Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0402C | 0402C | 100nF | DISCRETE | 28 | C78; C107; C108; C109; C110; C113; C114; C115; C116; C117; C118; C121; C122; C123; C124; C125; C126; C128; C129; C130; C131; C132; C133; C168; C170; C171; C173; C176 |
0402C | 0402C | 100nF[N_A] | DISCRETE | 1 | C79 |
0402R | 0402R | 33 | IC | 66 | R22; R24; R26; R31; R34; R35; R37; R41; R42; R43; R44; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R232; R233; R236; R239; R240; R242; R245; R246; R248; R250; R251; R253; R254; R255; R256; R257; R258; R262; R263; R264; R265; R266; R267; R268; R269; R270; R271; R272; R273; R274; R276; R277; R278; R279 |
0402R | 0402R | 10K | IC | 4 | R25; R159; R175; R226 |
0402R | 0402R | 33[N_A] | IC | 1 | R39 |
0402R | 0402R | 5K6 | IC | 1 | R151 |
0402R | 0402R | 2K2 | IC | 1 | R152 |
0402R | 0402R | 510 | IC | 1 | R172 |
0402R | 0402R | 47K[N_A] | IC | 1 | R181 |
0402R | 0402R | 10K[N_A] | IC | 1 | R182 |
0402R | 0402R | 180 | IC | 2 | R196; R220 |
0402R | 0402R | 1K | IC | 2 | R197; R219 |
0603C | 0603C | 100nF | DISCRETE | 74 | C1; C2; C11; C15; C25; C27; C29; C33; C34; C35; C37; C40; C41; C42; C43; C44; C45; C46; C51; C52; C55; C57; C60; C62; C68; C76; C77; C83; C84; C86; C89; C90; C96; C99; C101; C102; C103; C119; C120; C134; C135; C136; C137; C140; C141; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C169; C172; C174; C175 |
0603C | 0603C | [N_A] | DISCRETE | 15 | C6; C7; C8; C9; C10; C12; C13; C14; C18; C24; C26; C28; C100; C104; C127 |
0603C | 0603C | 1nF | DISCRETE | 1 | C16 |
0603C | 0603C | 10nF | DISCRETE | 1 | C17 |
0603C | 0603C | 20pF | DISCRETE | 4 | C20; C23; C80; C81 |
0603C | 0603C | 1.5pF | DISCRETE | 2 | C21; C22 |
0603C | 0603C | 22pF | DISCRETE | 2 | C30; C31 |
0603C | 0603C | 33pF | DISCRETE | 2 | C38; C39 |
0603C | 0603C | 10nF_X7R_0603 | DISCRETE | 1 | C49 |
0603C | 0603C | 1uF_X5R_0603 | DISCRETE | 2 | C50; C53 |
0603C | 0603C | 4.7uF | DISCRETE | 8 | C63; C65; C66; C72; C74; C85; C88; C98 |
0603C | 0603C | 1uF | DISCRETE | 4 | C64; C67; C69; C87 |
0603C | 0603C | 2.2uF | DISCRETE | 3 | C71; C73; C75 |
0603C | 0603C | 10nF[N_A] | DISCRETE | 5 | C91; C92; C93; C94; C95 |
0603C | 0603C | 30pF | DISCRETE | 1 | C97 |
0603D | 0603D | Green | DISCRETE | 4 | LD1; LD5; LD7; LD9 |
0603D | 0603D | Orange | DISCRETE | 1 | LD2 |
0603D | 0603D | Red | DISCRETE | 4 | LD3; LD6; LD8; LD11 |
0603D | 0603D | Blue | DISCRETE | 1 | LD4 |
0603D | 0603D | red | DISCRETE | 1 | LD10 |
0603L | 0603L | EXC-3BP121H[BEAD] | DISCRETE | 2 | L1; L2 |
0603L | 0603L | BEAD(FCM1608KF-601T03) | DISCRETE | 3 | L4; L5; L7 |
0603L | 0603L | Ferrite | DISCRETE | 1 | L6 |
0603R | 0603R | 47 | DISCRETE | 2 | R1; R28 |
0603R | 0603R | 5.1 | DISCRETE | 1 | R2 |
0603R | 0603R | 0 | DISCRETE | 60 | R3; R5; R7; R8; R9; R10; R11; R16; R17; R18; R19; R27; R29; R30; R33; R73; R88; R91; R95; R100; R102; R106; R107; R109; R115; R117; R119; R121; R123; R124; R125; R130; R132; R147; R153; R154; R165; R166; R168; R169; R174; R180; R189; R192; R193; R195; R203; R215; R221; R222; R225; R260; R275; R281; R283; R284; R287; R290; R291; R295 |
0603R | 0603R | 10K | DISCRETE | 23 | R4; R20; R74; R85; R90; R92; R94; R116; R129; R145; R146; R148; R149; R163; R184; R188; R198; R199; R229; R249; R261; R285; R293 |
0603R | 0603R | 150 | DISCRETE | 1 | R6 |
0603R | 0603R | 100K | DISCRETE | 5 | R12; R156; R173; R292; R297 |
0603R | 0603R | 3K3 | DISCRETE | 2 | R13; R122 |
0603R | 0603R | [N_A] | DISCRETE | 27 | R14; R21; R111; R113; R136; R137; R140; R141; R143; R144; R150; R167; R170; R176; R183; R185; R194; R205; R207; R223; R231; R235; R259; R289; R298; R301; R302 |
0603R | 0603R | 120 | DISCRETE | 2 | R15; R164 |
0603R | 0603R | 220K | DISCRETE | 6 | R23; R32; R36; R38; R40; R217 |
0603R | 0603R | 33 | DISCRETE | 18 | R45; R46; R47; R48; R49; R50; R62; R126; R227; R228; R237; R238; R241; R243; R244; R247; R252; R280 |
0603R | 0603R | 1K5 | DISCRETE | 4 | R75; R171; R190; R191 |
0603R | 0603R | 2K2 | DISCRETE | 6 | R76; R77; R79; R81; R82; R177 |
0603R | 0603R | 240 | DISCRETE | 2 | R78; R131 |
0603R | 0603R | 22K | DISCRETE | 3 | R80; R105; R139 |
0603R | 0603R | 4.87K | DISCRETE | 1 | R83 |
0603R | 0603R | 47K | DISCRETE | 9 | R84; R108; R134; R138; R157; R158; R160; R161; R162 |
0603R | 0603R | 22 | DISCRETE | 8 | R86; R93; R99; R101; R104; R112; R286; R288 |
0603R | 0603R | 1M | DISCRETE | 1 | R87 |
0603R | 0603R | 50 | DISCRETE | 4 | R89; R97; R114; R120 |
0603R | 0603R | 330 | DISCRETE | 4 | R96; R118; R135; R216 |
0603R | 0603R | 12K[1%] | DISCRETE | 1 | R98 |
0603R | 0603R | 820 | DISCRETE | 3 | R103; R142; R224 |
0603R | 0603R | 4K7 | DISCRETE | 7 | R110; R128; R186; R187; R208; R230; R234 |
0603R | 0603R | 1K | DISCRETE | 2 | R127; R200 |
0603R | 0603R | 620 | DISCRETE | 2 | R133; R282 |
0603R | 0603R | 10K[N_A] | DISCRETE | 6 | R155; R210; R211; R212; R213; R214 |
0603R | 0603R | 20 | DISCRETE | 2 | R178; R179 |
0603R | 0603R | 100 | DISCRETE | 4 | R201; R202; R218; R294 |
0603R | 0603R | 680 | DISCRETE | 3 | R204; R206; R300 |
0603R | 0603R | 2K7 | DISCRETE | 1 | R209 |
0603R | 0603R | 36K | DISCRETE | 1 | R296 |
0603R | 0603R | 510 | DISCRETE | 1 | R299 |
1206C | 1206C | 2.2uF | IC | 2 | C32; C138 |
3386P | 3386P | 3386P-103(10K) | IO | 1 | RV1 |
BAT_2SM_CR1220 | BAT_2SM_CR1220 | CR1220 holder | IO | 1 | BT1 |
BGA4_0R4_0R8X0R8 | BGA4_0R4_0R8X0R8 | ESDA14V2-2BF3 | IC | 1 | D3 |
BGA4_0R4_1X1 | BGA4_0R4_1X1 | USBULC6-2F3 | IC | 1 | D4 |
BGA11_0R5_1R57X2R07 | BGA11_0R5_1R57X2R07 | EMIF02-USB03F2 | IC | 2 | D5; D6 |
BGA48_0R75_9X11 | BGA48_0R75_9X11 | IS61WV102416BLL-10MLI | IC | 1 | U14 |
BGA72_0R5_4R5X4 | BGA72_0R5_4R5X4 | WM8994ECS_R | IC | 1 | U23 |
BGA216_0R8_13X13_SKT | BGA216_0R8_13X13_SKT | STM32F7 | IC | 1 | U4 |
BNX001 | BNX001 | BNX002-01 | IO | 1 | L3 |
C310M-6 | C310M-6 | 220uF | IC | 1 | C58 |
CAE_5R3X5R3_H5R4 | CAE_5R3X5R3_H5R4 | 47uF | IC | 1 | C54 |
CLM-120-02-L-D | CLM-120-02-L-D | F1000-2_20MGF-L0A | IC | 1 | CN4 |
CONN_DLR11H0 | CONN_DLR11H0 | DLR11H0 | IO | 1 | CN28 |
COUPON | COUPON | Coupon Connectors | IO | 2 | CN24; CN27 |
DB9_M | DB9_M | DB9-male USART1 | IO | 1 | CN7 |
DB9_M | DB9_M | DB9-male CAN connector | IO | 1 | CN22 |
FBGA64_1_11X13 | FBGA64_1_11X13 | PC28F128M29EWLA | IC | 1 | U9 |
FBGA90_0R8_8X13 | FBGA90_0R8_8X13 | IS42S32800G-6BLI | IC | 1 | U13 |
FTR-120-53-L-D-LC | FTR-120-53-L-D-LC | P1039-2_20MGF-089-1A | IC | 2 | CN10; CN11 |
FTR-130-53-L-D-LC | FTR-130-53-L-D-LC | P1039-2_30MGF-089-1A | IC | 2 | CN5; CN6 |
FTSH-110-01-L-DV | FTSH-110-01-L-DV | P127B-2_10MGF-079-1E7A | IC | 1 | CN12 |
FTSH-125-01-F-DV | FTSH-125-01-F-DV | P127B-2_25MGF-079-1A | IC | 1 | CN20 |
HDR_2X3-1_2R54-6 | HDR_2X3-1_2R54-6 | [N_A] | IO | 2 | CN18; CN19 |
HDR_2X6_2R54 | HDR_2X6_2R54 | Header 6X2 | IO | 1 | JP13 |
HOLE_C9D4R5 | HOLE_C9D4R5 | POSITION HOLE | IO | 2 | H1; H2 |
IDC20S | IDC20S | JTAG | IC | 1 | CN15 |
IDC34S | IDC34S | MC_connector | IO | 1 | CN1 |
IR_VISHAY3 | IR_VISHAY3 | TFDU6300 | IC | 1 | U1 |
LED2_3528 | LED2_3528 | HSMF-A201-A00J1 | IC | 1 | LD12 |
LQFP48_0R5_9X9 | LQFP48_0R5_9X9 | DP83848CVV | IC | 1 | U6 |
LQFP48_0R5_9X9 | LQFP48_0R5_9X9 | STM32F103CBT6 | IC | 1 | U21 |
LQFP48_0R5_9X9 | LQFP48_0R5_9X9 | STM32L152CCT6 | IC | 1 | U22 |
MOLEX_47590001 | MOLEX_47590001 | 475900001 | IC | 3 | CN8; CN13; CN14 |
MP34DT01TR | MP34DT01TR | MP34DT01TR | IC | 2 | U24; U25 |
MSD_PJS008_ | MSD_PJS008_ | PJS008-2000 | IC | 1 | CN16 |
OSC_4SM_7X5 | OSC_4SM_7X5 | SM7745HEX-24.0M[N_A] | IC | 1 | X3 |
PB10 | PB10 | TD-0341 [RESET_Black] | IC | 1 | B1 |
PB10 | PB10 | WKUP_TAMPER | IC | 1 | B2 |
PJ3028B | PJ3028B | PJ3028B-3 | IC | 2 | CN25; CN26 |
PWR_JACK_DC10 | PWR_JACK_DC10 | DC-10B | IO | 1 | CN17 |
QFN32_0R5_5X5 | QFN32_0R5_5X5 | USB3300-EZK | IC | 1 | U8 |
RJ45_J0011D01BNL | RJ45_J0011D01BNL | J0011D21B | IO | 1 | CN9 |
SB_0603 | SB_0603 | Open | IC | 33 | SB1; SB2; SB9; SB13; SB14; SB19; SB23; SB25; SB26; SB27; SB28; SB30; SB31; SB34; SB35; SB36; SB38; SB39; SB40; SB42; SB44; SB46; SB47; SB48; SB50; SB51; SB53; SB56; SB58; SB59; SB60; SB62; SB64 |
SB_0603 | SB_0603 | Closed | IC | 30 | SB3; SB4; SB5; SB6; SB7; SB8; SB10; SB11; SB12; SB15; SB16; SB17; SB18; SB20; SB21; SB22; SB24; SB29; SB32; SB37; SB41; SB43; SB45; SB49; SB52; SB54; SB55; SB57; SB61; SB63 |
SIP2 | SIP2 | | IC | 9 | CN3; CN23; JP1; JP2; JP3; JP8; JP10; JP12; JP15 |
SIP2 | SIP2 | [N_A] | IC | 1 | JP16 |
SIP3 | SIP3 | | IC | 15 | JP4; JP5; JP6; JP7; JP9; JP11; JP14; JP17; JP18; JP19; JP20; JP21; JP22; JP23; JP24 |
SMA | SMA | SMAJ5.0A-TR | DISCRETE | 1 | Z1 |
SOD-323 | SOD-323 | BAT60JFILM | IC | 10 | D1; D2; D7; D8; D9; D10; D11; D12; D15; D16 |
SOIC8_1R27_4R9X6 | SOIC8_1R27_4R9X6 | ST890CDR | IC | 1 | U17 |
SOIC8_1R27_4R9X6 | SOIC8_1R27_4R9X6 | SN65HVD230 | IC | 1 | U20 |
SOIC16W_1R27_10R3X10R33 | SOIC16W_1R27_10R3X10R33 | MT25QL512ABA8ESF-0SIT | IC | 1 | U3 |
SOT23-5 | SOT23-5 | STMPS2151STR | IC | 2 | U7; U11 |
SOT23-5 | SOT23-5 | LD3985M33R | IC | 1 | U16 |
SOT-23 | SOT-23 | ESDCAN24-2BLY | IC | 1 | D14 |
SOT-23 | SOT-23 | 9012 | IC | 1 | T1 |
SOT-23 | SOT-23 | 9013 | IC | 4 | T2; T3; T6; T7 |
SOT-23 | SOT-23 | BSN20 | IC | 2 | T4; T5 |
SOT-223 | SOT-223 | LD1117STR | IC | 1 | U2 |
SOT-223 | SOT-223 | LD1117S18TR | IC | 1 | U19 |
SOT-353 | SOT-353 | ESDALC6V1W5 | IC | 3 | U10; U12; U15 |
SSM-104-L-DH | SSM-104-L-DH | F206A-2_04MGF-A | IC | 1 | CN2 |
SSOP28_0R65_10R2X7R8 | SSOP28_0R65_10R2X7R8 | ST3241EBPR | IC | 1 | U5 |
SW1_3TH_2R54_10X2R5 | SW1_3TH_2R54_10X2R5 | 09.03290.01 | IO | 1 | SW1 |
SW-JOY | SW-JOY | EVQQ7 | IC | 1 | B3 |
TAN-A | TAN-A | 4.7uF | DISCRETE | 9 | C3; C4; C36; C47; C48; C59; C106; C112; C142 |
TAN-A | TAN-A | 10uF | DISCRETE | 6 | C5; C19; C56; C61; C70; C139 |
TAN-A | TAN-A | 1uF | DISCRETE | 3 | C82; C105; C111 |
TO263-3 | TO263-3 | LD1086D2M33 | IC | 1 | U18 |
TP | TP | 1V8 | DISCRETE | 1 | TP1 |
TP | TP | Ground | DISCRETE | 4 | TP2; TP3; TP13; TP16 |
TP | TP | +3V3 | DISCRETE | 1 | TP4 |
TP | TP | 2V8 | DISCRETE | 1 | TP5 |
TP | TP | VREF | DISCRETE | 1 | TP6 |
TP | TP | mco1 | DISCRETE | 5 | TP7; TP8; TP10; TP11; TP15 |
TP | TP | VDDA | DISCRETE | 1 | TP9 |
TP | TP | 25MHz | DISCRETE | 1 | TP12 |
TP | TP | 5V | DISCRETE | 1 | TP14 |
TYCO_ZEN056V130A24LS | TYCO_ZEN056V130A24LS | ZEN056V130A24LS | IC | 1 | D13 |
USB-B | USB-B | USB-typeB connector | IO | 1 | CN21 |
XTAL1 | XTAL1 | 24MHz | IC | 1 | X5 |
XTAL_2SM_3R2X1R5 | XTAL_2SM_3R2X1R5 | NX3215SA-32.768KHZ-EXS00A-MU00525 | DISCRETE | 1 | X2 |
XTAL_2SM_12R7X4R7 | XTAL_2SM_12R7X4R7 | 8MHz(12pF) | DISCRETE | 1 | X6 |
XTAL_SOCKET | XTAL_SOCKET | 25MHz(with socket) | IC | 1 | X1 |
XTAL_SOCKET | XTAL_SOCKET | 25MHz (with socket) | IC | 1 | X4 |
附件:
