查看: 196|回复: 0
[allegro16.3][8层]TWR-KV46F150M Kinetis KV4x系列塔式系统模块(PKV40Z256VLL100...
发表于 2020-2-15 20:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][8层]TWR-KV46F150M Kinetis KV4x系列塔式系统模块(PKV40Z256VLL100+PK20DX128VFM5+USB)原理图和pcb文件- z' p3 v/ s. u9 d0 l: `/ O0 L
4 r3 v6 \* d) N5 D* s文件描述:6 p" ]2 @9 y' |( R$ \  w' r; }/ E- D$ |( c
( h5 c$ V: {" E9 K/ _/ P) r
1. 作品用途:TWR-KV46F150M Kinetis KV4x系列塔式系统模块
- `3 B/ s2 C! n9 m9 @0 [2. 软件版本:allegro16.3
5 y. l+ d  P. `6 W8 S3. 层数:8层: j/ C, v" Y+ g/ j' _# ]2 {, K
4. 用到的主要芯片:PKV40Z256VLL100+PK20DX128VFM5+USB
1 b; V6 n; ]- W. Y- L1 P: i5. pcb尺寸: 3543*3174 MIL6 o* v* c0 o8 j3 N. t" [9 Y9 ?5 ~; \
' a- P& V! H8 C
作品截图如下:
* e6 O: Y% M2 w! _2 Y! r  t5 n2 ?3 `7 J6 [7 n7 [
顶层截图:& L9 g' ~, n9 I/ M3 J- G# k
0 z# B9 k/ f4 L( u底层截图:
) T* a6 z6 p( b9 p- X/ ] ' {5 c8 n  ~8 d
  k- D. a# c; N4 b
全层截图:
/ b. S9 j1 A) N7 W, T4 p 9 O: B# m* P! f/ s  m2 [
5 r- j' r. [6 ?$ V( W! }; f2 Z3 I
叠层阻抗信息如下:! G# `& J8 j. I. o: f2 K6 F3 h$ A
0 s3 w4 D, G3 s" |- c( k9 sBOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.550.1uFDISCRETE5C24; C25; C26; C29; C551
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.1uFDISCRETE4C34; C35; C36; C37
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M2200PFDISCRETE10C502; C504; C507; C512; C517; C523; C525; C526; C527; C528
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_2470PFDISCRETE5C518; C519; C521; C522; C524
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE18C3; C4; C500; C501; C503; C505; C513; C514; C515; C533; C537; C543; C547; C548; C549; C550; C552; C553
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE1C30
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1uFDISCRETE1C31
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4 M22PFDISCRETE2C5; C6
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UFDISCRETE3C23; C27; C28
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_110UFDISCRETE4C32; C33; C38; C39
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE1C516
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J500
CON213_SSMHDR_13X2_CON213_SSM_IO_7.8MM_21CON2X13IO1J502
CON220_SSM_MIRRORED_ANYTCONN_HDR_20X2_CON220_SSM_MIRRORHDR_2X20IO1J501
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19PIO1J18
CON_USB_5_548190572USB_MINI_B_SKT_CON_USB_5_548190CONN USB MINI-B 1x5IO1J511
DQFN14_3X2P5MM74LVC125ABQ_DQFN_14P_DQFN14_3X274LVC125IC1U507
FUSE_SMD050FUSE_RESETTABLE_FUSE_SMD050_IC_1AIC1F2
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO6J15; J20; J21; J520; J521; J522
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO5J4; J5; J512; J514; J517
HDR105_STAG_TSM_SM1X5HEADER_HDR105_STAG_TSM_SM_IOHDR_1X5IO2J505; J506
HDR203CONN_HDR_3X2_HDR203_IO_8.5MM_21HDR 2X3IO1J519
HDR205_10M_50_SMCONN_HDR_5X2_HDR205_10M_50_SM_IFTSH-105-01-L-DVIO1J513
HDR_1X1CONN_HDR_1X1_TH_HDR_1X1_IO_8.89HDR_1X1IO2J515; J518
HDR_2X2_100_SM_5X5CONN_HDR_2X2_HDR_2X2_100_SM_5X5HDR 2X2IO6J1; J2; J13; J16; J19; J23
IND_0603INDUCTOR_IND_0603_DISCRETE_0.95600OHMDISCRETE1L501
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L1; L2
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRNIC4D1; D3; D5; D7
LED_0603LED_LED_0603_IC_1.0MM_370-76471YELIC4D2; D4; D6; D8
LED_0603LED_LED_0603_IC_1.0MM_370-76470AMBIC1D9
LED_0603LED_LED_0603_IC_0.8MM_370-75083LED REDIC1D503
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGEIC1D505
LED_0603LED_LED_0603_IC_1.0MM_370-76476YELIC1D506
LQFP100_0P5_14X14PKV40Z256VLL100_LQFP100_LQFP100PKV40Z256VLL100IC1U506
POT3_3224WPOT_POT3_3224W_DISCRETE_470-305100KDISCRETE1R582
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPPK20DX128VFM5IC1U2
RAPC722DC_POWER_JACK_3_RAPC722_IO_11.0CON_1_PWRIO1J516
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE2R2; R3
RC0402_25RES_RC0402_25_DISCRETE_470-755510KDISCRETE11R11; R12; R14; R19; R24; R26; R27; R28; R29; R30; R577
RC0402_25RES_RC0402_25_DISCRETE_470-3077240DISCRETE3R13; R22; R31
RC0402_25RES_RC0402_25_DISCRETE_470-75641.0MDISCRETE1R15
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE2R16; R25
RC0402_25RES_RC0402_25_DISCRETE_0.6MM_470DISCRETE2R17; R18
RC0402_25RES_RC0402_25_DISCRETE_470-757933DISCRETE2R20; R21
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_471KDISCRETE1R23
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110KDISCRETE5R49; R50; R581; R584; R585
RC0402_25RES_RC0402_25_DISCRETE_470-7646330DISCRETE9R500; R501; R502; R503; R504; R507; R556; R558; R559
RC0402_25RES_RC0402_25_DISCRETE_470-3108158KDISCRETE2R505; R506
RC0402_25RES_RC0402_25_DISCRETE_470-30914.99KDISCRETE4R508; R509; R571; R576
RC0402_25RES_RC0402_25_DISCRETE_470-3045100DISCRETE40R510; R511; R512; R513; R514; R515; R516; R517; R518; R519; R520; R521; R522; R523; R524; R525; R526; R529; R530; R531; R532; R533; R534; R535; R537; R538; R540; R541; R542; R543; R544; R545; R546; R547; R548; R549; R550; R551; R552; R553
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0KDISCRETE1R557
RC0402_25RES_RC0402_25_DISCRETE_470-3014120DISCRETE1R560
RC0402_25RES_RC0402_25_DISCRETE_470-762353.6KDISCRETE2R566; R567
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470DISCRETE5R53; R578; R579; R580; R583
RC0603_OVTHERMISTOR_RC0603_OV_DISCRETE_410KDISCRETE4RT1; RT2; RT3; RT4
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440DISCRETE5R4; R5; R7; R10; R568
RC0805_OVRES_RC0805_OV_DISCRETE_470-75951.0MDISCRETE1R6
SH0603RES_SHORT-2_SH0603_DISCRETE_4700DISCRETE1SH6
SKT_100_LQFP_0P5_33P6X33P6PKV40Z256VLL100_LQFP100_SKT_100PKV40Z256VLL100 + IC500-1004-004PIC1U513
SLP1616P6RCLAMP1654P_NEW_SLP1616P6_IC_0.RCLAMP1654P.TCTIC1U512
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D504
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45IC1U5
SO8PCA82C250A_SO8_IC_1.75MM_315-30PCA82C250TDIC1U503
SOD-123DIODE_TVS_SOD-123_IC_1MM_480-78SMF12AT1GIC1D507
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q1
SOT23-6TXB0101_6P_SOT23-6_IC_1.45 MM_3TXS0101IC2U3; U511
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U508
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U509
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8IC1U510
SSOP8_DCUSN74LVC2T45DCUT_8P_SSOP8_DCU_ICSN74LVC2T45IC1U6
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW1; SW2; SW5
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACKIO5TP2; TP3; TP7; TP8; TP30
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8 MM_21TEST POINT WHITEIC5TP6; TP24; TP25; TP26; TP27
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO1TP22
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_210TEST POINT BLACKIC1TP28
TSM116-01-DVCONN_HDR_16X2_TSM116-01-DV_IO_9HDR_2X16IO1J503
TSSOP-1474_04_TSSOP-14_IC_1.2MM_312-753SN74LVC04APWE4IC2U500; U502
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1X2
XTL2_237X79_CSMXTAL_XTL2_237X79_CSM_IC_4.3MM_28MHzIC1Y1
$ B9 z( s9 T/ [( \- {- ?) \附件:
: V4 `/ l6 x! Q  o1 [- j原理图和pcb文件如下:
2 m1 z0 N0 L/ v* }  X) P9 L
游客,如果您要查看本帖隐藏内容请回复
  K6 X1 D; D; g0 B2 [1 O
* ]3 W( i- H# ]" `; K8 Y" z% ~
GMT+8, 2025-7-25 11:28 , Processed in 0.140625 second(s), 28 queries , Gzip On.
