作品名:[AD 15][4层] B_L475E_IoT01A STM32L4 IoT节点探索套件(STM32L475VGTx+MP34DT01-M+LSM6DSL)原理图、PCB源文件
6 W3 X) p0 E8 L7 M/ f# C/ Y" l5 L4 K% v
文件描述
' n9 E* r4 @5 R3 T1. 作品用途:节点探索套件
U6 ]/ L& q3 R/ Q) L$ H( p' h2. 软件版本:AD 15- [' L) n7 A0 K# l7 T
3. 层数:4层板2 G( K! T3 }: E; y1 \/ v4 l! e( A
4. 用到的主要芯片:STM32L475VGTx+MP34DT01-M+LSM6DSL
/ u. m* J& }' `/ c5. PCB尺寸:92mm*60mm
3 Q9 [: O3 Z5 y2 v/ b4 k, x i+ @# e9 k- \/ k6 ~" `$ t
作品截图如下:% i/ \4 E6 o8 o
顶层截图:: M1 v1 u/ ?6 d- A% x# S. C- v X3 e) C
; d0 L3 Z3 _9 |2 Z: {3 m8 B底层截图:+ P6 ^4 z8 N9 ^2 k$ ~' c2 H+ y3 ]
& h$ @7 a3 d t
全层截图:& ~7 H# t& d$ m, d2 U2 w3 [- B' m
) q1 {5 Z, p, m) w4 h* \# h叠层信息截图如下:6 ]) X! K8 f; q3 Q/ j6 o, b% a
6 C M, B- \+ s* p8 LBOM:
m, f3 N4 c& Y. QComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | SW-PUSH-CMS_BLACK | B1 | SWI_WEALTHMETAL_TD-0341_4P - BACK | 1 | SW-PUSH-CMS_BLUE | B2 | SWI_WEALTHMETAL_TD-0341_4P - BLUE | 1 | 100nF | C1, C3, C5, C7, C9, C10, C11, C12, C13, C17, C19, C20, C22, C23, C25, C26, C28, C29, C31, C32, C33, C34, C36, C42, C43, C44, C45, C47, C48, C54, C55, C57, C60, C61, C62, C63, C65, C73, C74 | 0402_CAP_NPOL | 39 | Not Fitted (8.2pF) | C2, C4 | 0402_CAP_NPOL | 2 | 1uF | C6, C8, C24, C56, C59, C64, C68 | 0402_CAP_NPOL | 7 | 5.1pF | C14, C15 | 0402_CAP_NPOL | 2 | 10uF | C16, C38, C39, C40, C41, C46, C49, C50 | 0603_CAP_NPOL | 8 | 4.7uF | C18, C21, C30, C66 | 0603_CAP_NPOL | 4 | 2.2uF | C27, C75, C76 | 0603_CAP_NPOL | 3 | 10pF | C35, C37, C51, C52 | 0402_CAP_NPOL | 4 | 47pF | C53, C71 | 0402_CAP_NPOL | 2 | 10nF | C58 | 0402_CAP_NPOL | 1 | 100pF | C67 | 0402_CAP_NPOL | 1 | Not Fitted | C69, C70, C72 | 0402_CAP_NPOL | 3 | Header 10X1_Female_SMD | CN1 | F-V50XC-1X10R-LF | 1 | Header 8X1_Female_SMD | CN2, CN3 | F-V50XC-1X08R-LF | 2 | Header 6X1_Female_SMD | CN4 | F-V50XC-1X06R-LF | 1 | TC2050-IDC-NL | CN5 | CON_TAG-C_TC2050-IDC-NL | 1 | header 2 pins 2.54mm | CN6 | CON_SAMTEC_TSW-102-07-G-S | 1 | 1050170001 | CN7 | CON_USBMICROB_MOLEX_105017-0001_H2P90 | 1 | Header 4 pins | CN8 | CON_SAMTEC_TSW-104-07-G-S | 1 | 475900001 | CN9 | CON_USBMICROAB_MOLEX_47590-0001_H3 | 1 | HEADER_2X6_PMOD | CN10 | Header F 2x6x2.54 TH H PMOD | 1 | BAT60JFILM | D2, D3, D4, D5 | DIO_SOD323 | 4 | HEADER_2X5 | JP4 | Header M 2x5x2.54 TH V | 1 | Jumper_2.54mm | JP5, JP6, JP7, JP8 | CON_SAMTEC_TSW-102-07-G-S | 4 | FCM1608KF-601T03 | L1 | 0603L | 1 | 742792042 | L2 | 0603L | 1 | LED | LD1, LD2, LD5, LD9 | 0603_LED_GREEN | 4 | LED | LD3 | 0603_LED_Yellow | 1 | LED | LD4 | 0603_LED_Blue | 1 | LD_BICOLOR_CMS | LD6 | LED_BI-GR_HSMF-A201-A00J1 | 1 | LED | LD7, LD8 | 0603_LED_RED | 2 | Comment | Logo_ST | LOGO_ST_Size3 | 1 | BT Module | M1 | SPBTLE-RF | 1 | ISM43362-M3G-L44 | M2 | ISM43362-M3G-L44 | 1 | SPSGRF | M3 | SPSGRF | 1 | BSR14 | Q1, Q2 | SOT23-3 | 2 | 30K | R1 | 0402_RES | 1 | 0R | R2, R6, R12, R13, R42, R43 | 0402_RES | 6 | 1K | R3, R18, R19, R21, R24, R52, R56 | 0402_RES | 7 | 20K | R4 | 0402_RES | 1 | Not Fitted (0R) | R5, R7, R30 | 0402_RES | 3 | 2K2 | R8, R9, R10, R11, R53 | 0402_RES | 5 | 10K | R14, R15, R16, R31, R48, R51, R67 | 0402_RES | 7 | 330R | R20, R25, R44, R47, R55 | 0402_RES | 5 | 680R | R22 | 0402_RES | 1 | 100K | R23, R29, R49, R54, R59 | 0402_RES | 5 | 47K | R26, R57, R58, R62 | 0402_RES | 4 | 4K7 | R27, R40, R41 | 0402_RES | 3 | 2K7 | R28 | 0402_RES | 1 | 22R | R32, R33, R34, R35 | 0402_RES | 4 | Not Fitted (10K) | R36, R64, R65, R66 | 0402_RES | 4 | 200K | R38 | 0402_RES | 1 | 100R | R39, R45 | 0402_RES | 2 | 36K | R46 | 0402_RES | 1 | 1K5 | R50 | 0402_RES | 1 | 0R | R61 | 0603_RES | 1 | Close | SB1, SB2, SB3, SB4, SB5, SB6, SB7, SB8, SB10, SB13, SB14, SB15, SB17, SB18, SB21 | SB | 15 | Open | SB9, SB11, SB12, SB16, SB19, SB20 | SB | 6 | PT | TP1, TP2, TP3, TP4, TP5, TP6 | PTB | 6 | STM32L475VGTx | U1 | LQFP100 14x14x1.6 | 1 | MP34DT01-M | U2, U10 | HCLGA-4LD 3x4x1 | 2 | LSM6DSL | U3 | LGA14L-2.5X3X0.86p0.5 | 1 | VL53L0X | U4 | LGA12-optical | 1 | LIS3MDL | U5 | VFLGA12-2x2x1 | 1 | HTS221 | U6 | HLGA6L-2x2x0.9 | 1 | LPS22HB | U7 | HLGA10L-2X2X0.76 | 1 | M24SR64-Y | U8 | SOP8 | 1 | STSAFE-A100 | U9 | SOP8 | 1 | MX25R6435F | U11 | SOP8L | 1 | LT1963EST-3.3 | U12 | SOT223_SC73 | 1 | LD1117S50TR | U13 | REG_SOT223-TAB | 1 | LD1117S33TR | U14 | REG_SOT223-TAB | 1 | STM32F103CBT6 | U15 | ICC_LQFP48_7X7_P050 | 1 | LD3985M33R | U16 | REG_SOT23-5L | 1 | ST890CDR | U17 | ICC_SO8_5X4_P127 | 1 | EMIF02-USB03F2 | U18, U20 | ESD_FLIP-CHIP-BGA11_1P44X1P94_P050 | 2 | STMPS2141STR | U19 | MOS_SOT23-5L | 1 | TSV631AILT | U21 | SOT23-5 | 1 | Not Fitted (NX3225GD-8.00M) | X1 | CRY_NX3225GD_2P | 1 | NX3215SA-32.768K | X2 | CRY_NX3215SA_2P | 1 | NX3225GD-8.00M | X3 | CRY_NX3225GD_2P | 1 | 附件:
2 z1 N8 u& ]6 k; g9 `原理图和PCB源文件如下:- d/ S: I/ U! R- p$ r3 {
2 @" q9 t" H1 j9 C* c
5 G$ K6 f) ]/ S% m- E' t
