查看: 168|回复: 0
[allegro16.0][4层]USB转4路串口评估板(SI2333DS+SP6669+USB)pcb文件
发表于 2020-2-17 09:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
/ R( V: \' }/ h5 Y  T+ R' Z# P" d2 ?[allegro16.0][4层]USB转4路串口评估板(SI2333DS+SP6669+USB)pcb文件
  X8 J) `/ ~; t1 C( A6 Q  d4 \" x9 \" T# P$ Y7 Z# I
文件描述:
$ W- h. W. b( G- m
; X: A+ y, B2 p; |9 G1 g$ w1. 作品用途:USB转4路串口评估板! s% t2 I5 ?/ s+ u4 q/ S
2. 软件版本:allegro16.0
4 ^- k3 }  p. `3. 层数:4层& `- q3 _: B, Z0 q. a
4. 用到的主要芯片:SI2333DS+SP6669+USB
& z# M2 s3 X! C( m5. pcb尺寸: 3349.98*2859.98 MIL1 _# a# K& W  k2 I$ Q
" o8 j* a. H: P9 [
作品截图如下:
' I# d4 X' R! g5 i
3 j) Y) D5 P9 N顶层截图:2 x: |# [$ v6 r1 N; n1 @) o% Z
9 m8 M1 |! q2 }$ C2 ?
底层截图:
) b, p+ |' A2 A' v5 P% |
1 w8 l5 @2 c: y& w0 x1 ?( O
3 X3 K$ }: M- H5 e9 {. J* B: U  d全层截图:2 g" Q+ w% R+ k
) s6 n9 E& H  I1 i4 _" E . c! w3 R/ w: ^2 L
( J1 S5 G* I) g1 M: G. l& W. A: `
BOM:  a; x8 }/ l7 S! _# V$ r7 ?( N5 J0 n( w) i
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CR0603CAP NP_CR0603_100N-0603-399-109100n-0603-399-1095-1-NDIC26C4; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30
CR0603R_CR0603_0R-06030R-0603IC4R1; R2; R3; R10
CR0603R_CR0603_47K-0603_311-47KGRTR-N47K-0603_311-47KGRTR-NDIC28R4; R5; R7; R53; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81
CR0603R_CR0603_40K-0603_311-40KGRTR-N40K-0603_311-40KGRTR-NDIC1R6
CR0603R_CR0603_ZERO-0603ZERO-0603IC1R8
CR0603R_1_CR0603_475_0603475_0603IC1R9
CR0603R_CR0603_3.3K-0603_311-3.3KGRTR3.3K-0603_311-3.3KGRTR-NDIC2R82; R83
CR0805CAP NP_CR0805_1U-0805,16V_PCC221U-0805,16V_PCC2249TR-NDIC2C1; C3
CR0805CAP NP_CR0805_10U-0805, 10V_39910u-0805, 10V_399-4925-1-NDIC1C5
D1206LED_1_D1206_LED_1206LED_1206IC1D9
DIP8-300-50024C16A_DIP8-300-500_AT24C02B-PUAT24C02B-PU-DIP8 SocketIC1U2
DSUB9_MALECONNECTOR DB9 WITH MH_0_DSUB9_MRA DB9 Male Connector_182-709ME-NDIC4CON3; CON4; CON5; CON6
HDR254M-2X2CON4A_HDR254M-2X2_2X2 .1 HEADE2x2 .1 Header_PEC02DAANIC1JP4
HDR254S3-1X1TP_HDR254S3-1X1_1X1 .1 HEADER_P1x1 .1 Header_PEC01SAANIC6TP1; TP2; TP3; TP5; TP6; TP7
HDR254S3-1X2JUMPER_HDR254S3-1X2_JUMPERJUMPERIC5J5; J6; J7; J8; J9
HDR254S3-1X2CON2_HDR254S3-1X2_2X1 .1 HEADER2x1 .1 Header_PEC02SAANIC2JP25; JP26
HDR254S3-1X3CON3_HDR254S3-1X3_3X1 .1 HEADER3x1 .1 Header_PEC03SAANIC3JP2; JP3; JP38
HDR254S3-1X10CON10_HDR254S3-1X10_CON10CON10IC4J2; J3; J4; J10
JUMP2PIN_2P54JUMPER_JUMP2PIN_2P54_JUMPERJUMPERIC1J11
SOG0508WG244L20024C16A_SOG0508WG244L200_AT24C02AT24C02BN-SH-B-ND__SOICIC1U6
SOT_23SI2333DS_SOT_23_SI2333DS-T1-E3-SI2333DS-T1-E3-SOT-23IC1Q1
SOT_23_5SP6669_0_SOT_23_5_SP6260GEK-L/TSP6260GEK-L/TR150MAIC1U1
TACT_SMD_SWITCH_SWITRONICSSW PUSHBUTTON-SPST-2_TACT_SMD_SPB SWIC1SW1
TQFP_48_SOCKET_1XR21V1414_3_TQFP_48_SOCKET_1_XRXR21V1414IM48-TQFP48IC1U3
TSSOP65MM_28PSP3245E_2_TSSOP65MM_28P_SP3245ESP3245EEY-L-TSSOP-28IC4U13; U14; U15; U16
USB_B_TYPE_CON_1USB B-TYPE CONNECTOR_USB_B_TYPEUSB B-Type ConnectorIC1CON2
附件:4 p3 |3 b, |! i% L; ~" B
PCB文件如下:
; X5 ?8 c% _& b
游客,如果您要查看本帖隐藏内容请回复
; @; o* k3 u& ~6 ~& ~7 e. a2 i) h
8 Q1 q* \2 j' V. g$ `# o. W/ o7 ^
GMT+8, 2025-7-25 11:23 , Processed in 0.125000 second(s), 28 queries , Gzip On.
