Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0402C | 0402C | 100nF | DISCRETE | 29 | C82; C110; C111; C112; C113; C116; C117; C118; C119; C120; C121; C124; C125; C126; C127; C128; C129; C131; C132; C133; C134; C135; C136; C141; C174; C176; C177; C179; C182 |
0402C | 0402C | 100nF[N_A] | DISCRETE | 1 | C83 |
0402C | 0402C | 2.2uF | DISCRETE | 1 | C140 |
0402R | 0402R | 33 | IC | 66 | R23; R25; R27; R32; R34; R35; R37; R40; R41; R48; R49; R50; R51; R52; R53; R54; R55; R56; R58; R59; R60; R61; R62; R63; R64; R65; R66; R221; R222; R223; R226; R230; R232; R236; R237; R240; R241; R243; R244; R245; R246; R247; R248; R249; R250; R251; R256; R257; R258; R259; R260; R261; R262; R263; R264; R265; R266; R267; R268; R269; R270; R271; R273; R274; R275; R276 |
0402R | 0402R | 10K | IC | 4 | R26; R147; R158; R215 |
0402R | 0402R | 33[N_A] | IC | 1 | R38 |
0402R | 0402R | 2K2 | IC | 1 | R140 |
0402R | 0402R | 510 | IC | 1 | R156 |
0402R | 0402R | 47K[N_A] | IC | 1 | R164 |
0402R | 0402R | 10K[N_A] | IC | 1 | R165 |
0402R | 0402R | 180 | IC | 2 | R183; R209 |
0402R | 0402R | 1K | IC | 2 | R184; R208 |
0603C | 0603C | 100nF | DISCRETE | 76 | C1; C2; C11; C15; C25; C27; C29; C34; C35; C36; C38; C41; C42; C43; C44; C45; C46; C47; C52; C55; C56; C59; C62; C63; C64; C73; C80; C81; C87; C88; C90; C93; C94; C100; C102; C104; C105; C106; C122; C123; C137; C138; C139; C142; C145; C146; C148; C149; C150; C151; C152; C153; C154; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C175; C178; C180; C181; C183 |
0603C | 0603C | [N_A] | DISCRETE | 15 | C6; C7; C8; C9; C10; C12; C13; C14; C18; C24; C26; C28; C103; C107; C130 |
0603C | 0603C | 1nF | DISCRETE | 1 | C16 |
0603C | 0603C | 10nF | DISCRETE | 1 | C17 |
0603C | 0603C | 20pF | DISCRETE | 4 | C20; C23; C84; C85 |
0603C | 0603C | 1.5pF | DISCRETE | 2 | C21; C22 |
0603C | 0603C | 22pF | DISCRETE | 2 | C30; C33 |
0603C | 0603C | 33pF | DISCRETE | 2 | C39; C40 |
0603C | 0603C | 10nF_X7R_0603 | DISCRETE | 1 | C53 |
0603C | 0603C | 1uF_X5R_0603 | DISCRETE | 2 | C54; C57 |
0603C | 0603C | 4.7uF | DISCRETE | 8 | C68; C70; C71; C76; C78; C89; C92; C101 |
0603C | 0603C | 1uF | DISCRETE | 4 | C69; C72; C74; C91 |
0603C | 0603C | 2.2uF | DISCRETE | 3 | C75; C77; C79 |
0603C | 0603C | 10nF[N_A] | DISCRETE | 5 | C95; C96; C97; C98; C99 |
0603D | 0603D | Green | DISCRETE | 4 | LD1; LD5; LD7; LD9 |
0603D | 0603D | Orange | DISCRETE | 1 | LD2 |
0603D | 0603D | Red | DISCRETE | 4 | LD3; LD6; LD8; LD11 |
0603D | 0603D | Blue | DISCRETE | 1 | LD4 |
0603D | 0603D | red | DISCRETE | 1 | LD10 |
0603L | 0603L | EXC-3BP121H[BEAD] | DISCRETE | 2 | L1; L2 |
0603L | 0603L | BEAD(FCM1608KF-601T03) | DISCRETE | 5 | L3; L4; L7; L8; L9 |
0603L | 0603L | Ferrite | DISCRETE | 1 | L6 |
0603R | 0603R | 47 | DISCRETE | 2 | R1; R29 |
0603R | 0603R | 5.1 | DISCRETE | 1 | R2 |
0603R | 0603R | 10K | DISCRETE | 24 | R3; R6; R21; R68; R79; R84; R86; R88; R106; R116; R125; R133; R134; R136; R137; R167; R173; R185; R186; R218; R239; R253; R282; R292 |
0603R | 0603R | 0 | DISCRETE | 52 | R4; R5; R8; R9; R10; R11; R12; R17; R18; R19; R20; R28; R30; R31; R33; R67; R82; R85; R94; R98; R99; R107; R109; R111; R117; R119; R135; R141; R142; R153; R154; R163; R172; R176; R177; R179; R180; R181; R190; R203; R210; R211; R214; R252; R272; R278; R280; R281; R285; R287; R288; R290 |
0603R | 0603R | 150 | DISCRETE | 1 | R7 |
0603R | 0603R | 100K | DISCRETE | 5 | R13; R144; R157; R289; R291 |
0603R | 0603R | 3K3 | DISCRETE | 2 | R14; R112 |
0603R | 0603R | [N_A] | DISCRETE | 22 | R15; R22; R102; R104; R123; R124; R128; R129; R131; R132; R155; R159; R168; R174; R178; R212; R220; R225; R255; R286; R295; R296 |
0603R | 0603R | 120 | DISCRETE | 2 | R16; R175 |
0603R | 0603R | 220K | DISCRETE | 6 | R24; R39; R206; R229; R231; R234 |
0603R | 0603R | 33 | DISCRETE | 18 | R36; R42; R43; R44; R45; R46; R47; R57; R113; R216; R217; R227; R228; R233; R235; R238; R242; R277 |
0603R | 0603R | 1K5 | DISCRETE | 4 | R69; R151; R152; R182 |
0603R | 0603R | 2K2 | DISCRETE | 6 | R70; R71; R73; R75; R76; R160 |
0603R | 0603R | 240 | DISCRETE | 2 | R72; R118 |
0603R | 0603R | 22K | DISCRETE | 3 | R74; R97; R127 |
0603R | 0603R | 4.87K | DISCRETE | 1 | R77 |
0603R | 0603R | 47K | DISCRETE | 9 | R78; R100; R121; R126; R145; R146; R148; R149; R150 |
0603R | 0603R | 22 | DISCRETE | 8 | R80; R87; R92; R93; R96; R103; R283; R284 |
0603R | 0603R | 1M | DISCRETE | 1 | R81 |
0603R | 0603R | 50 | DISCRETE | 4 | R83; R90; R105; R110 |
0603R | 0603R | 330 | DISCRETE | 4 | R89; R108; R122; R205 |
0603R | 0603R | 12K[1%] | DISCRETE | 1 | R91 |
0603R | 0603R | 820 | DISCRETE | 3 | R95; R130; R213 |
0603R | 0603R | 4K7 | DISCRETE | 9 | R101; R115; R169; R170; R171; R195; R204; R219; R224 |
0603R | 0603R | 1K | DISCRETE | 2 | R114; R187 |
0603R | 0603R | 620 | DISCRETE | 2 | R120; R279 |
0603R | 0603R | 10K[N_A] | DISCRETE | 6 | R143; R197; R198; R199; R200; R201 |
0603R | 0603R | 20 | DISCRETE | 2 | R161; R162 |
0603R | 0603R | 100 | DISCRETE | 5 | R188; R189; R202; R207; R293 |
0603R | 0603R | 680 | DISCRETE | 3 | R191; R192; R193 |
0603R | 0603R | 510 | DISCRETE | 1 | R194 |
0603R | 0603R | 2K7 | DISCRETE | 1 | R196 |
0603R | 0603R | 33[N_A] | DISCRETE | 1 | R254 |
0603R | 0603R | 36K | DISCRETE | 1 | R294 |
1206C | 1206C | 2.2uF[N_A] | IC | 1 | C31 |
1206C | 1206C | 2.2uF | IC | 2 | C32; C143 |
3386P | 3386P | 3386P-103(10K) | IO | 1 | RV1 |
BAT_2SM_CR1220 | BAT_2SM_CR1220 | CR1220 holder | IC | 1 | BT1 |
BGA4_0R4_0R8X0R8 | BGA4_0R4_0R8X0R8 | ESDA14V2-2BF3 | IC | 1 | D3 |
BGA4_0R4_1X1 | BGA4_0R4_1X1 | USBULC6-2F3 | IC | 1 | D4 |
BGA11_0R5_1R57X2R07 | BGA11_0R5_1R57X2R07 | EMIF02-USB03F2 | IC | 2 | D5; D6 |
BGA48_0R75_9X11 | BGA48_0R75_9X11 | IS61WV102416BLL-10MLI | IC | 1 | U16 |
BGA72_0R5_4R5X4 | BGA72_0R5_4R5X4 | WM8994ECS_R | IC | 1 | U23 |
BGA216_0R8_13X13_SKT | BGA216_0R8_13X13_SKT | STM32F4 | IC | 1 | U4 |
BNX001 | BNX001 | BNX002-01 | IO | 1 | L5 |
C310M-6 | C310M-6 | 220uF | IC | 1 | C60 |
CAE_5R3X5R3_H5R4 | CAE_5R3X5R3_H5R4 | 47uF | IC | 1 | C58 |
CLM-120-02-L-D | CLM-120-02-L-D | F1000-2_20MGF-L0A | IC | 1 | CN4 |
COUPON | COUPON | Coupon Connectors | IO | 2 | CN25; CN28 |
DB9_M | DB9_M | DB9-male USART1 | IO | 1 | CN7 |
DB9_M | DB9_M | DB9-male CAN connector | IO | 1 | CN23 |
FBGA64_1_11X13 | FBGA64_1_11X13 | PC28F128M29EWLA | IC | 1 | U9 |
FBGA90_0R8_8X13 | FBGA90_0R8_8X13 | IS42S32800G-6BLI | IC | 1 | U15 |
FTR-120-53-L-D-LC | FTR-120-53-L-D-LC | P1039-2_20MGF-089-1A | IC | 2 | CN10; CN11 |
FTR-130-53-L-D-LC | FTR-130-53-L-D-LC | P1039-2_30MGF-089-1A | IC | 2 | CN5; CN6 |
FTSH-110-01-L-DV | FTSH-110-01-L-DV | P127B-2_10MGF-079-1E7A | IC | 1 | CN12 |
FTSH-125-01-F-DV | FTSH-125-01-F-DV | P127B-2_25MGF-079-1A | IC | 1 | CN18 |
HDR_2X3-1_2R54-6 | HDR_2X3-1_2R54-6 | [N_A] | IO | 2 | CN20; CN21 |
HDR_2X6_2R54 | HDR_2X6_2R54 | Header 6X2 | IO | 1 | JP14 |
HOLE_C9D4R5 | HOLE_C9D4R5 | POSITION HOLE | IO | 4 | H1; H2; H3; H4 |
IDC20S | IDC20S | JTAG | IC | 1 | CN16 |
IDC34S | IDC34S | MC_connector | IO | 1 | CN1 |
IR_VISHAY3 | IR_VISHAY3 | TFDU6300 | IC | 1 | U1 |
LED2_3528 | LED2_3528 | HSMF-A201-A00J1 | IC | 1 | LD12 |
LQFP48_0R5_9X9 | LQFP48_0R5_9X9 | DP83848CVV | IC | 1 | U6 |
LQFP48_0R5_9X9 | LQFP48_0R5_9X9 | STM32F103CBT6 | IC | 1 | U21 |
LQFP48_0R5_9X9 | LQFP48_0R5_9X9 | STM32L152CCT6 | IC | 1 | U22 |
MOLEX_47590001 | MOLEX_47590001 | 475900001 | IC | 3 | CN8; CN13; CN14 |
MP34DT01TR | MP34DT01TR | MP34DT01TR | IC | 2 | U25; U26 |
MSD_PJS008_ | MSD_PJS008_ | PJS008-2000 | IC | 1 | CN17 |
OSC_4SM_7X5 | OSC_4SM_7X5 | SM7745HEX-24.0M[N_A] | IC | 1 | X3 |
PB10 | PB10 | TD-0341 [RESET_Black] | IC | 1 | B1 |
PB10 | PB10 | WKUP | IC | 1 | B2 |
PB10 | PB10 | USER (Blue) | IC | 1 | B3 |
PJ3028B | PJ3028B | PJ3028B-3 | IC | 2 | CN26; CN27 |
PWR_JACK_DC10 | PWR_JACK_DC10 | DC-10B | IO | 1 | CN19 |
QFN32_0R5_5X5 | QFN32_0R5_5X5 | USB3300-EZK | IC | 1 | U8 |
QSH-030-01-F-D-A | QSH-030-01-F-D-A | QSH-030-01-F-D-A | IC | 1 | CN15 |
RJ45_J0011D01BNL | RJ45_J0011D01BNL | J0011D21B | IO | 1 | CN9 |
SB_0603 | SB_0603 | Open | IC | 39 | SB1; SB2; SB12; SB14; SB15; SB24; SB27; SB28; SB30; SB33; SB35; SB36; SB37; SB38; SB41; SB42; SB43; SB46; SB48; SB49; SB51; SB52; SB57; SB58; SB59; SB60; SB61; SB63; SB64; SB66; SB68; SB69; SB70; SB75; SB76; SB78; SB80; SB82; SB84 |
SB_0603 | SB_0603 | Closed | IC | 41 | SB3; SB4; SB5; SB6; SB7; SB8; SB9; SB10; SB11; SB13; SB16; SB17; SB18; SB19; SB25; SB26; SB29; SB31; SB32; SB34; SB39; SB40; SB44; SB45; SB47; SB50; SB53; SB54; SB55; SB56; SB62; SB65; SB67; SB71; SB72; SB73; SB74; SB77; SB79; SB81; SB83 |
SIP2 | SIP2 | | IC | 9 | CN3; CN24; JP1; JP2; JP4; JP9; JP11; JP13; JP20 |
SIP2 | SIP2 | [N_A] | IC | 1 | JP21 |
SIP3 | SIP3 | | IC | 12 | JP3; JP5; JP6; JP7; JP8; JP10; JP12; JP15; JP16; JP17; JP18; JP19 |
SMA | SMA | SMAJ5.0A-TR | DISCRETE | 1 | Z1 |
SOD-323 | SOD-323 | BAT60JFILM | IC | 10 | D1; D2; D7; D8; D9; D10; D11; D12; D15; D16 |
SOIC8_1R27_4R9X6 | SOIC8_1R27_4R9X6 | ST890CDR | IC | 1 | U18 |
SOIC8_1R27_4R9X6 | SOIC8_1R27_4R9X6 | SN65HVD230 | IC | 1 | U24 |
SOIC16W_1R27_10R3X10R33 | SOIC16W_1R27_10R3X10R33 | MT25QL512ABA8ESF-0SIT | IC | 1 | U3 |
SOT23-5 | SOT23-5 | STMPS2151STR | IC | 2 | U7; U11 |
SOT23-5 | SOT23-5 | LD3985M33R | IC | 1 | U17 |
SOT-23 | SOT-23 | ESDCAN24-2BLY | IC | 1 | D14 |
SOT-23 | SOT-23 | 9012 | IC | 1 | T1 |
SOT-23 | SOT-23 | 9013 | IC | 4 | T2; T4; T7; T8 |
SOT-23 | SOT-23 | BSN20 | IC | 2 | T5; T6 |
SOT-223 | SOT-223 | LD1117STR | IC | 1 | U2 |
SOT-223 | SOT-223 | LD1117S18TR | IC | 1 | U20 |
SOT-353 | SOT-353 | ESDALC6V1W5 | IC | 3 | U10; U13; U14 |
SSM-104-L-DH | SSM-104-L-DH | F206A-2_04MGF-A | IC | 1 | CN2 |
SSOP28_0R65_10R2X7R8 | SSOP28_0R65_10R2X7R8 | ST3241EBPR | IC | 1 | U5 |
SW1_3TH_2R54_10X2R5 | SW1_3TH_2R54_10X2R5 | 09.03290.01 | IO | 2 | SW1; SW2 |
SW-JOY | SW-JOY | EVQQ7 | IC | 1 | B4 |
TAN-A | TAN-A | 4.7uF | DISCRETE | 9 | C3; C4; C37; C48; C49; C65; C109; C115; C147 |
TAN-A | TAN-A | 10uF | DISCRETE | 7 | C5; C19; C61; C66; C67; C144; C155 |
TAN-A | TAN-A | 1uF | DISCRETE | 3 | C86; C108; C114 |
TO263-3 | TO263-3 | LD1086D2M33 | IC | 1 | U19 |
TP | TP | 1V8 | DISCRETE | 1 | TP1 |
TP | TP | Ground | DISCRETE | 4 | TP2; TP3; TP13; TP16 |
TP | TP | +3V3 | DISCRETE | 1 | TP4 |
TP | TP | 2V8 | DISCRETE | 1 | TP5 |
TP | TP | VREF | DISCRETE | 1 | TP6 |
TP | TP | mco1 | DISCRETE | 5 | TP7; TP8; TP10; TP11; TP15 |
TP | TP | VDDA | DISCRETE | 1 | TP9 |
TP | TP | 25MHz | DISCRETE | 1 | TP12 |
TP | TP | 5V | DISCRETE | 1 | TP14 |
TYCO_ZEN056V130A24LS | TYCO_ZEN056V130A24LS | ZEN056V130A24LS | IC | 1 | D13 |
USB-B | USB-B | USB-typeB connector | IO | 1 | CN22 |
XTAL1 | XTAL1 | 24MHz | IC | 1 | X5 |
XTAL_2SM_3R2X1R5 | XTAL_2SM_3R2X1R5 | NX3215SA-32.768KHZ-EXS00A-MU00525 | DISCRETE | 1 | X2 |
XTAL_2SM_12R7X4R7 | XTAL_2SM_12R7X4R7 | 8MHz(12pF) | DISCRETE | 1 | X6 |
XTAL_SOCKET | XTAL_SOCKET | 25MHz(with socket) | IC | 1 | X1 |
XTAL_SOCKET | XTAL_SOCKET | 25MHz (with socket) | IC | 1 | X4 |
附件:
