查看: 658|回复: 6
[allegro16.2][10层]TI8168核心板(NETRA_3+TPS56628+4片DDR)pcb文件
发表于 2020-2-13 16:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.2][10层]TI8168核心板(NETRA_3+TPS56628+4片DDR)pcb文件; E0 {7 y! p- Y, B+ ?2 @) C
2 ~$ D7 ~' X% H  k/ q" Y5 z文件描述:3 u' J* x# o$ w5 a- M
% ]( a$ C# m& D* i1. 作品用途:TI8168核心板
9 {6 b. e* y: Q& ~( n2. 软件版本:allegro16.2& `0 B  A8 `+ o9 Z! e4 ]
3. 层数:10层
9 C$ c- K3 S7 T8 O* [( K4. 用到的主要芯片:NETRA_3+TPS56628+4片DDR
7 P9 t& o9 T8 T. z5. pcb尺寸: 3385.827*3149.607 Mil
9 m; T+ t2 r, C. i. c
, n. t5 y$ |3 h7 {$ Z作品截图如下:
1 e4 n3 v6 m6 K, C+ Z
# N! E" O% X: H, w顶层截图:2 d. o2 |, f1 P3 J8 d
2 r$ f+ T* Z, I6 Z
底层截图:2 P8 v% e) O8 B2 |9 D. O5 i
1 H& h4 W; O% ~
3 Y: H) M1 w( \: Z% q2 v7 q& S6 p全层截图:& K! M! [( r$ Q, X. a- p9 o) G
! V9 P$ @) R8 j# U. P* e3 x# V+ h2 Y2 @
BOM:7 B. B' {; b: _: e, _
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
C0402CAP NP_C0402_0.1UF0.1uFIC140C1; C149; C157; C166; C172; C174; C176; C177; C185; C187; C189; C190; C192; C193; C196; C197; C198; C199; C200; C202; C205; C206; C207; C208; C210; C211; C212; C215; C216; C339; C340; C341; C342; C343; C344; C345; C346; C347; C352; C354; C355; C357; C358; C359; C360; C361; C362; C363; C364; C365; C366; C367; C368; C369; C370; C371; C372; C373; C374; C375; C376; C377; C378; C379; C380; C381; C382; C383; C384; C385; C386; C387; C388; C389; C390; C391; C392; C393; C396; C399; C400; C401; C402; C403; C404; C405; C406; C407; C408; C409; C410; C411; C412; C415; C416; C417; C418; C419; C420; C421; C422; C423; C424; C425; C426; C427; C428; C431; C432; C433; C434; C435; C436; C437; C438; C439; C440; C441; C442; C443; C444; C447; C448; C449; C451; C457; C462; C463; C466; C473; C477; C483; C485; C489; C491; C492; C493; C512; C513; C515
C0402CAP .1 UF 10% 0603_C0402_0.1UF0.1uFIC7C2; C160; C161; C162; C163; C353; C356
C0402SC10N16V2KX_0_C0402_0.1UF0.1uFIC1C4
C0402SC10N16V2KX_11_C0402_0.1UF0.1uFIC2C5; C6
C0402CAPACITOR NON-POL_C0402_0.1UF0.1uFIC84C8; C9; C10; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C182
C0402CAP NP_0_C0402_0.1UF0.1uFIC54C11; C12; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C68; C73; C74; C75; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C151; C152; C153; C298; C299; C300; C308; C309; C310; C311; C333
C0402CAP_C0402_0.1UF0.1uFIC14C67; C69; C70; C71; C72; C150; C329; C330; C331; C332; C348; C349; C350; C351
C0402CAP NP_3_C0402_0.1UF0.1uFIC1C148
C0402CAP NP_C0402_0.01UF0.01uFIC15C158; C159; C164; C165; C167; C168; C195; C203; C213; C456; C460; C488; C490; C498; C499
C0402CAP NP_C0402_0.001UF0.001uFIC7C173; C194; C201; C204; C209; C214; C508
C0402CAP NP_1_C0402_0.1UF0.1uFIC4C178; C179; C180; C181
C0402CAP NP_2_C0402_0.22UF0.22uFIC1C183
C0402CAP NP_3_C0402_18 PF18 pFIC2C186; C191
C0402NPCAP_0_C0402_0.1UF0.1uFIC100C218; C219; C220; C221; C222; C223; C224; C225; C226; C227; C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C239; C240; C241; C242; C243; C244; C245; C246; C247; C248; C249; C250; C251; C252; C253; C254; C255; C256; C257; C259; C261; C262; C263; C264; C265; C266; C267; C268; C269; C270; C271; C272; C273; C274; C275; C276; C277; C278; C279; C280; C282; C284; C285; C286; C287; C288; C289; C290; C291; C292; C293; C296; C297; C301; C302; C303; C304; C305; C306; C312; C313; C314; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C325; C326; C328; C334; C335; C336; C337; C338
C0402CAP NP_C0402_4.7NF4.7nFIC3C450; C501; C502
C0402CAP NP_C0402_NCNCIC3C453; C503; C504
C0402CAP NP_C0402_150PF150pFIC2C464; C496
C0402CAP NP_C0402_0.047UF/50V0.047uF/50VIC3C475; C480; C481
C0402CAP NP_C0402_1000PF1000pFIC1C509
C0402CAP NP_C0402_10PF10pFIC1C514
C0603CAP NP_C0603_1UF1uFIC7C3; C7; C156; C169; C459; C474; C500
C0603CAP_C0603_1UF1uFIC5C147; C170; C171; C184; C188
C0805CAP NP_C0805_10UF10uFIC16C13; C24; C35; C46; C76; C97; C98; C109; C154; C155; C175; C505; C506; C507; C510; C511
C0805CAP NP_C0805_10UF/16V10uF/16VIC1C454
C0805SC10U10V5ZY_3_C0805_22UF/6.3V22uF/6.3VIC3C458; C468; C494
C0805SC10U10V5ZY_1_C0805_22UF/6.3V22uF/6.3VIC1C478
C0805SC10U10V5ZY_2_C0805_22UF/6.3V22uF/6.3VIC1C486
C1206CAP P_C1206_47UF47uFIC18C217; C238; C258; C260; C281; C283; C294; C295; C307; C327; C394; C395; C397; C398; C413; C414; C429; C430
C1206CAP POL_C1206_47UF47uFIC2C445; C446
C1206CAP NP_C1206_47UF/6.3V47uF/6.3VIC3C461; C476; C482
C1206SC10U10V5ZY_3_C1206_47UF/6.3V47uF/6.3VIC2C469; C495
C1210SC10U10V5ZY_3_C1210_22UF/16V22uF/16VIC2C452; C484
C1210CAP NP_C1210_22UF/16V22uF/16VIC4C467; C470; C471; C472
COIL_6P7X6P7DIP_L-STANDUP_L70-P50-H70CDH6B38-4R7NIC3L2; L3; L4
CON_SOM_TL8168_A2-CONCON_SOM-TL8168-A2_CON_SOM_TL816CON_SOM-TL8168-A2IC1CON1
CT-7343CAP TAN_CT-7343_220UF/6.3V220uF/6.3VIC5C455; C465; C479; C487; C497
DBV6-27X39-6TPS3808G09DBVR_0_DBV6-27X39-6_TTPS3808G09DBVRG4IC1U18
DBV-20X60-5TLV431A_1_DBV-20X60-5_TLV431ADBTLV431ADBVIC1U11
DRB8-14X33-PADTPS40041_1_DRB8-14X33-PAD_TPS56TPS56628 DDAIC2U21; U23
DRC10-11X33TPS51200_DRC10-11X33_TPS51200TPS51200IC1U24
EMI-NFM21PNFM_1_EMI-NFM21P_NFM21PC474R1C3NFM21PC474R1C3DIC6E1; E2; E3; E4; E5; E6
FBGA96-0_8HYB18T1G160AF-3S 92-FBGA_0_FBGAK4B2G1646EIC4U7; U8; U9; U10
L8_3X8_3-SMDCOIL2_L8_3X8_3-SMD_CDH8B43B-150CDH8B43B-150MIC2L1; L5
L0603MAG FERRITE BEAD_8_L0603_220R 2220R 2AIC6FB1; FB2; FB4; FB5; FB6; FB7
L0603EBMS2012A-301220R 2AIC1FB3
LED-0603LED_LED-0603_RED LEDRED LEDIC3D2; D3; D4
LGA12PBMA150_0_LGA12P_BMA250EBMA250EIC1U4
MSOP-8CAT24WC02J,SOP8_2_MSOP-8_ADT75ADT75IC1U5
QFN40-6X6ISL6225_0_QFN40-6X6_TPS65251TPS65251IC1U22
R0402R0201_22_R0402_2222DISCRETE65R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R166; R167; R168; R169; R170; R173; R174; R175; R176; R177
R0402R_R0402_2.2K2.2KIC4R18; R19; R20; R21
R0402RESISTOR_R0402_10K10KIC5R22; R23; R165; R171; R172
R0402R_0_R0402_10K10KIC2R24; R27
R0402R_0_R0402_2222IC2R25; R26
R0402R_1_R0402_1K1KIC9R39; R40; R41; R42; R43; R44; R45; R46; R47
R0402R_1_R0402_10K10KIC5R48; R50; R52; R54; R55
R0402R_1_R0402_3K3KIC4R49; R51; R53; R56
R0402R_R0402_10K10KIC21R57; R58; R120; R154; R156; R157; R162; R163; R178; R179; R180; R181; R188; R193; R194; R200; R213; R226; R228; R229; R234
R0402R_R0402_49.949.9IC54R59; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R91; R92; R93; R94; R95; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116
R0402R_R0402_240R 1%240R 1%IC4R60; R61; R89; R90
R0402R_R0402_1.21K1.21KIC2R117; R121
R0402RES 10 KOHM 1%_1_R0402_1K1KIC1R118
R0402R_R0402_15K15KIC2R119; R186
R0402R_R0402_47K47KIC5R149; R150; R151; R191; R195
R0402R_R0402_100K100KIC4R152; R207; R220; R230
R0402R_R0402_5.90K 1%5.90K 1%IC1R153
R0402R_R0402_NC/100RNC/100RIC1R155
R0402R_R0402_NC/0NC/0IC1R158
R0402R_R0402_00IC2R159; R160
R0402R_R0402_NC/30.1KNC/30.1KIC1R161
R0402RESISTOR_R0402_NC/10KNC/10KIC1R164
R0402R_2_R0402_10K10KIC2R182; R184
R0402R_R0402_4.7K4.7KIC2R185; R192
R0402R_R0402_30.1K30.1KIC1R187
R0402R_R0402_1K1KIC3R189; R190; R196
R0402R_R0402_20K20KIC3R197; R223; R224
R0402R_R0402_40.2K 1%40.2K 1%IC3R199; R211; R212
R0402R_R0402_6.81K6.81KIC2R201; R215
R0402R_R0402_180K180KIC3R202; R217; R218
R0402R_R0402_22.1K22.1KIC2R205; R219
R0402R_R0402_32K 1%32K 1%IC1R206
R0402R_R0402_NCNCIC1R210
R0402R_R0402_12.7K 1%12.7K 1%IC1R221
R0402R_R0402_383K 1%383K 1%IC1R222
R0402R_R0402_45.3K 1%45.3K 1%IC1R225
R0402R_R0402_330R330RIC3R227; R231; R232
R0402R_R0402_1010IC1R233
R402-25R_R402-25_4.99K4.99KIC1R183
R0603R_R0603_00IC7R198; R203; R204; R208; R209; R214; R216
SKT-TSOP48SMU-NAND-MICRON 16BIT SOCKET_0_SKMicron NANDIC1U6
SKTBGA-1031-37X37_C9212_P65MM816X_0_SKTBGA-1031-37X37_C9212_NETRA_3IC1U1
SOD-123DIODE SCHOTTKY_0_SOD-123_1N41481N4148WIC1D1
SOP8-225-5024WC256_0_SOP8-225-50_CAT24C256CAT24C256WI-GIC1U2
SOP8-225-5024WC256_0_SOP8-225-50_W25X16W25X16IC1U3
SOT23-6PTPS77001DBV_1_SOT23-6P_TPS79301TPS79301DBVRIC1U13
SOT23-6PTPS77001DBV_2_SOT23-6P_TPS79301TPS79301DBVRIC1U19
SOT-23TRANSISTOR NPN SOT-23_SOT-23_MMMMBT3904IC2Q1; Q2
SW-40X126-EVQP1EVQ-PLMA15_2_SW-40X126-EVQP1_PUPUSHBUTTON SWIC1SW1
TPT POINT R_TP_NCNCIC3TP1; TP2; TP3
UMT51G08_UMT5_SN74LVC1G08DCKRG4SN74LVC1G08DCKRG4IC3U14; U16; U17
UMT51G00_0_UMT5_SN74LVC1G00DCKRG4SN74LVC1G00DCKRG4IC1U15
X3225OSC4/SM_1_X3225_NC/32K HERTZNC/32K HERTZIC1U20
X3225XT_4P_X3225_27MHZ27MHzIC1Y1
X5032_6P_100MSI500D_0_X5032_6P_100M_WX5031C0WX5031C0100.000000IC1U12
附件:
9 o! B) P$ I* i" J$ ~% Z' apcb文件如下:
) n! T7 D, @" u1 O5 r/ \0 g
游客,如果您要查看本帖隐藏内容请回复
% d/ C# z, ^+ d$ j' \+ F3 k
发表于 2022-3-6 14:45 | 只看该作者
学习一下8层板的结构
发表于 2024-4-23 15:44 | 只看该作者
1111111111111
GMT+8, 2025-7-19 13:10 , Processed in 0.125000 second(s), 27 queries , Gzip On.
