Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CASE403A_03 | ZDIODE_CASE403A_03_IC_2.56 MM_4 | 1SMB5919BT3G | IC | 1 | D50 |
CASE_D_AL | CAP_POL_CASE_D_AL_DISCRETE_8MM_ | 47UF | DISCRETE | 2 | C26; C27 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | DISCRETE | 12 | C5; C7; C11; C12; C14; C15; C16; C18; C51; C53; C54; C56 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 1.0UF | DISCRETE | 8 | C9; C13; C17; C50; C52; C55; C57; C60 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | DISCRETE | 4 | C19; C20; C21; C22 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.59M | 18PF | DISCRETE | 2 | C23; C29 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | DISCRETE | 6 | C24; C25; C65; C66; C67; C68 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | DISCRETE | 2 | C58; C59 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 4700PF | DISCRETE | 4 | C6; C8; C28; C30 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | DISCRETE | 2 | C61; C75 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 2.2UF | DISCRETE | 1 | C10 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.27M | 10.0uF | DISCRETE | 2 | C70; C71 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J5 |
CON1X3_3P81_9P2X12P82 | CONN_HDR_3X1_CON1X3_3P81_9P2X12 | PLUG_1X3 | IO | 2 | J10; J24 |
CON5_TH_1436686 | CON5_DIN_CON5_TH_1436686_IO_15. | 1436686 | IO | 2 | J12; J25 |
CON5_USB_RA_SMT | USB_MINI_AB_RECEPTACLE_CON5_USB | CONN USB MINI-B | IO | 1 | J52 |
FUSE_2X1P4 | FUSE_FUSE_2X1P4_IC_0.55 MM_510- | MFU0805FF00500P100 | IC | 1 | F50 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.58MM_2 | HDR 1X2 | IO | 4 | J18; J19; J20; J21 |
HDR106_TH_TSW | CONN_HDR_6X1_HDR106_TH_TSW_IO_8 | HDR 1X6 | IO | 1 | JP6 |
HDR203 | CONN_HDR_3X2_HDR203_IO_8.5MM_21 | HDR 2X3 | IO | 5 | J6; J7; J8; J13; J14 |
HDR_5X2_FTSH_TH | CONN_HDR_5X2_HDR_5X2_FTSH_TH_IO | HDR 2X5 | IO | 2 | J15; J53 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 2 | L50; L51 |
LED2_2P1X1P5_NSP | LED_LED2_2P1X1P5_NSP_IC_1.4 MM_ | LED/GRN | IC | 7 | D5; D6; D7; D13; D14; D15; D16 |
PJ-102AH | DC POWER JACK_PJ-102AH_IO_11MM_ | CON_1_PWR | IO | 1 | J17 |
QFN32_S142EP | KL17Z64VF_QFN_32P_EP_QFN32_S142 | MKL17Z64VFM4 | IC | 1 | U5 |
QFN48_0P5_7X7_EP3P9_NSP | MC34CM3120_48P_QFN48_0P5_7X7_EP | MC34CM3120EP | IC | 2 | U8; U9 |
QFN_48_0P5_7X7 | MKL25Z128VFT4_49P_QFN_48_0P5_7X | MKL25Z128VFT4 | IC | 1 | U50 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | DISCRETE | 2 | R51; R53 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 2.2K | DISCRETE | 2 | R59; R60 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 33 | DISCRETE | 2 | R63; R64 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 0 | DISCRETE | 17 | R7; R8; R9; R10; R11; R13; R14; R17; R20; R25; R31; R32; R33; R35; R44; R48; R68 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__1 | 560 | DISCRETE | 6 | R19; R23; R36; R37; R38; R39 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | 3.83K | DISCRETE | 1 | R21 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 10K | DISCRETE | 4 | R26; R30; R34; R52 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_1 | 2.2K | DISCRETE | 3 | R54; R57; R61 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__2 | 3.3K | DISCRETE | 1 | R65 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_3 | 33.0K | DISCRETE | 1 | R66 |
RC1206_OV | RES_RC1206_OV_DISCRETE_0.65MM_4 | 0.5 | DISCRETE | 4 | R40; R41; R42; R43 |
SMC_CASE403 | DIODE_SCHTKY_SMC_CASE403_IC_2.6 | B560C-13-F | IC | 1 | D12 |
SOD123W | DIODE_TVS_SOD123W_IC_1.1MM_480- | PTVS33VS1UR | IC | 8 | D8; D9; D10; D11; D17; D18; D19; D20 |
SOT23-40X40 | NPN_SOT23-40X40_IC_1.1MM_480-78 | BC847C | IC | 1 | Q50 |
SOT23_A | DIODE_2LINE_ESD_SOT23_A_IC_1.15 | GSOT05C-GS08 | IC | 1 | U7 |
SOT223 | LD1117AS18_SOT223_IC_1.8MM_312- | NCP1117ST33T3G | IC | 1 | U51 |
SOT1220 | PMPB85ENEA_SOT1220_8P_SOT1220_I | PMPB85ENEAX | IC | 4 | Q5; Q6; Q7; Q8 |
SW2_SPST_3P5X6P0_5P0 | SW2P_SW2_SPST_3P5X6P0_5P0_IC_5. | EVQ-PE105K | IC | 1 | SW5 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | IO | 44 | TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP14; TP15; TP17; TP18; TP19; TP20; TP21; TP22; TP57; TP58; TP64; TP66; TP67; TP68; TP69; TP70; TP71; TP72; TP73; TP74; TP75; TP76; TP77; TP78; TP79; TP80; TP81; TP82; TP83; TP84; TP85; TP86; TP87; TP88; TP89; TP90 |
TP_TH_063 | TESTLOOP_TP_TH_063_IO_8.13MM_21 | TESTLOOP_BLACK | IO | 1 | TP13 |
TP_TH_063 | TESTLOOP_TP_TH_063_IO_8.13MM__1 | TESTLOOP_RED | IO | 1 | TP16 |
TSSOP8 | ATMEL_SERIAL_EEPROM_64K-1_TSSOP | 24FC256 | IC | 1 | U6 |
WLCSP4_0P4_0P8X0P8_SMDP | ADP172_CSP_4P_WLCSP4_0P4_0P8X0P | NX3P190UK | IC | 2 | U52; U53 |
XTAL_4_7X5 | XTAL_13Y_XTAL_4_7X5_IC_1.2MM_23 | 14.7456MHZ | IC | 1 | Y5 |
XTLOSC4_5X3MM_SM | CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_ | 8MHZ | IC | 1 | Y50 |
附件:
