查看: 233|回复: 0
[allegro16.2][8层]TWR-K40X256 Kinetis K40塔式系统模块(MK40X256VMD100+SKT+MC9...
发表于 2020-2-14 12:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.2][8层]TWR-K40X256 Kinetis K40塔式系统模块(MK40X256VMD100+SKT+MC9S08JM60CLD+SN74LVC04APWE4)原理图和pcb文件
, F; W, z! w' `# }6 F( |5 a7 Y$ _1 N; g6 `, P/ J; C6 f8 U
文件描述:
8 u$ X1 b' F) O6 |. r8 L9 U. N: g8 {
1. 作品用途:TWR-K40X256 Kinetis K40塔式系统模块5 z& W/ Y( y+ z' D+ ~& l! I4 G
2. 软件版本:allegro16.22 R" ~, g% ?3 y4 x* p3 ?* T7 }
3. 层数:8层
4 J9 e% g' R2 D2 |1 i4. 用到的主要芯片:MK40X256VMD100+SKT+MC9S08JM60CLD+SN74LVC04APWE4
& X. R% {4 Y! X/ Z5. pcb尺寸: 3543*3174 MIL
$ a7 m3 }) n1 i/ M! G1 x1 A
. f% b; r( ]/ j; y5 N作品截图如下:
3 d6 y) c( k0 V/ {
. K; T% ~  B2 f4 L) v顶层截图:8 r6 p5 f  S9 }. x6 i
; [/ k5 U$ I5 M
底层截图:9 V. @0 I7 D; B$ A( @' H0 P
0 o  ]! l9 W6 c% n' m1 Z6 f9 R& s* J, O% c7 n4 _
全层截图:
* j9 S7 S7 [% [7 N4 L+ j2 n2 ^
+ z. p/ z6 w: m6 S* d, F8 F1 k/ v2 m5 J
叠层阻抗信息如下:  q0 l' F# P; I
8 a. r5 z$ l) w  v7 D" _! xBOM:# H% b% H- s+ n: @, W2 b1 T
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE32C3; C5; C6; C7; C8; C9; C10; C12; C13; C16; C21; C22; C23; C24; C25; C26; C27; C28; C29; C32; C33; C34; C36; C39; C40; C41; C44; C45; C46; C47; C48; C49
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C14
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE4C15; C18; C31; C37
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.871000PFDISCRETE1C17
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.01UFDISCRETE2C30; C35
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE6C11; C19; C20; C38; C42; C43
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uFIC1C4
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J10
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5IO1J16
CON_FTSH_20M_50_SMCONN_HDR_10X2_CON_FTSH_20M_50_SHDR_2X10IO1J14
CON_SDCARD_13F_SM_RA_511CONN_SDCARD_1X13_F_511_CON_SDCASD/MMC SKTIO1J18
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10IO1J7
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO2J8; J9
DFN_10_0P5_3X3AMMA7660FC_DFN_10_0P5_3X3A_IC_1MMMA7660FCIC1U8
DIODE_3P2X2P2LED_DIODE_3P2X2P2_IC_1.1MM_480-QTLP610CIRIC1D3
HDR2X4_TSM_SMCONN_HDR_4X2_HDR2X4_TSM_SM_IO_9HDR_2x4IO1J4
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO5J3; J6; J11; J13; J15
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3IO2J5; J12
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_9HDR_2X3IO1J17
IND_0603IND_IND_0603_0.8MM_180-75495_10100MHZIC5L3; L6; L7; L8; L9
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L4; L5
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_3LED_OR + ELECTRODEIC1D9
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_2LED_YEL + ELECTRODEIC1D10
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_1LED_GRN + ELECTRODEIC1D13
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_4LED2_ELECTRODEIC1D14
LED_0603_C1LED_LED_0603_C1_IC_0.8MM_370-_1ORANGEIC1D4
LED_0603_C1LED_LED_0603_C1_IC_0.8MM_370-75LED_YELLOWIC1D5
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-76YEL/GRNIC2D6; D7
POT3_3352TPOT_POT3_3352T_DISCRETE_470-8015KDISCRETE1R71
QTLP610TRAN_PHOTO_QTLP610_IC_1.1MM_480QTLP610CPDIC1Q3
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE30R22; R29; R30; R32; R33; R34; R35; R36; R38; R40; R41; R42; R43; R44; R45; R46; R77; R79; R101; R102; R103; R105; R106; R107; R109; R111; R112; R113; R114; R115
RC0402_25RES_RC0402_25_DISCRETE_470-757933DISCRETE5R23; R49; R50; R99; R100
RC0402_25RES_RC0402_25_DISCRETE_470-30851.54KDISCRETE1R24
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0KDISCRETE6R25; R27; R73; R76; R82; R92
RC0402_25RES_RC0402_25_DISCRETE_470-7646330DISCRETE1R26
RC0402_25RES_RC0402_25_DISCRETE__470-7601.0KDISCRETE1R28
RC0402_25RES_RC0402_25_DISCRETE_470-3078270DISCRETE1R31
RC0402_25RES_RC0402_25_DISCRETE_470-78352.2KDISCRETE2R39; R116
RC0402_25RES_RC0402_25_DISCRETE_470-75360DISCRETE2R47; R110
RC0402_25RES_RC0402_25_DISCRETE_470-30914.99KDISCRETE1R48
RC0402_25RES_RC0402_25_DISCRETE_470-764810MDISCRETE1R108
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE60R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R37; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R72; R74; R80; R89; R90; R96; R98; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70KDISCRETE2R75; R78
RC0603_OVRES_RC0603_OV_DISCRETE_470-75841.0MDISCRETE2R85; R94
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440DISCRETE11R81; R83; R84; R86; R87; R88; R91; R93; R95; R97; R104
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883IC1BT3
SKT_BGA144_1_18X18_CUSTOMMARCONI_SKT_BGA144_1_18X18_CUSTMK40X256VMD100+SKT 12X12 144BGAIC1U4
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D12
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U5
SOIC1474-125_14P_SOIC14_IC_1.75MM_31274HCT125IC1U9
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q4
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U6
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54CIC2D8; D11
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115TIC1Q5
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503BIC1U10
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW3; SW4; SW5
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO10TP3; TP4; TP5; TP6; TP7; TP8; TP10; TP11; TP12; TP14
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACKIO2TP9; TP13
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60 MMC9S08JM60CLDIC1U11
TSSOP1474LVC125_TSSOP14_IC_1.2MM_312-774LVC125IC1U12
TSSOP2074LVC573A_TSSOP20_IC_1.2MM_312-74LVC573AIC1U3
TSSOP-1474_04_TSSOP-14_IC_1.2MM_312-753SN74LVC04APWE4IC1U7
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC__8.00MHZIC1X3
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHzIC1Y4
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHzIC1Y3
附件:原理图和pcb文件如下:
% H2 `  P- G4 |# _5 g5 ^: k' e; G6 V
游客,如果您要查看本帖隐藏内容请回复
1 n9 P% N: d# h$ ?
5 _$ Q5 I. y1 U/ N+ }! w' A* b4 f( O
. [8 z5 a7 U$ G: o
- C6 J9 V4 I, ]3 n) Z
GMT+8, 2025-7-24 10:22 , Processed in 0.140625 second(s), 28 queries , Gzip On.
