Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BGA169_0P65_9X9 | PK65FN2M0VMF18_BGA_169P_BGA169_ | MK65FN2M0VMI18 | IC | 1 | U1 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 0.1uF | DISCRETE | 23 | C1; C2; C3; C4; C6; C15; C17; C20; C31; C34; C35; C36; C37; C41; C44; C45; C47; C48; C51; C52; C53; C54; C63 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.4MM | 0.01UF | DISCRETE | 14 | C7; C8; C9; C10; C11; C12; C55; C56; C57; C58; C59; C60; C61; C62 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | DISCRETE | 5 | C24; C25; C26; C29; C49 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 4.7uF | DISCRETE | 8 | C13; C23; C27; C28; C46; C50; C67; C72 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 4.7uF | DISCRETE | 9 | C32; C33; C38; C39; C42; C68; C69; C70; C71 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9 M | 2.2UF | DISCRETE | 1 | C43 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J26 |
CON5_MICROUSB | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | IO | 1 | J15 |
CON_FTSH_19M_50_SM | CONN_HDR_19_CON_FTSH_19M_50_SM_ | HDR_19P | IO | 1 | J18 |
CON_SDCARD_8F_SM_RA | CONN_MICRO_SD_CARD_REVERSED_CON | Conn MicroSD | IO | 1 | J29 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M_50 | CON_2X10 | IO | 2 | J11; J12 |
CON_USB_5_548190572 | USB_MINI_B_SKT_CON_USB_5_548190 | CONN USB MINI-B 1x5 | IO | 1 | J7 |
DFN1616-6 | RCLAMP1654P_NEW_DFN1616-6_IC_0. | PUSBM5V5X4-TL | IC | 2 | U9; U13 |
DQFN14_3X2P5MM | 74LVC125ABQ_DQFN_14P_DQFN14_3X2 | 74LVC125 | IC | 1 | U4 |
HDR2X4_2P54_TSM_SM | CONN_HDR_4X2_HDR2X4_2P54_TSM_SM | HDR 2X4 | IO | 2 | J9; J19 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | HDR 1X2 TH | IO | 11 | J1; J2; J8; J10; J13; J14; J20; J21; J24; J30; J32 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.65MM_2 | HDR TH 1X3 | IO | 7 | J3; J6; J16; J27; J33; J34; J36 |
HDR202_TSM_SM | CONN_HDR_2X2_HDR202_TSM_SM_IO_9 | HDR_2X2 | IO | 3 | J22; J23; J35 |
HDR205_10M_50_SM | CONN_HDR_5X2_HDR205_10M_50_SM_I | FTSH-105-01-L-DV | IO | 1 | J5 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 3 | L1; L2; L4 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 M_1 | 330 OHM | DISCRETE | 1 | L3 |
JUMP1X8-6040 | HDR-1X8_JUMP1X8-6040_IO_8.382 M | HDR_1X8 | IO | 1 | J4 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_I | LED_GRN + ELECTRODE | IC | 1 | D8 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_1 | LED2_ELECTRODE | IC | 1 | D9 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75080 | ORANGE | IC | 2 | D2; D7 |
LED_0603 | LED_LED_0603_IC_1.0MM_370-76476 | YEL | IC | 1 | D3 |
LED_0603 | LED_LED_0603_IC_1.0MM_370-76472 | YEL/GRN | IC | 1 | D5 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | IC | 1 | D6 |
POT3_3352T | POT_POT3_3352T_DISCRETE_4.32 MM | 5K | DISCRETE | 1 | R67 |
QFN5X3_0P5_3X3 | MMA8451Q_16P_A_QFN5X3_0P5_3X3_I | MMA8451Q | IC | 1 | U15 |
QFN32_S142EP | PK20DX128V_QFN_32P_QFN32_S142EP | MK20DX128VFM5 | IC | 1 | U2 |
R603-X2 | RES_0603_X2_R603-X2_DISCRETE_0. | 0 | DISCRETE | 4 | R181; R182; R189; R190 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 33 | DISCRETE | 2 | R1; R2 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | DISCRETE | 13 | R10; R12; R19; R24; R28; R29; R30; R47; R124; R125; R178; R179; R180 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_4 | 1.0M | DISCRETE | 2 | R15; R166 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 33 | DISCRETE | 2 | R20; R21 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | 10K | DISCRETE | 7 | R34; R35; R44; R45; R49; R50; R62 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | DISCRETE | 32 | R80; R100; R103; R135; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R161; R162; R171; R172 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_1 | 47K | DISCRETE | 2 | R3; R165 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 0 | DISCRETE | 35 | R4; R5; R8; R17; R18; R32; R63; R73; R76; R77; R78; R81; R82; R83; R84; R85; R86; R87; R101; R104; R107; R110; R126; R127; R128; R129; R130; R132; R160; R163; R164; R183; R184; R187; R188 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__3 | 100K | DISCRETE | 2 | R6; R7 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__1 | 1K | DISCRETE | 6 | R13; R22; R31; R61; R64; R66 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | 4.7K | DISCRETE | 3 | R16; R33; R36 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__2 | 1K | DISCRETE | 2 | R23; R60 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_4 | 0 | DISCRETE | 3 | R191; R192; R193 |
SH0603 | RES_SHORT-2_SH0603_DISCRETE_0.1 | 0 | DISCRETE | 1 | SH6 |
SKT_BAT_780X1210 | BATTERY_SKT_3V_SKT_BAT_780X1210 | BK-883 | IC | 1 | BT1 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7 | MSS1P3L | IC | 1 | D4 |
SO6_A | 1T45_SO6_A_IC_1.1MM_312-75172_S | SN74LVC1T45 | IC | 3 | U5; U17; U18 |
SOT23 | NPN_SOT23_IC_1.12 MM_480-75173_ | MMBT3904LT1G | IC | 1 | Q1 |
SOT23-6 | TXB0101_6P_SOT23-6_IC_1.45 MM_3 | TXS0101 | IC | 2 | U3; U7 |
SOT23-6_A | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | MIC2005-0.8YM6 | IC | 2 | U8; U12 |
SOT23-40X40 | MOSFET_P_SOT23-40X40_IC_1.1MM_4 | ZXM61P02F | IC | 1 | Q2 |
SOT223 | LT1963AST_SOT223_IC_1.8MM_312-7 | LT1963AEST-3.3 | IC | 1 | U10 |
SOT223 | MIC37139-1.8BS-1_SOT223_IC_1.8M | MIC5239-1.8 | IC | 1 | U11 |
SOT-23 | BAT721B_SOT-23_IC_1.3MM_480-779 | BAT54C | IC | 1 | D1 |
SSOP8_DCU | SN74LVC2T45DCUT_8P_SSOP8_DCU_IC | SN74LVC2T45 | IC | 1 | U6 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | PB switch | IC | 3 | SW1; SW2; SW3 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IC_4.8MM_210 | TEST POINT BLACK | IC | 2 | TP11; TP12 |
TSOP86 | MT48LC2M32B2P_86P_TSOP86_IC_1.2 | MT48LC2M32B2P-5 | IC | 1 | U14 |
TSSOP14 | 74LCX02_TSSOP14_IC_1.2MM_312-79 | 74LCX02 | IC | 1 | U16 |
XTAL3_3P35X1P45_SM | XTAL_CS_XTAL3_3P35X1P45_SM_IC_0 | 8.00MHZ | IC | 1 | X1 |
XTL2_ECS_SM | XTAL_XTL2_ECS_SM_IC_8.84MM_230- | 32.768KHz | IC | 1 | Y1 |
XTLOSC4_3P2X2P5MM_SM | XTAL_13Y_XTLOSC4_3P2X2P5MM_SM_I | FL1600084 | IC | 1 | Y2 |
附件:
