Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CASE457_04 | DIODE_SCHTKY_CASE457_04_IC_1.15 | MBRM120LT | IC | 2 | D3; D4 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 100PF | DISCRETE | 2 | C5; C41 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_.55MM | 27PF | DISCRETE | 4 | C32; C34; C43; C45 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.9652MM | 0.1UF | DISCRETE | 4 | C12; C14; C17; C23 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.1UF | DISCRETE | 8 | C1; C2; C3; C11; C13; C28; C33; C39 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_3 | 0.33UF | DISCRETE | 1 | C7 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_2 | 1.0UF | DISCRETE | 2 | C8; C27 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.95M | 150PF | DISCRETE | 1 | C15 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1000PF | DISCRETE | 17 | C20; C24; C25; C30; C31; C37; C38; C40; C47; C48; C49; C50; C51; C52; C53; C54; C55 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 0.01uF | DISCRETE | 1 | C22 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.27MM_1 | 4.7uF | DISCRETE | 2 | C16; C18 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 1.0uF | DISCRETE | 6 | C21; C35; C36; C42; C44; C46 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.27M | 4.7uF | DISCRETE | 1 | C29 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8MM | 10UF | DISCRETE | 4 | C4; C6; C10; C26 |
CCE63X55 | CAP_POL_CCE63X55_DISCRETE_5.5MM | 100uF | DISCRETE | 1 | C9 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J35 |
CON5_MUSB_B_0P8 | CON_MUSB_5P_CON5_MUSB_B_0P8_IO_ | USB TYPE B | IO | 1 | J33 |
CON_8F_100_TH | CONN_HDR_8X1_CON_8F_100_TH_IO_8 | 92816F08005-LF | IO | 1 | J17 |
CON_10F_2P54MM_TH | HDR-1X10_CON_10F_2P54MM_TH_IO_8 | TB 1x10 | IO | 1 | J18 |
DFN_10_0P5_3X3 | LT3471EDD_DFN_10P_DFN_10_0P5_3X | LT3471EDD | IC | 1 | U10 |
HDR102_TMM | CONN_HDR_2X1_HDR102_TMM_IO_5.2M | HDR 1X2 | IO | 7 | J24; J28; J29; J30; J31; J32; J37 |
HDR103_78MIL | CONN_HDR_3X1_HDR103_78MIL_IO_5. | HDR_1X3 | IO | 18 | J1; J2; J3; J4; J5; J6; J7; J8; J9; J10; J11; J12; J13; J14; J15; J16; J25; J34 |
HDR110 | HDR-1X10_HDR110_IO_8.38MM_210-7 | HDR 1X10 | IO | 1 | J38 |
HDR_2X7_M_2MM_TH | CONN_SHRHDR_7X2_HDR_2X7_M_2MM_T | HDR 2X7 | IO | 4 | J19; J20; J21; J22 |
HDR_12_6P75X31MM | RCPT_1X12_HDR_12_6P75X31MM_IO_8 | 92816F12005-LF | IO | 2 | J26; J27 |
IND_1206A | BEAD_IND_1206A_DISCRETE_1.3MM_1 | 26OHM | DISCRETE | 9 | L1; L2; L3; L4; L5; L7; L8; L9; L12 |
IND_NR4012 | INDUCTOR_IND_NR4012_DISCRETE_1. | 15uH | DISCRETE | 2 | L10; L11 |
IND_NR4018_4X4 | INDUCTOR_IND_NR4018_4X4_DISCRET | 10UH | DISCRETE | 1 | L6 |
LED_0603_C1 | LED_LED_0603_C1_IC_1.0MM_370-76 | YEL/GRN | IC | 1 | D1 |
MSOP_8P_0P65_3X3MM | LTC6655_MSOP_8P_MSOP_8P_0P65_3X | LTC6655BHMS8-5 | IC | 1 | U1 |
QFN38_0P5_5X7MM | LTC2498CUHF_QFN_38P_QFN38_0P5_5 | LTC2498CUHF | IC | 1 | U4 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3104 | 69.8K | DISCRETE | 1 | R5 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3091 | 4.99K | DISCRETE | 1 | R6 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7536 | 0 | DISCRETE | 6 | R15; R17; R22; R23; R24; R25 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3096 | 15K | DISCRETE | 1 | R18 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3109 | 226K | DISCRETE | 1 | R19 |
RC0603 | RES_RC0603_DISCRETE_470-75410_1 | 10K | DISCRETE | 3 | R3; R20; R21 |
RC0603 | RES_RC0603_DISCRETE_470-79779_7 | 7.5K | DISCRETE | 1 | R16 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7603 | 1K | DISCRETE | 1 | R1 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 1K | DISCRETE | 4 | R4; R12; R13; R14 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 4.7K | DISCRETE | 1 | R9 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7634 | 2K | DISCRETE | 1 | R2 |
SOD123 | ZDIODE_SOD123_IC_1.35MM_480-781 | MMSZ4689 | IC | 1 | D2 |
SO_8_1P27_4X5 | LT1236ACS8-5_SO_8P_SO_8_1P27_4X | LT1236ACS8-5 | IC | 1 | U5 |
SSOP16_5X4MM | LTC2600CGN_SSOP_16P_SSOP16_5X4M | LTC2600CGN | IC | 1 | U3 |
SSOP28_B | LTC1859CG_SSOP_28P_SSOP28_B_IC_ | LTC1859CG | IC | 1 | U6 |
SSOP44 | LTC2704CGW_SSOP_44P_SSOP44_IC_2 | LTC2704CGW | IC | 1 | U7 |
TP_TH_040 | TESTLOOP_TP_TH_040_IO_5.1MM_210 | GROUND PIN/LOOP | IO | 16 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP26 |
TSSOP16 | MC74HC138AD_TSSOP16_IC_1.2MM_31 | MC74HC138AD | IC | 1 | U9 |
TSSOP_24_0P65_8X4 | 74LVXC3245_TSSOP_24_0P65_8X4_IC | 74LVXC3245MTC | IC | 1 | U8 |
附件:
