查看: 172|回复: 0
[allegro16.6][4层] 光纤终端设备(88E6045+TK3715+MP1482DS)原理图和pcb文件
发表于 2020-2-12 18:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
( {7 `; e9 T' w1 j3 Q+ Q[allegro16.6][4层] 光纤终端设备(88E6045+TK3715+MP1482DS)原理图和pcb文件
; d2 L, Z3 k. q" t& c; U6 \
+ l1 s8 f9 Q3 a+ w5 B文件描述:6 r  ^9 {; F2 Y' T
( I. n3 a$ w& t# r0 \5 E& c, [" P1. 作品用途: 光纤终端设备$ |; W/ E" ]) U; J+ P! v
2. 软件版本:allegro16.6
+ o/ t& N$ n6 ~3. 层数:4层
! W% Q1 J) Y1 k0 G* L/ Z; c4. 用到的主要芯片:88E6045+TK3715+MP1482DS
8 k: w% y/ W$ V8 v. A5. pcb尺寸: 115*95.5 MM; U0 c6 N5 H$ D4 g
文件全套共享,自己出gerber可以直接打板
& r+ m: a' J" c9 J9 p# N( u作品截图如下:: G+ ]3 `, Z' @; Z" q( k3 f
& M3 F. a/ d  W& k
顶层截图:
! F1 q* z" d( _5 R+ X6 Y" b * I  R" g) b, y- r* p9 B4 T$ I
底层截图:' A3 v5 Z0 N8 b& [( [
4 K& d, L6 T" Y/ R% L
1 i; I) t6 n1 \8 F* }6 R全层截图:4 k; m  n+ t1 \5 o  m' Z; E
2 @: t0 i1 w$ I# Y+ v; U ; h9 J6 ^  s- S* V
3 o0 i! O# _; eBOM:
% `; s& p& i4 d4 W9 d7 _
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
AXIAL4LED_AXIAL4_LED_GREENLED_greenIC6D1; D2; D3; D5; D6; D7
AXIAL4LED_AXIAL4_LED_REDLED_redIC1D4
AXIAL7CAP NP_AXIAL7_0.01UF/2KV/AX_0.50.01uF/2KV/AX_0.5IC4C165; C186; C187; C196
AXIAL_SWSW PUSHBUTTON-SPST-2/SM_AXIAL_SSW_PUSHBUTTONIC1SW1
CAP0402CAP NP_CAP0402_0.01UF/10%/25V/00.01uF/10%/25V/0402IC29C1; C2; C3; C4; C45; C55; C57; C59; C60; C79; C80; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C190; C191; C198; C203; C210
CAP0402CAP NP_CAP0402_0.1UF/10%/25V/040.1uF/10%/25V/0402IC114C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C27; C28; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C46; C48; C49; C51; C52; C53; C54; C56; C58; C61; C62; C63; C64; C65; C66; C69; C81; C84; C87; C108; C111; C123; C124; C125; C126; C127; C130; C131; C132; C133; C134; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C166; C167; C168; C169; C170; C171; C172; C173; C174; C176; C180; C181; C182; C183; C184; C185; C188; C189; C192; C193; C194; C199; C200; C201; C204; C205; C206; C212; C213; C214; C215; C216
CAP0402CAP NP_CAP0402_100PF/5%/25V/040100pF/5%/25V/0402IC1C47
CAP0402CAP NP_CAP0402_1NF/10%/25V/04021nF/10%/25V/0402IC3C114; C115; C116
CAP0402CAP NP_CAP0402_1UF/10%/25V/04021uF/10%/25V/0402IC1C129
CAP0402CAP NP_CAP0402_0.1NF/5%/25V/0400.1nF/5%/25V/0402IC3C195; C202; C207
CAP0603CAP NP_CAP0603_0.01UF/10%/50V/00.01uF/10%/50V/0603IC3C68; C86; C110
CAP0603CAP NP_CAP0603_4.7NF/10%/50V/064.7nF/10%/50V/0603IC2C70; C112
CAP0603CAP NP_CAP0603_1UF/10%/6.3V/0601uF/10%/6.3V/0603IC3C72; C92; C117
CAP0603CAP NP_CAP0603_500PF/10%/50V/06500pF/10%/50V/0603IC1C78
CAP0603CAP NP_CAP0603_1UF/10%/25V/06031uF/10%/25V/0603IC1C82
CAP0603CAP NP_CAP0603_3.3NF/10%/50V/063.3nF/10%/50V/0603IC1C90
CAP1206CAP NP_CAP1206_10UF/10%/25V/12010uF/10%/25V/1206IC17C5; C26; C29; C50; C85; C113; C120; C121; C122; C128; C135; C163; C164; C175; C211; C217; C218
CAP1206CAP NP_CAP1206_22UF/10%/16V/12022uF/10%/16V/1206IC3C67; C109; C178
CAP1206CAP NP_CAP1206_22UF/10%/6.3V/1222uF/10%/6.3V/1206IC3C73; C93; C118
CAP1206CAP NP_CAP1206_47UF/10%/6.3V/1247uF/10%/6.3V/1206IC1C74
CAP1206CAP NP_CAP1206_10UF/10%/6.3V/1210uF/10%/6.3V/1206IC3C119; C179; C219
CB2CIRCUIT BREAKER_CB2_FUSE MQ3Fuse MQ3IC1CB1
CONSIPCON2_0_CONSIP_DC12V SWITCHDC12V SwitchIC1S1
CRY_XTAL4125M OSCILLATOR_CRY_XTAL4_125M125M OSCIC1U7
DC12VDC_DC12V_DCDCIC1J2
DIODE04DIODE ZENER_DIODE04_DIODE ZENERDIODE ZENERIC1D8
DIP6ONU_URT_DIP6_ONU_URTONU_URTIC1J1
DIP20FIBER SFF_0_DIP20_SFFSFFIC1U18
HOLETERMP_HOLE_TERMPtermpIC4X1; X2; X3; X4
IND_RES0603INDUCTOR_IND_RES0603_1UH/10%/351uH/10%/350mA/0603IC8L1; L2; L3; L14; L15; L16; L17; L18
IN_AXIAL8_8INDUCTOR_IN_AXIAL8_8_10UH/20%/310uH/20%/3.3A/SQ10x9.7IC3L4; L8; L12
LQFP128TK3715_LQFP128_TK3715TK3715IC1U5
RB2CAP POL_RB2_330UF/25V/EC_2_8X15330uF/25V/EC_2_8x15IC2C83; C177
RES0402R_RES0402_10K/5%/040210K/5%/0402IC47R1; R2; R3; R4; R5; R6; R7; R8; R9; R11; R12; R13; R14; R15; R19; R20; R21; R22; R23; R24; R25; R26; R65; R70; R72; R74; R76; R77; R78; R87; R88; R92; R93; R100; R101; R113; R120; R128; R134; R135; R145; R147; R148; R149; R150; R151; R215
RES0402R_RES0402_NI/10K/5%/0402NI/10K/5%/0402IC4R10; R16; R17; R18
RES0402R_RES0402_NI/1K/5%/0402NI/1K/5%/0402IC4R27; R29; R34; R36
RES0402R_RES0402_0R/5%/04020R/5%/0402IC12R28; R30; R35; R37; R63; R64; R73; R219; R222; R223; R224; R225
RES0402R_RES0402_49.9R/1%/040249.9R/1%/0402IC23R31; R33; R39; R40; R102; R103; R146; R152; R153; R154; R155; R156; R157; R158; R159; R180; R181; R182; R183; R184; R185; R186; R187
RES0402R_RES0402_130R/1%/0402130R/1%/0402IC2R32; R42
RES0402R_RES0402_1K/5%/04021K/5%/0402IC5R38; R41; R98; R213; R214
RES0402R_RES0402_4.7K/5%/04024.7K/5%/0402IC7R43; R67; R68; R69; R75; R80; R97
RES0402R_RES0402_82R/1%/040282R/1%/0402IC16R44; R45; R46; R47; R48; R49; R50; R51; R137; R138; R139; R140; R141; R142; R143; R144
RES0402R_RES0402_49.9R/1%040249.9R/1%0402IC3R52; R53; R54
RES0402R_RES0402_NI/49.9R/5%/0402NI/49.9R/5%/0402IC6R55; R56; R57; R58; R59; R60
RES0402R_RES0402_2K/1%/04022K/1%/0402IC1R61
RES0402R_RES0402_NI/0R/5%/0402NI/0R/5%/0402IC5R62; R66; R71; R91; R95
RES0402R_RES0402_75R/5%/040275R/5%/0402IC3R79; R83; R125
RES0402R_RES0402_33R/5%/040233R/5%/0402IC9R81; R82; R84; R85; R121; R193; R195; R199; R200
RES0402R_RES0402_NI/100K/5%/0402NI/100K/5%/0402IC1R86
RES0402R_RES0402_10K/1%/040210K/1%/0402IC5R89; R118; R119; R124; R132
RES0402R_RES0402_330R/5%/0402330R/5%/0402IC1R90
RES0402R_RES0402_1.3K/1%/04021.3K/1%/0402IC1R94
RES0402R_RES0402_NI/33R/5%/0402NI/33R/5%/0402IC4R96; R201; R217; R218
RES0402R_RES0402_49.9R/5%/040249.9R/5%/0402IC4R99; R112; R126; R136
RES0402R_RES0402_510R/5%/0402510R/5%/0402IC8R104; R105; R106; R108; R109; R110; R111; R133
RES0402R_RES0402_NI/510R/5%/0402NI/510R/5%/0402IC1R107
RES0402R_RES0402_3.4K/1%/04023.4K/1%/0402IC1R115
RES0402R_RES0402_4.99K/1%/04024.99K/1%/0402IC2R117; R191
RES0402R_RES0402_26.1K/1%/040226.1K/1%/0402IC1R122
RES0402R_RES0402_7.5K/5%/04027.5K/5%/0402IC1R123
RES0402R_RES0402_16.9K/1%/040216.9K/1%/0402IC1R130
RES0402R_RES0402_5.6K/5%/04025.6K/5%/0402IC1R131
RES0402R_RES0402_10R/5%/040210R/5%/0402IC3R164; R165; R166
RES0402R_RES0402_270R/5%/0402270R/5%/0402IC2R208; R209
RES0402R_RES0402_NI/33R/5%0402NI/33R/5%0402IC1R216
RES0603R_RES0603_130R/1%/0603130R/1%/0603IC1R188
RES0603R_RES0603_NI/100R/5%/0603NI/100R/5%/0603IC1R189
RES0603R_RES0603_82R/1%/060382R/1%/0603IC1R190
RES0603R_RES0603_NI/130R/5%/0603NI/130R/5%/0603IC4R194; R196; R206; R207
RES0603R_RES0603_NI/10K/5%0603NI/10K/5%0603IC2R197; R198
RES0603R_RES0603_NI/82R/5%/0603NI/82R/5%/0603IC4R202; R203; R210; R211
RES0603R_RES0603_NI/1K/5%/0603NI/1K/5%/0603IC1R204
RES0603R_RES0603_NI/1 K/5%0603NI/1 K/5%0603IC1R205
RES0805INDUCTOR_RES0805_220OHM/100M220ohm/100MIC3L13; L19; L20
RES0805R_RES0805_NI/0R/5%/0805NI/0R/5%/0805IC3R114; R116; R212
RES0805R_RES0805_75R/1%/080575R/1%/0805IC16R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R178; R179; R192; R220; R221
SIP8RJ45-1*1_6_SIP8_1*1 RJ451*1 RJ45IC1J6
SIP161*2 RJ45_0_SIP16_1*2 RJ451*2 RJ45IC1J5
SIP32RJ45-4*1_0_SIP32_1*4 RJ451*4 RJ45IC1J4
SMBGDT_BS201N_SMB_TSS_BS4200N-CTSS_BS4200N-CIC4U23; U24; U25; U26
SOC8MP1482_SOC8_MP1482DSMP1482DSIC3U8; U9; U11
SOIC8M25P80_0_SOIC8_W25Q80BVSIGW25Q80BVSIGIC1U3
SOIC1474HC11D_0_SOIC14_74HC11D74HC11DIC1U2
SOIC24MS00622_SOIC24_G2417SRG2417SRIC2U19; U20
SOP8MAX706_SOP8_MAX706MAX706IC1U4
TO18MPF6660_0_TO18_SI2305BDSSi2305BDSIC2Q1; Q2
TO18NPN_0_TO18_NPNNPNIC1Q3
TQFP17688E6045_TQFP176_88E604588E6045IC1U1
TVS1206DIODE TVS_TVS1206_TVS_BV03CWTVS_BV03CWIC8D9; D10; D11; D12; D13; D14; D15; D16
附件:! h, M1 [+ D5 D4 `
原理图和PCB文件如下:2 M' U% U, E2 N4 B% b% T
游客,如果您要查看本帖隐藏内容请回复
/ K( g  U5 R+ I9 C) V& B  p$ D& e. q. F
' O  s3 L- B" K% V5 K0 @
GMT+8, 2025-7-24 06:06 , Processed in 0.140625 second(s), 28 queries , Gzip On.
