Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 2200PF | DISCRETE | 15 | C502; C504; C507; C512; C517; C518; C519; C521; C522; C523; C524; C525; C526; C527; C528 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | DISCRETE | 25 | C3; C4; C8; C500; C501; C503; C505; C509; C510; C513; C514; C515; C530; C532; C533; C535; C536; C537; C538; C539; C542; C543; C544; C546; C547 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | DISCRETE | 2 | C7; C9 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9 M | 2.2UF | DISCRETE | 3 | C508; C511; C545 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1000PF | DISCRETE | 1 | C534 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | DISCRETE | 7 | C1; C2; C506; C516; C520; C540; C541 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4 M | 22PF | DISCRETE | 2 | C5; C6 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.473 | 0.47UF | DISCRETE | 2 | C529; C531 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J500 |
CON5_MUSB_AB_0P8_RA_SMT | USB_MINI_B_SKT_CON5_MUSB_AB_0P8 | USB_MINI_B 5 | IO | 1 | J18 |
CON213_SSM | HDR_13X2_CON213_SSM_IO_7.8MM_21 | CON2X13 | IO | 1 | J502 |
CON220_SSM_MIRRORED_ANYT | CONN_HDR_20X2_CON220_SSM_MIRROR | HDR_2X20 | IO | 1 | J501 |
FUSE_SMD050 | FUSE_RESETTABLE_FUSE_SMD050_IC_ | 1A | IC | 1 | F1 |
HDR2X4_TSM_SM | CONN_HDR_4X2_HDR2X4_TSM_SM_IO_1 | HDR 2X4 | IO | 1 | J21 |
HDR5X2 | CONN_HDR_5X2_HDR5X2_IO_10.51MM_ | HDR 2X5 | IO | 1 | J13 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | HDR 1X2 TH | IO | 4 | J12; J15; J17; J20 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.65MM_2 | HDR TH 1X3 | IO | 4 | J4; J5; J7; J11 |
HDR105_STAG_TSM_SM | 1X5HEADER_HDR105_STAG_TSM_SM_IO | HDR_1X5 | IO | 2 | J8; J9 |
HDR203_TSM_SM | CONN_HDR_3X2_HDR203_TSM_SM_IO_1 | HDR_2X3 | IO | 1 | J22 |
HDR207_TSM_SM | CONN_HDR_7X2_HDR207_TSM_SM_IO_1 | HDR_2X7 | IO | 1 | J14 |
HDR_1X1 | CONN_HDR_1X1_TH_HDR_1X1_IO_8.89 | HDR_1X1 | IO | 2 | J6; J10 |
HDR_2X2_100_SM_5X5 | CONN_HDR_2X2_HDR_2X2_100_SM_5X5 | HDR 2X2 | IO | 5 | J1; J2; J16; J19; J23 |
IND_0603 | INDUCTOR_IND_0603_DISCRETE_0.95 | 600OHM | DISCRETE | 2 | L500; L501 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 2 | L1; L2 |
LED_0603 | LED_LED_0603_IC_1.0MM_370-76472 | YEL/GRN | IC | 6 | D1; D3; D5; D7; D10; D12 |
LED_0603 | LED_LED_0603_IC_1.0MM_370-76471 | YEL | IC | 5 | D2; D4; D6; D8; D13 |
LED_0603 | LED_LED_0603_IC_1.0MM_370-76470 | AMB | IC | 1 | D9 |
LQFP100_0P5_14X14 | MC56F8400_LQFP_100P_LQFP100_0P5 | MC56F8400 | IC | 1 | U2 |
MIC_RF_4P82X3P76 | MINI_MIC_RF_MIC_RF_4P82X3P76_IC | SPM0408HE5H-SB | IC | 1 | U4 |
RAPC722 | DC_POWER_JACK_3_RAPC722_IO_11.0 | CON_1_PWR | IO | 1 | J3 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3078 | 270 | DISCRETE | 1 | R1 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | DISCRETE | 15 | R2; R3; R8; R9; R11; R12; R13; R14; R15; R554; R555; R561; R570; R574; R575 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7648 | 10M | DISCRETE | 1 | R16 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7646 | 330 | DISCRETE | 9 | R500; R501; R502; R503; R504; R507; R556; R558; R559 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3108 | 158K | DISCRETE | 2 | R505; R506 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3091 | 4.99K | DISCRETE | 6 | R508; R509; R562; R569; R571; R576 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3045 | 100 | DISCRETE | 41 | R510; R511; R512; R513; R514; R515; R516; R517; R518; R519; R520; R521; R522; R523; R524; R525; R526; R529; R530; R531; R532; R533; R534; R535; R536; R537; R538; R540; R541; R542; R543; R544; R545; R546; R547; R548; R549; R550; R551; R552; R553 |
RC0402_25 | RES_RC0402_25_DISCRETE__470-760 | 1.0K | DISCRETE | 3 | R527; R528; R563 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | 1.0K | DISCRETE | 2 | R557; R564 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3014 | 120 | DISCRETE | 1 | R560 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7835 | 2.2K | DISCRETE | 1 | R565 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7623 | 53.6K | DISCRETE | 2 | R566; R567 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | DISCRETE | 2 | R572; R573 |
RC0603_OV | THERMISTOR_RC0603_OV_DISCRETE_4 | 10K | DISCRETE | 4 | RT1; RT2; RT3; RT4 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | DISCRETE | 5 | R4; R5; R7; R10; R568 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7595 | 1.0M | DISCRETE | 1 | R6 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7545 | 100 | DISCRETE | 1 | R539 |
SKT_100_LQFP_0P5_33P6X33P6 | MC56F8400_LQFP_100P_SKT_100_LQF | MC56F8400 + IC500-1004-004P | IC | 1 | U3 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | IC | 1 | U501 |
SO8 | PCA82C250A_SO8_IC_1.75MM_315-30 | PCA82C250TD | IC | 1 | U503 |
SOD-123 | DIODE_TVS_SOD-123_IC_1MM_480-78 | SMF12AT1G | IC | 1 | D11 |
SOD-123 | DIODE_SCHTKY_SOD-123_IC_1 MM_48 | MBR130LSFT1G | IC | 1 | D500 |
SOIC14 | 74-125_14P_SOIC14_IC_1.75MM_312 | 74HCT125 | IC | 1 | U504 |
SOT23 | NPN_SOT23_IC_1.12 MM_480-75173_ | MMBT3904LT1G | IC | 1 | Q1 |
SOT223 | LT1129CST-3.3_SOT223_IC_1.8MM_3 | 3.3V | IC | 1 | U1 |
SOT-23 | BAT721B_SOT-23_IC_1.3MM_480-779 | BAT54C | IC | 1 | D501 |
SOT_143 | SPB0503_SOT_143_IC_1.22MM_480-7 | SP0503B | IC | 1 | U5 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | PB switch | IC | 3 | SW1; SW2; SW3 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_210 | TEST POINT BLACK | IO | 8 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8 |
TQFP44 | MC9S08JM60CFGE_TQFP44_IC_1.60 M | MC9S08JM60CLD | IC | 1 | U6 |
TSM116-01-DV | CONN_HDR_16X2_TSM116-01-DV_IO_9 | HDR_2X16 | IO | 1 | J503 |
TSSOP14 | 74LVC125_TSSOP14_IC_1.2MM_312-7 | 74LVC125 | IC | 1 | U505 |
TSSOP-14 | 74_04_TSSOP-14_IC_1.2MM_312-753 | SN74LVC04APWE4 | IC | 2 | U500; U502 |
XTL2_237X79_CSM | XTAL_XTL2_237X79_CSM_IC_4.3MM_2 | 8MHz | IC | 1 | Y1 |
XTL2_ECS_CSM7_SM | XTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_ | 4MHz | IC | 1 | Y2 |
