作品名:[AD 10][4层]新手练习的6层板新手练习的6层板( RTL8211EG+LJ245A+W25Q128FVFIG)PCB& Y0 V0 R/ |) ~/ W8 K) Z' g9 I' w5 Q
3 E5 G( I8 A2 \8 Q2 L/ R6 T# i文件描述
2 j4 G$ E$ i% R: Q: \3 p. S5 `) o1. 作品用途:新手练习的6层板/ Y* F& B$ b+ [9 g
2. 软件版本:AD 10) |0 k5 N/ r {* ^9 `1 t1 W9 f; g
3. 层数:4层板
0 v5 V9 s' B3 }; G2 {9 w4. 用到的主要芯片:RTL8211EG+LJ245A+W25Q128FVFIG
0 H. E7 t! ]( F$ R+ q) v9 L# C& f5. PCB尺寸:151mm*148mm
+ }8 h( V, R% H3 w$ ^% u8 f) q. V% a2 p- m
作品截图如下: r# Y8 t0 s0 c/ J& e+ ^9 [' C' c
顶层截图:
F' U, N9 m4 R# [. k) x
# V+ y( U, a2 {2 B& B$ w- w( e6 K+ b1 a& [
底层截图:: E9 z/ H7 N- J
! d m4 I3 r- k$ L' a- U- b
" U$ }9 U' {5 T: c全层截图:5 j- J! N% k0 r+ }- a8 d! r
; f2 @4 {+ J0 s3 k# u2 g
# A7 A+ B) d7 J5 @, q叠层信息截图如下:
2 K; {% @9 Y( U
; v, ~3 M0 t/ [. x5 g8 X3 j; R+ u: g5 k, Y' n% d. Q$ ]6 Y! |
BOM:3 |1 `. o4 Y4 t+ F' f
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | Cap Semi | C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16 | CC1608-0603 | 16 | 100uF | C17, C23, C29, C35, C41, C49 | CC3225-1210 | 6 | 4.7uF | C18, C24, C30, C36, C47, C55, C59 | CC1608-0603 | 7 | 0.47uF | C19, C20, C21, C22, C25, C26, C27, C28, C31, C32, C33, C34, C37, C38, C39, C40, C42, C43, C44, C45, C46, C48, C50, C51, C52, C53, C54, C56 | CC1005-0402 | 28 | 0.1uF | C57, C58, C61, C66, C67, C68, C69, C71, C76, C77, C78, C79, C81, C83, C84, C85, C86, C87, C88, C90, C91, C92, C93, C94, C95, C96, C97, C100 | CC1005-0402 | 28 | 10uF | C60, C64, C65, C70, C74, C75 | C0805 | 6 | 33nF | C62, C72 | CC1005-0402 | 2 | 0.01uF | C63, C73 | CC1005-0402 | 2 | 22uF | C80, C82, C89 | CC1608-0603 | 3 | 22pF | C98, C99 | CC1005-0402 | 2 | 1uF | C101 | CC1608-0603 | 1 | LED | DONE, INTB, POWER | SMD _LED | 3 | MF2410 | F1 | MF2410 | 1 | TJC3 | J1, J2, J3, J4, J5, J6, J7, J8 | TJC3 | 8 | oupiin 9001-1264 1C00A | J9, J10, J11, J12, J13, J14, J15, J16 | OUPIIN 9001-1264 1C00A | 8 | Header_2X7_2 | J17 | HEADER_2X7_2 | 1 | HR911130A | J18 | HR911130A | 1 | connector_10mm_4pin | J19 | connector_10mm_4pin | 1 | connector_8mm_2pin | J20 | connector_8mm_2pin | 1 | BEAD | L1 | INDC1608-0603 | 1 | 10uH | L2, L3 | BEAD | 2 | 2.2uH | L4 | BEAD_S | 1 | Button | PROG, RESET | Button | 2 | 4.7k | R1, R54, R55, R63, R64, R65 | CR1608-0603 | 6 | 1k | R2, R3, R8, R14, R15, R16, R17, R19, R33, R35, R42 | CR1608-0603 | 11 | 10k | R4, R5, R25, R30, R31, R34, R36, R56, R61, R62, R66, R67, R68, R71, R72, R73 | CR1608-0603 | 16 | 330R | R6, R37, R57, R58 | CR1608-0603 | 4 | 220R | R7, R9 | CR1608-0603 | 2 | 33R | R10, R11, R12, R13, R18, R20, R32, R41, R43, R44, R45, R46, R47, R48, R49, R50, R51, R52, R53 | CR1608-0603 | 19 | 47k | R21, R26 | CR1608-0603 | 2 | OTM | R22, R27, R69, R70, R74 | CR1608-0603 | 5 | 2.2k | R23, R28 | CR1608-0603 | 2 | 26.1k | R24 | CR1608-0603 | 1 | 3.09k | R29 | CR1608-0603 | 1 | 0R | R38, R59 | CR1608-0603 | 2 | 1.5k | R39, R40 | CR1608-0603 | 2 | 2.49k | R60 | CR1608-0603 | 1 | 33R | RN1, RN2, RN3, RN4, RN5, RN6, RN7, RN8, RN9, RN10, RN11, RN12, RN13, RN14, RN15, RN16 | respack_4_1206 | 16 | XC6SLX16-2CSG324C | U1 | BGA324 | 1 | LJ245A | U3, U4, U5, U6, U7, U8, U9, U10 | LJ245A | 8 | W25Q128FVFIG | U11 | W25Q128FVFIG | 1 | MP1482DS | U12, U13 | MP1482DS | 2 | RTL8211EG | U14 | QFN-64PIN | 1 | OSC 50Mhz | X1 | OSC 50Mhz | 1 | crystal_25M | Y1 | crystal_25M | 1 | " B6 v" E! o- c
附件:& Q5 ?: K1 H' s$ k/ z0 B" u
PCB源文件如下:
) L6 A$ G7 M9 R
* G. t( }+ b+ q8 @5 z/ D4 R9 r3 J: ~; k% @! X
