查看: 171|回复: 0
[AD 15][2层] 23DK-S3A7开发套件 原理图、PCB源文件
发表于 2020-2-12 14:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 15][2层] 23DK-S3A7开发套件  原理图、PCB源文件
' A6 H+ p  m  r! h  D
3 o/ ]8 [( q9 u$ i- U文件描述+ b( }" J1 I8 E, ]7 r% m2 j5 T/ {
1. 作品用途:23DK-S3A7开发套件$ H" U7 Q& w% K$ K6 |
2. 软件版本:AD 159 s9 w8 Y# d4 m7 K0 }. @3 B/ C
3. 层数:2层板. D  a* R7 j+ \( P6 b, H
4. 用到的主要芯片: + Z1 h: z" c9 m# F. [) f! [6 v9 A
5. PCB尺寸:190mm*130mm
5 r8 @' O8 {0 a. p
* [# \0 e  X- h% i作品截图如下:5 b! y( j$ |& _% W' A. h: a
顶层截图:, z; R; p' u1 u) |
& Q% b; J0 t4 S( o' B底层截图:
# a6 R6 ~7 ]5 V8 d' R
% s7 ?0 k+ w8 f" V  K" q全层截图:
" Z- W4 f0 J9 H2 Q# W ; R; g! ^/ n* q
叠层信息截图如下:2 o6 s( j" d" [2 g
) \0 T, H* `6 [! E2 uBOM:
7 O1 @) {# G# P' c1 E3 L* p
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
CAP-000029-01C100, C102, C106, C117, C134, C137, C138, C142, C143, C144, C145, C146, C147CAPC0603-01
13
CAP-000066-01C101, C110, C122CAPC0603-01
CAP-000072-01C103CAPC0603-01
CAP-000070-01C105CAPMP7343-31-01
CAP-000074-01C107, C139CAPC0603-01
CAP-000084-01C108, C109, C112, C113, C114, C115, C116, C126, C128, C129, C131, C132, C133CAPC0201-01
13
CAP-000067-01C111CAPC0402-01
CAP-000057-01C118, C124CAPC0201-01
CAP-000081-01C119, C121, C123, C125, C127CAPC0201-01
CAP-000063-01C120, C136, C148, C149CAPC0402-01
CAP-000073-01C130CAPC0402-01
CAP-000043-01C135, C141CAPC0603-01
CAP-000090-01C140CAPC0603-01
IND-000011-01FB100, FB102FB_0402
IND-000012-01FB101FB_0603
CON-000050-01J100, J111SAMTEC_SSW-106-02-F-D-RA-PMOD
CON-000036-01J101SAMTEC_USB-A-S-F
CON-000153-01J102, J109HARWIN_M20-9960345
CON-013002-01J103, J104MOLEX_79107-7214
CON-000076-01J105, J106, J108FCI_10106813-061112LF
CON-000163-01J107CUI_SJ-43516-SMT
CON-000124-01J110CUI_SJ-3524-GR
CON-000130-01J112CUI_SJ-3524-BE
CON-000174-01JMP100FCI_77313-801-04LF
CON-000184-01JMP101FCI_77313-801-06LF
IND-000007-01L100BOURNS_SRN3015
RES-000144-01R100RESC0402-01
RES-000137-01R101, R103, R104, R106, R108, R109, R110, R112, R113, R114, R115RESC0402-01
11
RES-000139-01R102, R105, R116RESC0402-01
RES-000155-01R107RESC0402-01
RES-000116-01RA100, RA101RESCAF0804
CON-000074-01SD100FCI_100067847-01
FAS-000018-01SO100, SO101, SO102, SO103PEM_SMTSO-M3-4
FAS-000043-01TOOL1, TOOL2Keystone-1377
CON-000047-01TP100, TP101, TP102, TP103, TP104, TP105, TP106, TP107, TP108, TP109KEYSTONE_5015
10
ICN-000072-01U100TI_PVSON-N10
ICN-000165-01U101TI PDSO-N5
ICN-000182-01U102MICRON_V-PDFN-8-6
ICN-000131-01U103TI_DSE-PWSON-N6
ICN-000129-01U104MAXIM_TQFN56
ICN-000181-01U105OSRAM_SFH7776
ICN-000184-01U106KIONIX_KX022-LGA12
ICN-000179-01U107HONEYWELL_LCC-16
ICN-000180-01U108ONSEMI_UDFN8
ICN-000010-01U109MSOP8_N
附件:
: j# Z% L. b! u1 E9 _' {1 E3 C6 D" T: }原理图和PCB源文件如下:
4 {5 y# G4 G: r7 O. \0 F) M% Q: T+ v
游客,如果您要查看本帖隐藏内容请回复
) V! d* ?  W1 x! i, M/ }! i% \6 C6 ?) P
GMT+8, 2025-7-24 05:12 , Processed in 0.140625 second(s), 28 queries , Gzip On.
