查看: 274|回复: 0
[allegro16.6][12层]TDA2x Vision EVM Application Board 视觉应用板(5M2210ZF324...
发表于 2020-2-12 16:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
+ r6 B. z5 v6 |1 x( @
[allegro16.6][12层]TDA2x Vision EVM Application Board 视觉应用板(5M2210ZF324C4MUX2+ADV7611BSWZ-P+TPS54362PWPRQ1)原理图和pcb文件
+ |" q+ Z7 B$ D2 c# U) A. z  a: f* }# l2 F6 u
文件描述:
: E; q, p+ F/ n, T+ A4 w. `& d* ?5 r$ `8 V# J/ A: f
1. 作品用途:TDA2x Vision EVM Application Board 视觉应用板$ f( r. n; w+ C" l+ h
2. 软件版本:allegro16.6" E) t1 b+ F: W8 Q, z+ Q
3. 层数:12层
6 |; ?& X" r/ O7 y8 [. ?# P4. 用到的主要芯片:5M2210ZF324C4MUX2+ADV7611BSWZ-P+TPS54362PWPRQ1
/ |: Z6 G+ J! i, ?% M5. pcb尺寸: 6693*6312MIL
6 F9 I2 }; c/ c* N(本板主要器件为cpld  5M2210ZF324C)可与TDA2Px 评估模块 配合使用
6 e( \% ?8 v: \" ~  \6 m+ h作品截图如下:! m# U( t. f6 a3 T- I# {$ {
% j2 t0 W: u/ y" O
顶层截图:
% G& |- o0 Q, y: D2 @, [4 I, g / E, w, b* I9 a0 a
底层截图:
5 N) C5 V8 P9 E: [9 u+ z' W + _0 Z' \6 E& i; A) Y( F
/ V  ~- J' i5 u7 P3 R" z( {; _9 \2 T全层截图:2 \6 ^( _; z$ F1 {: A( g5 t/ x
6 o* G) R7 m% }* c( q1 e. q
4 W3 l6 q  g( l0 M, R' hBOM:
/ ~( z0 d5 E7 ^2 v
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA324-18RD5M2210ZF324C4MUX2_BGA324-18RD__5M2210ZF324C4MUX2IC1U8
BGA324-18RD5M2210ZF324C4MUX1_1_BGA324-18RD5M2210ZF324C4MUX1IC1U9
C201-6P6SPCNPCAP_0_C201-6P6SPC_0.1UF0.1uFDISCRETE48C56; C57; C58; C59; C62; C63; C64; C65; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C103; C104; C105; C106; C109; C110; C111; C112
C402-25CAP NP_C402-25_0.001UF0.001uFDISCRETE3C2; C8002; C8018
C402-25CAP 100NF CERMC 16V 10% 603_0_C5.6pFDISCRETE3C3; C8003; C8019
C402-25CAP NP_1_C402-25_.1UF.1uFDISCRETE5C50; C52; C66; C67; C68
C402-25NPCAP_0_C402-25_0.047UF0.047uFDISCRETE8C54; C55; C60; C61; C107; C108; C113; C114
C402-25CAP NP_0_C402-25_0.047UF0.047uFDISCRETE2C115; C148
C402-25CAP_C402-25_.1UF.1uFDISCRETE3C122; C151; C158
C402-25CAP NP_0_C402-25_0.01UF0.01uFDISCRETE2C125; C152
C402-25CAP NP_0_C402-25_0.1UF0.1uFDISCRETE2C132; C159
C402-25CAP_C402-25_4700PF4700pFDISCRETE1C163
C402-25CAP NP_C402-25_0.1UF0.1uFIC6C8020; C8021; C8044; C8045; C8046; C8047
C402-25CAP .1 UF 10% 0603_C402-25_0.1U0.1uFIC1C8022
C402-25CAP_C402-25_0.1UF0.1uFIC14C8024; C8025; C8027; C8029; C8030; C8031; C8034; C8035; C8039; C8040; C8041; C8042; C8043; C8231
C402-25CAP NP_3_C402-25_18 PF18 pFIC2C8032; C8037
C402-25CAP_C402-25_0.01UF0.01uFIC1C8038
C603-35X45CAP NP_C603-35X45_10UF10uFDISCRETE3C4; C8001; C8017
C603-35X45CAP NP_C603-35X45_2.2UF2.2uFDISCRETE3C5; C8000; C8016
C603-35X45CAP_C603-35X45_10UF10uFDISCRETE19C6; C7; C8; C9; C11; C12; C13; C14; C17; C18; C19; C20; C8004; C8007; C8008; C8009; C8010; C8011; C8015
C603-35X45CAP NP_C603-35X45_0.1UF0.1uFDISCRETE2C16; C102
C603-35X45CAP NP_0_C603-35X45_22PF22pFDISCRETE2C31; C44
C603-35X45CAP NP_0_C603-35X45_2200PF2200pFDISCRETE2C121; C157
C603-35X45CAP NP_0_C603-35X45_10PF10pFDISCRETE2C124; C150
C603-35X45CAP NP_0_C603-35X45_4700PF4700pFDISCRETE2C126; C153
C603-35X45CAP NP_0_C603-35X45_470PF470pFDISCRETE2C128; C156
C603-35X45CAP NP_0_C603-35X45_1800PF1800pFDISCRETE1C129
C603-35X45CAP NP_0_C603-35X45_NO-POP ( 1UNO-POP ( 1uF )IC2C133; C160
C603-35X45CAP NP_0_C603-35X45_NO-POPNO-POPIC2C134; C161
C603-35X45CAP NP_0_C603-35X45_1UF1uFDISCRETE2C141; C164
C603-35X45CAP NP_0_C603-35X45_3300PF3300pFIC1C149
C805-35X60CAP NP_C805-35X60_1UF1uFDISCRETE2C15; C101
C1206-40X70-POLCAP NP_C1206-40X70-POL_10UF10uFDISCRETE2C1; C10
C1210-70X102CAP NP_C1210-70X102_4.7UF4.7uFDISCRETE1C21
C1210-70X102CAP P_C1210-70X102_47UF47uFDISCRETE4C26; C30; C42; C43
C7343-84X118CAP P_C7343-84X118_100UF100uFDISCRETE2C36; C49
CHOKE-115X212INDUCTOR IRON_CHOKE-115X212_4.74.7uHDISCRETE1L19
CHOKE-115X212INDUCTOR IRON_CHOKE-115X212_10U10uHIC1L25
CON-SKT-ASP-40-X4_SAMTECASP-127796-01_0_CON-SKT-ASP-40-ASP-127796-01IC1P4
CONN2X16-6040HEADER 16X2_CONN2X16-6040_SSQ-1SSQ-116-02-L-DIC1P3
CONN36-52559HEADER 36_CONN36-52559_MOLEX 05MOLEX 052559-3679IC1P2
CONN-SKT-2X16-RAHEADER 16X2_CONN-SKT-2X16-RA_SSSSQ-116-02-L-D-RAIC1P1
DBT38-12X70TPD12S520_DBT38-12X70_TPD12S520TPD12S520IC1U8005
DCK-5SN74LVC1G125_0_DCK-5_74CBTLV1G174CBTLV1G125CRG4IC2RU8000; RU8001
DCK-17X60-6TMP_095528_DCK-17X60-6_SN74AVC1SN74AVC1T45IC1U6
DPAK3-55X120-4RBO40_1_DPAK3-55X120-4_RBO40_40RBO40_40GIC1U10
DRC10-11X33U-TPS78601_AJUST - 1_0.5A LDO_DTPS74701IC3U3; U8002; U8004
EMI-36X15-DLW21DLW21SN900HQ2_EMI-36X15-DLW21_DDLW21SN900HQ2IC4FL8000; FL8001; FL8002; FL8003
FB1806-41X70FERRITE CHIP_FB1806-41X70_BLM41BLM41P750SPTIC14L1; L3; L4; L5; L7; L8; L10; L12; L13; L14; L15; L16; L17; L24
FUSEFOLDER-OMNI-BLOKNANO-SMF_0_FUSEFOLDER-OMNI-BLOK4A_QuickBlowIC1F1
HDMI-SMT-W-FLANGE-RDpadsHDMI-RA-19_0_HDMI-SMT-W-FLANGE-HDMI-RA-19-TYPEAIC1P8000
IND-DR73INDUCTOR_IND-DR73_1.5UH1.5uHDISCRETE1L11
JUMP1X3-6040HEADER 3_JUMP1X3-6040_NO-POP(HENO-POP(HEADER 3)IC1JP1
JUMP2X5-6040HEADER 5X2_0_JUMP2X5-6040_HEADEHEADER 5X2IC2J1; J2
L805-35X60INDUCTOR_0_L805-35X60_220 OHM @220 Ohm @ 100MhzDISCRETE8L2; L6; L9; L8000; L8001; L8002; L8003; L8004
LQFP64-10MM-SQ-SLUGADV7611BSWZ-P_LQFP64-10MM-SQ-SLADV7611BSWZ-PIC1U8003
MH62TESTPOINT_MH62_MHC2MHC2IC1MHC1
MH62TESTPOINT_MH62_MHC1MHC1IC1MHC2
MHP125-250MH_3MM_MHP125-250_MH_3MMMH_3MMIC4MH1; MH2; MH3; MH4
OSC4-71X79OSC4/SM_0_OSC4-71X79_24 MHZ24 MHzIC3U1; U4; U7
PWP20-14X70-PADTPS54362PWPRQ1_1_PWP20-14X70-PATPS54362PWPRQ1IC2U14; U18
PWRJACK-CUI-PJ063BHPWR_JACK_0_PWRJACK-CUI-PJ063BH_PJ-063BHIC1J3
QTE60-18X77J - SAMTEC QSH060 120PIN_2_QTE6QTE-060-01-L-D-A-KIC1EXP_P1
QTE-2X20J - SAMTEC QSH020 40PIN_1_QTE-2QTE-020-01-L-D-A-KIC2EXP_P2; EXP_P3
R201-6P6SPCR_1_R201-6P6SPC_00IC2R9298; R9299
R402-25RESISTOR_R402-25_2222DISCRETE11R1; R4; R5; R34; R39; R40; R78; R97; R99; R102; R104
R402-25R_R402-25_NO-POPNO-POPDISCRETE2R14; R137
R402-25R_2_R402-25_15K15KDISCRETE1R19
R402-25R_2_R402-25_10K10KDISCRETE2R21; R29
R402-25R_2_R402-25_30.1K 1%30.1K 1%DISCRETE1R27
R402-25R_R402-25_00DISCRETE2R35; R132
R402-25RESISTOR_R402-25_NO-POPNO-POPDISCRETE4R36; R37; R66; R67
R402-25RESISTOR_0_R402-25_10K10KDISCRETE12R38; R50; R56; R62; R68; R77; R85; R108; R109; R8022; R8023; R8031
R402-25R_1_R402-25_10K10KDISCRETE17R44; R45; R46; R59; R60; R80; R81; R96; R147; R148; R149; R150; R151; R152; R153; R154; R8029
R402-25R_1_R402-25_NO-POPNO-POPDISCRETE7R47; R48; R49; R63; R64; R89; R90
R402-25RESISTOR_R402-25_00IC5R55; R65; R70; R71; R79
R402-25R_0_R402-25_00DISCRETE12R72; R74; R75; R76; R84; R86; R87; R88; R91; R92; R93; R94
R402-25R_R402-25_1K1KDISCRETE6R73; R95; R119; R8020; R8021; R8046
R402-25R_0_R402-25_NO-POPNO-POPDISCRETE2R82; R83
R402-2510KOHMRESISTOR1/16W0402_R402-2510KDISCRETE3R100; R8006; R9177
R402-25R_2_R402-25_2K2KDISCRETE2R106; R124
R402-25R_2_R402-25_00DISCRETE2R116; R136
R402-25R_R402-25_10K10KDISCRETE4R138; R8013; R8041; R8047
R402-25R_1_R402-25_2222DISCRETE4R8002; R8003; R8004; R8005
R402-25R_R402-25_NPNPIC4R8011; R8012; R8037; R9435
R402-25R_0_R402-25_10K10KIC3R8014; R8017; R8018
R402-25R_0_R402-25_NPNPIC3R8015; R8016; R8019
R402-25R_R402-25_47K47KIC7R8026; R8027; R8035; R8036; R8038; R8042; R8043
R402-25R_1_R402-25_1M1MIC1R8034
R402-25R_R402-25_27K27KIC1R8045
R402-25R_1_R402-25_00IC1R8048
R402-2510KOHMRESISTOR1/16W0402_R402-_1NPIC4R9434; R9436; R9437; R9438
R603-35X45R_3_R603-35X45_4.99K 1%4.99K 1%DISCRETE3R2; R8000; R8007
R603-35X45R_3_R603-35X45_6.34K 1%6.34K 1%DISCRETE2R3; R8008
R603-35X45R_2_R603-35X45_147K 1%147K 1%DISCRETE1R15
R603-35X45R_2_R603-35X45_27K 1%27K 1%DISCRETE1R16
R603-35X45R_2_R603-35X45_4.02K 1%4.02K 1%DISCRETE1R18
R603-35X45R_2_R603-35X45_47K47KDISCRETE1R20
R603-35X45R_2_R603-35X45_130K 1%130K 1%DISCRETE1R23
R603-35X45R_2_R603-35X45_40.2K 1%40.2K 1%DISCRETE1R24
R603-35X45R_2_R603-35X45_6.04K 1%6.04K 1%DISCRETE1R26
R603-35X45R_2_R603-35X45_71.5K 1%71.5K 1%IC1R28
R603-35X45R_2_R603-35X45_49.949.9DISCRETE2R101; R122
R603-35X45R_2_R603-35X45_80.680.6DISCRETE1R103
R603-35X45R_2_R603-35X45_10K 1%10K 1%IC2R107; R125
R603-35X45R_2_R603-35X45_1.87K 1%1.87K 1%DISCRETE1R111
R603-35X45R_2_R603-35X45_26.1K 1%26.1K 1%DISCRETE1R114
R603-35X45R_2_R603-35X45_NO-POPNO-POPIC2R121; R143
R603-35X45R_2_R603-35X45_8282IC1R123
R603-35X45R_2_R603-35X45_3.24K3.24KDISCRETE1R126
R603-35X45R_2_R603-35X45_25.5K 1%25.5K 1%IC1R131
R603-35X45R_3_R603-35X45_15.8K 1%15.8K 1%IC3R8001; R9432; R9433
R603-35X45R_R603-35X45_AVR-M1608C080MTAABAVR-M1608C080MTAABIC1RV8000
R805-35X60R_R805-35X60_0.10.1DISCRETE2R10; R22
R1206-40X70R_R1206-40X70_6262DISCRETE2R32; R33
R2512R_4_R2512_0 OHM 1W0 OHM 1WDISCRETE1R6
R2512R_4_R2512_NO-POPNO-POPIC1R7
RPAK8-10X25-28VR-PAK4_0_RPAK8-10X25-28V_RPACK4RPACK4-22DISCRETE6RN8000; RN8001; RN8002; RN8003; RN8004; RN8005
SC-75NTA4153N_SC-75_NTA4153NNTA4153NIC1Q2022
SMA2-78SQDIODE_0_SMA2-78SQ_MBRA340T3MBRA340T3IC2D2; D3
SMC-80X120DIODE SCHOTTKY_1_SMC-80X120_DIODIODE SCHOTTKYIC1D1
SO8-25X75SN65HVDA541_SO8-25X75_SN65HVDA5SN65HVDA541IC1U16
SO8-25X7524WC256_0_SO8-25X75_AT24C02BN-SAT24C02BN-SH-BIC1U8001
SW4-30X50-TDASW DIP-4_0_SW4-30X50-TDA_SW DIPSW DIP-4IC1SW8000
SW8-30X50SW DIP-8_SW8-30X50_TDA08H0SB1RTDA08H0SB1RIC1SW3
TP1-18RD8TESTPOINT1_0_TP1-18RD8_TESTPOINTestPoint1IC10TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP14
TP1-18RD8TP_0_TP1-18RD8_TP_0TP_0IC16TP12; TP13; TP18; TP19; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP32; TP33
TP1-6040TEST POINT_TP1-6040_TEST POINTTEST POINTIC6TP1; TP15; TP16; TP34; TP38; TP39
TP30TESTPOINT1_TP30_TESTPOINT1TestPoint1IC35TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP57; TP58; TP59; TP60; TP61; TP62; TP63; TP64; TP65; TP66; TP67; TP68; TP69; TP70; TP71; TP72; TP73; TP74
TP-20RD10TESTPOINT1_0_TP-20RD10_TESTPOINTestPoint1IC4TP17; TP31; TP35; TP37
TP-30RD13TESTPOINT_1_TP-30RD13_RD30RD30IC6TP8002; TP8066; TP8117; TP8118; TP8119; TP8120
TSSOP16-14X70SN74AVC4T245_TSSOP16-14X70_SN74SN74AVC4T245IC1U12
TSSOP16-14X70SN74CBT3257PW_TSSOP16-14X70_SN7SN74CBTLV3257PWIC1U8000
XTAL2-75X94CRYSTAL_0_XTAL2-75X94_28.6363MH28.6363MHZIC1Y8000
附件:
! @& G) ]8 G/ D! C( Q原理图和PCB文件如下:3 f; `, B. c& |, n
游客,如果您要查看本帖隐藏内容请回复
, ^* w6 ~. c3 _4 y
) }; D, Y, S. w7 I
GMT+8, 2025-7-24 05:56 , Processed in 0.140625 second(s), 29 queries , Gzip On.
