Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0603LED | LED_0603LED_IC_0.8MM_370-76477_ | BLUE | IC | 1 | D9 |
BGA121_0P65_8X8MM | MK21FN1M0VMC10_121P_BGA121_0P65 | MK21FN1M0VMC10 | IC | 1 | U6 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | DISCRETE | 22 | C1; C6; C8; C10; C13; C15; C21; C200; C201; C203; C204; C206; C207; C209; C210; C211; C214; C215; C219; C220; C221; C222 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | DISCRETE | 4 | C2; C3; C212; C218 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1000PF | DISCRETE | 1 | C4 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | DISCRETE | 1 | C208 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | DISCRETE | 8 | C5; C19; C20; C202; C205; C213; C216; C217 |
CC3528-21 | CAP_POL_CC3528-21_DISCRETE_2.1M | 4.7uF | DISCRETE | 1 | C7 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J14 |
CON5_MICROUSB | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | IO | 1 | J19 |
CONN-MMC_SD_OPT | MMC_SD_CONN_2405_CONN-MMC_SD_OP | MMC-SD Connector | IO | 1 | P200 |
CON_FTSH_19M_50_SM | CONN_HDR_19_CON_FTSH_19M_50_SM_ | HDR_19P | IO | 1 | J1 |
CON_MICROUSBB_9F_0P65_SM_RA | MICRO_USB_CONN_9PIN_CON_MICROUS | 1050170001 | IO | 1 | J2 |
CON_SKT1X6_TH | CONN_HDR_6X1_CON_SKT1X6_TH_IO_8 | HDR 1X6 | IO | 1 | JP1 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M_50 | CON_2X10 | IO | 2 | J3; J4 |
HDR2X4_TSM_SM | CONN_HDR_4X2_HDR2X4_TSM_SM_IO_9 | HDR_2x4 | IO | 3 | J11; J15; J17 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | HDR 1X2 TH | IO | 8 | J6; J9; J10; J12; J16; J21; J22; J23 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.65MM_2 | HDR TH 1X3 | IO | 4 | J7; J8; J13; J24 |
HDR202_TSM_SM | CONN_HDR_2X2_HDR202_TSM_SM_IO_9 | HDR_2X2 | IO | 1 | J18 |
HDR203_TSM_SM | CONN_HDR_3X2_HDR203_TSM_SM_IO_9 | HDR_2X3 | IO | 1 | J5 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 4 | L1; L2; L3; L4 |
IND_1608 | IND_IND_1608_DISCRETE_0.95MM_18 | 100 OHM@100MHZ | DISCRETE | 2 | L200; L201 |
LED_0603 | LED_LED_0603_IC_1.0MM_370-76472 | YEL/GRN | IC | 3 | D1; D4; D5 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | IC | 2 | D2; D6 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75080 | ORANGE | IC | 2 | D7; D8 |
LQFP44 | MC9S08JM60CFGE_LQFP44_IC_1.60 M | MC9S08JM60CLD | IC | 1 | U200 |
POT3_3352T | POT_POT3_3352T_DISCRETE_4.32 MM | 5K | DISCRETE | 1 | R43 |
QFN5X3_0P5_3X3 | MMA8451Q_16P_A_QFN5X3_0P5_3X3_I | MMA8451Q | IC | 1 | U7 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 10.0K | DISCRETE | 27 | R9; R10; R11; R20; R36; R37; R46; R47; R50; R51; R53; R57; R58; R200; R201; R203; R205; R206; R215; R217; R219; R220; R221; R222; R223; R235; R236 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10M | DISCRETE | 1 | R14 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 MM_ | 4.99K | DISCRETE | 1 | R19 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 1.0K | DISCRETE | 4 | R40; R41; R45; R48 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_3 | 270 | DISCRETE | 2 | R42; R54 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 330 | DISCRETE | 2 | R49; R52 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 1.3K | DISCRETE | 1 | R202 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_2 | 18K | DISCRETE | 1 | R204 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 33 | DISCRETE | 4 | R213; R214; R224; R226 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 2.2K | DISCRETE | 1 | R218 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.6MM_47 | 0 | DISCRETE | 8 | R238; R239; R240; R241; R242; R243; R244; R245 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3045 | 100 | DISCRETE | 1 | R246 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 0 | DISCRETE | 23 | R1; R2; R3; R4; R5; R8; R12; R13; R21; R38; R39; R207; R208; R209; R210; R211; R212; R216; R229; R231; R232; R233; R234 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | 4.70K | DISCRETE | 3 | R6; R7; R44 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 1.0M | DISCRETE | 2 | R228; R230 |
SKT_BAT_780X1210 | BATTERY_SKT_3V_SKT_BAT_780X1210 | BK-883 | IC | 1 | BT200 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7 | MSS1P3L | IC | 1 | D3 |
SO6_A | 1T45_SO6_A_IC_1.1MM_312-75172_S | SN74LVC1T45 | IC | 3 | U4; U5; U201 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | IC | 2 | U202; U205 |
SOT23 | NPN_SOT23_IC_1.12 MM_480-75173_ | MMBT3904LT1G | IC | 1 | Q1 |
SOT223 | LT1129CST-3.3_SOT223_IC_1.8MM_3 | MIC2920A-3.3WS | IC | 1 | U203 |
SOT223 | MIC37139-1.8BS-1_SOT223_IC_1.8M | MIC5239-1.8 | IC | 1 | U204 |
SOT-23 | BAT721B_SOT-23_IC_1.3MM_480-779 | BAT54C | IC | 1 | D200 |
SOT-23 | TRAN_NPN_RES_SOT-23_IC_1.3MM_48 | PDTC115T | IC | 1 | Q200 |
SOT_143 | SPB0503_SOT_143_IC_1.22MM_480-7 | SP0503B | IC | 2 | U3; U8 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | PB switch | IC | 3 | SW1; SW2; SW3 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8 MM_21 | TEST POINT WHITE | IO | 9 | TP1; TP2; TP3; TP4; TP6; TP7; TP9; TP10; TP11 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_210 | TEST POINT BLACK | IO | 4 | TP5; TP8; TP12; TP13 |
TSM2X12_SMD | CONN_HDR_12X2_TSM2X12_SMD_IO_9. | HDR_2X12 | IO | 1 | J20 |
TSSOP14 | SN74LVC126A_TSSOP14_TSSOP14_IC_ | SN74LVC126APWG4 | IC | 1 | U2 |
UQFN10_0P4_1P45X1P85 | PI3USB102_UQFN_10P_UQFN10_0P4_1 | PI3USB102ZME | IC | 1 | U206 |
XTAL3_3P35X1P45_SM | XTAL_CS_XTAL3_3P35X1P45_SM_IC_0 | 8.00MHZ | IC | 1 | X200 |
XTL2_ECS_CSM7_SM | XTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_ | 4MHz | IC | 1 | Y2 |
XTL2_ECS_SM | XTAL_XTL2_ECS_SM_IC_2.25MM_230- | 32.768KHz | IC | 1 | Y200 |
