查看: 215|回复: 0
[allegro16.0][4层]TWR-MCF51JE ColdFire Flexis MCF51JE低功耗USB塔式系统模块(M...
发表于 2020-2-17 09:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.0][4层]TWR-MCF51JE ColdFire Flexis MCF51JE低功耗USB塔式系统模块(MMA7360L+MCF51JE256+MIC2526)原理图和pcb文件
* {, O# b& Y: S5 T% m1 t
/ a4 L5 `$ _7 c# u: q文件描述:# h0 N. \+ A  A# p* {% c
: f5 h# U( ]3 A! D9 n2 h" Z" `' j2 V  F1. 作品用途:TWR-MCF51JE ColdFire Flexis MCF51JE低功耗USB塔式系统模块5 V8 f) R" h5 }& V$ M
2. 软件版本:allegro16.0; D# a3 U# r0 l' \7 ?
3. 层数:4层
. B: u" U8 }& o$ P8 D6 Y6 v5 s4. 用到的主要芯片:MMA7360L+MCF51JE256+MIC25261 H9 V- [  d. p" ~  Y
5. pcb尺寸: 3543* 3175 MIL
' Q( @7 ?0 p* G  f6 [. w" F
! U! W( M% R. e作品截图如下:& o) p% W: U# m% u3 ^
4 G4 q3 H6 _2 e7 C4 P- m4 q
顶层截图:
$ v$ ]* T2 o& B) l  ~- C/ O' n  Q & ?- K' ]* ^4 `
底层截图:
& J) S+ v; ?9 }! u  G( ]! f ( a( ]5 P+ e- G# h% t
3 G7 Z- W+ y% c0 b5 Q+ k0 C& `
全层截图:
  c. Q: h' k! N/ @& }8 q3 u & ]6 B" {3 _3 x& z  u( T6 Q
' a" X$ ]2 i5 Z- G. l2 j叠层阻抗信息如下:$ a$ M/ H6 c5 {1 \4 o
$ i, m8 p. ~2 ?: g6 X( lBOM:
8 g) V0 z$ H1 }: I& O; j9 G
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BPW34SBPW_34_S_BPW34S_4MM_480-77972_QQ65110A1209IC1D1
CASE_ACAP_POL_CASE_A_1.8MM_150-30020_10UFDISCRETE2C1;C52
CASE_ACAP_POL_CASE_A_1.8MM_150-75413_4.7UFDISCRETE1C54
CC0603CAP_NP_CC0603_0.95MM_150-75142_0.1UFDISCRETE1C56
CC0603_OVCAP_NP_CC0603_OV_0.95MM_150-7510.1UFDISCRETE24C4;C10;C13;C14;C15;C16;C19;C21;C25;C26;C27;C29;C32;C34;C36;C39;C41;C45;C46;C47;C48;C49;C50;C51
CC0603_OVCAP_NP_CC0603_OV_0.9 MM_150-7500.1UFDISCRETE1C5
CC0603_OVCAP_NP_CC0603_OV_0.90MM_150-75118PFDISCRETE4C7;C8;C30;C31
CC0603_OVCAP_NP_CC0603_OV_0.9 MM_150-77312.0PFDISCRETE2C9;C11
CC0603_OVCAP_NP_CC0603_OV_0.95MM_150-7500.01UFDISCRETE1C17
CC0603_OVCAP_NP_CC0603_OV_1MM_150-30233_0.47UFDISCRETE1C18
CC0603_OVCAP_NP_CC0603_OV_0.87 MM_150-781000PFDISCRETE2C28;C40
CC0603_OVCAP_NP_CC0603_OV_0.9MM_150-77353300PFDISCRETE3C42;C43;C44
CC0603_OVCAP_NP_CC0603_OV_0.86MM_150-75847PFDISCRETE2C53;C57
CC0603_OVCAP_NP_CC0603_OV_0.86MM_150-750180PFDISCRETE1C55
CC1206_OVCAP_NP_CC1206_OV_0.9MM_150-77548200PFDISCRETE1C2
CC3216CAP_POL_CC3216_1.8MM_150-75055_10UFDISCRETE6C3;C12;C22;C23;C24;C33
CC3528-21CAP_POL_CC3528-21_2.1MM_150-78547UFDISCRETE2C37;C38
CCE40X54CAP_POL_CCE40X54_5.5MM_150-30324.7UFDISCRETE1C20
CCE63X55CAP_POL_CCE63X55_5.7MM_150-7683100UFDISCRETE1C35
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS X 16IO1J28
CON3_JACK_5X15_SMMJ1-3510-SMT_CON3_JACK_5X15_SM_MJ1-3510-SMTIC1J3
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5IC1J17
DIODE_3P2X2P2_SMDLED_1A2C_DIODE_3P2X2P2_SMD_1.10IR12-21C/TR8IC1D2
HC49SDLFXTAL_HC49SDLF_4.2MM_230-77716_116MHZDISCRETE1Y2
HC49SDLFXTAL_HC49SDLF_4.2MM_230-77700_44MHzDISCRETE1Y3
HDR102CONN_HDR_1X2_HDR102_8.6MM_210-7HDR 1X2 THIC11J1;J2;J4;J6;J7;J8;J9;J11;J12;J20;J24
HDR103CONN_HDR_3X1_HDR103_8.6MM_210-7HDR TH 1X3IC6J5;J10;J15;J16;J26;J27
HDR203_M20CONN_HDR_3X2_HDR203_M20_8.64MM_HDR 2X3IC4J13;J14;J19;J25
HDR205CONN_HDR_5X2_HDR205_8.6MM_210-3HDR 2X5IC1J21
IND_0603IND_IND_0603_0.8MM_180-75495_10100MHZDISCRETE3L1;L2;L3
IND_1206ABEAD_IND_1206A_1.3MM_180-75060_26OHMDISCRETE2L4;L5
JUMP2X7-6040HDR-2X7_JUMP2X7-6040_8.6MM_210-HDR_2X7IC1J18
LED_0603_C1LED_LED_0603_C1_1.0MM_370-76473OR/REDIC2D3;D11
LED_0603_C1LED_LED_0603_C1_1.0MM_370-76472YEL/GRNIC2D6;D9
LED_0603_C1LED_LED_0603_C1_1.0MM_370-76471YELIC2D7;D12
LED_0603_C1LED_LED_0603_C1_1.0MM_370-76470AMBIC2D8;D10
LGA14_0P80_3X5_SHMMA7360L_LGA14_0P80_3X5_SH_1.05MMA7361LIC1U6
LQFP100_0P5_14X14MCF51JE256-LQFP100_LQFP100_0P5_MCF51JE256-LQFP100IC1U1
MIC_WM-63PRMIC_MIC_WM-63PR_1.4MM_510-75938MICIC1P500
PHTRANS_2P2X3P2PT12_PHTRANS_2P_PHTRANS_2P2X3P2PT12-21C/TR8IC1Q1
POT3_3352TPOT_POT3_3352T_470-80115_5K5KIC1R52
POT3_3352WPOT_POT3_3352W_470-79999_10K10KIC1R35
RC0402_25RES_RC0402_25_470-75557_10K10KDISCRETE2R45;R48
RC0603_OVRES_RC0603_OV_470-75846_1.0M1.0MDISCRETE4R2;R11;R14;R43
RC0603_OVRES_RC0603_OV_0.55 MM_470-754211.0KDISCRETE2R4;R13
RC0603_OVRES_RC0603_OV_470-75421_1.0K1.0KDISCRETE1R8
RC0603_OVRES_RC0603_OV_470-75399_2.2K2.2KDISCRETE2R9;R18
RC0603_OVRES_RC0603_OV_470-75420_100100DISCRETE1R10
RC0603_OVRES_RC0603_OV_0.55MM_470-75400_22KDISCRETE1R12
RC0603_OVRES_RC0603_OV_0.55 MM_470-7538933DISCRETE1R15
RC0603_OVRES_RC0603_OV_470-75451_330330DISCRETE6R16;R34;R37;R38;R39;R40
RC0603_OVRES_RC0603_OV_470-75414_4.7K4.7KDISCRETE4R17;R27;R41;R42
RC0603_OVRES_RC0603_OV_470-79994_47.047DISCRETE2R19;R24
RC0603_OVRES_RC0603_OV__470-75412_1K1KDISCRETE2R20;R28
RC0603_OVRES_RC0603_OV_470-75410_10K10KDISCRETE4R21;R23;R25;R26
RC0603_OVRES_RC0603_OV_470-75412_1K1KDISCRETE1R22
RC0603_OVRES_RC0603_OV_470-79996_1.8K1.8KDISCRETE1R29
RC0603_OVRES_RC0603_OV_470-75553_10M10MDISCRETE1R31
RC0603_OVRES_RC0603_OV_470-75407_00DISCRETE4R36;R46;R47;R50
RC0603_OVRES_RC0603_OV_470-78668_1.5K1.5KDISCRETE2R44;R49
RC0603_OVRES_RC0603_OV_470-78114_150.0K150.0KDISCRETE1R51
RC0603_OVRES_RC0603_OV_470-30141_330K330KDISCRETE1R53
RC0805_OVRES_RC0805_OV_470-75498_3333DISCRETE4R32;R33;R54;R55
RNET_4_8RES_ISO4_SINGLE_RNET_4_8_470-8010kDISCRETE3RN1;RN2;RN3
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_0.73MMMSS1P2LIC1D4
SO6_A1T45_SO6_A_1.1MM_312-75172_SN74SN74LVC1T45IC2U3;U9
SO8MIC2526_8P_SO8_1.73MM_312-75936MIC2026-1YMIC1U2
SO8_UMAXTS462CST_SO8_UMAX_1.1MM_315-788TS462IC1U8
SOT23PNP_SOT23_1.3MM_480-75192_MMBT3MMBT3906LIC1Q2
SOT23NPN_SOT23_1.12 MM_480-75173_MMBMMBT3904LT1GIC2Q4;Q5
SOT223LM1117_SOT223_1.9 MM_315-78813_LD1117-3.3IC1U5
SOT-23DIODE_SCH_123_SOT-23_1.3MM_480-BAT54CIC1D5
SOT-23TRAN_NPN_RES_SOT-23_1.3MM_480-7PDTC115TIC1Q3
SW4_6P5X7MMSW_DIP-2_SW4_6P5X7MM_4.2MM_510-SW_DIP-2/SMIC1SW3
SW_SPST_THSW_PSHBT_SPST_2_SW_SPST_TH_7MM_LIGHT TOUCH PUSH BUTTONIC3SW1;SW2;SW4
TESTPOINT_35MILTEST PAD_TESTPOINT_35MIL_0.1 MM35 MILIC3TP503;TP505;TP506
TP_TH_040TESTLOOP_TP_TH_040_5.1MM_210-79GROUND PIN/LOOPIC8TP2;TP4;TP5;TP6;TP7;TP8;TP9;TP10
TQFP44MC9S08JM60CFGE_TQFP44_1.60 MM_3MC9S08JM60CLDIC1U4
TSSOP16ICL3232_TSSOP16_1.1 MM_312-7954ICL3232IC1U7
XTL2_ECS_SMXTAL_XTL2_ECS_SM_2.0MM_230-777032.768kHzDISCRETE1Y1
附件:
+ b7 V8 T" Q. ^* \0 j. G; [, V原理图和pcb文件如下:5 p7 s' G# R! Y, J1 d, P  f6 x
游客,如果您要查看本帖隐藏内容请回复
( H7 X$ T4 G$ T1 X3 ~0 b8 f
GMT+8, 2025-7-25 11:30 , Processed in 0.125000 second(s), 28 queries , Gzip On.
