查看: 1459|回复: 1
[HyperLynx] 串扰问题?
发表于 2009-12-21 10:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问各位大虾,1、HyperLynx对PCB板做快速串扰分析时,需要加入器件IBIS模型吗?2、在加入IBIS模型之后,串扰的值一般是多大,不影响设计?
1 `: t/ V% Z& D& C( k* {. s& Q我在DXP下面找了个example,对其进行快速串扰分析时,不加如IBIS模型,采用默认的模型参数为4 \3 D, Z; o' ]
Board temperature ................ 20.0 degrees C( G2 M* k# l+ y/ B( l
  Default IC model (used for quick analysis if IC model is missing)
  C( i% o2 i- q) \4 ^$ S& P) K    IC driver rise/fall time ..2.000 ns* ~$ L% Q, l) d& @  D, Q0 x
    IC driver switching voltage range ..3.00 V
5 u/ P+ A3 K, y' o    IC driver output impedance 1.0 ohms
  H  I+ \$ v/ S! f4 C    IC input capacitance ..... 7.0 pF% H' s; Z, n  ~! Z" r3 l
串扰门限为6 v. i6 [5 x& }( O) d* J) S
Maximum allowed crosstalk ........... 200 mv peak
) C* H1 y+ I7 R+ B特定看一个网络:
- o6 s- y3 H8 D0 R. P" y  NET = SOFT_TCK
9 Q0 R! f  s" V! N0 ]   ELECTRICALLY ASSOCIATED NETS --------------------------------------
4 x! O$ Y! O0 C8 s1 m4 ~8 m8 S) y+ t     None
( v" M! K$ g  h7 \8 i, B' a, ^   AGGRESSOR NETS (Estimated peak crosstalk)
( H" M8 o) X' F8 B# g3 ~     NetFPGA1S_B22 .................. 233 mv
+ {* R3 Y2 N' a+ w$ O     Total estimated crosstalk ....................... 233 mv2 \$ `8 ?: M) M) Z; S
     ** Warning ** Estimate exceeds maximum allowed crosstalk!
9 O* W4 n% u- u! n而我分配模型之后,该网络的串扰增加了很多:9 H7 {4 @5 ~) t7 `- L
  NET = SOFT_TCK
! f( L3 l5 }* ]; _" u  W   ELECTRICALLY ASSOCIATED NETS --------------------------------------
1 B; _6 S+ \0 O, s- Y     None; Q  b% [: K- b% y1 M  |
   AGGRESSOR NETS (Estimated peak crosstalk)) X3 p) ~& M0 Q# }# o; W
     NetFPGA1S_B22 ..................1268 mv$ Y% I8 m& g6 U2 _5 Y
     NetFPGA1S_A21 ..................1053 mv7 E% m  E. O4 G- H2 i6 A& k; u
     NetFPGA1S_A20 .................. 456 mv
8 Y' O8 F) t- h2 ^% \3 q     SOFT_TDI ....................... 319 mv1 w2 B- p( f4 _  }
     DIG5_SEG2 ...................... 227 mv
  n  t# s/ j* x- R     Sum of the two strongest aggressors .............2321 mv, b$ g, X4 C, ]  a* O7 d0 L* E2 P! c
发表于 2010-3-30 16:21 | 只看该作者
需要加入模型,阈值一般可以通过简单计算得到.不同的电平,阈值是不同的,5v的10%=500mv,考虑串扰是500mv的30%=150mv;
GMT+8, 2025-7-20 20:35 , Processed in 0.109375 second(s), 24 queries , Gzip On.
