查看: 334|回复: 0
[allegro16.6][8层] SPAC5330A 方案的行车记录仪(运动DV)(FPGA+DDR+FLASH)pcb...
发表于 2020-2-11 16:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
, {8 u4 l" z8 B5 |3 y# `[allegro16.6][8层] SPAC5330A 方案的行车记录仪(运动DV)(FPGA+DDR+FLASH)pcb文件
7 L- S$ r9 ~, f+ c
% G1 q" w2 |6 @; s0 T* Z/ N文件描述:, ^- r4 k: ]  h
, N1 A" g' v4 Y9 Y$ E% H/ Y1. 作品用途:SPAC5330A 方案的行车记录仪(运动DV)5 W* ]; ]+ C& B
2. 软件版本:allegro16.6
. M# V9 ]5 t1 \8 B3 ], L3. 层数:8层
# z* f. t1 W) K; M4. 用到的主要芯片:FPGA+DDR+FLASH
' S% k/ m" k3 m$ z6 O5. pcb尺寸: 异形# D2 A1 b7 [% C/ \3 h: W
5 B4 b, L6 R4 g6 N5 n
作品截图如下:) F, q: X, T' u! X9 I1 q7 W0 t1 R
9 S! Q4 {$ W/ L& Q6 i2 H
顶层截图:. l: x+ y7 [# S) @  `9 R
& L# w# |( ~8 C  g6 x: Z7 }
底层截图:* q3 K0 G; O8 m
9 U) r3 F, M! h- H 3 N; S! t1 \! U' p6 D2 r
全层截图:; i+ e- S9 O4 n  I! J4 E* p
& V2 r8 u, z- G2 y
) m& a, R) I1 ?, J2 D叠层阻抗信息如下:0 ]! P+ }4 p+ G7 f# }$ b8 K
5 T  ]$ E2 [5 |" T) i7 o2 e. b
BOM:
7 @* [; i* t- V4 H* [7 y6 I
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
1X2_342MIL1X2_342MILIC1TP204
1X3_2MM1X3_2MMIC1J12
3P_2MM3P_2MMIC1J11
6X6SMTPULSEIC2SW2; SW3
84FBGA84FBGAIC1U4
ACM7060ACM7060IC1L43
BGA281BGA281IC1U1
C0402C0402IC116C1; C2; C4; C5; C7; C10; C11; C12; C13; C14; C15; C16; C17; C18; C20; C21; C23; C24; C25; C26; C27; C29; C31; C32; C33; C35; C36; C37; C38; C40; C42; C43; C44; C45; C48; C49; C53; C54; C55; C56; C60; C61; C63; C65; C67; C68; C72; C73; C76; C85; C86; C92; C96; C97; C100; C101; C102; C121; C125; C128; C132; C133; C134; C137; C138; C144; C145; C146; C147; C148; C149; C150; C151; C156; C157; C160; C163; C167; C172; C173; C177; C180; C181; C182; C436; C437; C438; C465; C468; C469; C470; C472; C473; C474; C479; C482; C483; C484; C486; C494; C499; C505; C519; C521; C522; C525; C530; C531; C532; C533; C534; C536; C537; C538; C539; C540
C0603C06030_1uFIC41C3; C22; C47; C50; C52; C59; C70; C71; C75; C77; C78; C79; C80; C81; C82; C83; C84; C88; C89; C90; C91; C93; C94; C95; C98; C99; C120; C122; C124; C152; C153; C199; C463; C464; C487; C488; C492; C495; C506; C508; C535
C0805C0805IC39C6; C19; C28; C30; C39; C41; C46; C51; C57; C58; C62; C64; C66; C69; C74; C87; C131; C139; C466; C477; C478; C480; C481; C489; C490; C491; C500; C501; C504; C509; C510; C511; C514; C516; C517; C518; C520; C526; C527
C1206C1206IC4C467; C502; C503; CAP2
C1210C1210IC2C485; C507
CAS09U_B1N9B_2CAS09U_B1N9B_2IC1J8
CDRH4D18CCDRH4D18CIC2L7; L8
CON_2P_0D8MM_1_2CON_2P_0D8MM_1_2IC1JP5
CON_2P_1D25MM_1_2CON_2P_1D25MM_1_2IC2JP6; JP9
CON_50P_0_5MM_2CON_50P_0_5MM_2IC1CON1
CS6CS6IC3C512; C513; C524
DIP48_TSOPDIP48_TSOPIC1U3
F0402F0402IC9F8; F13; F14; F15; F16; F17; F18; F19; F20
FB0603FB0603IC10L5; L6; L28; L29; L30; L31; L39; L40; L45; L46
FB0805L0805IC3FB5; FB8; FB9
FB1206FB1206IC1FU1
FC-135FC-135IC1Y2
FPC8-0-5MMFPC8-0-5MMIC1J5
HYT_2015_01HYT_2015_01IC1SW5
ICXX5212ICXX5212IC59MP1; MP2; MP3; MP4; MP5; MP6; MP7; MP8; MP9; MP10; MP11; MP12; MP13; MP14; MP15; MP16; MP17; MP18; MP19; MP20; MP21; MP22; MP23; MP24; MP25; MP32; MP33; MP34; MP35; MP36; MP37; MP38; MP39; MP40; MP41; MP42; MP43; MP44; MP45; MP46; MP47; MP48; MP49; MP50; MP51; MP52; MP53; MP54; MP55; MP56; MP57; MP58; MP59; MP60; MP61; MP62; MP63; MP64; MP65
L3225L3225IC1L42
MSOP-8MSOP-8IC1U12
NFL18STNFL18STIC2L47; L48
NFM21PCNFM21PCIC2L49; L50
NFM21PSNFM21PSIC1L52
PAD_C80D44PAD_C80D44IC1ANT
PAD_S100X100PAD_S100X100IC4EMI_P4; EMI_P5; EMI_P6; EMI_P9
PAD_S200DC91PAD_S200DC91IC7EMI_P1; EMI_P2; EMI_P3; EMI_P7; EMI_P8; EMI_P10; EMI_P11
QFN40-S5-R4QFN40-S5-R4IC1U14
R0402R0402IC214D3; D4; D5; D7; D20; D21; D23; D24; D25; D26; D27; D30; D31; D32; D33; D34; D35; D36; D37; D38; D39; D40; D41; D42; D43; D44; D45; D46; D50; D51; FB6; FB7; R1; R2; R3; R4; R5; R6; R7; R9; R10; R11; R12; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R30; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R80; R81; R82; R86; R104; R105; R106; R107; R108; R109; R110; R111; R115; R118; R119; R120; R121; R122; R123; R144; R146; R148; R150; R153; R157; R158; R159; R162; R163; R164; R165; R166; R167; R169; R170; R171; R172; R173; R174; R175; R177; R178; R179; R181; R182; R197; R198; R199; R201; R202; R246; R325; R326; R327; R328; R329; R330; R333; R334; R335; R336; R337; R338; R357; R387; R388; R389; R391; R392; R400; R401; R402; R409; R410; R411; R412; R413; R414; R415; R416; R437; R438; R441; R442; R446; R459; R460; R461; R462; R463; R464; R465; R466; R467; R468; R469; R470; R471; R472; R473; R474; R475; R476; R477; R478; R479; R480; R481; R482; R483; R485; R486; R487; R492
R0603R060310KIC52F1; F2; F3; F4; F5; F6; F7; F9; F10; F11; F12; R8; R13; R113; R116; R200; R358; R359; R360; R361; R362; R363; R364; R365; R366; R367; R368; R369; R370; R371; R372; R373; R374; R375; R376; R377; R378; R379; R380; R381; R450; R451; R452; R453; R454; R455; R456; R457; R484; R489; R490; R491
R1206R12061IC1R458
RES_0805R08050R5IC4FB10; L2; L3; R488
RF4463-14PRF4463-14PIC1JP8
RFM210LRFM210LIC1JP7
RGB0603RGB0603IC8LED9; LED10; LED11; LED12; LED13; LED14; LED15; LED16
SC70_3PSC70_3PIC6Q24; Q55; Q59; Q61; Q63; Q65
SIM_MSN47S050U_X0SIM_MSN47S050U_X0IC1U18
SLF6025SLF6025IC2L35; L44
SMASMAIC2D70; D71
SMD12_2X4X1D27MMSMD12_2X4X1D27MMIC1J9
SMD3225_4PSMD3225_4PIC1U13
SOD123SOD123IC2D15; D58
SOD323SOD323IC7D1; D2; D6; D8; D9; D74; D75
SOD-123LFSOD-123LFIC2D57; D61
SOD-323SOD-323IC4D69; D72; D73; D76
SOIC-8-EDP-3SOIC-8-EDP-3IC2Q56; Q60
SOIC_8P_50_197X236SOIC_8P_50_197X236IC3Q54; Q57; Q58
SOP-8SOP-8IC2U66; U68
SOT23SOT23IC16D14; D59; Q7; Q22; Q23; Q27; Q28; Q29; Q30; Q31; Q32; Q53; Q64; Q66; U8; U76
SOT23-5SOT23-5IC1U70
SOT23_5SOT23_5IC6U5; U6; U7; U10; U11; U65
SOT23_6SOT23_6IC4U9; U56; U57; U75
SOT-363SOT-363IC2Q41; Q44
SS5_0D5_10_PINSS5_0D5_10_PINIC1J10
SS5_0D5_20_PINSS5_0D5_20_PINIC1J13
SSOP5SSOP5IC1U71
T17T17IC1L4
TP0_5TP0_5IC29TP2; TP3; TP4; TP5; TP7; TP8; TP12; TP13; TP14; TP17; TP24; TP34; TP36; TP37; TP39; TP40; TP41; TP42; TP67; TP68; TP69; TP70; TP71; TP72; TP73; TP74; TP76; TP77; TP196
TP1_0TP1_0IC20TP15; TP16; TP18; TP26; TP32; TP33; TP35; TP75; TP78; TP79; TP80; TP81; TP82; TP83; TP84; TP85; TP199; TP200; TP201; TP202
TSSOP8TSSOP8IC1U15
TSSOP20-4D4X6D4-R65TSSOP20-4D4X6D4-R65IC1U58
U6F05E-CXT1-BWU6F05E-CXT1-BWIC1J2
UQFN_6LUQFN_6LIC1FB1
VLP8040T-100MVLP8040T-100MIC1L37
WDFN8_0D4_1D7X1D35WDFN8_0D4_1D7X1D35IC6RN1; RN2; RN3; RN4; RN5; RN6
WDFN-10L_3X3WDFN-10L_3X3IC1U67
XTAL4-37X34-FA128XTAL4-37X34-FA128IC1Y1
附件:
8 I: {. }2 _1 j: }! D' I* Z+ f6 mPCB文件如下:: J# O! s0 Z+ R# v5 A' h
游客,如果您要查看本帖隐藏内容请回复
/ t- d" |, c7 ?4 T& V( N( b* p! x% M% U- ]$ U/ K% T: Y% E
GMT+8, 2025-7-25 05:16 , Processed in 0.156250 second(s), 29 queries , Gzip On.
