Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | DISCRETE | 4 | C2; C22; C25; C82 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_.55MM | 27PF | DISCRETE | 2 | C41; C48 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | DISCRETE | 32 | C3; C4; C5; C9; C13; C14; C15; C16; C17; C18; C23; C24; C26; C29; C30; C31; C32; C33; C34; C36; C37; C38; C40; C42; C44; C45; C47; C50; C51; C86; C87; C88 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | DISCRETE | 1 | C7 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | DISCRETE | 4 | C8; C10; C21; C28 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 0.1UF | DISCRETE | 1 | C20 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | DISCRETE | 8 | C6; C11; C12; C19; C27; C35; C39; C49 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_0.94M | 1000pF | DISCRETE | 1 | C43 |
CC3528-21 | CAP_POL_CC3528-21_2.1MM_150-785 | 4.7uF | IC | 2 | C1; C46 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J7 |
CON5_USB_MINI_A_SMT | USB_MINI_B_SKT_CON5_USB_MINI_A_ | CONN USB MINI-B 1x5 | IO | 1 | J13 |
CON_FTSH_19M_50_SM | CONN_HDR_19_CON_FTSH_19M_50_SM_ | HDR_19P | IO | 1 | J11 |
CON_SDCARD_8F_SM_RA | CONN_MICRO_SD_CARD_REVERSED_CON | Conn MicroSD | IO | 1 | J15 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M_50 | CON_2X10 | IO | 1 | J3 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M__1 | CON_2X10 | IO | 2 | J4; J5 |
DIODE_3P2X2P2 | LED_DIODE_3P2X2P2_IC_1.1MM_480- | QTLP610CIR | IC | 1 | D1 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | HDR 1X2 TH | IO | 8 | J1; J2; J8; J10; J12; J16; J18; J19 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.65MM_2 | HDR TH 1X3 | IO | 6 | J6; J9; J21; J22; J23; J24 |
HDR203_TSM_SM | CONN_HDR_3X2_HDR203_TSM_SM_IO_9 | HDR_2X3 | IO | 1 | J14 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100 OHM@100MHZ | IC | 5 | L1; L4; L6; L7; L8 |
IND_0603 | BEAD_FERRITE_IND_0603_DISCRETE_ | 120OHM | DISCRETE | 1 | L5 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 2 | L2; L3 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_2 | LED_OR + ELECTRODE | IC | 1 | D7 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_3 | LED_YEL + ELECTRODE | IC | 1 | D8 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_I | LED_GRN + ELECTRODE | IC | 1 | D11 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_1 | LED2_ELECTRODE | IC | 1 | D12 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75080 | ORANGE | IC | 1 | D2 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | IC | 1 | D3 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-76537 | YEL/GRN | IC | 2 | D4; D5 |
LQFP144_0P5_20X20MM | K60_LQ_LQFP_144P_LQFP144_0P5_20 | PK60FN1M0VLQ12 | IC | 1 | U1 |
POT3_3352T | POT_POT3_3352T_DISCRETE_470-801 | 5K | DISCRETE | 1 | R52 |
QFN5X3_0P5_3X3 | MMA8451Q_16P_A_QFN5X3_0P5_3X3_I | MMA8451Q | IC | 1 | U5 |
QTLP610 | TRAN_PHOTO_QTLP610_IC_1.1MM_480 | QTLP610CPD | IC | 1 | Q1 |
RC0402_25 | RES_RC0402_25_470-80310_10K | 10k | IC | 2 | R13; R14 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7646 | 330 | DISCRETE | 1 | R15 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | 1.0K | DISCRETE | 5 | R16; R58; R64; R67; R77 |
RC0402_25 | RES_RC0402_25_DISCRETE__470-760 | 1.0K | DISCRETE | 1 | R17 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3078 | 270 | DISCRETE | 1 | R18 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3084 | 1.3K | DISCRETE | 2 | R38; R39 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3091 | 4.99K | DISCRETE | 1 | R40 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3128 | 10M | DISCRETE | 2 | R78; R133 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7835 | 2.2K | DISCRETE | 1 | R83 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3072 | 68 | DISCRETE | 1 | R94 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 4.7K | DISCRETE | 3 | R118; R128; R130 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | DISCRETE | 55 | R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R43; R44; R45; R46; R47; R48; R49; R50; R51; R57; R59; R60; R61; R62; R63; R65; R66; R68; R72; R85; R86; R87; R88; R91; R92; R93; R95; R96; R97; R98; R100; R101; R102; R103; R104; R105; R106; R107; R122; R123; R124; R125; R126; R132 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7538 | 33 | DISCRETE | 5 | R12; R22; R23; R41; R42 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | DISCRETE | 33 | R19; R20; R21; R24; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R53; R56; R69; R70; R71; R73; R74; R75; R76; R79; R80; R81; R82; R84; R89; R90; R313 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7543 | 4.70K | DISCRETE | 2 | R54; R55 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-8021 | 0 | DISCRETE | 1 | R99 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | DISCRETE | 3 | R25; R138; R139 |
SKT_BAT_780X1210 | BATTERY_SKT_3V_SKT_BAT_780X1210 | BK-883 | IC | 1 | BT1 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7 | MSS1P3L | IC | 1 | D10 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | IC | 1 | U2 |
SOIC14 | 74-125_14P_SOIC14_IC_1.75MM_312 | 74HCT125 | IC | 1 | U6 |
SOT23 | NPN_SOT23_IC_1.12 MM_480-75173_ | MMBT3904LT1G | IC | 1 | Q2 |
SOT223 | LT1129CST-3.3_SOT223_IC_1.8MM_3 | MIC2920A-3.3WS | IC | 1 | U3 |
SOT416 | TRAN_NPN_RES_SOT416_IC_0.95MM_4 | PDTC115T | IC | 1 | Q3 |
SOT-23 | BAT721B_SOT-23_IC_1.3MM_480-779 | BAT54C | IC | 2 | D6; D9 |
SOT_143 | SPB0503_SOT_143_IC_1.22MM_480-7 | SP0503B | IC | 1 | U7 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | PB switch | IC | 3 | SW1; SW2; SW3 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IC_4.8MM_210 | TEST POINT BLACK | IC | 2 | TP15; TP17 |
TPAD_040 | TESTLOOP_TPAD_040_IC_0.1MM_211- | TPAD_040 | IC | 16 | TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP12; TP13; TP14; TP16; TP18; TP19; TP21 |
TQFP44 | MC9S08JM60CFGE_TQFP44_IC_1.60 M | MC9S08JM60CLD | IC | 1 | U8 |
TSOP48_18P5X12P4 | MT29F2G16AADWP_TSOP48_18P5X12P4 | MT29F2G16ABAEAWP:E | IC | 1 | U14 |
TSSOP14 | 74LVC125_TSSOP14_IC_1.2MM_312-7 | 74LVC125 | IC | 1 | U9 |
TSSOP-14 | 74_04_TSSOP-14_IC_1.2MM_312-753 | SN74LVC04APWE4 | IC | 1 | U4 |
XTAL4_3P3X2P6_SM_FL | CRYSTAL_JXS63_XTAL4_3P3X2P6_SM_ | 12MHZ | IC | 1 | Y5 |
XTL2_ECS_CSM7_SM | XTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_ | 4MHz | IC | 1 | Y3 |
XTL2_ECS_SM | XTAL_XTL2_ECS_SM_IC_2.25MM_230- | 32.768KHz | IC | 1 | Y2 |
XTLOSC4_SM | CLKGEN-SM_XTLOSC4_SM_IC_1.75MM_ | 50MHZ | IC | 1 | Y1 |
