查看: 172|回复: 0
[allegro16.3][8层]TWR-K60D100M Kinetis K60 100 MHz MCU塔式系统模块(PK60DN512...
发表于 2020-2-14 13:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][8层]TWR-K60D100M Kinetis K60 100 MHz mcu塔式系统模块(PK60DN512VMD10+MC9S08JM60CLD+MMA8451Q)原理图和pcb文件3 p; N# ]8 t/ ^- G. W& R# F
5 V* r  ~$ n0 _) v( f9 q文件描述:5 L; s: i+ [6 n' Y, x/ D
9 y- f; }: N% b( O2 @) X1. 作品用途:TWR-K60D100M Kinetis K60 100 MHz MCU塔式系统模块4 M7 g( R" G* o
2. 软件版本:allegro16.3" o, w- J; d/ W& y6 o- b
3. 层数:8层
. ]  ]" d, k: }8 V: c7 M3 y4. 用到的主要芯片:PK60DN512VMD10+MC9S08JM60CLD+MMA8451Q
: R9 j, K5 q& m1 t& p% a5. pcb尺寸: 3543*3174 MIL
( d! I4 _9 M6 c: O$ u; O: z8 \% A+ s2 h8 V; X+ [6 |
作品截图如下:+ P5 p7 W7 j) [8 |7 l$ Q& {/ _
8 D* T8 m" w/ w- g/ U$ w/ R' R7 o顶层截图:
$ t) r& J/ Z" j
4 ^, N0 g( i2 o  k$ y6 K底层截图:4 r  f3 E9 X" c- [4 v
8 O- q+ i+ t+ ~% v! r! S
0 q' X3 @$ q  e- ^2 f全层截图:3 \, Z* ^9 X/ Z! {4 p
' V1 ~0 r7 M* z  c- U8 g5 G3 J
! E$ U, `  S! I! I" F叠层阻抗信息如下:
5 o4 c& a) Y3 Y$ x" ]
8 w: X3 i4 O, L3 H+ t) C5 q8 HBOM:
0 ?# `6 c- d8 R. D& h
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE1C1
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UFDISCRETE31C3; C4; C5; C9; C11; C12; C13; C14; C15; C16; C17; C18; C21; C22; C23; C24; C27; C29; C30; C32; C33; C34; C36; C37; C41; C42; C43; C44; C46; C47; C49
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE4C8; C10; C25; C31
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.01UFDISCRETE2C26; C28
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C40
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1000PFDISCRETE1C48
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE8C2; C6; C7; C35; C38; C39; C45; C50
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uFIC2C19; C20
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J11
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5IO1J17
CONN-MMC_SD_OPTMMC_SD_CONN_2405_CONN-MMC_SD_OPMMC-SD ConnectorIO1J20
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19PIO1J16
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO1J6
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10IO2J8; J9
DIODE_3P2X2P2LED_DIODE_3P2X2P2_IC_1.1MM_480-QTLP610CIRIC1D5
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO8J2; J3; J4; J5; J7; J14; J15; J19
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO3J1; J12; J13
HDR104_STAG_TSM_SMCONN_HDR_4X1_HDR104_STAG_TSM_SMHDR_4X1IO1J10
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_9HDR_2X3IO1J18
IND_0603BEAD_FERRITE_IND_0603_DISCRETE_120OHMDISCRETE1L1
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZIC5L2; L5; L6; L7; L8
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L3; L4
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_1LED_OR + ELECTRODEIC1D7
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_2LED_YEL + ELECTRODEIC1D8
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_3LED_GRN + ELECTRODEIC1D9
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_ILED2_ELECTRODEIC1D11
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWIC1D1
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRNIC2D2; D4
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGEIC1D3
MAPBGA144_1_13X13PK60DN512VMD10_BGA_144P_MAPBGA1PK60DN512VMD10IC1U2
POT3_3352TPOT_POT3_3352T_DISCRETE_470-8015KDISCRETE1R50
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451QIC1U1
QTLP610TRAN_PHOTO_QTLP610_IC_1.1MM_480QTLP610CPDIC1Q2
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0KDISCRETE6R1; R18; R58; R66; R70; R77
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE25R17; R19; R22; R26; R27; R28; R29; R30; R33; R34; R35; R36; R37; R38; R40; R41; R42; R51; R52; R53; R63; R65; R79; R80; R82
RC0402_25RES_RC0402_25_DISCRETE__470-7601.0KDISCRETE1R20
RC0402_25RES_RC0402_25_DISCRETE_470-7646330DISCRETE1R21
RC0402_25RES_RC0402_25_DISCRETE_470-3078270DISCRETE1R23
RC0402_25RES_RC0402_25_DISCRETE_470-757933DISCRETE5R25; R54; R55; R73; R76
RC0402_25RES_RC0402_25_DISCRETE_470-30851.54KDISCRETE1R64
RC0402_25RES_RC0402_25_DISCRETE_470-78352.2KDISCRETE1R72
RC0402_25RES_RC0402_25_DISCRETE_470-764810MDISCRETE1R75
RC0402_25RES_RC0402_25_DISCRETE_470-30914.99KDISCRETE1R81
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE28R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R31; R39; R43; R44; R45; R46; R47; R48; R49; R56; R62; R67; R71; R74; R78
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70KDISCRETE4R15; R16; R24; R57
RC0603_OVRES_RC0603_OV_DISCRETE_470-758262.0KDISCRETE1R32
RC0603_OVRES_RC0603_OV_DISCRETE_470-75841.0MDISCRETE1R60
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440DISCRETE4R59; R61; R68; R69
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883IC1BT1
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D10
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45IC4U3; U4; U8; U12
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U5
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q1
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U9
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8IC1U10
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54CIC1D6
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115TIC1Q3
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503BIC1U6
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW1; SW2; SW3
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8 MM_21TEST POINT WHITEIC21T1; TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP13; TP14; TP15; TP16; TP17; TP18; TP20; TP21; TP22
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_210TEST POINT BLACKIC2TP12; TP19
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60 MMC9S08JM60CLDIC1U11
TSSOP14SN74LVC126A_TSSOP14_TSSOP14_IC_SN74LVC126APWG4IC1U7
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHzIC1Y3
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHzIC1Y2
XTLOSC4_SMCLKGEN-SM_XTLOSC4_SM_IC_1.75MM_50MHZIC1Y1
附件:
- q! C( \8 z! a) B; a+ `  E- {5 u原理图和pcb文件如下:. a) X6 }% |) Y& w% H1 ^) c
游客,如果您要查看本帖隐藏内容请回复
2 n- `- f/ o( M: B) f% r/ N- _
GMT+8, 2025-7-24 10:18 , Processed in 0.125000 second(s), 28 queries , Gzip On.
