查看: 235|回复: 0
[allegro16.3][6层]TWR-KV58F220M Kinetis KV5x MCU系列塔式系统模块(MKV58F1M0VL...
发表于 2020-2-15 20:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][6层]TWR-KV58F220M Kinetis KV5x mcu系列塔式系统模块(MKV58F1M0VLQ22+MK20DX128VFM5+FXOS8700CQ)原理图和pcb文件
" B( M6 M. N7 V& C& H$ s6 X. v/ g' i! P& O/ H+ G8 e
文件描述:
; ?5 J1 Z% h9 x: h  Y; G; E6 n9 y$ b. y
1. 作品用途:TWR-KV58F220M Kinetis KV5x MCU系列塔式系统模块( T+ p: Q2 X" a/ y% b
2. 软件版本:allegro16.3
" e6 U& L! V. I& s! I% {* ?0 P% x( u3. 层数:6层% U  A1 B3 `0 g: L; k
4. 用到的主要芯片:MKV58F1M0VLQ22+MK20DX128VFM5+FXOS8700CQ! L  m( [1 k# V! `1 m1 ^3 h
5. pcb尺寸: 3543*3174 MIL
% Z1 l$ Y9 t! Q- T2 z
; X8 E9 r& N& f' ?作品截图如下:
! A1 Z( {9 C/ g6 F. ^* v
  N; |; ?% L% f+ C$ d顶层截图:+ L& J( M8 ?+ w! z: y2 O+ f& }
$ ?6 U5 k7 u. H8 H+ u3 u2 N+ G. W
底层截图:
" v) X% c8 c6 c+ W' r9 \
9 s& M) F9 n8 E7 d* r
  e" e& c. o' x* U( |, @5 J& I全层截图:* W4 C7 f% u; ^: `0 H
' ~0 l. m% e! h# |0 _
6 A; P9 ]2 ~5 d9 h' n叠层阻抗信息如下:
6 y0 o8 B3 J3 V$ @0 @
4 y7 K; g  g5 ]; R; SBOM:
# ~( b# t0 h1 ?1 g4 V( D5 D$ l) y3 ?
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE22C4; C5; C6; C9; C10; C12; C24; C25; C26; C27; C29; C30; C32; C36; C37; C38; C39; C40; C41; C47; C54; C57
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.550.1uFDISCRETE1C8
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UFDISCRETE1C28
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE2C42; C49
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M1000PFDISCRETE1C46
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM4.7uFDISCRETE1C3
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_11uFDISCRETE1C7
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_110uFDISCRETE1C11
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_210uFDISCRETE1C14
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE15C15; C18; C31; C33; C34; C35; C44; C45; C48; C50; C51; C52; C53; C55; C58
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.473220PFDISCRETE10C1; C2; C21; C22; C23; C61; C62; C63; C64; C65
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE6C16; C17; C19; C43; C59; C60
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_110UFDISCRETE1C20
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J15
CON2X20_2P54_HLE_BECONN_HDR_20X2_CON2X20_2P54_HLE_CON_2X20IO1J31
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19PIO1J13
CON_MICROAB_10F_25_SM_RAMICRO_USB_CONN_10PIN_A_CON_MICRUSB_MICRO_ABIO1J22
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO2J5; J6
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO15J1; J2; J3; J4; J7; J8; J9; J10; J12; J17; J19; J20; J21; J28; J29
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO5J11; J23; J24; J25; J26
HDR204_TSM_SMCONN_HDR_4X2_HDR204_TSM_SM_IO_9HDR_2X4IO2J14; J30
HDR_5X2_FTSH_THCONN_HDR_5X2_HDR_5X2_FTSH_TH_IOHDR 2X5IO1J27
IND_0603BEAD_FERRITE_IND_0603_DISCRETE_120OHMDISCRETE1L3
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L1; L2
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGEIC1D1
LED_0603LED_LED_0603_IC_0.8MM_370-76653BLUEIC1D2
LED_0603LED_LED_0603_IC_0.80 MM_370-750GREENIC1D3
LED_0603LED_LED_0603_IC_0.9MM_370-75079REDIC2D4; D6
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREENIC1D5
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRNIC1D8
LQFP144_0P5_20X20MMMKV58_144P_A_LQFP144_0P5_20X20MMKV58F1M0VLQ22IC1U8
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32 MM5KDISCRETE1R29
QFN5X3_0P5_3X3FXOS8700CQ_QFN_16P_QFN5X3_0P5_3FXOS8700CQIC1U1
QFN8_1P6X1P6MM74LVC2T45GM_8P_QFN8_1P6X1P6MM_I74LVC2T45GM,125IC1U2
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPMK20DX128VFM5IC1U15
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_470DISCRETE19R1; R2; R3; R4; R5; R6; R11; R12; R13; R14; R15; R16; R17; R18; R46; R54; R55; R62; R63
RC0402_25RES_RC0402_25_DISCRETE_0.55 M_1100DISCRETE11R7; R8; R56; R57; R58; R108; R116; R117; R118; R119; R120
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE3R19; R76; R77
RC0402_25RES_RC0402_25_DISCRETE_0.45 MM_0DISCRETE4R20; R28; R74; R75
RC0402_25RES_RC0402_25_DISCRETE_470-3074110DISCRETE4R23; R24; R25; R26
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__210.0KDISCRETE5R35; R78; R84; R85; R90
RC0402_25RES_RC0402_25_DISCRETE_470-75390DISCRETE2R38; R39
RC0402_25RES_RC0402_25_DISCRETE_0.55MM_410.0KDISCRETE8R40; R48; R51; R91; R93; R98; R101; R104
RC0402_25RES_RC0402_25_DISCRETE_0.55 MM_4.7KDISCRETE4R42; R43; R92; R100
RC0402_25RES_RC0402_25_DISCRETE_470-75624.7KDISCRETE3R47; R82; R83
RC0402_25RES_RC0402_25_DISCRETE_0.7 MM_4180KDISCRETE1R49
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__31.0KDISCRETE1R50
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0KDISCRETE2R52; R105
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_41KDISCRETE1R53
RC0402_25RES_RC0402_25_DISCRETE_470-80902.2KDISCRETE2R68; R73
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__410.0KDISCRETE2R86; R87
RC0402_25RES_RC0402_25_DISCRETE_0.55 M_2330DISCRETE1R94
RC0402_25RES_RC0402_25_DISCRETE_470-757933DISCRETE2R96; R97
RC0402_25RES_RC0402_25_DISCRETE_470-75641.0MDISCRETE1R102
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_68DISCRETE1R109
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470DISCRETE2R36; R80
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE2R99; R103
RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_4180KDISCRETE1R45
SC70_3MOSFET_N_SC70_3_IC_1.0MM_480-76NTS4001NT1GIC1Q1
SH0603RES_SHORT-2_SH0603_DISCRETE_4700DISCRETE2SH1; SH2
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D9
SOD-123DIODE_SCHTKY_SOD-123_IC_1 MM_48MBR130LSFT1GIC1D7
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U12
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8IC1U13
SOT223LD1117AS18_SOT223_IC_1.8MM_312-NCP1117ST33T3GIC1U16
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503BIC1U14
SW2_SPST_3P5X6P0_5P0SW2P_SW2_SPST_3P5X6P0_5P0_IC_5.EVQ-PE105KIC1SW1
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC4SW2; SW3; SW4; SW5
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACKIO5TP1; TP2; TP3; TP26; TP28
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030IO4TP15; TP19; TP20; TP25
TP_PTHTESTLOOP_TP_PTH_IO_0.1 MM_210-7TP_PTHIO17TP4; TP5; TP6; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP16; TP17; TP18; TP21; TP22; TP23; TP24
UDFN6_1P45X1_0P5MMNLX2G14_6P_UDFN6_1P45X1_0P5MM_INLX2G14IC1U11
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45IC5U3; U4; U5; U6; U7
XQFN8_1P45X1P25MMNTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HIC1U10
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1X1
XTLOSC4_SMCLKGEN-SM_XTLOSC4_SM_IC_1.75MM_50MHZIC1Y1
附件:# c, c4 ~1 l5 Q# d3 q) _
原理图和pcb文件如下:4 x1 ~: P" y5 C5 f% [
游客,如果您要查看本帖隐藏内容请回复
1 ?5 R, X: w! f- p, M4 w
GMT+8, 2025-7-25 11:34 , Processed in 0.125000 second(s), 28 queries , Gzip On.
