Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
7343 | 47UFCAPACITOR10V10%SMD2917_7343 | 47uF | IC | 1 | C48 |
ACM2012H | ACM2012_ACM2012H_ACM2012 | ACM2012 | IC | 1 | L6 |
AM33XX_15X15 | AM335X_15MMX15MM_AM33XX_15X15_A | AM335X_15x15 | IC | 1 | U14 |
BGA14X10-96 | MT41J128M16JT-125_BGA14X10-96_M | MT41J128M16JT-125 | IC | 1 | U15 |
CNRAPC722 | CONN_PWRJACK_RAPC722_CNRAPC722_ | Power Jack RAPC722X | IC | 1 | J11 |
CNRJ45-1X1WLED | 2J_CONNECTORRJ45_10_100MBAMDIX_ | RJ-45 10_100Mb | IC | 2 | J1; J2 |
CON14_P5MM_3P75X9P5SMD | CONN_14PIN_0.5MM_FPC_CON14_P5MM | 10051922-1410ELF | IC | 1 | J17 |
CONN_OSTTC02 | CONN_LEADSCREWDOWN_2PIN_CONN_OS | Connector_Screwdown | IC | 1 | J12 |
DA2304 | DA2304-ALB_DA2304_DA2304-AL | DA2304-AL | IC | 1 | L1 |
DBV5 | TPS61041DBV_DBV5_TPS61041 | TPS61041 | IC | 1 | U34 |
DCK5 | SN74LVC1G06DCK_DCK5_SN74LVC1G06 | SN74LVC1G06DCK | IC | 1 | U10 |
DCK5 | SN74LVC1G07_DCK5_SN74LVC1G07 | SN74LVC1G07 | IC | 1 | U20 |
DO157LS_116X220SMA | DIODE_3ARECT_REV40V_DO157LS_116 | B340A-13-F | IC | 1 | D17 |
DRCPSO_10PIN | TPS51200_DRCPSO_10PIN_TPS51200 | TPS51200 | IC | 1 | U29 |
EXB-2HV330JV | 33OHMX8_1/16W5%SMD_EXB-2HV330JV | 33x8 | IC | 3 | RP1; RP2; RP3 |
HDR2X9VER_335M | HEADER9X2_0.1IN_FEMALE_HDR2X9VE | Header 9x2 Female | IC | 1 | J3 |
HDR2X15-344M | HEADER15X2_0.1IN_FEMALE_HDR2X15 | Header 15x2 Female | IC | 1 | J4 |
HDR2X20-335M | HEADER20X2_0.1IN_FEMALE_HDR2X20 | Header 20x2 Female | IC | 1 | J14 |
HEADER10X2 | HEADER10X2_CJTAG_HEADER10X2_CTI | CTI JTAG | IC | 1 | J15 |
HEADER_3X1 | 2H_HEADER_3X1_HEADER_3X1_HEADER | HEADER 3 | IC | 2 | J18; J19 |
HTQFP_48PIN | TLK110_HTQFP_48PIN_TLK110 | TLK110 | IC | 2 | U2; U3 |
IND108SMD_110X102 | 2.2UHINDUCTOR20%1ASMD_IND108SMD | 2.2uH | IC | 1 | L2 |
IND_354SMD_400SQ | 68UHINDUCTOR20%1.4ASMD_IND_354S | 68uH | IC | 1 | L3 |
LED-SM1210 | LED_TRICOLOR_REDGREENYELLOW_LED | Red_Green_Yellow_LED | IC | 2 | D1; D2 |
LEDLTST-S220 | LED_YELLOW_LEDLTST-S220_LED YEL | LED Yellow | IC | 2 | D4; D5 |
LQFP64_10X10 | FT2232_0_LQFP64_10X10_FT2232HL | FT2232HL | IC | 1 | U18 |
MBR0520L | DIODE_500MA20V_MBR0520L_MBR0520 | MBR0520LT1 | IC | 3 | D11; D13; D20 |
MBRS140T | DIODE_MBRS140T3_MBRS140T_MBRS14 | MBRS140T | IC | 1 | D18 |
MC-306 | CRYSTAL_SMD32_768KHZ_MC-306_32. | 32.768KHz MC-306 | IC | 1 | Y4 |
MH163X138PL | MOUNTHOLE_3MM_MH163X138PL_3.5MM | 3.5MM_MHOLE | IC | 3 | MH1; MH2; MH3 |
MH163X138PL | MOUNTHOLE_3MM_MH163X138PL_3MM_M | 3MM_MHOLE | IC | 1 | MH4 |
MSOP3X3-8-43M | PCA9536_MSOP3X3-8-43M_PCA9536DG | PCA9536DGK | IC | 1 | U25 |
NORCOMP_DB9F_SMD | CONN_DSUB9F_NORCOMP_DB9F_SMD_CO | Conn_DB9F | IC | 1 | J9 |
PW8 | SN74CB3Q3306APW_PW8_SN74CB3Q330 | SN74CB3Q3306APWR | IC | 1 | U4 |
QFN4X3P5-16-39M | SN74CBTLV3257RGY_QFN4X3P5-16-39 | SN74CBTLV3257RGY | IC | 2 | U9; U11 |
SC70-5-43M | SN74LVC1G32DCK_SC70-5-43M_SN74L | SN74LVC1G32DCK | IC | 2 | U7; U8 |
SC70-5 | LM94022_SC70-5_LM94022 | LM94022 | IC | 1 | U19 |
SD-MICRO-SCHA5B0300 | CONN_MICROSD_8_SD-MICRO-SCHA5B0 | SCHA5B0200 | IC | 1 | J16 |
SIP2_50LS | HEADER_1.27MM_2PIN_SIP2_50LS_TM | TMS-102-01 | IC | 3 | J6; J7; J10 |
SIP3_50LS | HEADER_1.27MM_3PIN_SIP3_50LS_TM | TMS-103-01 | IC | 2 | J5; J8 |
SM-7351-CAP-0402 | 0.01UFCAPACITOR16V10%0402_SM-73 | 0.01uF | IC | 82 | C1; C2; C3; C5; C8; C9; C10; C11; C12; C15; C34; C35; C36; C37; C43; C46; C56; C68; C69; C98; C106; C108; C109; C110; C111; C112; C113; C114; C116; C119; C120; C123; C124; C125; C130; C131; C132; C134; C135; C137; C139; C142; C143; C148; C149; C150; C151; C152; C155; C157; C160; C163; C164; C166; C169; C170; C171; C172; C173; C175; C177; C181; C182; C187; C189; C190; C192; C193; C194; C196; C197; C201; C202; C203; C204; C218; C219; C229; C236; C240; C254; C264 |
SM-7351-CAP-0402 | 0.1UFCAPACITOR16V10%0402_SM-735 | 0.1uF | IC | 52 | C4; C6; C7; C13; C14; C16; C17; C18; C19; C20; C32; C41; C55; C70; C71; C72; C73; C74; C75; C77; C78; C79; C80; C82; C83; C85; C86; C87; C88; C91; C93; C96; C159; C162; C167; C185; C188; C206; C207; C208; C213; C214; C220; C221; C225; C227; C230; C231; C232; C265; C269; C272 |
SM-7351-CAP-0402 | 1C_0.1UFCAPACITOR16V10%0402_SM- | 0.1uF | IC | 2 | C21; C22 |
SM-7351-CAP-0402 | 0.001UFCAPACITOR50V5%0402_SM-73 | 0.001uF | IC | 3 | C33; C216; C273 |
SM-7351-CAP-0402 | 22PFCAPACITOR50V10%SMD0402_SM-7 | 22pF | IC | 2 | C40; C42 |
SM-7351-CAP-0402 | 2.2UFCAPACITOR6.3V20%SMDX5R0402 | 2.2uF | IC | 6 | C49; C50; C53; C244; C245; C261 |
SM-7351-CAP-0402 | 2.2UFCAPACITOR10V20%SMD0402_SM- | 2.2uF, 10V | IC | 3 | C51; C52; C237 |
SM-7351-CAP-0402 | 1UFCAPACITOR10V10%0402_SM-7351- | 1uF | IC | 14 | C76; C195; C198; C199; C200; C223; C226; C228; C235; C238; C266; C268; C270; C271 |
SM-7351-CAP-0402 | 1C_18PFCAPACITOR50V5%0402_SM-73 | 18pF, 50V | IC | 2 | C89; C90 |
SM-7351-CAP-0402 | 24PFCAPACITOR50V5%SMD0402_SM-73 | 24pF | IC | 2 | C99; C100 |
SM-7351-CAP-0402 | 100PFCAPACITOR16V10%0402_SM-735 | 100pF25V10% | IC | 2 | C145; C184 |
SM-7351-CAP-0402 | 18PFCAPACITOR50V5%0402_SM-7351- | 18pF, 50V | IC | 2 | C211; C222 |
SM-7351-CAP-0402 | 0.022UFCAPACITOR16VX7RSMD0402_S | 0.022uF | IC | 9 | C239; C241; C246; C247; C250; C253; C256; C259; C267 |
SM-7351-CAP-0402 | 0.1UFCAPACITOR50V10%0402_SM-735 | 0.1uF | IC | 2 | C242; C243 |
SM-7351-CAP-0402 | 10PFCAPACITOR50V1%SMD0402_SM-73 | 10pF | IC | 1 | C255 |
SM-7351-CAP-0402 | 1C_0.01UFCAPACITOR16V10%0402_SM | 0.01uF | IC | 2 | C275; C277 |
SM-7351-CAP-0603 | 4.7UFCAPACITOR16V10%0603_SM-735 | 4.7uF | IC | 9 | C44; C45; C57; C58; C59; C66; C186; C257; C263 |
SM-7351-CAP-0603 | 4.7UFCAPACITOR6.3V20%SMDX5R0603 | 4.7uF | IC | 1 | C224 |
SM-7351-CAP-0603 | 1UFCAPACITOR50V10%0603_SM-7351- | 1uF | IC | 1 | C252 |
SM-7351-CAP-0805 | 10UFCAPACITOR16V10%0805_SM-7351 | 10uF | IC | 32 | C23; C27; C28; C29; C38; C39; C47; C54; C61; C64; C65; C67; C81; C84; C92; C94; C95; C101; C102; C104; C107; C121; C154; C178; C179; C205; C209; C210; C212; C215; C251; C260 |
SM-7351-CAP-0805 | 4.7UFCAPACITOR16V20%TANT_SM-735 | 4.7uF | IC | 2 | C24; C191 |
SM-7351-CAP-0805 | 2.2UF16V10%SMD0805_SM-7351-CAP- | 2.2uF | IC | 5 | C60; C97; C217; C234; C258 |
SM-7351-CAP-0805 | 2.2UFCAPACITOR35V20%SMD0805_SM- | 2.2uF | IC | 2 | C62; C63 |
SM-7351-CAP-1206 | 10UFCAPACITOR50V10%1206_SM-7351 | 10uF | IC | 4 | C233; C248; C249; C262 |
SM-7351-IND-0805 | FERBEAD_180OHM200MA_SM-7351-IND | 150OHM800mA | IC | 7 | FB2; FB3; FB9; FB10; FB11; FB12; FB13 |
SM-7351-RES-0402 | 330OHM1/16W5%SMD0402_SM-7351-RE | 330 | IC | 13 | R1; R2; R3; R4; R5; R6; R89; R93; R94; R98; R128; R130; R131 |
SM-7351-RES-0402 | 2.2KOHMRESISTOR1/16W0402_SM-735 | 2.2K | IC | 29 | R7; R8; R15; R16; R27; R28; R29; R30; R31; R32; R33; R34; R61; R90; R92; R95; R97; R110; R112; R113; R114; R124; R129; R134; R135; R174; R196; R205; R207 |
SM-7351-RES-0402 | 1R_4.87KOHMRESISTOR1/16W0402_SM | 4.87K | IC | 2 | R9; R10 |
SM-7351-RES-0402 | 10KOHMRESISTOR1/10W1%0402_SM-73 | 10K, 1% | IC | 7 | R11; R62; R63; R178; R184; R191; R195 |
SM-7351-RES-0402 | 33OHMRESISTOR1/16W5%0402_SM-735 | 33 | IC | 7 | R12; R13; R179; R180; R181; R182; R186 |
SM-7351-RES-0402 | 4.7KOHMRESISTOR1/16W0402_SM-735 | 4.7K | IC | 6 | R14; R24; R25; R70; R71; R137 |
SM-7351-RES-0402 | ZEROOHMRESISTOR1/16W0402_SM-735 | 0 | DISCRETE | 39 | R17; R22; R23; R26; R35; R36; R60; R64; R69; R72; R91; R96; R105; R126; R138; R139; R142; R146; R147; R149; R150; R156; R175; R190; R192; R194; R198; R201; R202; R203; R204; R209; R222; R223; R224; R225; R228; R229; R230 |
SM-7351-RES-0402 | 1R_2.2KOHMRESISTOR1/16W0402_SM- | 2.2K | IC | 6 | R18; R19; R145; R148; R243; R244 |
SM-7351-RES-0402 | 100OHM1/10W1%SMD0402_SM-7351-RE | 100, 1% | IC | 1 | R20 |
SM-7351-RES-0402 | 10KOHMRESISTOR1/16W0402_SM-7351 | 10K | IC | 21 | R21; R65; R67; R75; R101; R111; R125; R141; R187; R197; R199; R200; R206; R210; R211; R231; R233; R234; R235; R236; R237 |
SM-7351-RES-0402 | 1R_10KOHMRESISTOR1/10W1%0402_SM | 10K, 1% | IC | 7 | R37; R44; R45; R50; R54; R55; R188 |
SM-7351-RES-0402 | 100KOHMRESISTOR1/16W0402_SM-735 | 100K | IC | 29 | R38; R43; R46; R47; R48; R49; R51; R52; R53; R56; R57; R152; R153; R157; R158; R159; R160; R161; R162; R163; R164; R165; R166; R167; R168; R169; R170; R171; R176 |
SM-7351-RES-0402 | 1R_4.7KOHMRESISTOR1/16W0402_SM- | 4.7K | IC | 3 | R39; R277; R278 |
SM-7351-RES-0402 | 1KOHMRESISTOR1/16W0402_SM-7351- | 1K | IC | 17 | R40; R41; R59; R87; R88; R99; R100; R102; R103; R104; R106; R107; R108; R109; R115; R127; R177 |
SM-7351-RES-0402 | 1R_33OHMRESISTOR1/16W5%0402_SM- | 33 | IC | 3 | R42; R144; R154 |
SM-7351-RES-0402 | 22OHMRESISTOR1/16W1%0402_SM-735 | 22 | DISCRETE | 1 | R58 |
SM-7351-RES-0402 | 3.24KOHMRESISTOR1/10W1%0402_SM- | 3.24K | IC | 1 | R66 |
SM-7351-RES-0402 | 49.9OHMRESISTOR1/16W0402_SM-735 | 49.9 | IC | 9 | R116; R117; R118; R119; R120; R121; R122; R123; R185 |
SM-7351-RES-0402 | 150OHM1/16W1%SMD0402_SM-7351-RE | 150 | IC | 9 | R132; R133; R136; R140; R143; R151; R155; R173; R208 |
SM-7351-RES-0402 | 1MOHMRESISTOR1/16W0402_SM-7351- | 1M | IC | 1 | R172 |
SM-7351-RES-0402 | 240OHMRESISTOR1/10W1%0402_SM-73 | 240, 1% | IC | 1 | R183 |
SM-7351-RES-0402 | 1R_4.75KOHMRESISTOR1/16W1%0402_ | 4.75K, 1% | IC | 1 | R189 |
SM-7351-RES-0402 | 12.1KOHMRESISTOR1/16W1%0402_SM- | 12.1K, 1% | IC | 1 | R193 |
SM-7351-RES-0402 | 1.62MOHMRESISTOR1/16W0402_SM-73 | 1.62M | IC | 1 | R220 |
SM-7351-RES-0402 | 180KOHMRESISTOR1/16W0402_SM-735 | 180K | IC | 1 | R221 |
SM-7351-RES-0402 | 392KOHMRESISTOR1/10W1%0402_SM-7 | 392K | IC | 1 | R232 |
SM-7351-RES-0402 | 1R_120OHM1/16W1%SMD0402_SM-7351 | 120 | IC | 1 | R238 |
SM-7351-RES-0603 | ZEROOHMRESISTOR1/16W0603_SM-735 | 0 | IC | 12 | R73; R76; R77; R78; R85; R86; R213; R214; R215; R216; R217; R218 |
SM-7351-RES-0603 | 25KOHM1/10W0.1%SMD0603_SM-7351- | 25K | IC | 1 | R82 |
SM-7351-RES-0603 | 1R_ZEROOHMRESISTOR1/16W0603_SM- | 0 | IC | 6 | R239; R240; R241; R242; R279; R280 |
SM-SO-SC70-5 | SN74LVC1G08DCKT_SC70_SM-SO-SC70 | SN74LVC1G08 | IC | 1 | U5 |
SMCJ36CA | DIODE_SMCJ26CA_SMCJ36CA_SMCJ26C | SMCJ26CA | IC | 1 | D19 |
SMD0201 | 0.1UFCAPACITOR6.3V10%0201_SMD02 | 0.1uF, 6.3V | IC | 32 | C25; C26; C30; C31; C103; C105; C115; C117; C118; C122; C126; C127; C128; C129; C133; C136; C138; C140; C141; C144; C146; C147; C153; C156; C158; C161; C165; C168; C174; C176; C180; C183 |
SMDFUSEBLK | FUSE_4A_SMDFUSEBLK_FUSE 4A | Fuse 4A | IC | 1 | F1 |
SMDSC70-5 | TPS71718_SMDSC70-5_TPS71718 | TPS71718 | IC | 1 | U30 |
SMD_MELF0102 | 1.2KOHM1/3W1%SMDMELF0102_SMD_ME | 1.2K, MELF | IC | 8 | R68; R74; R79; R80; R81; R83; R84; R226 |
SMD_MELF0102 | 49.9OHM1/3W1%SMDMELF0102_SMD_ME | 49.9 | IC | 1 | R227 |
SMINI6-F3-B | NPN_DMC564040R_SMINI6-F3-B_DMC5 | DMC564040R | IC | 4 | Q1; Q2; Q3; Q4 |
SM_LED_0805 | LED_GREEN_SM_LED_0805_GREEN LED | Green LED | IC | 10 | D3; D6; D7; D8; D9; D10; D12; D14; D15; D16 |
SM_OSC_ABM3 | CRYSTAL25MHZABM3_SM_OSC_ABM3_25 | 25MHz | IC | 1 | Y1 |
SM_RES_LVK12 | 0.05OHM0.5W1%SENSE1206_SM_RES_L | 0.05ohm1% Sense | IC | 2 | R212; R219 |
SO8_W_DUB | ISO1050_SO8_W_DUB_ISO1050 | ISO1050 | IC | 1 | U16 |
SOIC8_208 | CAT24C256W_SOIC8_208_CAT24C256W | CAT24C256W | IC | 1 | U6 |
SOIC8_265 | W25Q64_SOIC8_265_W25Q64 | W25Q64 | IC | 1 | U17 |
SOIC-8 | TPS5420D_SOIC-8_TPS5420D | TPS5420D | IC | 1 | U21 |
SOIC_8 | TPS76650_SOIC_8_TPS76650 | TPS76650 | IC | 1 | U27 |
SOT23-6 | 93C46B_SSOT23-6_SOT23-6_93LC56B | 93LC56B | IC | 1 | U33 |
SOT223_6PIN | TPS78633DCQ_SOT223_6PIN_TPS7863 | TPS78633 | IC | 1 | U32 |
SW3_4X2P5 | SWITCHTACTILE3POS_SMD_SW3_4X2P5 | SwitchTactile3Pos | IC | 1 | S1 |
SW-ND3FR10 | SWITCHDIPROTARIES_SMD_SW-ND3FR1 | Rotary Switch | IC | 1 | SW1 |
TFBGA48 | M29W160G_TFBGA48_M29W160EB | M29W160EB | IC | 1 | U1 |
TH_TP_5002 | TESTPOINTTHROUGHHOLE_TH_TP_5002 | TP | IC | 4 | TP17; TP18; TP19; TP20 |
TP60C_SMD | TESTPT1_TP60C_SMD_TESTPT1 | TESTPT1 | IC | 2 | TP24; TP25 |
TP_SMD1MMCIRCLE | TESTPOINT_SMD1MMCIRCLE_TP_SMD1M | TP1mm | IC | 28 | TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP21; TP22; TP23; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40 |
TSSOP4X6-20 | 1A_SN74LV244APWRG3_TSSOP4X6-20_ | SN74LV244A | IC | 2 | U37; U38 |
TSSOP5X4-14-47M | 1A_CDCE913_TSSOP5X4-14-47M_CDCE | CDCE913 | IC | 1 | U12 |
TVSOP-48 | SN74ALVCH16374DGVR_TVSOP-48_SN7 | SN74ALVCH16374DGV | IC | 1 | U26 |
U_6_DRY | TPD4S012_U_6_DRY_TPD4S012 | TPD4S012 | IC | 1 | U23 |
U_8_DCU | SN74AUP2G08_U_8_DCU_SN74AUP2G08 | SN74AUP2G08 | IC | 1 | U13 |
U_10_RSE | TPD6E001RSE_U_10_RSE_TPD6E001 | TPD6E001 | IC | 1 | U24 |
U_16_D | TPIC2810_U_16_D_TPIC2810 | TPIC2810 | IC | 1 | U31 |
U_16_DW | ISO1176T_U_16_DW_ISO1176T | ISO1176T | IC | 1 | U28 |
U_28_PWP | SN65HVS882_U_28_PWP_SN65HVS882 | SN65HVS882 | IC | 1 | U35 |
U_48_RSL | TPS65910A3_U_48_RSL_TPS65910A3 | TPS65910A3 | IC | 1 | U22 |
VLCF5020T | 2.2UHINDUCTOR10%2.6ASMD_VLCF502 | 2.2uH | IC | 3 | L4; L5; L7 |
XTAL4_3P2X2P5_SMD | CRYSTAL24MHZ18PFSMD_XTAL4_3P2X2 | 24MHz | IC | 1 | Y3 |
XTAL4_3P2X5SMD | CRYSTAL12MHZ_ECS-120-20-30B_XTA | 12MHz,+/-50ppm | IC | 1 | Y2 |
ZX62-AB-5PA | CONN_MICROUSBAB_ZX62-AB-5PA_USB | USB_MicroAB | IC | 1 | J13 |
