查看: 192|回复: 0
[allegro15.2][2层]Tiny6410SDK参考板(WM9714LGEFL+MAX3232CSE+DM9000AEP)原理...
发表于 2020-2-12 17:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
# h) w3 G/ T5 B( P6 a7 _! D[allegro15.2][2层]Tiny6410SDK参考板(WM9714LGEFL+MAX3232CSE+DM9000AEP)原理图和pcb文件; e. ^( e4 H4 {. ~! C! H% }  @
, u8 l/ a; q3 q' ]! i) {- j( `5 m5 C文件描述:
. R' z+ R/ q) y9 y4 J) L% J' V! \* [% G. Z- N
1. 作品用途: Tiny6410SDK参考板
0 ]. M/ `/ }; x2. 软件版本:allegro15.2
6 _2 D; q4 @( y) r1 |( ~7 x1 P3. 层数:2层# f( @- {* R1 R; R, w
4. 用到的主要芯片:WM9714LGEFL+MAX3232CSE+DM9000AEP+ P0 O' O/ M! I9 Y  p* R3 i1 o
5. pcb尺寸: 7086.6*5118.1 MIL
  {* M- R# M+ U6 c5 G9 r  h' ^& a! a1 A0 E$ x% A; b4 H
作品截图如下:4 o% w% ?) P6 h" f: l/ \
! S* A; Q# D/ L; w- ^5 B6 E
顶层截图:& q) ?* z$ ?) p& \
0 ]+ f  a- `  z  f+ @6 J1 l/ }底层截图:: X. Q! R6 ~8 ?/ P7 |" ?5 G* b
* x1 o+ d9 |  q+ _2 v" @
8 P* j$ p/ w! N  Z; F
全层截图:  d. O  t2 F6 Y6 _0 F; e% K
1 n/ b' t( W; W1 z
3 i0 z# }9 U1 e% {. `; _& j; L5 v! {" H* @
BOM:
5 e* N3 h. P0 h+ e- V' n
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0603A0603A104IC10C4; C5; C6; C7; C8; C54; C55; C56; C58; C59
0603A0603A10nFIC4C69; C70; C71; C72
0603R0603R10KIC15R3; R4; R5; R6; R7; R8; R9; R10; R12; R33; R35; R36; R37; R38; R40
0603R0603R330IC1R11
0603R0603R100KIC3R13; R34; R45
0603R0603R1.5KIC1R23
0603R0603R0RIC4R25; R27; R28; R46
0603R0603R680IC1R29
0603R0603R47KIC3R30; R31; R32
0603R0603R50RIC1R59
0603R0603R150RIC1R60
0603R0603R4.7KIC1R61
BAT600BAT600BATTERYIC1BAT1
C0603C0603104IC28C3; C14; C15; C16; C18; C20; C21; C22; C23; C24; C25; C26; C30; C35; C36; C44; C48; C49; C50; C51; C52; C53; C57; C60; C61; C62; C148; C149
C0603C0603220pFIC3C27; C28; C29
C0603C060315pFIC4C31; C64; C75; C76
C0603C06031uFIC6C33; C34; C37; C38; C39; C40
C0603C0603100nIC1C43
C0603C06030.1uFIC1C145
C0805C080547uF/10VIC1C2
C0805C321610uF/16VIC2C17; C45
C0805C321610uF/10VIC1C32
C0805C321647uF/10VIC2C41; C42
C0805C080510uF/16VIC2C73; C74
C3216C121033uFIC2C46; C47
CAPSOPCAPSOP47uF/10VIC1C1
CON4-BCON4-BCON4IC1CON8
D1206D12061N4148IC1D1
DB9RA_MDB9RA_MBOXCONN_DB9IC3COM0; COM1; COM2
DC023BDC023BDC_JACKIC1CN1
EARJACK5EARJACK5PHONEJACK STEREO SWIC2CON9; CON10
H1H1CON1IC11H1; H2; H3; H4; H5; H6; H7; H8; H9; H10; H11
HR911105AHR911105AHR911105AIC1LAN
IDC40SIDC40SHEADER 20X2IC1LCD3
L0603L0603F.B/120IC1L1
LEDLEDREDIC1LED_3V3
LEDIR-IRM3638LEDIR-IRM3638IRM3638IC1U12
LQFP48FALQFP48FADM9000AEPIC1U8
MINIUSBMINIUSBUSBOTGIC1MINIUSB
NEWSDNEWSDSD/MMC CARDIC1CON6
OSC2PR-1OSC2PR-112MHzIC1Y1
OSC2PR-1OSC2PR-125MHzIC1Y2
PUSHSWPUSHSWPUSHSWIC9K1; K2; K3; K4; K5; K6; K7; K8; RST
QFN48-19P7-THQFN48-19P7-THWM9714LGEFLIC1U7
R0603R060310KIC14R1; R18; R19; R20; R47; R48; R71; R72; R73; R74; R75; R76; R77; R78
R0603R06030RIC4R2; R14; R21; R26
R0603R06036.8K,1%IC1R15
R0603R060322RIC2R16; R17
R0603R06031KIC1R22
R0603R0603330RIC2R24; R39
R0603R06034K7IC1R41
R0603R060315KIC10R42; R43; R44; R49; R50; R51; R52; R53; R79; R80
R0603R06031K5IC1R54
R0603R060351RIC4R62; R66; R67; R68
SCONSCONHEADER 10X2IC1CON5
SDWIFISDWIFIHEADER 10X2IC1CON11
SIP4-FA2SIP4-FA2CON4IC3CON1; CON3; CON4
SIP6-FA2SIP6-FA2CON6IC1CON2
SMD40-0_5FASMD40-0_5FAHEADER 20X2IC2LCD1; LCD2
SOP8SOP8AT24LC04IC1U4
SOP16SOP16MAX3232CSEIC2U1; U2
SOT23FASOT23FA9014IC1Q1
SOT223SSOT223SAMS1086CM-3.3IC1U5
SOT-23-6SOT-23-6NJM2561F1IC1U9
SPEAKERSPEAKERSPEAKERIC1BUZZER
SW35SW35CON5IC2S1; S2
TINY6410TINY6410TINY6410IC1TINY6410
TO-92BTO-92BDS18B20IC1U10
TSSOP28TSSOP28UDA1341TSIC1U6
TVOUTTVOUTCON3IC1CON7
USB-A2USB-A2USB Port A typeIC3USBH1; USBH2; USBH3
VR3_7X7VR3_7X710KIC1W1
Y7050Y705024.576MHzIC1Y5
附件:
1 P9 L( b3 F: e  o* K2 F4 t0 Z& t原理图和PCB文件如下:
- r5 \# G% _3 w6 V8 \4 I4 h2 {; t. _
游客,如果您要查看本帖隐藏内容请回复
, U% ^4 |% |4 A+ {+ T
" R8 C  L- p! C4 R
GMT+8, 2025-7-24 05:56 , Processed in 0.125000 second(s), 28 queries , Gzip On.
