Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 15PF | DISCRETE | 4 | C11; C13; C25; C29 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56M | 0.01UF | DISCRETE | 2 | C19; C22 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | DISCRETE | 24 | C1; C4; C5; C7; C8; C9; C15; C17; C18; C20; C21; C26; C27; C28; C30; C502; C504; C505; C507; C508; C509; C510; C511; C517 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | DISCRETE | 7 | C10; C12; C23; C24; C501; C515; C516 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | DISCRETE | 1 | C16 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 4.7uF | DISCRETE | 1 | C503 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 0.1UF | DISCRETE | 1 | C506 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.473 | 0.47UF | DISCRETE | 2 | C6; C500 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | DISCRETE | 7 | C14; C31; C513; C514; C518; C520; C521 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_0.94M | 1000pF | DISCRETE | 1 | C519 |
CC3216 | CAP_POL_CC3216_DISCRETE_1.8MM_1 | 2.2UF | DISCRETE | 2 | C2; C3 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J14 |
CON5_MICROUSB | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | IO | 1 | J31 |
CON_FTSH_19M_50_SM | CONN_HDR_19_CON_FTSH_19M_50_SM_ | HDR_19P | IO | 1 | J22 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M_50 | CON_2X10 | IO | 2 | J3; J10 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M__1 | CON_2X10 | IO | 1 | J5 |
CON_USB_5_548190572 | USB_MINI_B_SKT_CON_USB_5_548190 | CONN USB MINI-B 1x5 | IO | 1 | J12 |
DIODE_3P2X2P2 | LED_DIODE_3P2X2P2_IC_1.10 MM_37 | IR12-21C/TR8 | IC | 1 | D503 |
HDR1X1_2P34X2P54_TH | CONN_HDR_1X1_HDR1X1_2P34X2P54_T | HDR_1X1_TH | IO | 4 | JP1; JP2; JP3; JP4 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | HDR 1X2 TH | IO | 22 | J1; J4; J6; J7; J9; J11; J13; J15; J16; J17; J18; J19; J20; J21; J23; J24; J25; J26; J32; J34; J35; J36 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.65MM_2 | HDR TH 1X3 | IO | 1 | J28 |
HDR203_TSM_SM | CONN_HDR_3X2_HDR203_TSM_SM_IO_9 | HDR_2X3 | IO | 1 | J27 |
HDR204_TSM_SM | CONN_HDR_4X2_HDR204_TSM_SM_IO_9 | HDR_2X4 | IO | 2 | J29; J30 |
HDR205_SM | CONN_HDR_5X2_HDR205_SM_IO_9.65 | HDR_2X5 | IO | 1 | J2 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100 OHM@100MHZ | IC | 5 | L3; L4; L5; L6; L7 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 4 | L1; L2; L8; L9 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_I | LED_YEL + ELECTRODE | IC | 1 | D501 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_1 | LED_OR + ELECTRODE | IC | 1 | D502 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75080 | ORANGE | IC | 1 | D1 |
LED_0603 | LED_LED_0603_IC_0.67MM_370-7656 | LED GREEN | IC | 1 | D2 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75083 | LED RED | IC | 1 | D3 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-76537 | YEL/GRN | IC | 2 | D6; D8 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | IC | 1 | D7 |
LQFP64_0P5_10X10 | MK20DX64VLH5_LQFP_64P_LQFP64_0P | MK20DX128VLH5(R) | IC | 1 | U5 |
MIC_RF_4P82X3P76 | MINI_MIC_RF_MIC_RF_4P82X3P76_IC | SPM0408HE5H-SB | IC | 1 | U2 |
PHTRANS_2P2X3P2 | PT12_PHTRANS_2P_PHTRANS_2P2X3P2 | PT12-21C/TR8 | IC | 1 | Q500 |
POT3_3352T | POT_POT3_3352T_DISCRETE_4.32 MM | 5K | DISCRETE | 1 | R532 |
QFN5X3_0P5_3X3 | MMA8451Q_16P_A_QFN5X3_0P5_3X3_I | MMA8451Q | IC | 1 | U500 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | DISCRETE | 80 | R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R51; R55; R57; R58; R60; R65; R75; R78; R500; R501; R502; R503; R504; R505; R506; R507; R508; R509; R510; R511; R512; R513; R514; R515; R516; R517; R518; R519; R520; R521; R522; R523; R524; R525; R526; R527; R528; R529; R530; R531; R550; R558 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 10.0K | DISCRETE | 31 | R41; R42; R46; R47; R49; R50; R52; R54; R56; R63; R68; R69; R71; R73; R76; R77; R533; R535; R538; R539; R540; R541; R543; R544; R546; R547; R548; R549; R552; R553; R556 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 330 | DISCRETE | 1 | R43 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 1.0K | DISCRETE | 7 | R45; R48; R64; R66; R534; R536; R542 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 2.2K | DISCRETE | 1 | R59 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_2 | 4.99K | DISCRETE | 1 | R67 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_3 | 5.1K | DISCRETE | 1 | R72 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 MM_ | 1.54K | DISCRETE | 1 | R545 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 10M | DISCRETE | 1 | R554 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | 4.70K | DISCRETE | 2 | R39; R44 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 1.0M | DISCRETE | 2 | R53; R70 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_1 | 33 | DISCRETE | 5 | R61; R62; R537; R555; R557 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_4 | 100 | DISCRETE | 1 | R40 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.65 MM_ | 270 | DISCRETE | 1 | R74 |
SKT_BAT_780X1210 | BATTERY_SKT_3V_SKT_BAT_780X1210 | BK-883 | IC | 1 | BT500 |
SKT_QFP64_0P5_29P9_29P9 | MK20DX64VLH5_LQFP_64P_SKT_QFP64 | MK20DX128VLH5R + IC500-0644-008P | IC | 1 | U6 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7 | MSS1P3L | IC | 1 | D5 |
SO6_A | 1T45_SO6_A_IC_1.1MM_312-75172_S | SN74LVC1T45 | IC | 3 | U12; U13; U14 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | IC | 2 | U4; U10 |
SOT23 | NPN_SOT23_IC_1.12 MM_480-75173_ | MMBT3904LT1G | IC | 1 | Q1 |
SOT223 | LT1129CST-3.3_SOT223_IC_1.8MM_3 | MIC2920A-3.3WS | IC | 1 | U503 |
SOT223 | MIC37139-1.8BS-1_SOT223_IC_1.8M | MIC5239-1.8 | IC | 1 | U504 |
SOT416 | TRAN_NPN_RES_SOT416_IC_0.95MM_4 | PDTC115T | IC | 1 | Q2 |
SOT-23 | BAT721B_SOT-23_IC_1.3MM_480-779 | BAT54C | IC | 2 | D4; D500 |
SOT-23-5 | NC7SZ14_SOT-23-5_IC_1.45MM_312- | SN74LVC1G04 | IC | 2 | U8; U11 |
SOT_143 | SPB0503_SOT_143_IC_1.22MM_480-7 | SP0503B | IC | 2 | U3; U9 |
SPEAKER_12X12MM | SPEAKER_SPEAKER_12X12MM_IC_3.0M | PKLCS1212E4001 | IC | 1 | LS500 |
SW_TACT_SKQY | SW2_STM151_SW_TACT_SKQY_IC_2.5M | SW_MOM | IC | 3 | SW1; SW2; SW3 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8 MM_21 | TEST POINT WHITE | IO | 10 | TP1; TP4; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP14 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IC_4.8 MM_21 | TEST POINT WHITE | IC | 2 | TP5; TP13 |
TPAD_040 | TESTLOOP_TPAD_040_IC_0.1MM_211- | TPAD_040 | IC | 2 | TP2; TP3 |
TQFP44 | MC9S08JM60CFGE_TQFP44_IC_1.60 M | MC9S08JM60CLD | IC | 1 | U502 |
TSSOP14 | 74LVC125_TSSOP14_IC_1.2MM_312-7 | 74LVC125 | IC | 1 | U7 |
TSSOP20 | 74LVC573A_TSSOP20_IC_1.2MM_312- | 74LVC573A | IC | 1 | U1 |
XTAL3_3P35X1P45_SM | XTAL_CS_XTAL3_3P35X1P45_SM_IC_0 | 8.00MHZ | IC | 1 | X1 |
XTL2_ECS_CSM7_SM | XTAL_XTL2_ECS_CSM7_SM_IC_2.6MM_ | 4MHz | IC | 1 | Y500 |
XTL2_ECS_SM | XTAL_XTL2_ECS_SM_IC_2.25MM_230- | 32.768KHz | IC | 1 | Y1 |
