Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | DISCRETE | 27 | C1; C2; C6; C7; C8; C11; C14; C15; C16; C18; C21; C22; C23; C25; C29; C30; C34; C35; C37; C38; C42; C47; C49; C83; C84; C85; C86 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 24PF | DISCRETE | 4 | C9; C12; C39; C43 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | DISCRETE | 14 | C10; C13; C17; C24; C41; C66; C69; C72; C75; C78; C79; C80; C81; C82 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 0.01uF | DISCRETE | 6 | C27; C46; C51; C68; C71; C74 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 47PF | DISCRETE | 2 | C44; C45 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_2 | 1000pF | DISCRETE | 1 | C50 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.047UF | DISCRETE | 8 | C60; C61; C62; C63; C67; C70; C73; C76 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_3 | 0.027uF | DISCRETE | 1 | C87 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.6MM | 10UF | DISCRETE | 6 | C3; C4; C5; C36; C40; C48 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J32 |
CON_2X5_1P27_FTS_SM | CONN_HDR_5X2_CON_2X5_1P27_FTS_S | HDR_2X5 | IO | 2 | J24; J26 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M_50 | CON_2X10 | IO | 2 | J22; J23 |
CON_USB_5_548190572 | USB_MINI_B_SKT_CON_USB_5_548190 | CONN USB MINI-B 1x5 | IO | 1 | J27 |
DIODE_3P2X2P2_SMD | LED_DIODE_3P2X2P2_SMD_IC_1.10 M | IR12-21C/TR8 | IC | 1 | D6 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | HDR 1X2 TH | IO | 17 | J3; J6; J9; J10; J11; J12; J13; J14; J15; J16; J17; J18; J19; J20; J21; J28; J33 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.65MM_2 | HDR TH 1X3 | IO | 3 | J1; J4; J7 |
HDR211 | CONN_HDR_11X2_HDR211_IO_8.55 MM | HDR 2X11 | IO | 1 | J31 |
HDR213 | CONN_HDR_13X2_HDR213_IO_8.55MM_ | HDR_2X13 | IO | 1 | J25 |
IND_0603 | INDUCTOR_FERRITE_IND_0603_DISCR | 470 Ohm | DISCRETE | 7 | L1; L2; L3; L4; L5; L6; L7 |
LCD28_2MM_60X25MM_TH | LCD_28P_LCD28_2MM_60X25MM_TH_IC | GDH-1247WP | IC | 1 | DS1 |
LED_0603 | LED_LED_0603_IC_0.45MM_370-7663 | YEL | IC | 1 | D2 |
LED_0603 | LED_LED_0603_IC_0.45MM_370-7662 | GRN | IC | 2 | D3; D7 |
LED_0603 | LED_LED_0603_IC_0.9MM_370-75079 | RED | IC | 1 | D4 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75080 | ORANGE | IC | 2 | D5; D9 |
LQFP144_0P5_20X20MM | PKM34Z256CLQ7_LQFP_144P_LQFP144 | MKM34Z256VLQ7 | IC | 1 | U1 |
PHTRANS_2P2X3P2 | PT12_PHTRANS_2P_PHTRANS_2P2X3P2 | PT12-21C/TR8 | IC | 1 | Q1 |
POT3_3352T | POT_POT3_3352T_DISCRETE_4.32 MM | 5K | DISCRETE | 1 | R21 |
QFN5X3_0P5_3X3 | MMA8451Q_16P_A_QFN5X3_0P5_3X3_I | MMA8451Q | IC | 1 | U5 |
QFN32_S142EP | PK20DX128V_QFN_32P_QFN32_S142EP | MK20DX128VFM5 | IC | 1 | U6 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | DISCRETE | 35 | R3; R6; R34; R43; R86; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R133; R134; R135; R136 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 470 | DISCRETE | 14 | R1; R9; R13; R14; R15; R42; R44; R60; R65; R69; R74; R79; R82; R84 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_5 | 1M | DISCRETE | 2 | R2; R33 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | 4.7K | DISCRETE | 5 | R7; R10; R17; R23; R25 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_1 | 10K | DISCRETE | 4 | R11; R24; R26; R41 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_1 | 47.0K | DISCRETE | 5 | R16; R27; R28; R29; R58 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_3 | 1.1M | DISCRETE | 1 | R18 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_6 | 82.5 | DISCRETE | 8 | R22; R61; R66; R70; R75; R80; R83; R85 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_2 | 4.7K | DISCRETE | 2 | R30; R39 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_7 | 10K | DISCRETE | 2 | R32; R37 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_8 | 33 | DISCRETE | 3 | R35; R36; R49 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_9 | 1.2K | DISCRETE | 2 | R38; R48 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_2 | 10K | DISCRETE | 10 | R46; R47; R125; R126; R127; R128; R129; R130; R131; R132 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55M_11 | 22 | DISCRETE | 8 | R62; R64; R67; R71; R72; R76; R77; R81 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_3 | 47 | DISCRETE | 3 | R63; R68; R73 |
RC0603_OV | RES_RC0603_OV_DISCRETE_.55MM_47 | 1K | DISCRETE | 1 | R137 |
RC0603_OV | THERMISTOR_NTC_RC0603_OV_DISCRE | NCP18WB473J03RB | DISCRETE | 1 | RT1 |
SKT_BAT_780X1210 | BATTERY_SKT_3V_SKT_BAT_780X1210 | BK-883 | IC | 1 | BT1 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7 | MSS1P3L | IC | 1 | D8 |
SO8-25X75-200 | MX25L6406EM2I_SOP8_SO8-25X75-20 | MX25L6406EM2I-12G | IC | 1 | U4 |
SOT23 | PNP_SOT23_IC_1.1MM_480-76358_MM | MMBT2907A | IC | 1 | Q3 |
SOT23-6_A | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | MIC2005-0.8YM6 | IC | 1 | U11 |
SOT23_A | NPN_SOT23_A_IC_1.11MM_480-77960 | MMBT2222LT1 | IC | 1 | Q2 |
SOT223 | CE6208A_FXD_SOT223_IC_1.8MM_315 | CE6208A33G | IC | 1 | U2 |
SOT-23 | BAT721B_SOT-23_IC_1.3MM_480-779 | BAT54C | IC | 1 | D1 |
SOT_143 | DIODE_TVS_SOT143_SOT_143_IC_1.1 | TVLS14302AC0 | IC | 1 | D22 |
SSOP14 | 74LVC125_SSOP14_IC_2MM_312-7993 | 74LVC125ADB | IC | 1 | U10 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | PB switch | IC | 4 | SW1; SW2; SW3; SW4 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8 MM_21 | TEST POINT WHITE | IO | 3 | TP4; TP5; TP6 |
XTAL4_5X3 | CRYSTAL_JXS63_XTAL4_5X3_IC_1.1M | 8MHz | IC | 2 | Y2; Y3 |
XTL2_TF_SM | XTAL_XTL2_TF_SM_IC_2.45 MM_230- | 32.768KHz | IC | 1 | Y1 |
