Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0402C | 0402C | 100nF | DISCRETE | 79 | C3; C11; C12; C17; C18; C19; C20; C25; C26; C30; C31; C35; C36; C38; C39; C40; C41; C42; C43; C44; C45; C48; C49; C50; C51; C52; C60; C61; C62; C63; C64; C65; C66; C68; C69; C70; C72; C74; C75; C76; C78; C79; C83; C84; C85; C86; C87; C90; C91; C92; C93; C94; C95; C96; C97; C101; C105; C106; C109; C111; C113; C114; C117; C119; C121; C123; C124; C132; C133; C134; C135; C136; C137; C139; C141; C142; C143; C144; C145 |
0402C | 0402C | 1nF | DISCRETE | 3 | C5; C7; C77 |
0402C | 0402C | 10nF | DISCRETE | 2 | C8; C82 |
0402R | 0402R | 20pF | IC | 4 | C54; C55; C88; C89 |
0402R | 0402R | 47K | IC | 8 | R1; R8; R175; R176; R178; R182; R185; R259 |
0402R | 0402R | 330 | IC | 2 | R6; R244 |
0402R | 0402R | 620 | IC | 1 | R9 |
0402R | 0402R | 3K3 | IC | 3 | R14; R20; R29 |
0402R | 0402R | 100K | IC | 21 | R19; R100; R101; R102; R110; R114; R117; R138; R139; R168; R181; R187; R190; R193; R213; R214; R215; R229; R239; R241; R242 |
0402R | 0402R | 10K | IC | 35 | R21; R22; R25; R28; R32; R40; R41; R42; R45; R67; R74; R122; R133; R159; R161; R163; R164; R166; R167; R172; R200; R211; R212; R217; R218; R230; R232; R238; R243; R246; R247; R248; R249; R250; R262 |
0402R | 0402R | 1K | IC | 11 | R26; R27; R37; R63; R121; R124; R165; R224; R226; R260; R268 |
0402R | 0402R | 8.2K | IC | 1 | R51 |
0402R | 0402R | 120 | IC | 1 | R55 |
0402R | 0402R | 1K2 | IC | 4 | R57; R60; R263; R264 |
0402R | 0402R | 150 | IC | 1 | R59 |
0402R | 0402R | 820 | IC | 2 | R79; R80 |
0402R | 0402R | 5.1 | IC | 1 | R112 |
0402R | 0402R | 47 | IC | 1 | R115 |
0402R | 0402R | 3K6 0.1% | IC | 2 | R125; R136 |
0402R | 0402R | 220K | IC | 3 | R127; R137; R245 |
0402R | 0402R | 22K | IC | 3 | R128; R261; R267 |
0402R | 0402R | 180K 0.1% | IC | 2 | R129; R132 |
0402R | 0402R | 30K | IC | 1 | R130 |
0402R | 0402R | 15K | IC | 1 | R134 |
0402R | 0402R | 2K2 | IC | 2 | R169; R184 |
0402R | 0402R | 4K7 | IC | 4 | R170; R183; R186; R216 |
0402R | 0402R | 36K | IC | 1 | R171 |
0402R | 0402R | 100 | IC | 4 | R173; R251; R253; R254 |
0402R | 0402R | 1.5K | IC | 1 | R177 |
0402R | 0402R | 22 | IC | 2 | R179; R180 |
0402R | 0402R | 20 | IC | 2 | R195; R196 |
0402R | 0402R | 180 | IC | 2 | R225; R227 |
0402R | 0402R | 680 | IC | 3 | R255; R256; R257 |
0402R | 0402R | 510 | IC | 1 | R258 |
0603C | 0603C | [N_A] | DISCRETE | 10 | C1; C2; C4; C6; C9; C10; C13; C14; C16; C47 |
0603C | 0603C | 4.7uF | DISCRETE | 12 | C15; C29; C112; C120; C122; C125; C126; C127; C128; C129; C130; C138 |
0603C | 0603C | 1uF | DISCRETE | 17 | C21; C22; C23; C24; C27; C28; C32; C33; C46; C53; C58; C73; C80; C81; C108; C110; C118 |
0603C | 0603C | 220nF | DISCRETE | 1 | C34 |
0603C | 0603C | 6pF | DISCRETE | 2 | C56; C57 |
0603C | 0603C | 2.2uF | DISCRETE | 3 | C102; C103; C104 |
0603D | 0603D | Green | DISCRETE | 2 | LD1; LD5 |
0603D | 0603D | Orange | DISCRETE | 1 | LD2 |
0603D | 0603D | Red | DISCRETE | 4 | LD3; LD6; LD7; LD9 |
0603D | 0603D | Blue | DISCRETE | 1 | LD4 |
0603L | 0603L | BEAD | DISCRETE | 3 | L1; L3; L4 |
0603R | 0603R | 0 | DISCRETE | 74 | R2; R3; R4; R5; R7; R10; R11; R12; R13; R15; R16; R17; R18; R23; R24; R34; R43; R44; R46; R58; R61; R69; R71; R72; R73; R75; R76; R77; R87; R88; R89; R92; R93; R94; R105; R106; R107; R111; R113; R116; R118; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R154; R156; R188; R189; R191; R192; R194; R198; R199; R201; R205; R208; R210; R220; R221; R222; R223; R228; R252; R265; R266 |
0603R | 0603R | 100 1% | DISCRETE | 1 | R31 |
0603R | 0603R | [N_A] | DISCRETE | 23 | R70; R96; R119; R120; R126; R131; R152; R153; R155; R157; R158; R160; R162; R174; R197; R202; R206; R219; R231; R233; R234; R237; R240 |
0603R | 0603R | 390 | DISCRETE | 1 | R95 |
0603R | 0603R | 1K[1%] | DISCRETE | 1 | R123 |
0603R | 0603R | 1[1%] | DISCRETE | 1 | R135 |
0603R | 0603R | 11.8K[1%] | DISCRETE | 1 | R203 |
0603R | 0603R | 20.5K[1%] | DISCRETE | 1 | R204 |
0603R | 0603R | 124[1%] | DISCRETE | 1 | R207 |
0603R | 0603R | 232[1%] | DISCRETE | 1 | R209 |
0603R | 0603R | 10.2K[1%] | DISCRETE | 1 | R235 |
0603R | 0603R | 20K[1%] | DISCRETE | 1 | R236 |
0805C | 0805C | 10uF[ESR<0.2ohm] | DISCRETE | 2 | C98; C131 |
1206C | 1206C | 22nF(COG)GRM3195C1H223JA01L | IC | 1 | C37 |
3386P | 3386P | 3386P-503H[5%] | IO | 1 | RV1 |
3386P | 3386P | 3386P-103(10K) | IO | 1 | RV3 |
BAT_2SM_CR1220 | BAT_2SM_CR1220 | CR1220 holder | IO | 1 | BT1 |
BGA11_0R5_1R57X2R07 | BGA11_0R5_1R57X2R07 | EMIF02-USB03F2 | IC | 1 | D1 |
BGA48_0R75_9X11 | BGA48_0R75_9X11 | IS61WV102416BLL-10MLI | IC | 1 | U2 |
BGA64_1_10X13 | BGA64_1_10X13 | M29W128GL70ZA6E | IC | 1 | U5 |
BGA72_0R5_4R5X4 | BGA72_0R5_4R5X4 | WM8994ECS_R | IC | 1 | U29 |
BNX001 | BNX001 | BNX002-01 | IO | 1 | L2 |
C310M-6 | C310M-6 | 220uF | IC | 1 | C100 |
DB9_M | DB9_M | DB9-male | IO | 2 | CN5; CN9 |
DFN6_0R95_3X3 | DFN6_0R95_3X3 | ST1L05BPUR | IC | 2 | U28; U34 |
DFN8_1R27_6X8_TP4R8X5R8 | DFN8_1R27_6X8_TP4R8X5R8 | N25Q256A13EF840E | IC | 1 | U9 |
FTR-120-53-L-D-LC | FTR-120-53-L-D-LC | P1039-2_20MGF-089-1A | IC | 2 | CN6; CN7 |
FTSH-110-01-L-DV | FTSH-110-01-L-DV | FTSH-110-01-L-DV | IC | 1 | CN12 |
HDR_1X2_1R27 | HDR_1X2_1R27 | PT100 | IO | 1 | R30 |
HDR_2X3-1_2R54-6 | HDR_2X3-1_2R54-6 | [N_A] | IO | 1 | CN16 |
HDR_2X3_2R54 | HDR_2X3_2R54 | Header 3X2 | IO | 1 | JP15 |
HDR_2X4_2R54 | HDR_2X4_2R54 | Header 4X2 | IO | 1 | JP17 |
HDR_2X4_2R54_N | HDR_2X4_2R54_N | female conn 4X2 | IO | 1 | CN13 |
HDR_2X17_2R54 | HDR_2X17_2R54 | 16-bit connector | IO | 1 | CN19 |
HDR_2X24_2R54 | HDR_2X24_2R54 | Header 24X2 | IO | 2 | CN11; CN14 |
IDC20S | IDC20S | JTAG | IC | 1 | CN15 |
IDC34S | IDC34S | MC_connector | IO | 1 | CN2 |
IR_VISHAY3 | IR_VISHAY3 | TFDU6300 | IC | 1 | U11 |
LED2_3528 | LED2_3528 | HSMF-A201-A00J1 | IC | 1 | LD8 |
LQFP48_0R5_9X9 | LQFP48_0R5_9X9 | STM32F103CBT6 | IC | 1 | U23 |
MOLEX_47590001 | MOLEX_47590001 | 475900001 | IC | 1 | CN1 |
MP34DT01TR | MP34DT01TR | MP34DT01TR | IC | 2 | U35; U36 |
MSD_PJS008_ | MSD_PJS008_ | PJS008-2000 (SMS064FF or SMS128FF) | IC | 1 | CN18 |
MT-008A | MT-008A | MT008-A | IC | 1 | B3 |
PB10 | PB10 | RESET | IC | 1 | B1 |
PB10 | PB10 | WKUP | IC | 1 | B2 |
PJ3028B | PJ3028B | PJ3028B-3 | IC | 2 | CN20; CN21 |
PTF_3314J | PTF_3314J | 3314J-1-103 | IC | 1 | RV2 |
PVT901 | PVT901 | VT9ON1 | IC | 1 | R52 |
PWR_JACK_DC10 | PWR_JACK_DC10 | DC-10B | IO | 1 | CN22 |
QFN16_0R5_3X3 | QFN16_0R5_3X3 | STMPE811QTR | IC | 1 | U32 |
QFN16_0R65_4X4 | QFN16_0R65_4X4 | STPMS2L-PUR | IC | 2 | U3; U4 |
QFN24_0R5_4X4 | QFN24_0R5_4X4 | STMPE1600QTR | IC | 1 | U33 |
RP0402X8_REV | RP0402X8_REV | 22 | IC | 1 | RS1 |
SAM_C816 | SAM_C816 | C816 | IC | 1 | CN23 |
SB_0603 | SB_0603 | 0 | IC | 31 | R33; R35; R36; R38; R39; R48; R50; R53; R54; R56; R62; R64; R65; R66; R68; R78; R81; R82; R83; R84; R85; R86; R90; R91; R97; R98; R99; R103; R104; R108; R109 |
SB_0603 | SB_0603 | Open by default | IC | 46 | SB1; SB2; SB3; SB4; SB5; SB6; SB8; SB9; SB10; SB11; SB12; SB13; SB14; SB15; SB16; SB17; SB18; SB19; SB20; SB21; SB22; SB23; SB24; SB25; SB26; SB27; SB28; SB29; SB30; SB31; SB32; SB33; SB34; SB35; SB36; SB37; SB38; SB39; SB40; SB41; SB42; SB43; SB44; SB46; SB49; SB51 |
SB_0603 | SB_0603 | Closed by default | IC | 5 | SB7; SB45; SB47; SB48; SB50 |
SC70-5 | SC70-5 | SN74LVC1G66DCKT | IC | 1 | U13 |
SC70-5 | SC70-5 | SN74LVC1G04DCKT | IC | 1 | U16 |
SIP2 | SIP2 | Header 2X1 | IC | 1 | CN8 |
SIP2 | SIP2 | | IC | 8 | CN10; JP3; JP6; JP8; JP9; JP13; JP18; JP19 |
SIP3 | SIP3 | Header 3X1 | IC | 1 | CN4 |
SIP3 | SIP3 | | IC | 9 | JP1; JP2; JP4; JP5; JP7; JP10; JP12; JP14; JP16 |
SIP4 | SIP4 | Header 4 | IC | 1 | JP11 |
SMA | SMA | SMAJ5.0A-TR | DISCRETE | 1 | Z1 |
SOD-323 | SOD-323 | BAT60JFILM | IC | 6 | D3; D4; D5; D6; D7; D8 |
SOIC8_1R27_4R9X6 | SOIC8_1R27_4R9X6 | SN65HVD230 | IC | 1 | U8 |
SOIC8_1R27_4R9X6 | SOIC8_1R27_4R9X6 | ST890CDR | IC | 1 | U37 |
SOIC28W_1R27_17R9X10R325 | SOIC28W_1R27_17R9X10R325 | ST8024CDR | IC | 1 | U30 |
SOT23-5 | SOT23-5 | STMPS2151STR | IC | 1 | U1 |
SOT23-5 | SOT23-5 | LD3985M33R | IC | 1 | U20 |
SOT23-6 | SOT23-6 | FDC606P | IC | 2 | T2; T3 |
SOT23-213 | SOT23-213 | ESDCAN24-2BLY | IC | 1 | D2 |
SOT-23 | SOT-23 | 9013-SOT23 | IC | 3 | T1; T4; T6 |
SOT-223 | SOT-223 | LD1117STR | IC | 1 | U26 |
SOT-223 | SOT-223 | LD1117S18TR | IC | 1 | U27 |
SOT-353 | SOT-353 | ESDALC6V1W5 | IC | 3 | U17; U18; U19 |
SSM-104-L-DH | SSM-104-L-DH | F206A-2_04MGF-A | IC | 1 | CN3 |
SSOP28_0R65_10R2X7R8 | SSOP28_0R65_10R2X7R8 | ST3241EBPR | IC | 1 | U10 |
SW1_3TH_2R54_10X2R5 | SW1_3TH_2R54_10X2R5 | 09.03290.01 | IO | 1 | SW1 |
TAN-A | TAN-A | 1uF | DISCRETE | 1 | C59 |
TAN-A | TAN-A | 4.7uF | DISCRETE | 4 | C67; C71; C116; C140 |
TAN-A | TAN-A | 10uF | DISCRETE | 3 | C99; C107; C115 |
TP | TP | [N_A] | DISCRETE | 18 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18 |
TP_C79 | TP_C79 | [N_A] | IC | 1 | TP19 |
TQFP144_0R5_22X22_SOCKET | TQFP144_0R5_22X22_SOCKET | STM32L476ZGT6U | IC | 1 | U7 |
TSSOP8_0R65_3X6R4 | TSSOP8_0R65_3X6R4 | M24128-DFDW6TP | IC | 1 | U6 |
TSSOP14_0R65_5X6R4 | TSSOP14_0R65_5X6R4 | TSZ124IPT | IC | 1 | U15 |
TSSOP16_0R65_5X6R4 | TSSOP16_0R65_5X6R4 | 74LV4060PW | IC | 1 | U14 |
TSSOP48_0R5_12R5X8R1 | TSSOP48_0R5_12R5X8R1 | SN74LVC16T245DGGR | IC | 2 | U21; U22 |
TS_PAD | TS_PAD | TS_PAD | IC | 1 | TS1 |
TYCO_ZEN056V130A24LS | TYCO_ZEN056V130A24LS | ZEN056V130A24LS | IC | 1 | U31 |
USB-B | USB-B | USB-typeB connector | IO | 1 | CN17 |
USOP8_0R5_2X3R1 | USOP8_0R5_2X3R1 | SN74LVC2T45DCUT | IC | 3 | U12; U24; U25 |
XTAL_2SM_3R2X1R5 | XTAL_2SM_3R2X1R5 | NDK NX3215SA-32.768K-STD-MUA-14 | DISCRETE | 1 | X1 |
XTAL_2SM_12R7X4R7 | XTAL_2SM_12R7X4R7 | 8MHz | DISCRETE | 1 | X3 |
XTAL_SOCKET | XTAL_SOCKET | 8MHz (with socket) | IC | 1 | X2 |
