Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
ANTENNA868_915MHZ | ANTENNA_ANTENNA868_915MHZ_ANTEN | Antenna PCB helix 868/915MHz | IC | 1 | A1 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_3.6PF_CA | 3.6pF | IC | 2 | C11; C22 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_2.7PF_CA | 2.7pF | IC | 1 | C12 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_6.2PF_CA | 6.2pF | IC | 1 | C13 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_3.3PF_CA | 3.3pF | IC | 1 | C14 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100PF_CA | 100pF | IC | 2 | C15; C21 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_1PF_CAPC | 1pF | IC | 1 | C16 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_12PF_CAP | 12pF | IC | 2 | C41; C51 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | IC | 6 | C131; C221; C351; C441; C451; C481 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_1UF_CAPC | 1uF | IC | 1 | C231 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_DNM_CAPC | DNM | IC | 3 | C461; C471; C482 |
CAPC1608X90L | CAPACITOR_CAPC1608X90L_DNM_CAPC | DNM | IC | 1 | C1 |
CAPC1608X90L | CAPACITOR_CAPC1608X90L_100NF_CA | 100nF | IC | 1 | C342 |
CAPC1608X90L | CAPACITOR_CAPC1608X90L_NC_CAPC1 | NC | IC | 1 | C343 |
CAPC1608X100A2L | CAPACITOR_CAPC1608X100A2L_22UF_ | 22uF | IC | 2 | C331; C341 |
FID100X115 | FIDMARK_FID100X115_FIDU_1MM | FIDU_1MM | IC | 6 | FIDU1; FIDU2; FIDU3; FIDU4; FIDU5; FIDU6 |
FIL_BLM18HE152SN1DL | FILTER_2PIN_FIL_BLM18HE152SN1DL | BLM18HE152SN1 | IC | 1 | FL1 |
HUSTSAN_SMA10V21TGGAN | CONN_COAX_1+4_HUSTSAN_SMA10V21T | SMA-10V21-TGG | IC | 1 | J1 |
INDC1005X60L | INDUCTOR_IND_LQW15AL_18NH_IND_L | 18nH | IC | 1 | L11 |
INDC2012X150L | INDUCTOR_INDC2012X150L_6.8UH_IN | 6.8uH | IC | 1 | L331 |
IND_LQW15AL | INDUCTOR_IND_LQW15AN_7.5NH_IND_ | 7.5nH | IC | 2 | L12; L21 |
IND_LQW15AL | INDUCTOR_IND_LQW15AL_6.8NH_IND_ | 6.8nH | IC | 2 | L13; L14 |
IND_LQW15AL | INDUCTOR_IND_LQW15AL_12NH_IND_L | 12nH | IC | 1 | L15 |
OSCCC250X320X60-4L | XTAL_4PIN_S_OSCCC250X320X60-4L_ | 24MHz | IC | 1 | Y2 |
QFNFC50P700X700X80-49CN | IC_RF_CC13XX_7X7_QFN48_V2_QFNFC | CC13xx 7x7 | IC | 1 | U1 |
RESC1005X40L | RESISTOR_RESC1005X40L_0_RESC100 | 0 | IC | 1 | R11 |
RESC1005X40L | RESISTOR_RESC1005X40L_DNM_RESC1 | DNM | IC | 1 | R12 |
RESC1005X40L | RESISTOR_RESC1005X40L_100K_RESC | 100k | IC | 1 | R351 |
SAMTEC_SFM11002AN | CONN_HEADER_2X10_P_S_SAMTEC_SFM | SFM-110-02-S-D-A-K-TR | IC | 2 | P1; P2 |
XTAL_FC-135N | CRYSTAL_XTAL_FC-135N_32.768KHZ_ | 32.768kHz | IC | 1 | Y1 |
附件:
