查看: 245|回复: 0
[allegro16.5][6层]TWR-KL46Z48M Kinetis KL3x, KL4x塔式系统模块(PKL46Z256VLL4+...
发表于 2020-2-14 16:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
2 p) P0 K% G+ b( \8 f' ?9 O9 F7 [! T" t. ^: t* H" `
[allegro16.5][6层]TWR-KL46Z48M Kinetis KL3x, KL4x塔式系统模块(PKL46Z256VLL4+PK20DX128VFM5+MMA8451Q)原理图和pcb文件
) {8 I! Z) K6 C" E0 ]+ T4 ^+ G# L# K' E1 s2 _% m7 k
文件描述:
) |, T* L/ a, ^! N2 N! Q3 q5 d: E2 I
1. 作品用途:TWR-KL46Z48M Kinetis KL3x, KL4x塔式系统模块; c" C4 M+ u* K; K9 [$ C- r
2. 软件版本:allegro16.5" X" t" a9 A+ Y- V
3. 层数:6层
  I, I* R- G& `0 ]& D6 S  h4. 用到的主要芯片:PKL46Z256VLL4+[size=13.3333px]PK20DX128VFM5+MMA8451Q
* y) Y5 `, l' M3 l+ m  x& X5. pcb尺寸: 3543*3174 MIL
$ K% K5 ^! j  Z/ D- `3 |3 U8 M/ }9 w0 X. `
作品截图如下:, `  n- I! `5 W1 J) B' J, ~
  \0 B0 V' H6 `+ {6 [
顶层截图:
( o/ n" V2 S5 T8 U
5 r5 o* }( |) Q& o# Z' t9 g底层截图:
& H- p% V0 i% B8 p- M8 {+ p 4 i0 _& [, Z0 Y2 [# }
) O6 N6 a) O2 J3 O, x" e( s全层截图:; r- i: i* ]0 \3 t9 U
! X( g0 Q. r3 c8 i0 t% ]  w$ x) W
) z+ X0 J( A! R5 s3 M& O, \1 y' h
叠层阻抗信息如下:+ \) _% f- d3 j# P
4 O1 [4 y  S5 J4 ]
BOM:3 e9 F: K/ ]# g
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLPIC6U2; U3; U6; U12; U13; U14
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M47PFDISCRETE5C3; C17; C20; C21; C531
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE28C4; C5; C8; C16; C19; C22; C23; C24; C25; C502; C504; C506; C507; C509; C510; C512; C513; C515; C520; C526; C528; C529; C534; C535; C536; C537; C538; C539
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.01UFDISCRETE4C525; C527; C532; C533
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE2C516; C524
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE3C518; C519; C521
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM4.7uFDISCRETE1C530
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE9C1; C2; C503; C505; C508; C514; C517; C522; C523
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_12.2UFDISCRETE2C500; C501
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J12
CON5_MICROUSBUSB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5IO1J14
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5IO2J8; J29
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO2J1; J6
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10IO1J2
CON_USB_5_548190572USB_MINI_B_SKT_CON_USB_5_548190CONN USB MINI-B 1x5IO1J5
DIODE_3P2X2P2_SMDLED_DIODE_3P2X2P2_SMD_IC_1.10 MIR12-21C/TR8IC1D6
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO14J13; J15; J16; J17; J19; J20; J21; J22; J23; J24; J25; J26; J27; J28
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO5J3; J4; J10; J11; J18
HDR203CONN_HDR_3X2_HDR203_IO_8.58MM_2HDR_2X3IO1J7
HDR210CONN_HDR_10X2_HDR210_IO_8.71 MMHDR_10X2IO1J9
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE4L1; L2; L3; L500
IND_1608IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZDISCRETE5L6; L501; L502; L503; L504
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_ILED_OR + ELECTRODEIC1D502
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_1LED_YEL + ELECTRODEIC1D503
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREENIC2D1; D4
LED_0603LED_LED_0603_IC_0.8MM_370-76537YEL/GRNIC2D3; D500
LED_0603LED_LED_0603_IC_0.8MM_370-75083LED REDIC1D5
LQFP100_0P5_14X14PKL46Z_LQFP100_LQFP100_0P5_14X1PKL46Z256VLL4IC1U10
OSC4_10P5X5MMCRYSTAL-SG3030JF_OSC4_10P5X5MM_32.768KHZIC1Y500
PHTRANS_2P2X3P2PT12_PHTRANS_2P_PHTRANS_2P2X3P2PT12-21C/TR8IC1Q2
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32 MM5KDISCRETE1R550
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451QIC1U507
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPPK20DX128VFM5IC1U503
RC0402_25RES_RC0402_25_DISCRETE_0.45 MM_0DISCRETE70R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R29; R30; R31; R32; R33; R34; R38; R39; R500; R501; R502; R503; R504; R505; R506; R507; R508; R509; R510; R511; R512; R513; R514; R515; R516; R517; R518; R520; R528; R531; R533; R539; R540; R548; R549; R554; R555; R556; R557; R558; R559; R560; R561
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0KDISCRETE12R40; R43; R44; R47; R48; R530; R532; R536; R542; R545; R551; R552
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE6R42; R53; R524; R525; R546; R553
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_11.0KDISCRETE1R50
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__2330DISCRETE2R54; R55
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__11.0KDISCRETE4R57; R534; R538; R547
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_21.54KDISCRETE1R58
RC0402_25RES_RC0402_25_DISCRETE_0.55MM_410.0KDISCRETE2R522; R526
RC0402_25RES_RC0402_25_DISCRETE_0.55 MM_330DISCRETE1R523
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_15KDISCRETE1R527
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_415KDISCRETE1R535
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_15.1KDISCRETE1R541
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_33DISCRETE7R45; R46; R51; R52; R56; R543; R544
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_42.2KDISCRETE1R519
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_11.0MDISCRETE2R529; R537
RC0805_OVRES_RC0805_OV_DISCRETE_0.65 MM_270DISCRETE1R49
RC0805_OVRES_RC0805_OV_DISCRETE_0.65 M_1270DISCRETE1R521
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D501
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45IC5U5; U7; U504; U508; U509
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U506
SOT23NPN_SOT23_IC_1.11 MM_480-75151_MMBT2484LIC1Q1
SOT23-6TXB0101_6P_SOT23-6_IC_1.45 MM_3TXB0101IC1U4
SOT23-6TXB0101_6P_SOT23-6_IC_1.45 MM_1TXS0101IC1U502
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U505
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U1
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8IC1U500
SSOP1474LVC125_SSOP14_IC_2MM_312-799374LVC125ADBIC1U501
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW1; SW2; SW4
SW_DIP8_4POS_SMSW_DIP4_SW_DIP8_4POS_SM_IC_2.32SW DIP-4IC1SW3
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO8TP1; TP3; TP4; TP5; TP13; TP14; TP18; TP21
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8 MM_21TEST POINT WHITEIC2TP11; TP12
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040IC11TP2; TP6; TP7; TP8; TP9; TP10; TP15; TP16; TP17; TP19; TP20
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC2X500; X501
附件:+ X$ x' y! K7 d- C! D; l
原理图和pcb文件如下:
* ?4 {; a, }/ z
游客,如果您要查看本帖隐藏内容请回复
( m' P4 M) Z7 d' D3 v9 o9 D
GMT+8, 2025-7-26 09:46 , Processed in 0.140625 second(s), 28 queries , Gzip On.
