1K | R1, R3, R6, R18, R19, R21, R22, R23, R24, R25, R26, R28, R44, R72, R130, R131, R132, R133, R134, R135 | 0603_1 | 20 | 10 | R2, R4, R15 | 0603_1 | 3 | 510 | R5, R13, R20, R27, R29 | 0603_1 | 5 | 10K | R8, R10, R11, R12, R14, R17, R30, R43, R45, R46, R48, R52, R56, R62, R64, R67, R74, R76, R77, R83, R84, R85, R86, R91, R94, R95, R96, R97, R99, R104, R105, R106, R107, R108, R109, R110, R111, R112, R113, R114, R115, R117, R118, R119, R120, R121, R297, R299 | 0603_1 | 48 | 4.7K | R9, R16, R65 | 0603_1 | 3 | 100 | R31, R35, R36, R38, R57, R58, R89, R205 | 0603_1 | 8 | MZ11-09M60RH420 | R32, R33, R34 | R-JK250-060 | 3 | 7K330 | R37 | R-JK250-060 | 1 | 2.2K | R39 | 0603_1 | 1 | 54.9K/1% | R40 | 0603_1 | 1 | 24K/1% | R41 | 0603_1 | 1 | 100×4 | R42 | R-0603-4 | 1 | 10K*4 | R47 | R-0603-4 | 1 | 0 | R49, R50, R53, R54, R88, R92, R93, R100, R101 | 0603_1 | 9 | 33 | R51, R63 | 0603_1 | 2 | 1.5K | R55, R334, R335, R336, R337, R338, R339, R341, R342, R343 | 0603_1 | 10 | 10M | R59, R60 | 0603_1 | 2 | 10k×4 | R61, R98 | R-0603-4 | 2 | 12.1K/1% | R66, R300, R301 | 0603_1 | 3 | 49.9/1% | R68, R69, R70, R71 | 0603_1 | 4 | 1M | R73, R79 | 0603_1 | 2 | 3.9K | R75 | 0603_1 | 1 | NC | R78 | 0603_1 | 1 | 2.4K | R80, R168 | 0603_1 | 2 | 0805L050 | R81 | 0805 | 1 | 220 | R82 | 0603_1 | 1 | 330 | R87 | 0603_1 | 1 | 100k | R90 | 0603_1 | 1 | 10×4 | R290, R291 | R-0603-4 | 2 | 2k | R328, R329, R330 | 0603_1 | 3 | 9014 | T1, T2 | T-SOT-23 | 2 | 9013 | T3, T4, T8 | T-SOT-23 | 3 | 8550 | T5, T6 | T-SOT-23 | 2 | TSOP34838 | U1 | IC-IRM3638FT4 | 1 | 74LVC1G32GW | U2 | IC-SOT753 | 1 | SPX29302T5 | U3 | IC-TO-263-5 | 1 | SPX3819M5-3.3V | U4 | IC-SOT-23-5 | 1 | K9F1G08U0D-SIB0 | U5 | IC-TSOP-48 | 1 | SPX3819M5-1.2 | U6 | IC-SOT-23-5 | 1 | SP706S | U7 | IC-SO-8 | 1 | RX8025T | U8 | SOJ-14 | 1 | SPX3819M5-1.8 | U9 | IC-SOT-23-5 | 1 | NUC970 | U10 | IC-P216QFP | 1 | FM24CL16 | U12 | IC-SO-8 | 1 | LAN8720AI | U14 | QFN24 | 1 | ESAM | U15 | IC-11-10C4 | 1 | TLP785 | U21, U22, U23, U24, U25, U26, U27 | IC-TLP781 | 7 | ESAM | U29 | vsop8 | 1 | SN65HVD3082ED | U30, U31, U32 | SO-8 | 3 | 32.768K | X1 | X-SMLF-3215 | 1 | 12MHz | X2 | X-SMAC-3225 | 1 | 25MHz/20pF | X3 | SMAC-5032 | 1 |
6 a- `" I1 t& H/ i附件:* i% G7 r) W( S* E ^# M4 @$ [
PCB源文件如下:
/ a; x: V& _' Z1 `$ M9 o* s7 u
4 z4 I7 O' a4 S" v* ~: p! g0 c6 f( u# s5 w& D$ E
