查看: 215|回复: 0
[allegro16.3][6层]TWR-KL28Z72M Kinetis KL28 MCU塔式系统模块(MKL28Z512VLL7+MK...
发表于 2020-2-14 16:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][6层]TWR-KL28Z72M Kinetis KL28 mcu塔式系统模块(MKL28Z512VLL7+MK20DX128VFM5+MMA8451Q)原理图和pcb文件& g9 H, u& P1 A. ^  u- s
% u! [0 E- E# c& `% U文件描述:
3 U4 e+ n+ x( S2 X( {
; {# c% z9 l& }* ?1 c: Z1. 作品用途:TWR-KL28Z72M Kinetis KL28 MCU塔式系统模块* O9 ~' ~% a2 W2 k$ ?7 L
2. 软件版本:allegro16.3) t# D  P( b4 q& B
3. 层数:6层, z/ s# [5 V# \# }5 w/ J; E: k$ z
4. 用到的主要芯片:MKL28Z512VLL7+MK20DX128VFM5+MMA8451Q- O1 {2 ]. n5 l: X4 }  L# g
5. pcb尺寸: 3543*3174 MIL0 v, u) @+ y6 X3 l3 g$ E
8 q1 u3 @% h% h5 p作品截图如下:$ N; o3 ?4 `4 ]3 ?$ A: Q
2 W9 R# {4 I% i. f6 B- u) p7 w
顶层截图:
: V+ @/ d  p$ G, s1 A  o4 d
; e- k. c0 i2 l底层截图:
, s" d. ~$ a7 h& c" `; p5 S/ j: ^7 R7 B 1 r# o- p0 ~- G) C$ x
! x6 z) z5 K8 y: m( |! q# J
全层截图:1 Y- \* N0 m# g* p
8 o9 ^: R3 G& w: h3 D8 J; ~& U
( Y' A% I6 n0 s7 p% U叠层阻抗信息如下:
7 D% B) b/ f2 v& ?/ ?7 a# D" Y # f- d  M. C9 |4 \& o* `
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLPIC6U4; U5; U6; U17; U18; U19
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE25C1; C2; C5; C6; C8; C10; C11; C15; C17; C22; C25; C26; C28; C30; C31; C34; C35; C36; C38; C41; C45; C46; C48; C49; C52
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M0.01UFDISCRETE7C4; C7; C9; C12; C13; C14; C16
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_147PFDISCRETE2C32; C33
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE4C3; C29; C53; C54
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM24PFDISCRETE2C20; C23
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_14.7uFDISCRETE1C47
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.6MM10UFDISCRETE9C24; C27; C37; C40; C42; C43; C44; C50; C51
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J31
CON5_MICROUSBUSB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5IO1J29
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5IO2J11; J30
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO2J23; J25
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10IO1J24
CON_USB_5_548190572USB_MINI_B_SKT_CON_USB_5_548190CONN USB MINI-B 1x5IO1J10
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO19J4; J6; J8; J13; J14; J15; J16; J17; J18; J19; J20; J21; J22; J27; J28; J32; J33; J35; J36
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO5J1; J5; J7; J9; J34
HDR203CONN_HDR_3X2_HDR203_IO_8.58MM_2HDR_2X3IO1J12
HDR216CONN_HDR_16X2_HDR216_IO_8.58 MMHDR_2X16IO1J26
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE4L6; L7; L8; L9
IND_1608IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZDISCRETE5L1; L2; L3; L4; L5
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_ILED_OR + ELECTRODEIC1D5
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_1LED_YEL + ELECTRODEIC1D6
LED_0603LED_LED_0603_IC_0.8MM_370-76537YEL/GRNIC2D1; D4
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREENIC2D2; D7
LED_0603LED_LED_0603_IC_0.8MM_370-75083LED REDIC1D8
LQFP100_0P5_14X14PKL28Z512VLL7_LQFP_100P_LQFP100MKL28Z512VLL7IC1U21
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32 MM5KDISCRETE1R33
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451QIC1U15
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPMK20DX128VFM5IC1U2
RC0402_25RES_RC0402_25_DISCRETE_0.45 MM_0DISCRETE44R9; R15; R22; R28; R30; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_471.0KDISCRETE3R18; R29; R31
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_41.0KDISCRETE1R20
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_1330DISCRETE1R4
RC0603_OVRES_RC0603_OV_DISCRETE_0.4MM_4710.0KDISCRETE11R6; R10; R17; R26; R35; R36; R37; R38; R41; R43; R90
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_41.0MDISCRETE1R7
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_33DISCRETE6R8; R11; R44; R45; R46; R47
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_110.0KDISCRETE1R12
RC0603_OVRES_RC0603_OV_DISCRETE_0.40 MM_15KDISCRETE1R13
RC0603_OVRES_RC0603_OV_DISCRETE_0.4MM__1330DISCRETE4R14; R21; R32; R34
RC0603_OVRES_RC0603_OV_DISCRETE_0.4 MM_415KDISCRETE1R19
RC0603_OVRES_RC0603_OV_DISCRETE_0.41MM_44.70KDISCRETE5R23; R25; R39; R40; R88
RC0603_OVRES_RC0603_OV_DISCRETE_0.40 M_15.1KDISCRETE1R42
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D3
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45IC2U11; U12
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U16
SOT23NPN_SOT23_IC_1.11 MM_480-75151_MMBT2484LIC1Q1
SOT23-6TXB0101_6P_SOT23-6_IC_1.45 MM_1TXS0101IC1U3
SOT23-6TXB0101_6P_SOT23-6_IC_1.45 MM_3TXB0101IC2U9; U20
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U10
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U13
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8IC1U14
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW1; SW2; SW3
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO4TP14; TP15; TP16; TP17
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040IC8TP1; TP3; TP4; TP5; TP10; TP11; TP12; TP13
TSSOP1474LVC125_TSSOP14_IC_1.2MM__74LV74LVC125APWIC1U7
XTAL2-3P2X1P5-SMXTAL_XTAL2-3P2X1P5-SM_IC_0.65MM32.768kHzIC1Y4
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1X1
XTAL4_5X3CRYSTAL_JXS63_XTAL4_5X3_IC_1.1M8MHzIC1Y1
! u# D5 C7 i* [$ K# W! z# `/ j附件:
- R: y  D& @0 H/ @原理图和pcb文件如下:7 B9 f4 t+ f8 ]. [0 C
游客,如果您要查看本帖隐藏内容请回复
: w( Q4 t2 i. K  L( l* C
- `( z1 z0 b0 D) B; m
GMT+8, 2025-7-24 10:26 , Processed in 0.125000 second(s), 28 queries , Gzip On.
